[GRASS-SVN] r62264 - grass-addons/grass7/gui/wxpython/wx.metadata/templates
svn_grass at osgeo.org
Wed Oct 15 07:04:36 PDT 2014
Author: madi
Date: 2014-10-15 07:04:36 -0700 (Wed, 15 Oct 2014)
New Revision: 62264
grass-addons/grass7/gui/wxpython/wx.metadata/templates/inspireTemplate.xml
Small typos corrected
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/templates/inspireTemplate.xml
--- grass-addons/grass7/gui/wxpython/wx.metadata/templates/inspireTemplate.xml 2014-10-15 09:26:41 UTC (rev 62263)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/templates/inspireTemplate.xml 2014-10-15 14:04:36 UTC (rev 62264)
@@ -147,7 +147,7 @@
<gmd:resourceConstraints>
<gmd:MD_LegalConstraints>
<gmd:accessConstraints>
- <gmd:MD_RestrictionCode codeList="http://www.isotc211.org/2005/resources/Codelist/ML_gmxCodelists.xml#MD_RestrictionCode" codeListValue="{{ oc }}{# tag="oc" , name="Other constraionts" , ref= "Part B 8.1" , desc= "Restrictions on the access and use of a resource or metadata" , example = "No conditions apply" , type ="MD_RestrictionCode" ,group= "Constraints" , multi= 0, multiline= False,inbox="Other restriction", inboxmulti=1 #}">{{ oc }}</gmd:MD_RestrictionCode>
+ <gmd:MD_RestrictionCode codeList="http://www.isotc211.org/2005/resources/Codelist/ML_gmxCodelists.xml#MD_RestrictionCode" codeListValue="{{ oc }}{# tag="oc" , name="Other constraints" , ref= "Part B 8.1" , desc= "Restrictions on the access and use of a resource or metadata" , example = "No conditions apply" , type ="MD_RestrictionCode" ,group= "Constraints" , multi= 0, multiline= False,inbox="Other restriction", inboxmulti=1 #}">{{ oc }}</gmd:MD_RestrictionCode>
</gmd:accessConstraints>
{% endfor -%}
{% for ac in md.identification.accessconstraints -%}{# tag="for oc in md.identification.accessconstraints" , group= "Constraints",inbox="Limitation on public access", inboxmulti=1 #}
@@ -220,7 +220,7 @@
<gmd:EX_TemporalExtent>
<gmd:extent>
<gml:TimePeriod xsi:type="gml:TimePeriodType">
- <gml:beginPosition>{{ md.identification.temporalextent_start }}{# tag="md.identification.temporalextent_start" , name="Starting date" , ref= "Part B 5.1" , desc= "Time period covered by the content of the dataset." , example = "2000-11-30" , type ="date" , group= "Temporal" , inbox= "Temporal extend", multi=0 , inboxmulti= 0, multiline= False #}</gml:beginPosition>
+ <gml:beginPosition>{{ md.identification.temporalextent_start }}{# tag="md.identification.temporalextent_start" , name="Starting date" , ref= "Part B 5.1" , desc= "Time period covered by the content of the dataset." , example = "2000-11-30" , type ="date" , group= "Temporal" , inbox= "Temporal extent", multi=0 , inboxmulti= 0, multiline= False #}</gml:beginPosition>
<gml:endPosition>{{ md.identification.temporalextent_end }}{# tag="md.identification.temporalextent_end" , name="Ending date" , ref= "Part B 5.1" , desc= "Time period covered by the content of the dataset." , example = "2000-11-30" , type ="date" , group= "Temporal" , inbox= "Temporal extend", multi=0 , inboxmulti= 0, multiline= False #}</gml:endPosition>
</gml:TimePeriod>
</gmd:extent>
