[GRASS-SVN] r62225 - grass/branches/releasebranch_7_0/gui/wxpython/rlisetup
svn_grass at osgeo.org
Thu Oct 9 07:47:42 PDT 2014
Author: neteler
Date: 2014-10-09 07:47:42 -0700 (Thu, 09 Oct 2014)
New Revision: 62225
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/frame.py
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/functions.py
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/g.gui.rlisetup.html
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/sampling_frame.py
grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/wizard.py
wxrlisetup: sync comments to trunk
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/frame.py 2014-10-09 12:49:24 UTC (rev 62224)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/frame.py 2014-10-09 14:47:42 UTC (rev 62225)
@@ -75,11 +75,11 @@
self.Layout()
def OnClose(self, event):
- """!Close window"""
+ """Close window"""
self.Destroy()
def OnOk(self, event):
- """!Launches help"""
+ """Launches help"""
dlg = wx.MessageDialog(parent=self.parent,
message=_("Are you sure that you want modify" \
" r.li configuration file {name}?" \
@@ -188,7 +188,7 @@
self.Layout()
def ListFiles(self):
- """!Check the configuration files inside the path"""
+ """Check the configuration files inside the path"""
# list of configuration file
listfiles = []
#return all the configuration files in self.rlipath, check if there are
@@ -199,15 +199,15 @@
return sorted(listfiles)
self.Destroy()
def OnHelp(self, event):
gcmd.RunCommand('g.manual', parent=self, entry='wxGUI.rlisetup')
def OnRemove(self, event):
- """!Remove configuration file from path and update the list"""
+ """Remove configuration file from path and update the list"""
confile = self.listfiles[self.listfileBox.GetSelections()[0]]
message=_("Do you want remove r.li " \
@@ -223,14 +223,14 @@
return
def OnNew(self, event):
RLIWizard(self)
self.listfiles = self.ListFiles()
self.listfileBox.Clear()
self.listfileBox.Set(self.listfiles)
def OnRename(self, event):
- """!Rename an existing configuration file"""
+ """Rename an existing configuration file"""
try:
except:
@@ -250,7 +250,7 @@
def OnView(self, event):
- """!Show and edit a configuration file"""
+ """Show and edit a configuration file"""
try:
except:
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/functions.py
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/functions.py 2014-10-09 12:49:24 UTC (rev 62224)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/functions.py 2014-10-09 14:47:42 UTC (rev 62225)
@@ -67,7 +67,7 @@
def checkMapExists(name, typ='rast'):
- """!Check if a map already exist in the working mapset"""
+ """Check if a map already exist in the working mapset"""
env = grass.gisenv()
mapset = env['MAPSET']
mapp = grass.find_file(name, typ, mapset)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/g.gui.rlisetup.html
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/g.gui.rlisetup.html 2014-10-09 12:49:24 UTC (rev 62224)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/g.gui.rlisetup.html 2014-10-09 14:47:42 UTC (rev 62225)
@@ -36,6 +36,7 @@
<img src="g_gui_rlisetup_sampleAreas.jpg" alt="Sampling area definitions">
+<p>
Definition of region for analysis:
<ul>
<li> Whole map layer: entire map (current region),</li>
@@ -165,7 +166,7 @@
Screenshots of the wizard window frames:
<center>
- <table border=1>
+ <table border=0>
<tr>
<td align=center>
<img src="g_gui_rlisetup_1.png" alt="g.gui.rlisetup: First frame of wizard for selecting existing configuration files or creating a new one">
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/sampling_frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/sampling_frame.py 2014-10-09 12:49:24 UTC (rev 62224)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/sampling_frame.py 2014-10-09 14:47:42 UTC (rev 62225)
@@ -1,5 +1,5 @@
# -*- coding: utf-8 -*-
@package rlisetup.sampling_frame
@brief r.li.setup - draw sample frame
@@ -64,7 +64,7 @@
class RLiSetupMapPanel(wx.Panel):
- """!Panel with mapwindow used in r.li.setup"""
+ """Panel with mapwindow used in r.li.setup"""
def __init__(self, parent, samplingType, icon=None, map_=None):
wx.Panel.__init__(self, parent=parent)
@@ -127,15 +127,15 @@
return self.map_
def OnPan(self, event):
- """!Panning, set mouse to drag."""
+ """Panning, set mouse to drag."""
self.mapWindow.SetModePan()
def OnZoomIn(self, event):
- """!Zoom in the map."""
+ """Zoom in the map."""
self.mapWindow.SetModeZoomIn()
def OnZoomOut(self, event):
- """!Zoom out the map."""
+ """Zoom out the map."""
self.mapWindow.SetModeZoomOut()
def OnZoomToMap(self, event):
@@ -143,7 +143,7 @@
self.mapWindow.ZoomToMap(layers=layers, ignoreNulls=False, render=True)
def OnDrawRadius(self, event):
- """!Start draw mode"""
+ """Start draw mode"""
self.mapWindow.mouse['use'] = "None"
self.mapWindow.mouse['box'] = "line"
self.mapWindow.pen = wx.Pen(colour=wx.RED, width=1,
@@ -152,7 +152,7 @@
self.mapWindow.mouseLeftUp.connect(self._radiusDrawn)
def OnDigitizeRegion(self, event):
@@ -164,7 +164,7 @@
self._registeredGraphics.GetItem(0).SetCoords([])
def OnDraw(self, event):
self.mapWindow.mouse['box'] = "box"
self.mapWindow.pen = wx.Pen(colour=wx.RED, width=2,
@@ -270,7 +270,7 @@
return marea
def _onToolChanged(self):
- """!Helper function to disconnect drawing"""
+ """Helper function to disconnect drawing"""
try:
self.mapWindow.mouseLeftUp.disconnect(self._rectangleDrawn)
self.mapWindow.mouseLeftUp.disconnect(self._radiusDrawn)
@@ -281,7 +281,7 @@
pass
def _radiusDrawn(self, x, y):
- """!When drawing finished, get region values"""
+ """When drawing finished, get region values"""
mouse = self.mapWindow.mouse
item = self._registeredGraphics.GetItem(0)
p1 = mouse['begin']
@@ -340,7 +340,7 @@
return marea
def _rectangleDrawn(self):
p1 = self.mapWindow.Pixel2Cell(mouse['begin'])
@@ -375,7 +375,7 @@
dlg.Destroy()
elif self.samplingtype != SamplingType.WHOLE:
self.sampleFrameChanged.emit(region=region)
icons = {'draw': MetaIcon(img='edit',
@@ -393,10 +393,10 @@
class RLiSetupToolbar(BaseToolbar):
- """!IClass toolbar
+ """IClass toolbar
def __init__(self, parent, toolSwitcher):
- """!RLiSetup toolbar constructor
+ """RLiSetup toolbar constructor
BaseToolbar.__init__(self, parent, toolSwitcher,
@@ -426,7 +426,7 @@
self.Realize()
def _toolbarData(self):
- """!Toolbar data"""
+ """Toolbar data"""
if self.parent.samplingtype == SamplingType.REGIONS:
drawTool = ('digitizeregion', icons['digitizeregion'],
self.parent.OnDigitizeRegion, wx.ITEM_CHECK)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/wizard.py
--- grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/wizard.py 2014-10-09 12:49:24 UTC (rev 62224)
+++ grass/branches/releasebranch_7_0/gui/wxpython/rlisetup/wizard.py 2014-10-09 14:47:42 UTC (rev 62225)
@@ -36,11 +36,7 @@
from functions import SamplingType, sampleAreaVector, convertFeature, obtainAreaVector
from core.gcmd import GError, GMessage, RunCommand
-#@NOTE: r.li.setup writes in the settings file with
-## r.li.windows.tcl:
-#exec echo "SAMPLINGFRAME $per_x|$per_y|$per_rl|$per_cl" >> $env(TMP).set
class RLIWizard(object):
!Start wizard here and finish wizard here
@@ -54,7 +50,7 @@
self.rlipath = retRLiPath()
self.msAreaList = []
- #pages
+ # pages
self.startpage = FirstPage(self.wizard, self)
self.drawsampleframepage = DrawSampleFramePage(self.wizard, self)
self.keyboardpage = KeyboardPage(self.wizard, self)
@@ -67,7 +63,7 @@
self.moving = MovingKeyPage(self.wizard, self)
self.regions = DrawRegionsPage(self.wizard, self)
- #order of pages
+ # order of pages
self.startpage.SetNext(self.samplingareapage)
self.keyboardpage.SetPrev(self.startpage)
self.keyboardpage.SetNext(self.samplingareapage)
@@ -96,7 +92,7 @@
self.summarypage.SetPrev(self.samplingareapage)
- #layout
+ # layout
self.startpage.DoLayout()
self.drawsampleframepage.DoLayout()
self.keyboardpage.DoLayout()
@@ -110,7 +106,7 @@
self.vectorareas.DoLayout()
self.wizard.FitToPage(self.startpage)
- #run_wizard
+ # run_wizard
if self.wizard.RunWizard(self.startpage):
message=_("Do you want to create r.li "
@@ -132,7 +128,7 @@
self._cleanup()
def _write_confile(self):
- """!Write the configuration file"""
+ """Write the configuration file"""
f = open(os.path.join(self.rlipath, self.startpage.conf_name), 'wb')
self.rasterinfo = grast.raster_info(self.startpage.rast)
self._write_region(f)
@@ -150,16 +146,16 @@
self.SF_EWRES = self.gregion['ewres']
def _write_region(self, fil):
- """!Write the region"""
+ """Write the region"""
if self.startpage.region == 'whole':
fil.write("SAMPLINGFRAME 0|0|1|1\n")
self._temp_region()
self.SF_X = 0.0
self.SF_Y = 0.0
self.SF_RL = abs(int(float(self.gregion['s'] - self.gregion['n'])
- / float(self.gregion['nsres'])))
+ / float(self.gregion['nsres'])))
self.SF_CL = abs(int(float(self.gregion['e'] - self.gregion['w'])
- / float(self.gregion['ewres'])))
+ / float(self.gregion['ewres'])))
self.SF_N = self.gregion['n']
self.SF_S = self.gregion['s']
self.SF_E = self.gregion['e']
@@ -226,7 +222,7 @@
return
def _circle(self, radius, mask):
- """!Create a circle mask"""
+ """Create a circle mask"""
self._value_for_circle(radius)
eastEdge = float(self.SF_W + (self.CIR_RL * self.SF_EWRES))
southEdge = float(self.SF_N - (self.CIR_CL * self.SF_NSRES))
@@ -243,7 +239,7 @@
grass.run_command('g.region', rast=self.startpage.rast)
def getSamplingType(self):
- """!Obtain the sampling type"""
+ """Obtain the sampling type"""
devicetype = self.samplingareapage.regionbox
samplingtype = self.samplingareapage.samplingtype
shapetype = self.units.boxtype
@@ -281,7 +277,7 @@
return samtype
def _write_area(self, fil):
- """!Write the area according the type"""
+ """Write the area according the type"""
samtype = self.getSamplingType()
#sampling type is whole
@@ -402,7 +398,7 @@
fil.write("VECTORMAP {name}\n".format(name=self.startpage.vect))
def _cleanup(self):
- """!Clean all the variables to save into configuration file"""
+ """Clean all the variables to save into configuration file"""
self.startpage.conf_name = ''
self.startpage.rast = ''
self.startpage.vect = ''
@@ -492,7 +488,7 @@
wx.CallAfter(wx.FindWindowById(wx.ID_FORWARD).Enable, False)
def OnSampling(self, event):
- """!Change region type"""
+ """Change region type"""
if event.GetInt() == 0:
self.region = 'whole'
self.SetNext(self.parent.samplingareapage)
@@ -504,7 +500,7 @@
self.SetNext(self.parent.drawsampleframepage)
def OnName(self, event):
- """!Sets the name of configuration file"""
+ """Sets the name of configuration file"""
if self.conf_name in self.parent.parent.listfiles:
GMessage(parent=self, message=_("The configuration file %s "
"already exists, please change name") % self.conf_name)
@@ -512,41 +508,42 @@
self.conf_name = ''
def OnNameChanged(self, event):
- """!Name of configuration file has changed"""
+ """Name of configuration file has changed"""
self.conf_name = self.newconftxt.GetValue()
next = wx.FindWindowById(wx.ID_FORWARD)
next.Enable(self.CheckInput())
def OnRast(self, event):
- """!Sets raster map"""
+ """Sets raster map"""
self.rast = event.GetString()
def OnVector(self, event):
- """!Sets vector map"""
+ """Sets vector map"""
self.vect = event.GetString()
def OnEnterPage(self, event):
- """!Sets the default values, for the entire map
+ """Sets the default values, for the entire map
- wx.CallAfter(wx.FindWindowById(wx.ID_FORWARD).Enable, self.CheckInput())
+ wx.CallAfter(wx.FindWindowById(wx.ID_FORWARD).Enable,
+ self.CheckInput())
def CheckInput(self):
- """!Check input fields.
+ """Check input fields.
- @return True if configuration file is given and raster xor vector map,
- False otherwise
+ :return: True if configuration file is given and raster xor vector map,
+ False otherwise
#R#return bool(self.conf_name and (bool(self.rast) != bool(self.vect)))
return bool(self.conf_name and bool(self.rast))
def OnExitPage(self, event=None):
- """!Function during exiting"""
+ """Function during exiting"""
if event.GetDirection():
@@ -570,7 +567,6 @@
TitledPage.__init__(self, wizard, _("Insert sampling frame parameter"))
self.parent = parent
- self.sizer.AddGrowableCol(2)
self.col_len = ''
self.row_len = ''
self.col_up = '0'
@@ -589,6 +585,7 @@
flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL | wx.ALL)
self.sizer.Add(item=self.ColUpLefttxt, border=5, pos=(1, 2),
+ self.sizer.AddGrowableCol(2)
#row up/left
self.RowUpLeftlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
label=_('Row of upper left corner'))
@@ -637,27 +634,27 @@
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGING, self.OnExitPage)
def OnColLeft(self, event):
self.col_up = self.ColUpLefttxt.GetValue()
checkValue(self.col_up)
def OnRowLeft(self, event):
self.row_up = self.RowUpLefttxt.GetValue()
checkValue(self.row_up)
def OnColLen(self, event):
self.col_len = self.ColLentxt.GetValue()
checkValue(self.col_len)
def OnRowLen(self, event):
self.row_len = self.RowLentxt.GetValue()
checkValue(self.row_len)
#R# check if raster exists before anything
if self.col_len == '' and self.row_len == '':
@@ -669,7 +666,7 @@
self.RowLentxt.SetValue(self.row_len)
if self.row_len == '' or self.col_len == '' or self.row_up == '' or self.col_up == '':
wx.FindWindowById(wx.ID_FORWARD).Enable(False)
else:
@@ -677,7 +674,7 @@
class DrawSampleFramePage(TitledPage):
- """!Choose the region setting the values drawing a box"""
+ """Choose the region setting the values drawing a box"""
def __init__(self, wizard, parent):
TitledPage.__init__(self, wizard, _("Draw sampling frame"))
@@ -687,7 +684,7 @@
def SampleFrameChanged(self, region):
- """"!Enables the next dialog when region is set"""
+ """"Enables the next dialog when region is set"""
if region:
self.tregion = region
wx.FindWindowById(wx.ID_FORWARD).Enable(True)
@@ -695,7 +692,7 @@
- """!Function during entering"""
+ """Function during entering"""
if self.mapPanel is None:
self.mapPanel = RLiSetupMapPanel(self, samplingType='drawFrame')
self.mapPanel.sampleFrameChanged.connect(self.SampleFrameChanged)
@@ -716,7 +713,7 @@
name=rast, hidden=False, opacity=1.0, render=True)
self.parent.samplingareapage.SetPrev(self)
@@ -803,7 +800,7 @@
self.Bind(wiz.EVT_WIZARD_PAGE_CHANGED, self.OnEnterPage)
def OnNumRegions(self, event):
- """!Obtain the number of regions"""
+ """Obtain the number of regions"""
if event.GetString():
self.SetNext(self.parent.regions)
@@ -812,7 +809,7 @@
- """!Insert values into text controls for summary of location
+ """Insert values into text controls for summary of location
creation options
self.SetVal(None)
@@ -825,7 +822,7 @@
def SetVal(self, event):
- """!Choose method"""
+ """Choose method"""
radio = self.radioBox.GetSelection()
if radio == 0:
@@ -848,7 +845,7 @@
self.ShowExtraOptions(self.samplingtype)
def ShowExtraOptions(self, samtype):
- """!Show some extra options for some sampling type"""
+ """Show some extra options for some sampling type"""
if samtype == SamplingType.REGIONS:
self.sizer.Hide(self.regionBox)
self.sizer.Hide(self.areaPanel)
@@ -871,14 +868,14 @@
return
def OnVectYes(self, event):
- """!The user choose to select the vector areas, this function set the
+ """The user choose to select the vector areas, this function set the
next page to VectorAreasPage"""
self.SetNext(self.parent.vectorareas)
self.parent.wizard.ShowPage(self.parent.vectorareas)
def OnVectNo(self, event):
- """!The user choose to use all the vector areas, this function analyses
+ """The user choose to use all the vector areas, this function analyses
all the vector areas and fill the msAreaList variable"""
self.sizer.Show(self.calculatingAreas)
self.sizer.Hide(self.regionNumPanel)
@@ -911,7 +908,7 @@
self._progressDlg = None
def RegionDraw(self, regtype):
- """!Set the next page to units or drawunits"""
+ """Set the next page to units or drawunits"""
if regtype == 0:
self.regionbox = 'keyboard'
if self.samplingtype == SamplingType.UNITS:
@@ -960,7 +957,7 @@
if self.parent.samplingareapage.samplingtype == SamplingType.WHOLE:
self.title.SetLabel(_("Draw moving windows region"))
elif self.parent.samplingareapage.samplingtype == SamplingType.UNITS:
@@ -995,7 +992,7 @@
class SampleUnitsKeyPage(TitledPage):
- """!Set values from keyboard for sample units
+ """Set values from keyboard for sample units
It is used if you choose keyboard from Sampling Units or Moving windows
in sampling areas page
@@ -1091,20 +1088,20 @@
self.OnType(None)
def OnEnterPage(self, event=None):
# This is an hack to force the user to choose Rectangle or Circle
self.typeBox.SetSelection(2),
self.typeBox.ShowItem(2, False)
self.panelSizer.Layout()
self.SetNext(self.parent.summarypage)
self.SetPrev(self.parent.samplingareapage)
def OnType(self, event):
- """!Set if rectangle or circle will be used"""
+ """Set if rectangle or circle will be used"""
chosen = self.typeBox.GetSelection()
self.widthLabel.SetLabel(self.widthLabels[chosen])
self.heightLabel.SetLabel(self.heightLabels[chosen])
@@ -1166,13 +1163,12 @@
class MovingKeyPage(TitledPage):
- """!Set values from keyboard for sample units"""
+ """Set values from keyboard for sample units"""
TitledPage.__init__(self, wizard, _("Set sample units"))
self.width = ''
self.height = ''
self.boxtype = 'rectangle'
@@ -1204,6 +1200,7 @@
self.sizer.Add(item=self.heightTxt, border=5, pos=(3, 2),
self.widthLabels = [_('Width size (in cells) ?'),
_('What radius size (in meters) ?')]
self.heightLabels = [_('Height size (in cells) ?'),
@@ -1227,23 +1224,17 @@
self.sizer.Layout()
if chosen == 0:
- if self.parent.samplingareapage.samplingtype == SamplingType.MVWIN:
- self.parent.samplingareapage.samplingtype = SamplingType.KMVWINR
- else:
- self.parent.samplingareapage.samplingtype = SamplingType.KMVWINC
+ self.parent.samplingareapage.samplingtype = SamplingType.KMVWINR
elif chosen == 1:
- else:
- self.parent.samplingareapage.samplingtype = SamplingType.MMVWINC
+ self.parent.samplingareapage.samplingtype = SamplingType.KMVWINC
self.boxtype = 'circle'
- False otherwise
+ vector map, False otherwise
return bool(self.width and bool(self.height))
@@ -1259,7 +1250,7 @@
class UnitsMousePage(TitledPage):
- """!Choose the sampling area setting the values using the mouse drawing the
+ """Choose the sampling area setting the values using the mouse drawing the
areas with rectangle or circle. It is used both from 'Moving windows'
and 'Sample units'.
@@ -1305,7 +1296,7 @@
self.regionNumTxt.SetValue('')
if self.numregions:
else:
@@ -1347,7 +1338,7 @@
self.drawtype = 'circle'
- """!Set the number of region"""
+ """Set the number of region"""
self.SetNext(self.parent.drawsampleunitspage)
@@ -1356,14 +1347,14 @@
self.SetNext(self.drawsampleunitspage)
self.SetPrev(self.samplingareapage)
class DrawSampleUnitsPage(TitledPage):
- """!Choose the sampling area drawing them"""
+ """Choose the sampling area drawing them"""
TitledPage.__init__(self, wizard, _("Draw sampling units"))
@@ -1388,7 +1379,7 @@
if self.parent.samplingareapage.samplingtype in [SamplingType.MVWIN,
SamplingType.MMVWINC,
@@ -1402,7 +1393,7 @@
gtype = self.parent.drawunits.drawtype
- samplingType=self.parent.samplingareapage.samplingtype,
+ samplingType=self.parent.samplingareapage.samplingtype,
if gtype == 'circle':
self.mapPanel.afterCircleDrawn.connect(self.SampleFrameChanged)
@@ -1434,7 +1425,7 @@
class VectorAreasPage(TitledPage):
- """!Choose the sampling area using the vector features"""
+ """Choose the sampling area using the vector features"""
TitledPage.__init__(self, wizard, _("Select sampling areas"))
@@ -1460,7 +1451,7 @@
self.sizer.Add(self.areaPanel, flag=wx.ALIGN_CENTER, pos=(2, 0))
def afterRegionDrawn(self):
- """!Function to update the title and the number of selected area"""
+ """Function to update the title and the number of selected area"""
self.areascount = self.areascount + 1
if self.areascount == self.areanum:
@@ -1472,19 +1463,19 @@
return False
def OnYes(self, event):
- """!Function to create the string for the conf file if the area
+ """Function to create the string for the conf file if the area
is selected"""
self.parent.msAreaList.append(obtainAreaVector(self.outname))
if not self.afterRegionDrawn():
self.newCat()
def OnNo(self, event):
- """!Function to pass to the next feature if it is not selected"""
+ """Function to pass to the next feature if it is not selected"""
self.newCat()
def newCat(self):
- """!Convert to raster and draw the new feature"""
+ """Convert to raster and draw the new feature"""
cat = self.vect_cats[self.areascount]
self.outname = "{name}_{cat}".format(name=self.vect.split('@')[0],
cat=cat)
@@ -1502,7 +1493,7 @@
self.areaText.SetLabel("Is this area (cat={n}) ok?".format(n=cat))
- """!Function during entering: draw the raster map and the first vector
+ """Function during entering: draw the raster map and the first vector
feature"""
self.mapPanel = RLiSetupMapPanel(self, samplingType=self.parent.samplingareapage.samplingtype,
@@ -1535,7 +1526,7 @@
self.newCat()
grass.del_temp_region()
# if event.GetDirection():
# self.SetNext(self.parent.samplingareapage)
@@ -1543,13 +1534,12 @@
class SummaryPage(TitledPage):
- """!Shows summary result of choosing data"""
+ """Shows summary result of choosing data"""
TitledPage.__init__(self, wizard, _("Summary"))
global rlisettings
#configuration file name
self.conflabel = wx.StaticText(parent=self, id=wx.ID_ANY,
@@ -1560,7 +1550,6 @@
self.sizer.Add(item=self.conftxt, border=5, pos=(0, 1),
#raster name
self.rastlabel = wx.StaticText(parent=self, id=wx.ID_ANY,
label=_('Raster name:'))
@@ -1652,8 +1641,9 @@
self.sizer.Add(item=self.unitsmoretxt2, border=5, pos=(11, 1),
creation options
self.conftxt.SetLabel(self.parent.startpage.conf_name)
