[GRASS-SVN] r62370 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Fri Oct 24 00:01:34 PDT 2014
Author: mmetz
Date: 2014-10-24 00:01:34 -0700 (Fri, 24 Oct 2014)
New Revision: 62370
grass/trunk/lib/vector/Vlib/read.c
Vlib: fix r55582, restore behaviour of Vect_*_alive() fns
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c 2014-10-23 22:02:14 UTC (rev 62369)
+++ grass/trunk/lib/vector/Vlib/read.c 2014-10-24 07:01:34 UTC (rev 62370)
@@ -192,13 +192,13 @@
\param line feature id
\return 1 feature alive
- \return 0 feature is dead
- \return -1 on error
+ \return 0 feature is dead or index is out of range
int Vect_line_alive(const struct Map_info *Map, int line)
if (line < 1 || line > Map->plus.n_lines) {
- return -1;
+ G_warning(_("Line index is out of range"));
+ return 0;
if (Map->plus.Line[line] != NULL)
@@ -216,12 +216,13 @@
\param node node id
\return 1 node alive
- \return 0 node is dead
+ \return 0 node is dead or index is out of range
int Vect_node_alive(const struct Map_info *Map, int node)
if (node < 1 || node > Map->plus.n_nodes) {
- return -1;
+ G_warning(_("Node index is out of range"));
+ return 0;
if (Map->plus.Node[node] != NULL)
@@ -239,13 +240,14 @@
\param area area id
\return 1 area alive
- \return 0 area is dead
+ \return 0 area is dead or index is out of range
int Vect_area_alive(const struct Map_info *Map, int area)
- if (area < 1 || area > Map->plus.n_areas)
- return -1;
+ if (area < 1 || area > Map->plus.n_areas) {
+ G_warning(_("Area index is out of range"));
+ return 0;
if (Map->plus.Area[area] != NULL)
return 1;
@@ -262,12 +264,14 @@
\param isle isle id
\return 1 isle alive
- \return 0 isle is dead
+ \return 0 isle is dead or index is out of range
int Vect_isle_alive(const struct Map_info *Map, int isle)
- if (isle < 1 || isle > Map->plus.n_isles)
- return -1;
+ if (isle < 1 || isle > Map->plus.n_isles) {
+ G_warning(_("Isle index is out of range"));
+ return 0;
if (Map->plus.Isle[isle] != NULL)
return 1;
