[GRASS-SVN] r62369 - grass/branches/releasebranch_7_0/scripts/v.report
svn_grass at osgeo.org
Thu Oct 23 15:02:14 PDT 2014
Author: neteler
Date: 2014-10-23 15:02:14 -0700 (Thu, 23 Oct 2014)
New Revision: 62369
grass/branches/releasebranch_7_0/scripts/v.report/v.report.py
python indentation fix backport
Modified: grass/branches/releasebranch_7_0/scripts/v.report/v.report.py
--- grass/branches/releasebranch_7_0/scripts/v.report/v.report.py 2014-10-23 21:56:55 UTC (rev 62368)
+++ grass/branches/releasebranch_7_0/scripts/v.report/v.report.py 2014-10-23 22:02:14 UTC (rev 62369)
@@ -124,8 +124,8 @@
records2.sort()
#make pre-table
- # len(records1) may not be the same as len(records2) because
- # v.db.select can return attributes that are not linked to features.
+ # len(records1) may not be the same as len(records2) because
+ # v.db.select can return attributes that are not linked to features.
records3 = []
for r2 in records2:
records3.append(filter(lambda r1: r1[0] == r2[0], records1)[0] + r2[1:])
