[GRASS-SVN] r62374 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Fri Oct 24 02:50:38 PDT 2014
Author: zarch
Date: 2014-10-24 02:50:38 -0700 (Fri, 24 Oct 2014)
New Revision: 62374
grass/trunk/lib/python/pygrass/modules/interface/module.py
pygrass: back to a pickable Module instance
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-10-24 07:30:52 UTC (rev 62373)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-10-24 09:50:38 UTC (rev 62374)
@@ -3,6 +3,7 @@
with_statement, print_function, unicode_literals)
import sys
from multiprocessing import cpu_count
+from functools import wraps
if sys.version_info[0] == 2:
from itertools import izip_longest as zip_longest
@@ -19,8 +20,44 @@
from grass.pygrass.modules.interface.flag import Flag
from grass.pygrass.modules.interface.typedict import TypeDict
from grass.pygrass.modules.interface.read import GETFROMTAG, DOC
-from grass.pygrass.messages import Messenger
+from grass.pygrass.messages import get_msgr
+def mdebug(level, msg='', extra=None):
+ """Debug decorators for class methods.
+ :param level: the debug level
+ :type level: int
+ :param msg: Debug message
+ :type msg: str
+ :param extra: Function that return a string
+ :type msg: func
+ msgr = get_msgr()
+ def decorator(method):
+ @wraps(method)
+ def wrapper(self, *args, **kargs):
+ sargs = ', ' + ' , '.join([repr(a) for a in args]) if args else ''
+ skargs = (' , '.join(['%s=%r' % (k, v) for k, v in kargs.items()])
+ if kargs else '')
+ opts = "%s%s%s" % (sargs, ',' if sargs and skargs else '', skargs)
+ dmsg = "%s.%s(self%s): %s %s" % (self.__class__.__name__,
+ method.__name__,
+ opts, msg,
+ extra(self, *args, **kargs)
+ if extra else '')
+ msgr.debug(level, dmsg)
+ return method(self, *args, **kargs)
+ return wrapper
+ return decorator
+def _get_bash(self, *args, **kargs):
+ return self.get_bash()
class ParallelModuleQueue(object):
"""This class is designed to run an arbitrary number of pygrass Module
processes in parallel.
@@ -337,8 +374,6 @@
and keyword arguments to the grass module.
def __init__(self, cmd, *args, **kargs):
- self._msgr = Messenger()
if isinstance(cmd, unicode):
self.name = str(cmd)
elif isinstance(cmd, str):
@@ -421,7 +456,7 @@
if not args and not kargs:
self.run()
return self
# check for extra kargs, set attribute and remove from dictionary
@@ -458,11 +493,6 @@
raise ParameterError('%s is not a valid parameter.' % key)
- # print debug message
- self._msgr.debug(1, "Module.__call__(): %s" % (self.get_bash()))
# check if execute
if self.run_:
@@ -558,7 +588,8 @@
args.append(str(self.flags[flg]))
return args
- def run(self, node=None):
+ @mdebug(1, extra=_get_bash)
+ def run(self):
"""Run the module
:param node:
