[GRASS-SVN] r62276 - grass/trunk/gui/wxpython/gui_core
svn_grass at osgeo.org
Fri Oct 17 08:14:26 PDT 2014
Author: annakrat
Date: 2014-10-17 08:14:26 -0700 (Fri, 17 Oct 2014)
New Revision: 62276
grass/trunk/gui/wxpython/gui_core/query.py
wxGUI/query: convert to string only when necessary
Modified: grass/trunk/gui/wxpython/gui_core/query.py
--- grass/trunk/gui/wxpython/gui_core/query.py 2014-10-17 12:31:00 UTC (rev 62275)
+++ grass/trunk/gui/wxpython/gui_core/query.py 2014-10-17 15:14:26 UTC (rev 62276)
@@ -173,10 +173,10 @@
def QueryTreeBuilder(data, column):
"""Builds tree model from query results.
:param data: query results as a dictionary
:param column: column name
:return: tree model
def addNode(parent, data, model):
@@ -185,8 +185,10 @@
node = model.AppendNode(parent=parent, label=k)
addNode(parent=node, data=v, model=model)
else:
+ if not isinstance(v, basestring):
+ v = str(v)
node = model.AppendNode(parent=parent, label=k,
- data={column: str(v)})
+ data={column: v})
model = TreeModel(DictNode)
for part in data:
