[GRASS-SVN] r62323 - grass/trunk/lib/python/docs/src
    svn_grass at osgeo.org
    Tue Oct 21 07:52:47 PDT 2014
Author: neteler
Date: 2014-10-21 07:52:47 -0700 (Tue, 21 Oct 2014)
New Revision: 62323
   grass/trunk/lib/python/docs/src/index.rst
   grass/trunk/lib/python/docs/src/pygrass_gis.rst
   grass/trunk/lib/python/docs/src/pygrass_messages.rst
   grass/trunk/lib/python/docs/src/pygrass_raster.rst
   grass/trunk/lib/python/docs/src/pygrass_vector.rst
pygrass manual: cosmetics
Modified: grass/trunk/lib/python/docs/src/index.rst
--- grass/trunk/lib/python/docs/src/index.rst	2014-10-21 14:42:00 UTC (rev 62322)
+++ grass/trunk/lib/python/docs/src/index.rst	2014-10-21 14:52:47 UTC (rev 62323)
@@ -4,7 +4,7 @@
 Contents:
 .. toctree::
-   :maxdepth: 2
+   :maxdepth: 3
    script
    pygrass_index
Modified: grass/trunk/lib/python/docs/src/pygrass_gis.rst
--- grass/trunk/lib/python/docs/src/pygrass_gis.rst	2014-10-21 14:42:00 UTC (rev 62322)
+++ grass/trunk/lib/python/docs/src/pygrass_gis.rst	2014-10-21 14:52:47 UTC (rev 62323)
@@ -6,6 +6,8 @@
 These classes are used to manage the infrastructure
 of GRASS database: Gisdbase, Location and Mapset
+Details about the GRASS GIS database management (locations and mapsets)
+can be found in the `GRASS GIS 7 User's Manual: GRASS GIS Quickstart <http://grass.osgeo.org/grass71/manuals/helptext.html>`_
 .. _Region-label:
@@ -15,3 +17,5 @@
 The Region class it is useful to obtain information
 about the computational region and to change it.
+Details about the GRASS GIS computational region management can be found
+in the `GRASS GIS Wiki: Computational region <http://grasswiki.osgeo.org/wiki/Computational_region>`_
Modified: grass/trunk/lib/python/docs/src/pygrass_messages.rst
--- grass/trunk/lib/python/docs/src/pygrass_messages.rst	2014-10-21 14:42:00 UTC (rev 62322)
+++ grass/trunk/lib/python/docs/src/pygrass_messages.rst	2014-10-21 14:52:47 UTC (rev 62323)
@@ -4,3 +4,47 @@
 The PyGRASS message interface is a fast and exit-safe
 interface to the `GRASS C-library message functions <http://grass.osgeo.org/programming7/gis_2error_8c.html>`_.
+This class implements a fast and exit-safe interface to the GRASS
+C-library message functions like: G_message(), G_warning(),
+G_important_message(), G_verbose_message(), G_percent() and G_debug().
+Usage:
+    >>> msgr = Messenger()
+    >>> msgr.debug(0, "debug 0")
+    >>> msgr.verbose("verbose message")
+    >>> msgr.message("message")
+    >>> msgr.important("important message")
+    >>> msgr.percent(1, 1, 1)
+    >>> msgr.warning("Ohh")
+    >>> msgr.error("Ohh no")
+    >>> msgr.fatal("Ohh no no no!")
+    Traceback (most recent call last):
+      File "__init__.py", line 239, in fatal
+        sys.exit(1)
+    SystemExit: 1
+    >>> msgr = Messenger(raise_on_error=True)
+      File "__init__.py", line 241, in fatal
+        raise FatalError(message)
+    FatalError: Ohh no no no!
+    >>> msgr.set_raise_on_error(False)
+        sys.exit(1)
+    SystemExit: 1
+    >>> msgr = Messenger(raise_on_error=False)
+    >>> msgr.set_raise_on_error(True)
Modified: grass/trunk/lib/python/docs/src/pygrass_raster.rst
--- grass/trunk/lib/python/docs/src/pygrass_raster.rst	2014-10-21 14:42:00 UTC (rev 62322)
+++ grass/trunk/lib/python/docs/src/pygrass_raster.rst	2014-10-21 14:52:47 UTC (rev 62323)
@@ -3,7 +3,8 @@
 Introduction to Raster classes
-Details about the architecture can be found in the `GRASS GIS 7 Programmer's Manual: GRASS Raster Library <http://grass.osgeo.org/programming7/rasterlib.html>`_
+Details about the GRASS GIS raster architecture can be found in the
+`GRASS GIS 7 Programmer's Manual: GRASS Raster Library <http://grass.osgeo.org/programming7/rasterlib.html>`_
 PyGRASS uses 4 different Raster classes, that respect the 4 different approaches
 of GRASS-C API. The classes use a standardized interface to keep methods
Modified: grass/trunk/lib/python/docs/src/pygrass_vector.rst
--- grass/trunk/lib/python/docs/src/pygrass_vector.rst	2014-10-21 14:42:00 UTC (rev 62322)
+++ grass/trunk/lib/python/docs/src/pygrass_vector.rst	2014-10-21 14:52:47 UTC (rev 62323)
@@ -3,13 +3,13 @@
 Introduction to Vector classes
-Details about the GRASS vector architecture can be found in the
+Details about the GRASS GIS vector architecture can be found in the
 `GRASS GIS 7 Programmer's Manual: GRASS Vector Library <http://grass.osgeo.org/programming7/vectorlib.html>`_
 PyGrass has two classes for vector maps: :ref:`Vector-label` and :ref:`VectorTopo-label`.
 As the names suggest, the Vector class is for vector maps, while VectorTopo
-opens vector maps with GRASS topologies. VectorTopo is an extension
-of the Vector class, so supports all the Vector class methods, with additions.
+opens vector maps with `GRASS GIS topology <http://grass.osgeo.org/programming7/vlibTopology.html>`_.
+VectorTopo is an extension of the Vector class, so supports all the Vector class methods, with additions.
 .. _Vector-label:
@@ -165,7 +165,6 @@
     5128
 Get the number of different feature types in the vector map: ::
     >>> municip.number_of("areas")
@@ -310,7 +309,6 @@
     [Area(...), ..., Area(...)]
 Of course is still possible work only with a specific area, with: ::
     >>> from pygrass.vector.geometry import Area
@@ -331,3 +329,5 @@
     >>> isle = area.isles[0]
     >>> isle.bbox()
     Bbox(199947.296494, 199280.969494, 754920.623987, 754351.812986)
+.. _Vector library: http://grass.osgeo.org/programming7/vectorlib.html
