[GRASS-SVN] r62322 - in grass/branches/releasebranch_7_0: . vector/v.surf.rst
svn_grass at osgeo.org
Tue Oct 21 07:42:00 PDT 2014
Author: annakrat
Date: 2014-10-21 07:42:00 -0700 (Tue, 21 Oct 2014)
New Revision: 62322
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c
v.surf.rst: attempt to fix #2452 (merge from trunk, r62300)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:61280,62141,62144,62269,62271,62276,62288,62305,62310
+ /grass/trunk:61280,62141,62144,62269,62271,62276,62288,62300,62305,62310
Modified: grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c
--- grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c 2014-10-21 14:08:47 UTC (rev 62321)
+++ grass/branches/releasebranch_7_0/vector/v.surf.rst/main.c 2014-10-21 14:42:00 UTC (rev 62322)
@@ -592,6 +592,7 @@
G_fatal_error(_("Unable to create table: '%s'"),
db_get_string(&sql2));
+ db_begin_transaction(driver2);
count = 1;
@@ -751,8 +752,8 @@
unlink(Tmp_file_xy);
if (cvdev != NULL || devi != NULL) {
- /* db_close_database_shutdown_driver ( driver2 ); */
- db_close_database(driver2);
+ db_commit_transaction(driver2);
+ db_close_database_shutdown_driver(driver2);
Vect_build(&Map2);
Vect_close(&Map2);
