[GRASS-SVN] r62219 - grass/trunk/lib/gis
Wed Oct 8 14:19:54 PDT 2014
Author: wenzeslaus
Date: 2014-10-08 14:19:54 -0700 (Wed, 08 Oct 2014)
New Revision: 62219
   grass/trunk/lib/gis/parser.c
   grass/trunk/lib/gis/parser_dependencies.c
lib/parser: more doxygen documentation
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2014-10-08 19:56:35 UTC (rev 62218)
+++ grass/trunk/lib/gis/parser.c	2014-10-08 21:19:54 UTC (rev 62219)
@@ -290,19 +290,19 @@
  * The usual order a module calls functions is:
- *  # G_gisinit()
- *  # G_define_module()
- *  # G_define_standard_flag()
- *  # G_define_standard_option()
- *  # G_define_flag()
- *  # G_define_option()
- *  # G_option_exclusive()
- *  # G_option_required()
- *  # G_option_requires()
- *  # G_option_requires_all()
- *  # G_option_excludes()
- *  # G_option_collective()
- *  # G_parser()
+ *  1. G_gisinit()
+ *  2. G_define_module()
+ *  3. G_define_standard_flag()
+ *  4. G_define_standard_option()
+ *  5. G_define_flag()
+ *  6. G_define_option()
+ *  7. G_option_exclusive()
+ *  8. G_option_required()
+ *  9. G_option_requires()
+ *  10. G_option_requires_all()
+ *  11. G_option_excludes()
+ *  12. G_option_collective()
+ *  13. G_parser()
  * \param argc number of arguments
  * \param argv argument list
Modified: grass/trunk/lib/gis/parser_dependencies.c
--- grass/trunk/lib/gis/parser_dependencies.c	2014-10-08 19:56:35 UTC (rev 62218)
+++ grass/trunk/lib/gis/parser_dependencies.c	2014-10-08 21:19:54 UTC (rev 62219)
@@ -176,7 +176,11 @@
     st->error[st->n_errors++] = G_store(msg);
-/* at most one option from a set */
+/*! \brief Sets the options to be mutually exclusive.
+    When running the module, at most one option from a set can be
+    provided.
 void G_option_exclusive(void *first, ...)
     va_list ap;
@@ -214,8 +218,17 @@
-/* if the first option is present, at least one of the other
-   options must also be present */
+/*! \brief Define a list of options from which at least one option
+    is required if first option is present.
+    If the first option is present, at least one of the other
+    options must also be present.
+    If you want all options to be provided use G_option_requires_all()
+    function.
+    If you want more than one option to be present but not all,
+    call this function multiple times.
 void G_option_requires(void *first, ...)
     va_list ap;
@@ -236,8 +249,16 @@
-/* if the first option is present, all the other options must also
-   be present. */
+/*! \brief Define additionally required options for an option.
+    If the first option is present, all the other options must also
+    be present.
+    If it is enough if only one option from a set is present,
+    use G_option_requires() function.
+    \see G_option_collective()
 void G_option_requires_all(void *first, ...)
     va_list ap;
@@ -258,7 +279,7 @@
-/* if the first option is present, none of the other options may also
+/* if the first option is present, none of the other options may also (should?)
    be present. */
 void G_option_excludes(void *first, ...)
