[GRASS-SVN] r62224 - grass-addons/grass7/raster/r.droka
svn_grass at osgeo.org
Thu Oct 9 05:49:24 PDT 2014
Author: kikapu
Date: 2014-10-09 05:49:24 -0700 (Thu, 09 Oct 2014)
New Revision: 62224
grass-addons/grass7/raster/r.droka/r.droka.py
r.droka: update
Modified: grass-addons/grass7/raster/r.droka/r.droka.py
--- grass-addons/grass7/raster/r.droka/r.droka.py 2014-10-09 10:38:22 UTC (rev 62223)
+++ grass-addons/grass7/raster/r.droka/r.droka.py 2014-10-09 12:49:24 UTC (rev 62224)
@@ -43,6 +43,7 @@
#% key: red
#% type: double
#% description: Reduction value
+#% answer: 0.9
#% options : 0-1
#% required: yes
#%end
@@ -63,13 +64,13 @@
#% type: string
#% gisprompt: new,cell,raster
#% key_desc: name
-#% description: Prefix for output raster map(s)
+#% description: Prefix for output raster maps
#% required: yes
#%end
#%option
#% key: n
#% type: integer
-#% description: Buffer distance ((n*cellsize)/2)
+#% description: Buffer distance (meters)
#% required: no
#%end
@@ -111,10 +112,12 @@
num = options['num']
n = options['n']
- if n == '':
- n = 1
- else:
- n = float(n)
+ #if n == '':
+ # n = 1
+ #else:
+ # n = float(n)
grass.message("Setting variables...")
prefix = options['prefix']
rocks = prefix + '_propagation'
@@ -125,18 +128,18 @@
eMax = e + '_max'
eMean = e + '_mean'
- #print 'x = ' , x
- #print 'y = ' , y
- #print 'z = ' , z
- #print 'ang = ' , ang
- #print 'red = ' , red
- #print 'm = ' , m
gregion = grass.region()
PixelWidth = gregion['ewres']
- d_buff = (n * PixelWidth)/2
+ if n == '':
+ n = 1
+ d_buff = (float(num) * PixelWidth)/2
+ else:
+ n = float(n)
+ d_buff = n
+ #d_buff = (n * PixelWidth)/2
grass.message("Defining starting points...")
if int(num) == 1:
grass.run_command('g.copy' ,
