[GRASS-SVN] r62220 - in grass/trunk/general: g.list g.remove
svn_grass at osgeo.org
Thu Oct 9 02:11:48 PDT 2014
Author: annakrat
Date: 2014-10-09 02:11:48 -0700 (Thu, 09 Oct 2014)
New Revision: 62220
grass/trunk/general/g.list/main.c
grass/trunk/general/g.remove/main.c
g.list/remove: do not add mapset to the selected name in GUI
Modified: grass/trunk/general/g.list/main.c
--- grass/trunk/general/g.list/main.c 2014-10-08 21:19:54 UTC (rev 62219)
+++ grass/trunk/general/g.list/main.c 2014-10-09 09:11:48 UTC (rev 62220)
@@ -93,7 +93,7 @@
opt.pattern->type = TYPE_STRING;
opt.pattern->required = NO;
opt.pattern->multiple = NO;
- opt.pattern->gisprompt = "old,element,element";
+ opt.pattern->gisprompt = "new,element,element";
opt.pattern->description = _("Map name search pattern (default: all)");
opt.pattern->guisection = _("Pattern");
@@ -102,7 +102,7 @@
opt.exclude->type = TYPE_STRING;
opt.exclude->required = NO;
opt.exclude->multiple = NO;
- opt.exclude->gisprompt = "old,element,element";
+ opt.exclude->gisprompt = "new,element,element";
opt.exclude->description = _("Map name exclusion pattern (default: none)");
opt.exclude->guisection = _("Pattern");
Modified: grass/trunk/general/g.remove/main.c
--- grass/trunk/general/g.remove/main.c 2014-10-08 21:19:54 UTC (rev 62219)
+++ grass/trunk/general/g.remove/main.c 2014-10-09 09:11:48 UTC (rev 62220)
@@ -79,7 +79,7 @@
opt.pattern->key = "pattern";
opt.pattern->required = YES;
opt.pattern->description = _("Map name search pattern or map names separated by a comma");
@@ -87,7 +87,7 @@
opt.exclude->key = "exclude";
