[GRASS-SVN] r62277 - in grass/branches/releasebranch_7_0: . gui/wxpython/gui_core
Fri Oct 17 08:15:34 PDT 2014
Author: annakrat
Date: 2014-10-17 08:15:34 -0700 (Fri, 17 Oct 2014)
New Revision: 62277
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/gui/wxpython/gui_core/query.py
wxGUI/query: convert to string only when necessary (merge from trunk, r62276)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:61280,62144,62269,62271
   + /grass/trunk:61280,62144,62269,62271,62276
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/query.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/query.py	2014-10-17 15:14:26 UTC (rev 62276)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/query.py	2014-10-17 15:15:34 UTC (rev 62277)
@@ -173,10 +173,10 @@
 def QueryTreeBuilder(data, column):
     """!Builds tree model from query results.
     @param data query results as a dictionary
     @param column column name
     @returns tree model
     def addNode(parent, data, model):
@@ -185,8 +185,10 @@
                 node = model.AppendNode(parent=parent, label=k)
                 addNode(parent=node, data=v, model=model)
             else:
+                if not isinstance(v, basestring):
+                    v = str(v)
                 node = model.AppendNode(parent=parent, label=k,
-                                        data={column: str(v)})
+                                        data={column: v})
     model = TreeModel(DictNode)
     for part in data:
