[GRASS-SVN] r62265 - grass-addons/grass7/raster/r.random.weight
svn_grass at osgeo.org
Wed Oct 15 15:00:20 PDT 2014
Author: pvanbosgeo
Date: 2014-10-15 15:00:19 -0700 (Wed, 15 Oct 2014)
New Revision: 62265
grass-addons/grass7/raster/r.random.weight/r.random.weight.py
Corrections subsampling
Modified: grass-addons/grass7/raster/r.random.weight/r.random.weight.py
--- grass-addons/grass7/raster/r.random.weight/r.random.weight.py 2014-10-15 14:04:36 UTC (rev 62264)
+++ grass-addons/grass7/raster/r.random.weight/r.random.weight.py 2014-10-15 22:00:19 UTC (rev 62265)
@@ -83,7 +83,10 @@
def cleanup():
grass.run_command('g.remove',
- rast = tmp_map, quiet = True)
+ type = 'rast',
+ pattern = 'tmp_map',
+ flags='f',
+ quiet = True)
# main function
def main():
@@ -112,13 +115,13 @@
flags='g')
if seed == "auto":
- grass.mapcalc("$tmp_map = rand(${minval},${maxval})",
+ grass.mapcalc("$tmp_map = rand(float(${minval}),float(${maxval}))",
seed='auto',
minval = minval,
maxval = maxval,
tmp_map = tmp_map)
else:
seed=1,
minval = minval,
maxval = maxval,
@@ -130,18 +133,17 @@
tmp_map = tmp_map)
if not subsample == '':
+ grass.run_command('r.null',
+ map = outmap,
+ setnull = 0)
grass.run_command('r.random',
input = outmap,
n = subsample,
- raster_output = tmp_map2)
+ raster_output = outmap,
+ overwrite=True)
- map = tmp_map2,
+ map = outmap,
null = 0)
- grass.mapcalc("${outmap} = if(${outmap}>=0,${tmp_map2},null())",
- overwrite = True,
- outmap = outmap,
- tmp_map2 = tmp_map2)
- grass.run_command('g.remove', rast=tmp_map2)
print("------------------")
print("Ready!")
