[GRASS-SVN] r62375 - in grass/trunk/temporal: . t.connect t.create t.info t.list t.merge t.rast.accdetect t.rast.accumulate t.rast.aggregate t.rast.aggregate.ds t.rast.colors t.rast.export t.rast.extract t.rast.import t.rast.list t.rast.mapcalc t.rast.neighbors t.rast.out.vtk t.rast.series t.rast.to.rast3 t.rast.univar t.rast3d.extract t.rast3d.list t.rast3d.mapcalc t.rast3d.mapcalc2 t.rast3d.univar t.register t.rename t.sample t.select t.shift t.snap t.support t.topology t.unregister t.vect.db.select t.vect.export t.vect.extract t.vect.import t.vect.list t.vect.mapcalc t.vect.observe.strds t.vect.univar t.vect.what.strds
Fri Oct 24 04:13:20 PDT 2014
Author: neteler
Date: 2014-10-24 04:13:20 -0700 (Fri, 24 Oct 2014)
New Revision: 62375
   grass/trunk/temporal/t.connect/t.connect.html
   grass/trunk/temporal/t.create/t.create.html
   grass/trunk/temporal/t.info/t.info.html
   grass/trunk/temporal/t.list/t.list.html
   grass/trunk/temporal/t.merge/t.merge.html
   grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.html
   grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html
   grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.html
   grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html
   grass/trunk/temporal/t.rast.colors/t.rast.colors.html
   grass/trunk/temporal/t.rast.export/t.rast.export.html
   grass/trunk/temporal/t.rast.extract/t.rast.extract.html
   grass/trunk/temporal/t.rast.import/t.rast.import.html
   grass/trunk/temporal/t.rast.list/t.rast.list.html
   grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.html
   grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
   grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.html
   grass/trunk/temporal/t.rast.series/t.rast.series.html
   grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.html
   grass/trunk/temporal/t.rast.univar/t.rast.univar.html
   grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.html
   grass/trunk/temporal/t.rast3d.list/t.rast3d.list.html
   grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.html
   grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html
   grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.html
   grass/trunk/temporal/t.register/t.register.html
   grass/trunk/temporal/t.rename/t.rename.html
   grass/trunk/temporal/t.sample/t.sample.html
   grass/trunk/temporal/t.select/t.select.html
   grass/trunk/temporal/t.shift/t.shift.html
   grass/trunk/temporal/t.snap/t.snap.html
   grass/trunk/temporal/t.support/t.support.html
   grass/trunk/temporal/t.topology/t.topology.html
   grass/trunk/temporal/t.unregister/t.unregister.html
   grass/trunk/temporal/t.vect.db.select/t.vect.db.select.html
   grass/trunk/temporal/t.vect.export/t.vect.export.html
   grass/trunk/temporal/t.vect.extract/t.vect.extract.html
   grass/trunk/temporal/t.vect.import/t.vect.import.html
   grass/trunk/temporal/t.vect.list/t.vect.list.html
   grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.html
   grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html
   grass/trunk/temporal/t.vect.univar/t.vect.univar.html
   grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html
   grass/trunk/temporal/temporalintro.html
t.* temporal manual: some HTML cleanup; example stubs added
Modified: grass/trunk/temporal/t.connect/t.connect.html
--- grass/trunk/temporal/t.connect/t.connect.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.connect/t.connect.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -4,23 +4,26 @@
 <h2>NOTES</h2>
-Values are stored in the mapset's <tt>VAR</tt> file;
-the connection is not tested for validity.
-<p>The <b>-d</b> flag will set the default TGIS connection parameters.
-A sqlite3 database "tgis/sqlite.db" will be created in the PERMANET directory
-of the current location. It will be located in the "tgis" sub-directory to not
-interfere with the sqlite3 database used for vector attribute storage.
-<p>The <b>-p</b> flag will display the current TGIS connection parameters.
-<p>The <b>-pg</b> flag will display the current TGIS connection parameters using shell style.
-<p>The <b>-c</b> flag will silently check if the TGIS connection parameters have
-been set, and if not will set them to use GRASS's default values.
+Values are stored in the mapset's <tt>VAR</tt> file; the connection is
+not tested for validity. <p>The <b>-d</b> flag will set the default
+TGIS connection parameters. A sqlite3 database "tgis/sqlite.db" will be
+created in the PERMANET directory of the current location. It will be
+located in the "tgis" sub-directory to not interfere with the sqlite3
+database used for vector attribute storage. <p>The <b>-p</b> flag will
+display the current TGIS connection parameters. <p>The <b>-pg</b> flag
+will display the current TGIS connection parameters using shell style.
+<p>The <b>-c</b> flag will silently check if the TGIS connection
+parameters have been set, and if not will set them to use GRASS's
+default values.
 <h2>Note</h2>
-The default TGIS database of type sqlite3 is located in the PERMANENT mapset directory.
-Temporal GIS content from all created mapsets will be stored here. In case
-you have thousends of maps to register in the temporal database or you need concurrent read
-and write access in the TGIS database, consider to use a postgresql database instead.
+The default TGIS database of type sqlite3 is located in the PERMANENT
+mapset directory. Temporal GIS content from all created mapsets will be
+stored here. In case you have thousends of maps to register in the
+temporal database or you need concurrent read and write access in the
+TGIS database, consider to use a postgresql database instead.
 <h3>SQLite</h3>
 <div class="code"><pre>
@@ -28,11 +31,15 @@
 t.connect -p
 t.info -s
 </pre></div>
-<p>The SQLite database is created automatically when used the first time.
+<p>
+The SQLite database is created automatically when used the first time.
 <h3>PostgreSQL</h3>
-In case you use a postgresql database, you will need to specify the TGIS database connection
-for each mapset.
+In case you use a PostgreSQL database, you will need to specify the
+TGIS database connection for each mapset.
 t.connect driver=pg database="dbname=grass_test user=soeren password=abcdefgh"
 t.connect -p
Modified: grass/trunk/temporal/t.create/t.create.html
--- grass/trunk/temporal/t.create/t.create.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.create/t.create.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -3,30 +3,29 @@
 The purpose of this module is the creation of space time datasets of
 type raster (STRDS), 3D raster (STR3DS) and vector (STVDS).
 <p>
-Space time datasets represent spatio-temporal fields in the temporal GRASS framework.
-They are designed to collect any amount of time stamped maps with time intervals
-and time instances.
-The temporal type of a space time dataset
-can be absolute or relative and must be set on dataset creation besides the name and the description.
+Space time datasets represent spatio-temporal fields in the temporal
+GRASS framework. They are designed to collect any amount of time
+stamped maps with time intervals and time instances. The temporal type
+of a space time dataset can be absolute or relative and must be set on
+dataset creation besides the name and the description.
 <p>
-Time stamped maps can registered in and unregistered from space time datasets.
-The spatio-temporal extent as well as the metadata of a space time dataset is derived from its registered maps.
-Hence the metadata is dependent from the dataset type (raster, 3D raster, vector).
-<p>
+Time stamped maps can registered in and unregistered from space time
+datasets. The spatio-temporal extent as well as the metadata of a space
+time dataset is derived from its registered maps. Hence the metadata is
+dependent from the dataset type (raster, 3D raster, vector).
 <h2>EXAMPLE</h2>
-In this example we create 7 raster maps using r.mapcalc with random values
-that will be registered in a single space time
-raster dataset named <em>precipitation_daily</em> using a daily temporal granularity.
-The names of the raster maps are stored in a text
-file that is used for raster map registration.
-We use <em>t.create</em> for the space time raster dataset creation
-and <em>t.register</em> to register the raster maps
-in the space time raster dataset.
-At the end we report informations about the
-space time raster dataset to stdout using <em>t.info</em>.
+In this example we create 7 raster maps using r.mapcalc with random
+values that will be registered in a single space time raster dataset
+named <em>precipitation_daily</em> using a daily temporal granularity.
+The names of the raster maps are stored in a text file that is used for
+raster map registration. We use <em>t.create</em> for the space time
+raster dataset creation and <em>t.register</em> to register the raster
+maps in the space time raster dataset. At the end we report
+informations about the space time raster dataset to stdout using
+<em>t.info</em>.
 MAPS="map_1 map_2 map_3 map_4 map_5 map_6 map_7"
Modified: grass/trunk/temporal/t.info/t.info.html
--- grass/trunk/temporal/t.info/t.info.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.info/t.info.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,31 +1,33 @@
 <h2>DESCRIPTION</h2>
-<em>t.info</em> reports informations about any dataset that is registered in the temporal database in
-human readable or shell script style. Datasets are raster, 3D raster and vector maps as well as their
-corresponding space time datasets (STRDS, STR3DS and STVDS). This module reports the informations that
-are stored in the temporal database. These are basic informations (id, name, mapset, creator,
-creation time, temporal type),
-the temporal and spatial extent and dataset type specific metadata.
-The user has to utilize <em>r.info, r3.info, v.info</em>
-to report detailed informations about raster, 3D raster and vector maps, since
-not all map specific informations and metadata are stored in the temporal database.
+<em>t.info</em> reports informations about any dataset that is
+registered in the temporal database in human readable or shell script
+style. Datasets are raster, 3D raster and vector maps as well as their
+corresponding space time datasets (STRDS, STR3DS and STVDS). This
+module reports the informations that are stored in the temporal
+database. These are basic informations (id, name, mapset, creator,
+creation time, temporal type), the temporal and spatial extent and
+dataset type specific metadata. The user has to utilize <em>r.info</em>,
+<em>r3.info</em>, <em>v.info</em> to report detailed informations about
+raster, 3D raster and vector maps, since not all map specific
+informations and metadata are stored in the temporal database.
 <p>
-In addition, informations about the chosen temporal database backend can be reported.
+In addition, informations about the chosen temporal database backend
+can be reported.
 <h2>EXAMPLE</h2>
-In this example we first report temporal database backend information using <em>t.info -s</em>.
-Then we create a single raster maps using <em>r.mapcalc</em> with random values
-At the end we report informations about the raster map and the
-space time raster dataset to stdout.
+In this example we first report temporal database backend information
+using <em>t.info -s</em>. Then we create a single raster maps using
+<em>r.mapcalc</em> with random values that will be registered in a
+single space time raster dataset named <em>precipitation_daily</em>
+using a daily temporal granularity. We use <em>t.create</em> for the
+space time raster dataset creation and <em>t.register</em> to register
+the raster map in the space time raster dataset. At the end we report
+informations about the raster map and the space time raster dataset to
+stdout.
 t.info -s
  +------------------- Temporal DBMI backend information ----------------------+
  | DBMI Python interface:...... sqlite3
@@ -128,6 +130,7 @@
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.list/t.list.html
--- grass/trunk/temporal/t.list/t.list.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.list/t.list.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,20 +1,21 @@
-<em>t.list</em> lists any dataset that is registered in the temporal database.
-Datasets are raster, 3D raster and vector maps as well as their
-corresponding space time datasets (STRDS, STR3DS and STVDS). The type of the dataset
-can be specified using the <em>type</em> option, default is STRDS. By default all datasets with
-relative and absolute time are listed. However, the user has the ability to specify
-a single temporal type with the <em>temporaltype</em> option.
-The user can define the columns that should
-be printed for each dataset and the order of the datasets. In addition a SQL WHERE statement can
-be specified to select a subset of the requested datasets.
+<em>t.list</em> lists any dataset that is registered in the temporal
+database. Datasets are raster, 3D raster and vector maps as well as
+their corresponding space time datasets (STRDS, STR3DS and STVDS). The
+type of the dataset can be specified using the <em>type</em> option,
+default is STRDS. By default all datasets with relative and absolute
+time are listed. However, the user has the ability to specify a single
+temporal type with the <em>temporaltype</em> option. The user can
+define the columns that should be printed for each dataset and the
+order of the datasets. In addition a SQL WHERE statement can be
+specified to select a subset of the requested datasets.
 <h2>EXAMPLE</h2>
-In this example we will create 3 raster maps and register them first only in the
-temporal database an then in the newly created space time raster dataset.
-We use t.list to show what maps are already in the
+In this example we will create 3 raster maps and register them first
+only in the temporal database an then in the newly created space time
+raster dataset. We use t.list to show what maps are already in the
 # Generate data
Modified: grass/trunk/temporal/t.merge/t.merge.html
--- grass/trunk/temporal/t.merge/t.merge.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.merge/t.merge.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,20 +1,23 @@
-This module is designed to register the maps of several input space time datasets in a single output dataset.
-The datasets to merge can be either space time raster, 3D raster or vector datasets and must
-have the same temporal type (absolute or relative).
+This module is designed to register the maps of several input space
+time datasets in a single output dataset. The datasets to merge can be
+either space time raster, 3D raster or vector datasets and must have
+the same temporal type (absolute or relative).
 <p>
-Existing space time datasets located in the current mapset can be specified as output as well. The
-maps from the input space time datasets will be added to the output.
+Existing space time datasets located in the current mapset can be
+specified as output as well. The maps from the input space time
+datasets will be added to the output.
 <p>
-Maps from the input space time datasets will be registered only once in the
-output space time dataset, hence the same maps can be registered in different input space time datasets.
+Maps from the input space time datasets will be registered only once in
+the output space time dataset, hence the same maps can be registered in
+different input space time datasets.
 <h2>Examples</h2>
-In this example we will create two space time raster datasets and register
-two unique maps in each of it. Then we merge the two space time raster
-datasets together.
+In this example we will create two space time raster datasets and
+register two unique maps in each of it. Then we merge the two space
+time raster datasets together.
 r.mapcalc expr="map1 = rand(0, 10)"  -s
@@ -193,7 +196,6 @@
  |     output="precipitation_daily_3"
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.html
--- grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,44 +1,64 @@
-<b>t.rast.accdetect</b> is designed to detect accumulation pattern in temporally accumulated
-space time raster datasets created by <a href="t.rast.accumulate.html">t.rast.accumulate</a>.
+<b>t.rast.accdetect</b> is designed to detect accumulation pattern in
+temporally accumulated space time raster datasets created by
+<a href="t.rast.accumulate.html">t.rast.accumulate</a>.
 This module expects a space time raster dataset as input that is the result
 of a <a href="t.rast.accumulate.html">t.rast.accumulate</a> run.
 <p>
-The <b>start</b> time and the <b>end</b> time of the pattern detection process must be set,
-eg. <b>start="2000-03-01" end="2011-01-01"</b>. The <b>start</b> and <b>end</b> time do not need to be the same
-as for the accumulation run that produced the input space time raster dataset.
-In addition a <b>cycle</b>, eg. "8 months", can be specified, that defines
-after which time interval the accumulation pattern detection process restarts. The <b>offset</b> option specifies the
-time between two cycles that should be skipped, eg. "4 months". Please make sure that the <b>cycle</b> and
-<b>offset</b> options are same as in the accumulation process that produces the input space time raster dataset, otherwise the accumulation pattern detection will produce wrong results.
+The <b>start</b> time and the <b>end</b> time of the pattern detection
+process must be set, eg. <b>start="2000-03-01" end="2011-01-01"</b>.
+The <b>start</b> and <b>end</b> time do not need to be the same as for
+the accumulation run that produced the input space time raster dataset.
+In addition a <b>cycle</b>, eg. "8 months", can be specified, that
+defines after which time interval the accumulation pattern detection
+process restarts. The <b>offset</b> option specifies the time between
+two cycles that should be skipped, eg. "4 months". Please make sure
+that the <b>cycle</b> and <b>offset</b> options are same as in the
+accumulation process that produces the input space time raster dataset,
+otherwise the accumulation pattern detection will produce wrong
+results.
 <p>
 The <b>minimum</b> and <b>maximum</b> values of the pattern detection
 process can be set, either by using space time raster datasets or
 by using fixed values for all raster cells and time steps.
 <p>
-Using space time raster datasets allow to specify minimum and maximum values for each raster cell and each time step. For example,
-we want to detect the germination (minimum value) and harvesting (maximum value) dates for different crops in Germany using the growing-degree-day (GDD) method for several years. Different crops may grow in different raster cells and change with time because of crop rotation.
-Hence we need to specify different GDD germination/harvesting (minimum/maximum) values for different raster cells and different years.
+Using space time raster datasets allow to specify minimum and maximum
+values for each raster cell and each time step. For example, we want to
+detect the germination (minimum value) and harvesting (maximum value)
+dates for different crops in Germany using the growing-degree-day (GDD)
+method for several years. Different crops may grow in different raster
+cells and change with time because of crop rotation. Hence we need to
+specify different GDD germination/harvesting (minimum/maximum) values
+for different raster cells and different years.
 <p>
-The raster maps that specifies the
-minimum and maximum values of the actual granule will be detected using the following temporal relations:
-equals, during, overlaps, overlapped and contains.
-First all maps with equal time stamps to the current granule of the input STRDS will be detected,
-the first minimum map and the first maximum map that were found are used as range definitions.
-If no equal maps are found then maps with a temporal during relation are detected,
-then maps that temporally overlap the actual granules, until
-maps are detected that have a temporal contain relation.
-If no maps are found or minimum/maximum STRDS are not set, then the <b>range</b> option is used, eg. <b>range=480,730</b>.
+The raster maps that specifies the minimum and maximum values of the
+actual granule will be detected using the following temporal relations:
+equals, during, overlaps, overlapped and contains. First all maps with
+equal time stamps to the current granule of the input STRDS will be
+detected, the first minimum map and the first maximum map that were
+found are used as range definitions. If no equal maps are found then
+maps with a temporal during relation are detected, then maps that
+temporally overlap the actual granules, until maps are detected that
+have a temporal contain relation. If no maps are found or
+minimum/maximum STRDS are not set, then the <b>range</b> option is
+used, eg. <b>range=480,730</b>.
 <p>
 The <b>base</b> name of of the generated maps must always be set.
 <p>
-This module produces two output space time raster datasets. The <b>occurrence</b> output STRDS stores the time in days
-from the begin of a cycle for each raster cell and time step that has a value within the minimum and maximum definition.
-These values can be used to compute the duration of the recognized accumulation pattern. The <b>indicator</b> output STRDS
-uses three values, that can be set using the <b>staend</b> option, to mark raster cells with integer values that indicate the start, the intermediate state and the end of a accumulation pattern. As default specifies the value 1 the start, the value 2 the intermediate state and the value 3 the end of the accumulation pattern in a cycle.
+This module produces two output space time raster datasets. The
+<b>occurrence</b> output STRDS stores the time in days from the begin
+of a cycle for each raster cell and time step that has a value within
+the minimum and maximum definition. These values can be used to compute
+the duration of the recognized accumulation pattern. The
+<b>indicator</b> output STRDS uses three values, that can be set using
+the <b>staend</b> option, to mark raster cells with integer values that
+indicate the start, the intermediate state and the end of a
+accumulation pattern. As default specifies the value 1 the start, the
+value 2 the intermediate state and the value 3 the end of the
+accumulation pattern in a cycle.
 <h2>EXAMPLE</h2>
@@ -46,14 +66,14 @@
 <h2>SEE ALSO</h2>
-<b>
-<a href="t.rast.accumulate.html">t.rast.accumulate</a><br>
-<a href="t.rast.aggregate.html">t.rast.aggregate</a><br>
-<a href="t.rast.mapcalc.html">t.rast.mapcalc</a><br>
-<a href="t.info.html">t.info</a><br>
-<a href="r.series.accumulate.html">r.series.accumulate</a><br>
-<a href="g.region.html">g.region</a><br>
-</b>
+<em>
+<a href="t.rast.accumulate.html">t.rast.accumulate</a>,
+<a href="t.rast.aggregate.html">t.rast.aggregate</a>,
+<a href="t.rast.mapcalc.html">t.rast.mapcalc</a>,
+<a href="t.info.html">t.info</a>,
+<a href="r.series.accumulate.html">r.series.accumulate</a>,
+<a href="g.region.html">g.region</a>
+</em>
 <h2>AUTHOR</h2>
Modified: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html
--- grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,51 +1,65 @@
-<b>t.rast.accumulate</b> is designed to perform temporal accumulations of space time raster datasets.
+<b>t.rast.accumulate</b> is designed to perform temporal accumulations
+of space time raster datasets.
-This module expects a space time raster dataset as input that will be sampled by a given <b>granularity</b>.
-All maps that have the start time during the actual granule will be accumulated with the predecessor
-granule accumulation result using the raster module <a href="r.series.accumulate.html">r.series.accumulate</a>.
-The default granularity is 1 day, but any temporal granularity can be set.
+This module expects a space time raster dataset as input that will be
+sampled by a given <b>granularity</b>. All maps that have the start
+time during the actual granule will be accumulated with the predecessor
+granule accumulation result using the raster module
+<a href="r.series.accumulate.html">r.series.accumulate</a>. The default
+granularity is 1 day, but any temporal granularity can be set.
 <p>
-The <b>start</b> time and the <b>end</b> time of the accumulation process must be set,
-In addition a <b>cycle</b>, eg. <b>cycle="8 months"</b>, can be specified, that defines
-after which time interval the accumulation process restarts. The <b>offset</b> option specifies the
-time between two cycles that should be skipped, eg. <b>offset="4 months"</b>.
+The <b>start</b> time and the <b>end</b> time of the accumulation
+process must be set, eg. <b>start="2000-03-01" end="2011-01-01"</b>. In
+addition a <b>cycle</b>, eg. <b>cycle="8 months"</b>, can be specified,
+that defines after which time interval the accumulation process
+restarts. The <b>offset</b> option specifies the time between two
+cycles that should be skipped, eg. <b>offset="4 months"</b>.
 <p>
 The <b>lower</b> and <b>upper</b> <b>limits</b> of the accumulation
-process can be set, either by using space time raster datasets or
-by using fixed values for all raster cells and time steps.  The raster maps that specifies the
-lower and upper limits of the actual granule will be detected using the following temporal relations:
-First all maps with equal time stamps to the current granule will be detected,
-the first lower map and the first upper map that were found are used as limit definitions.
-If no maps are found or lower/upper STRDS are not defined, then the <b>limits</b> option is used, eg. <b>limits=10,30</b>.
+process can be set, either by using space time raster datasets or by
+using fixed values for all raster cells and time steps.  The raster
+maps that specifies the lower and upper limits of the actual granule
+will be detected using the following temporal relations: equals,
+during, overlaps, overlapped and contains. First all maps with equal
+time stamps to the current granule will be detected, the first lower
+map and the first upper map that were found are used as limit
+definitions. If no equal maps are found then maps with a temporal
+during relation are detected, then maps that temporally overlap the
+actual granules, until maps are detected that have a temporal contain
+relation. If no maps are found or lower/upper STRDS are not defined,
+then the <b>limits</b> option is used, eg. <b>limits=10,30</b>.
 <p>
-The <b>upper</b> <b>limit</b> is only used in the Biologically Effective Degree Days calculation.
+The <b>upper</b> <b>limit</b> is only used in the Biologically
+Effective Degree Days calculation.
 <p>
 The options <b>shift</b>, <b>scale</b> and <b>method</b> are passed to
 Please refer to the manual page of <a href="r.series.accumulate.html">r.series.accumulate</a>
 for detailed option description.
 <p>
-The <b>output</b> is a new space time raster dataset with the provided start time, end time and granularity
-containing the accumulated raster maps. The <b>base</b> name of of the generated maps must always be set.
-The <b>output</b> space time raster dataset can then be analyzed
-using <a href="t.rast.accdetect.html">t.rast.accdetect</a> to detect specific accumulation patterns.
+The <b>output</b> is a new space time raster dataset with the provided
+start time, end time and granularity containing the accumulated raster
+maps. The <b>base</b> name of of the generated maps must always be set.
+The <b>output</b> space time raster dataset can then be analyzed using
+<a href="t.rast.accdetect.html">t.rast.accdetect</a> to detect specific
+accumulation patterns.
 <h2>EXAMPLE</h2>
-This is an example how to accumulate the daily mean temperature of Europe from 1990 to 2000 using
-the growing-degree-day method to detect grass hopper reproduction cycles that are critical
-to agriculture.
+This is an example how to accumulate the daily mean temperature of
+Europe from 1990 to 2000 using the growing-degree-day method to detect
+grass hopper reproduction cycles that are critical to agriculture.
 # Get the temperature data
-wget www-pool.math.tu-berlin.de/~soeren/grass/temperature_mean_1990_2000_daily_celsius.tar.gz
+wget http://www-pool.math.tu-berlin.de/~soeren/grass/temperature_mean_1990_2000_daily_celsius.tar.gz
 # Create a temporary location directory
 mkdir -p /tmp/grassdata/LL
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,13 +1,13 @@
-<em>t.rast.aggregate</em> temporally aggregates space time raster datasets
-by a specific temporal granularity.
-This module support <em>absolute</em> and <em>relative time</em>.
-The temporal granularity of absolute time can be
-<em>seconds, minutes, hours, days, weeks, months</em> or <em>years</em>.
-Mixing of granularities eg. "1 year, 3 months 5 days" is not supported.
-In case of relative time the temporal unit of the input space time raster
-dataset is used. The granularity must be specified with an integer value.
+<em>t.rast.aggregate</em> temporally aggregates space time raster
+datasets by a specific temporal granularity. This module support
+<em>absolute</em> and <em>relative time</em>. The temporal granularity
+of absolute time can be <em>seconds, minutes, hours, days, weeks,
+months</em> or <em>years</em>. Mixing of granularities eg. "1 year, 3
+months 5 days" is not supported. In case of relative time the temporal
+unit of the input space time raster dataset is used. The granularity
+must be specified with an integer value.
 <p>
 This module is sensitive to the current region and mask settings,
 hence spatial extent and spatial resolution. In case the registered
@@ -17,12 +17,13 @@
 <h2>NOTES</h2>
-The raster module <em>r.series</em> is used internally. Hence all aggregate
-methods of <em>r.series</em> are supported. See the
+The raster module <em>r.series</em> is used internally. Hence all
+aggregate methods of <em>r.series</em> are supported. See the
 <a href="r.series.html">r.series</a> manual page for details.
 <p>
-This module will shift the start date for each aggregation process depending on the
-provided temporal granularity. The following shifts will performed:
+This module will shift the start date for each aggregation process
+depending on the provided temporal granularity. The following shifts
+will performed:
 <ul>
     <li><em>granularity years</em>: will start at the first of January, hence 14-08-2012 00:01:30 will be shifted to 01-01-2012 00:00:00</li>
@@ -34,27 +35,35 @@
 </ul>
 <p>
-The specification of the temporal relation between the aggregation intervals and the raster map layers
-is always formulated from the aggregation interval viewpoint. Hence, the relation <em>contains</em>
-has to be specified to aggregate map layer that are temporally located in an aggregation interval.
+The specification of the temporal relation between the aggregation
+intervals and the raster map layers is always formulated from the
+aggregation interval viewpoint. Hence, the relation <em>contains</em>
+has to be specified to aggregate map layer that are temporally located
+in an aggregation interval.
 <p>
-Parallel processing is supported in case that more than one interval is available for aggregation computation. Internally several
-<em>r.series</em> modules will be started, depending on the number of specified parallel processes (<em>nprocs</em>)
-and the number of intervals to aggregate.
+Parallel processing is supported in case that more than one interval is
+available for aggregation computation. Internally several
+<em>r.series</em> modules will be started, depending on the number of
+specified parallel processes (<em>nprocs</em>) and the number of
+intervals to aggregate.
 <h2>EXAMPLES</h2>
-In this example, we create 7 raster maps that will be registered in a single space time
-The names of the raster maps are stored in a text file that is used for raster map registration.
+In this example, we create 7 raster maps that will be registered in a
+using a daily temporal granularity. The names of the raster maps are
+stored in a text file that is used for raster map registration.
 <p>
-The space time raster dataset <em>precipitation_daily</em> with daily temporal granularity
-will be aggregated to weekly precipitation resulting in the output space time raster dataset
-<em>precipitation_weekly</em>. The base name of the new generated raster maps is <em>prec_weekly</em>, the
-granularity is 1 week. The aggregation method is set to <em>sum</em> to accumulate the precipitation values
-of all raster maps that are temporally <em>contained</em> in a week.
-The sampling option <em>contains</em> assures that only raster maps that are
-temporally during a week will be considered for computation:
+The space time raster dataset <em>precipitation_daily</em> with daily
+temporal granularity will be aggregated to weekly precipitation
+resulting in the output space time raster dataset
+<em>precipitation_weekly</em>. The base name of the new generated
+raster maps is <em>prec_weekly</em>, the granularity is 1 week. The
+aggregation method is set to <em>sum</em> to accumulate the
+precipitation values of all raster maps that are temporally
+<em>contained</em> in a week. The sampling option <em>contains</em>
+assures that only raster maps that are temporally during a week will be
+considered for computation:
Modified: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.html
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,30 +1,33 @@
-This module works like <a href="t.rast.aggregate.html">t.rast.aggregate</a> but instead
-of defining a fixed granularity for temporal aggregation the time intervals of
-all maps registered in a second space time dataset (can be STRDS, STR3DS or STVDS)
-are used to aggregate the maps of the input space time raster dataset.
+This module works like
+<a href="t.rast.aggregate.html">t.rast.aggregate</a> but instead of
+defining a fixed granularity for temporal aggregation the time
+intervals of all maps registered in a second space time dataset (can be
+STRDS, STR3DS or STVDS) are used to aggregate the maps of the input
+space time raster dataset.
 <h2>EXAMPLE</h2>
-In this example we create 7 raster maps that will be registered in a single space time
+In this example we create 7 raster maps that will be registered in a
 <p>
-A space time vector dataset is created out of two vector maps with different
-temporal resolution. The maps are created using v.random.
-The first map has a granule of 3 days the second a granule of 4 days.
+A space time vector dataset is created out of two vector maps with
+different temporal resolution. The maps are created using v.random. The
+first map has a granule of 3 days the second a granule of 4 days.
 <p>
-will be aggregated using the space time vector dataset
-resulting in the output space time raster dataset
-<em>precipitation_agg</em>. The aggregation method is set to <em>sum</em> to accumulate the precipitation values
-of all intervals in the space time vector dataset. The sampling option assures that only raster maps that are
-temporally during the time intervals of the space time vector dataset are
-considered for computation:
+temporal granularity will be aggregated using the space time vector
+dataset resulting in the output space time raster dataset
+<em>precipitation_agg</em>. The aggregation method is set to
+<em>sum</em> to accumulate the precipitation values of all intervals in
+the space time vector dataset. The sampling option assures that only
+raster maps that are temporally during the time intervals of the space
+time vector dataset are considered for computation:
 for map in ${MAPS} ; do
Modified: grass/trunk/temporal/t.rast.colors/t.rast.colors.html
--- grass/trunk/temporal/t.rast.colors/t.rast.colors.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.colors/t.rast.colors.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -15,13 +15,13 @@
 <h2>EXAMPLE</h2>
-In this example we create 6 raster maps that will be registered in a single space time
-raster dataset named <em>precip_abs</em> using a monthly temporal granularity.
-Then we set an equilized grey color table using <em>t.rast.colors</em> and print the
-color table of the first map to stdout representing the data range of the space time raster dataset.
+In this example we create 6 raster maps that will be registered in a
+single space time raster dataset named <em>precip_abs</em> using a
+monthly temporal granularity. Then we set an equilized grey color table
+using <em>t.rast.colors</em> and print the color table of the first map
+to stdout representing the data range of the space time raster dataset.
 g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
 r.mapcalc --o expr="prec_1 = 100"
@@ -56,7 +56,6 @@
 600 234:234:234
 nv 255:255:255
 default 255:255:255
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.rast.export/t.rast.export.html
--- grass/trunk/temporal/t.rast.export/t.rast.export.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.export/t.rast.export.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,27 +1,33 @@
-This module exports a space time raster dataset as a tar archive. The archive contains the
-raster maps either as geotiff files or as GRASS binary files exported using r.out.bin.
-The map specific color tables are exported as well in case of geotiff files.
-In addition several meta data files are created in the archive that describe the
-temporal layout. All time stamps are stored in the file "list.txt", for each map one row.
-The name of the map, the start time and the end time are written. In case of a time instance,
-the start time is equal to the end time. The "init.txt" files stores the temporal
-type, the number of maps, the chosen export format and some other metadata. The "proj.txt"
-files stores the projection information as proj4 string of the
-location the space time raster dataset was exported from.
-The file "readme.txt" describes the file format. The output of r.info is stored in "metadata.txt".
+This module exports a space time raster dataset as a tar archive. The
+archive contains the raster maps either as geotiff files or as GRASS
+binary files exported using r.out.bin. The map specific color tables
+are exported as well in case of geotiff files. In addition several meta
+data files are created in the archive that describe the temporal
+layout. All time stamps are stored in the file "list.txt", for each map
+one row. The name of the map, the start time and the end time are
+written. In case of a time instance, the start time is equal to the end
+time. The "init.txt" files stores the temporal type, the number of
+maps, the chosen export format and some other metadata. The "proj.txt"
+files stores the projection information as proj4 string of the location
+the space time raster dataset was exported from. The file "readme.txt"
+describes the file format. The output of r.info is stored in
+"metadata.txt".
 <p>
-The tar archive can be compressed using the <b>compress</b> option. Gzip and bzip2 are
-available. A <b>where</b> option can be specified, to export only a subset of the space time dataset.
-Archives exported with <b>t.rast.export</b> can be importet with <b>t.rast.import</b>.
+The tar archive can be compressed using the <b>compress</b> option.
+Gzip and bzip2 are available. A <b>where</b> option can be specified,
+to export only a subset of the space time dataset. Archives exported
+with <b>t.rast.export</b> can be importet with <b>t.rast.import</b>.
 <h2>EXAMPLE</h2>
-We export the created space time raster dataset and will have a look at some files that are created:
+stored in a text file that is used for raster map registration. We
+export the created space time raster dataset and will have a look at
+some files that are created:
@@ -106,9 +112,8 @@
                  time stamps in ISO-Format. Field separator is |
  metadata.txt -- The output of t.info
    readme.txt -- This file
+</pre></div>
-</div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.rast.extract/t.rast.extract.html
--- grass/trunk/temporal/t.rast.extract/t.rast.extract.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.extract/t.rast.extract.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,16 +1,18 @@
-The purpose of <b>t.rast.extract</b> is to extract a subset of a space time
-raster dataset and to store that subset in a different space time raster dataset.
-The <b>where</b> condition is used to select the subset. In addition a r.mapcalc
-sub-expression can be specified that performs operations on all maps of the selected subset.
-In this expression the name of the input space time raster dataset can be used
-as simple map name. Other STRDS than the input STRDS can not be specified, but
-any raster map. In case a r.mapcalc sub-expression is defined, the base name
-of the resulting raster maps must be specified. The r.mapcalc expression can be
-used to select maps as well, since by default resulting empty maps are not registered
-in the output space time raster dataset and removed after processing. The number of
-parallel grass processes can be specified to speed up the processing.
+The purpose of <b>t.rast.extract</b> is to extract a subset of a space
+time raster dataset and to store that subset in a different space time
+raster dataset. The <b>where</b> condition is used to select the
+subset. In addition a r.mapcalc sub-expression can be specified that
+performs operations on all maps of the selected subset. In this
+expression the name of the input space time raster dataset can be used
+as simple map name. Other STRDS than the input STRDS can not be
+specified, but any raster map. In case a r.mapcalc sub-expression is
+defined, the base name of the resulting raster maps must be specified.
+The r.mapcalc expression can be used to select maps as well, since by
+default resulting empty maps are not registered in the output space
+time raster dataset and removed after processing. The number of
+parallel GRASS GIS processes can be specified to speed up the processing.
 <p>
 If no r.mapcalc expression is defined, the selected maps are simply registered in
 the new created output space time raster dataset to avoid data duplication.
@@ -29,16 +31,16 @@
 <h2>EXAMPLE</h2>
-In this example we create 8 raster maps that will be registered in a single space time
-raster dataset named <em>precipitation_yearly</em> using a yearly temporal granularity.
+In this example we create 8 raster maps that will be registered in a
+single space time raster dataset named <em>precipitation_yearly</em>
+using a yearly temporal granularity. The names of the raster maps are
 <p>
 Then we extract all maps that are later 2005 and store the selected maps in
 the space time raster dataset <em>precipitation_yearly_later_2005</em>.
 <p>
 MAPS="map_1 map_2 map_3 map_4 map_5 map_6 map_7 map_8"
Modified: grass/trunk/temporal/t.rast.import/t.rast.import.html
--- grass/trunk/temporal/t.rast.import/t.rast.import.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.import/t.rast.import.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -8,13 +8,13 @@
 <h2>EXAMPLE</h2>
-We export the created space time raster dataset and will import it again.
+export the created space time raster dataset and will import it again.
@@ -54,8 +54,7 @@
 new_map_5   soeren  2012-09-07 00:00:00 2012-09-08 00:00:00
 new_map_6   soeren  2012-09-08 00:00:00 2012-09-09 00:00:00
 new_map_7   soeren  2012-09-09 00:00:00 2012-09-10 00:00:00
-</pre>
-</div>
+</pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.rast.list/t.rast.list.html
--- grass/trunk/temporal/t.rast.list/t.rast.list.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.list/t.rast.list.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,25 +1,33 @@
-List time stamped raster map layers that are registered in a space time raster dataset. This module provides
-several options to list map layers and their metadata. Listing of map layer can be ordered by metadata,
-metadata columns can be specified and SQL where conditions can be provided to select a map layer subset
-of the input space time raster dataset. Most of the raster map  specific metadat is available for column selection,
-sorting and SQL where statements.
+List time stamped raster map layers that are registered in a space time
+raster dataset. This module provides several options to list map layers
+and their metadata. Listing of map layer can be ordered by metadata,
+metadata columns can be specified and SQL where conditions can be
+provided to select a map layer subset of the input space time raster
+dataset. Most of the raster map  specific metadat is available for
+column selection, sorting and SQL where statements.
-Using the <b>method</b> option allows the specification of different methods to list map layers.
-Method <i>col</i> is the deafult option and sensitive to the <b>column</b>,<b>order</b>
-and <b>where</b> options. It will simply print user specified metadata columns of one map layer per line.
-The <i>comma</i> method will list the map layer as comma separated list that can be used as input
-for spatial modules.
-To print interval length in days and distance from the begin use method <i>delta</i>. Method
-<i>deltagap</i> will additionally print temporal gaps between map layer. The <i>gran</i>
-method allows the listing of map layer sampled by a user defined <b>granule</b>. As default the granularity
-of the space time raster dataset is used for sampling.
+Using the <b>method</b> option allows the specification of different
+methods to list map layers. Method <i>col</i> is the deafult option and
+sensitive to the <b>column</b>,<b>order</b> and <b>where</b> options.
+It will simply print user specified metadata columns of one map layer
+per line. The <i>comma</i> method will list the map layer as comma
+separated list that can be used as input for spatial modules.
+<p>
+To print interval length in days and distance from the begin use method
+<i>delta</i>. Method <i>deltagap</i> will additionally print temporal
+gaps between map layer. The <i>gran</i> method allows the listing of
+map layer sampled by a user defined <b>granule</b>. As default the
+granularity of the space time raster dataset is used for sampling.
-For user defined column separator can be specified with the <b>separator</b> option.
+For user defined column separator can be specified with the <b>separator</b>
+option.
 <h2>EXAMPLE</h2>
 This example shows several options that are available for map layers listing.
Modified: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.html
--- grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,23 +1,28 @@
-The purpose of <em>t.rast.mapcalc</em> is to perform spatio-temporal <em>mapcalc</em> expressions
-on maps of temporally sampled space time raster datasets (STRDS). Spatial and temporal
-operators and internal variables are available in the expression string. The description of the spatial
-operators, functions and internal variables is available in the <a href="r.mapcalc.html">r.mapcalc</a> manual page.
-The temporal functions are described in detail below.
+The purpose of <em>t.rast.mapcalc</em> is to perform spatio-temporal
+<em>mapcalc</em> expressions on maps of temporally sampled space time
+raster datasets (STRDS). Spatial and temporal operators and internal
+variables are available in the expression string. The description of
+the spatial operators, functions and internal variables is available in
+the <a href="r.mapcalc.html">r.mapcalc</a> manual page. The temporal
+functions are described in detail below.
 <p>
-This module expects several parameter. All space time raster datasets that are referenced in
-the <em>mapcalc expression</em> must be listed in the <em>input</em> option. The <em>first</em> space time raster
-dataset that is listed as input will be used to temporally sample all other
-space time raster datasets. The temporal sampling method can be chosen using
-the <em>method</em> option. The order of the STRDS's in the mapcalc expression can be different
-to the order of the STRDS's in the input option. The resulting space time raster dataset
-must be specified in the <em>output</em> option together with the <em>base</em> name
-of generated raster maps that are registered in the resulting STRDS. Empty maps
-resulting from map-calculation are not registered by default. This behavior can be changed
-with the <em>-n</em> flag. The flag <em>-s</em> can be used to assure that only spatial related
-maps in the STRDS's are processed. Spatial related means that temporally related maps overlap
-in their spatial extent.
+This module expects several parameter. All space time raster datasets
+that are referenced in the <em>mapcalc expression</em> must be listed
+in the <em>input</em> option. The <em>first</em> space time raster
+dataset that is listed as input will be used to temporally sample all
+other space time raster datasets. The temporal sampling method can be
+chosen using the <em>method</em> option. The order of the STRDS's in
+the mapcalc expression can be different to the order of the STRDS's in
+the input option. The resulting space time raster dataset must be
+specified in the <em>output</em> option together with the <em>base</em>
+name of generated raster maps that are registered in the resulting
+STRDS. Empty maps resulting from map-calculation are not registered by
+default. This behavior can be changed with the <em>-n</em> flag. The
+flag <em>-s</em> can be used to assure that only spatial related maps
+in the STRDS's are processed. Spatial related means that temporally
+related maps overlap in their spatial extent.
 <p>
 The module <em>t.rast.mapcalc</em> supports parallel processing. The option
 <em>nprocs</em> specifies the number of processes that can be started in parallel.
@@ -74,13 +79,15 @@
 <h2>NOTE</h2>
-We will discuss the internal work of <em>t.rast.mapcalc</em> with an example.
-Imagine we have two STRDS as input, each with monthly granularity. The first one
-<em>A</em> has 6 raster maps (a3 ... a8) with a temporal range from March to August. The second
-STRDS <em>B</em> has 12 raster maps (b1 ... b12) ranging from January to December.
-The value of the raster maps is the number of the month from their interval start time.
-Dataset <em>A</em> will be used to sample dataset <em>B</em> to create a dataset <em>C</em>.
-We want to add all maps with equal time stamps if the month of the start time is May or June,
+We will discuss the internal work of <em>t.rast.mapcalc</em> with an
+example. Imagine we have two STRDS as input, each with monthly
+granularity. The first one <em>A</em> has 6 raster maps (a3 ... a8)
+with a temporal range from March to August. The second STRDS <em>B</em>
+has 12 raster maps (b1 ... b12) ranging from January to December. The
+value of the raster maps is the number of the month from their interval
+start time. Dataset <em>A</em> will be used to sample dataset
+<em>B</em> to create a dataset <em>C</em>. We want to add all maps with
+equal time stamps if the month of the start time is May or June,
 otherwise we multiply the maps. The command will look as follows:
 <p>
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,31 +1,35 @@
-<em>t.rast.neighbors</em> performs <a href="r.neighbors.html">r.neighbors</a> computations
-on the maps of a space time raster dataset (STRDS). This module supports a subset of options
-that are available in <a href="r.neighbors.html">r.neighbors</a>.
-The size of the neighborhood and the aggregation method can be chosen.
+<em>t.rast.neighbors</em> performs <a href="r.neighbors.html">r.neighbors</a>
+computations on the maps of a space time raster dataset (STRDS). This
+module supports a subset of options that are available in
+<a href="r.neighbors.html">r.neighbors</a>. The size of the neighborhood
+and the aggregation method can be chosen.
 <p>
-The user must provide an input and an output space time raster dataset and the basename
-of the resulting raster maps. The resulting STRDS will have
+The user must provide an input and an output space time raster dataset and
+the basename  of the resulting raster maps. The resulting STRDS will have
 the same temporal resolution as the input dataset.
 All maps will be processed using the current region settings.
 <p>
-The user can select a subset of the input space time raster dataset for processing
-using a SQL WHERE statement. The number of CPU's to be used for parallel processing can be specified
-with the <em>nprocs</em> option, to speedup the computation on multicore system.
+The user can select a subset of the input space time raster dataset for
+processing using a SQL WHERE statement. The number of CPU's to be used
+for parallel processing can be specified with the <em>nprocs</em>
+option, to speedup the computation on multicore system.
 <h2>EXAMPLE</h2>
 <p>
-A neighborhood average smoothing with a window size of 5 cells will be performed on
-the space time raster dataset <em>precipitation_daily</em> resulting in the output space time raster dataset
-<em>precipitation_daily_smooth</em>. The base name of the new generated raster maps is <em>prec_smooth</em>.
-The temporal resolution of the resulting STRDS is identical to the input STRDS.
+A neighborhood average smoothing with a window size of 5 cells will be
+performed on the space time raster dataset <em>precipitation_daily</em>
+<em>precipitation_daily_smooth</em>. The base name of the new generated
+raster maps is <em>prec_smooth</em>. The temporal resolution of the
+resulting STRDS is identical to the input STRDS.
@@ -155,7 +159,6 @@
 prec_smooth_5   2012-08-24 00:00:00     163.966667      293.3
 prec_smooth_6   2012-08-25 00:00:00     204.98          324.611111
 prec_smooth_7   2012-08-26 00:00:00     154.25          340.366667
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.html
--- grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+The example is based on the XXX sample dataset:
+<div class="code"><pre>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.html
--- grass/trunk/temporal/t.rast.series/t.rast.series.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,7 +2,6 @@
 TBD.
 <h2>EXAMPLE</h2>
 Example for monthly aggregation:
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.html
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.rast.univar/t.rast.univar.html
--- grass/trunk/temporal/t.rast.univar/t.rast.univar.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast.univar/t.rast.univar.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -11,7 +11,6 @@
 median value, third quartile and percentile 90.
 maxn=10
Modified: grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.html
--- grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.rast3d.list/t.rast3d.list.html
--- grass/trunk/temporal/t.rast3d.list/t.rast3d.list.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast3d.list/t.rast3d.list.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,8 +1,18 @@
-This module provides the same functionality as <a href="t.rast.list.html">t.rast.list</a>,
-the only difference is the 3d raster map layer metadata. Please refer to the manpage of <a href="t.rast.list.html">t.rast.list</a>.
+This module provides the same functionality as
+<a href="t.rast.list.html">t.rast.list</a>, the only difference is the
+3D raster map layer metadata. Please refer to the manual page of
+<a href="t.rast.list.html">t.rast.list</a>.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.html
--- grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html
--- grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast3d.mapcalc2/t.rast3d.mapcalc2.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,16 +1,19 @@
-t.rast3d.mapcalc2 performs temporal and spatial map algebra operations on space time 3D raster datasets (STR3DS)
-by using the temporal raster algebra.
+<em>t.rast3d.mapcalc2</em> performs temporal and spatial map algebra
+operations on space time 3D raster datasets (STR3DS) by using the
+temporal raster algebra.
-<h3>PROGRAM USE</h3>
+<h3>NOTES</h3>
 The module expects an <b>expression</b> as input parameter in the following form: <br>
 <br>
 <b> "result = expression" </b>
 <br>
 <br>
-The statement structure is exact the same as of t.rast.mapcalc2, please study <a href="t.rast.mapcalc2.html">t.rast.mapcalc2</a>.
+The statement structure is exact the same as of <em>t.rast.mapcalc2</em>,
+see <a href="t.rast.mapcalc2.html">t.rast.mapcalc2</a>.
 <h2>REFERENCES</h2>
Modified: grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.html
--- grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,7 +1,9 @@
-This module provides the same functionality as <a href="t.rast.univar.html">t.rast.list</a>,
-the only difference is the vector map layer metadata. Please refer to the manpage of <a href="t.rast.univar.html">t.rast.list</a>.
+<a href="t.rast.univar.html">t.rast.list</a>, the only difference is the
+vector map layer metadata. Please refer to the manpage of
+<a href="t.rast.univar.html">t.rast.list</a>.
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.register/t.register.html
--- grass/trunk/temporal/t.register/t.register.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.register/t.register.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,37 +1,41 @@
-The module <em>t.register</em> is designed to register raster, 3D raster and
-vector maps in the temporal database and in specific space time datasets.
-This module must be used to assign time stamps to raster, 3D raster and vector maps.
-The existing timestamp modules <a href="r.timestamp.html">r.timestamp</a>,
-<a href="r3.timestamp.html">r3.timestamp</a> and <a href="v.timestamp.html">v.timestamp</a>
-do not register the maps in the temporal database of GRASS. However, timestamps that have been
-created with these modules can be read and used by <em>t.register</em>. This works only for
-maps that are not already registered in the temporal database.
+The module <em>t.register</em> is designed to register raster, 3D
+raster and vector maps in the temporal database and in specific space
+time datasets. This module must be used to assign time stamps to
+raster, 3D raster and vector maps. The existing timestamp modules
+<a  href="r.timestamp.html">r.timestamp</a>,
+<a href="r3.timestamp.html">r3.timestamp</a> and
+<a href="v.timestamp.html">v.timestamp</a> do not register the maps in the
+temporal database of GRASS. However, timestamps that have been created
+with these modules can be read and used by <em>t.register</em>. This
+works only for maps that are not already registered in the temporal
+database.
 <p>
-This module supports absolute and relative time. Maps can be registered by command line argument
-(a list of comma separated map names) or using an input file.
-The start time, the end time and a temporal increment can be provided by command line
-or in the input file.
-End time and increment are mutual exclusive.
-The user can register single maps or a list of maps at once. Maps can be registered in several
-space time datasets using the same timestamp.
+This module supports absolute and relative time. Maps can be registered
+by command line argument (a list of comma separated map names) or using
+an input file. The start time, the end time and a temporal increment
+can be provided by command line or in the input file. End time and
+increment are mutual exclusive. The user can register single maps or a
+list of maps at once. Maps can be registered in several space time
+datasets using the same timestamp.
 <p>
-Start time and end time with absolute time must be provided using the format <b>yyyy-mm-dd HH:MM:SS +HHMM</b>.
-It is supported to specify only the date <b>yyyy-mm-dd</b>.
-In case of relative time the temporal unit (years, months, days, hours, minutes or seconds) must be provided.
+Start time and end time with absolute time must be provided using the
+format <b>yyyy-mm-dd HH:MM:SS +HHMM</b>. It is supported to specify
+only the date <b>yyyy-mm-dd</b>. In case of relative time the temporal
+unit (years, months, days, hours, minutes or seconds) must be provided.
 The relative start time, end time and the increment are integers.
 <h2>Note</h2>
-The timestamps of registred maps will be stored in the temporal
-database and in the metadata of the grass maps in the spatial database. This assures
-that timestamps can always be accessed with <em>(r|r3|v).timestamp</em> and the temporal
-modules. Timestamps should only be modified with <em>t.register</em> because
-the <em>(r|r3|v).timestamp</em> modules have no access to the temporal database.
-<p>
+The timestamps of registred maps will be stored in the temporal
+database and in the metadata of the grass maps in the spatial database.
+This assures that timestamps can always be accessed with
+<em>(r|r3|v).timestamp</em> and the temporal modules. Timestamps should
+only be modified with <em>t.register</em> because the
+<em>(r|r3|v).timestamp</em> modules have no access to the temporal
+database.
 <h2>INPUT FILE FORMAT</h2>
 Specification of map names:
@@ -75,12 +79,12 @@
 <h2>EXAMPLE</h2>
-The -i flag generates interval time. The generated timestamps will be
-inspected using <em>r.timestamp</em> and t.rast.list.
-We will register an additional map with
-a timetsamp that was set with <em>r.timestamp</em>.
+monthly temporal granularity. The -i flag generates interval time. The
+generated timestamps will be inspected using <em>r.timestamp</em> and
+t.rast.list. We will register an additional map with a timetsamp that
+was set with <em>r.timestamp</em>.
 r.mapcalc expr="prec_1 = 100"
@@ -127,7 +131,6 @@
 prec_5	test2	2001-05-01 00:00:00	2001-06-01 00:00:00
 prec_6	test2	2001-06-01 00:00:00	2001-07-01 00:00:00
 prec_7	test2	2001-07-01 00:00:00	2001-08-01 00:00:00
 </pre></div>
Modified: grass/trunk/temporal/t.rename/t.rename.html
--- grass/trunk/temporal/t.rename/t.rename.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.rename/t.rename.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -3,6 +3,14 @@
 This module renames space time datasets of different types (strds, stvds, str3ds)
 and updates the space time dataset register entries of the registered maps.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.sample/t.sample.html
--- grass/trunk/temporal/t.sample/t.sample.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.sample/t.sample.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.select/t.select.html
--- grass/trunk/temporal/t.select/t.select.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.select/t.select.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,57 +1,63 @@
-t.select performs selection of maps that are registered in space time datasets using temporal algebra.
+<em>t.select</em> performs selection of maps that are registered in
+space time datasets using temporal algebra.
-The module expects an <b>expression</b> as input parameter in the following form: <br>
+The module expects an <b>expression</b> as input parameter in the
+following form:<br>
 <br>
 <br>
-<br>
 The statement structure is similar to r.mapcalc, see <a href="r.mapcalc.html">r.mapcalc</a>.
 Where <b>result</b> represents the name of a space time dataset (STDS)that will
 contain the result of the calculation that is given as <b>expression</b>
 on the right side of the equality sign.
 These expression can be any valid or nested combination of temporal
-operations and functions that are provided by the temporal algebra.  <br>
-The temporal algebra works with space time datasets of any type (STRDS, STR3DS and STVDS).
-The algebra provides methods for map selection from STDS based on their temporal relations.
-It is also possible to temporally shift maps, to create temporal buffer and to snap time
-instances to create a valid temporal topology. Furthermore expressions can be nested and
-evaluated in conditional statements (if, else statements). Within if-statements the algebra
-provides temporal variables like start time, end time, day of year, time differences or
-number of maps per time interval to build up conditions. These operations can be assigned
-to space time datasets or to the results of operations between space time datasets.
-<br>
-<br>
+operations and functions that are provided by the temporal algebra.
+<p>
+The temporal algebra works with space time datasets of any type (STRDS,
+STR3DS and STVDS). The algebra provides methods for map selection from
+STDS based on their temporal relations. It is also possible to
+temporally shift maps, to create temporal buffer and to snap time
+instances to create a valid temporal topology. Furthermore expressions
+can be nested and evaluated in conditional statements (if, else
+statements). Within if-statements the algebra provides temporal
+variables like start time, end time, day of year, time differences or
+number of maps per time interval to build up conditions. These
+operations can be assigned to space time datasets or to the results of
+operations between space time datasets.
+<p>
 The type of the input space time datasets must be defined with the input
 parameter <b>type</b>. Possible options are STRDS, STVDS or STR3DS.
 The default is set to space time raster datasets (STRDS).
-<br>
-<br>
+<p>
 As default, topological relationships between space time datasets will be
 evaluated only temporal. Use the <b>s</b> flag to activate the
 additionally spatial topology evaluation.
+<p>
+The expression option must be passed as <b>quoted</b>
+expression, for example:
 <br>
-<br>
-The expression option must be passed as <b>quoted</b>
-expression, for example: <br>
-<div class="code"><pre>t.select expression="C = A : B"</pre></div>
+t.select expression="C = A : B"
+</pre></div>
 Where <b>C</b> is the new space time raster dataset that will contain maps
 from <b>A</b> that are selected by equal temporal relationships
-to the existing dataset <b>B</b> in this case. <br>
-<br>
+to the existing dataset <b>B</b> in this case.
 <h2>TEMPORAL ALGEBRA</h2>
 The temporal algebra provides a wide range of temporal operators and
-functions that will be presented in the following section. <br>
-<br>
+functions that will be presented in the following section.
 <h3>TEMPORAL RELATIONS</h3>
 Several temporal topology relations between registered maps of space
-time datasets are supported: <br>
+time datasets are supported:
+<br>
 equals            A ------
                   B ------
@@ -90,15 +96,15 @@
 </pre></div>
 The relations must be read as: A is related to B, like - A equals B - A is
-during B - A contains B <br>
-<br>
-Topological relations must be specified in {} parentheses. <br>
+during B - A contains B
+<p>
+Topological relations must be specified in {} parentheses.
 <h3>TEMPORAL SELECTION</h3>
 The temporal selection simply selects parts of a space time dataset without
 processing raster or vector data.
+<p>
 The algebra provides a selection operator <b>:</b> that selects parts
 of a space time dataset that are temporally equal to parts of a second one
 by default. The following expression
@@ -106,23 +112,23 @@
 C = A : B
 </pre></div>
 means: Select all parts of space time dataset A that are equal to B and store
-it in space time dataset C. The parts are time stamped maps. <br>
-<br>
-In addition the inverse selection operator <b>!:</b> is defined as the complement of
-the selection operator, hence the following expression
+it in space time dataset C. The parts are time stamped maps.
+<p>
+In addition the inverse selection operator <b>!:</b> is defined as the
+complement of the selection operator, hence the following expression
 C = A !: B
 </pre></div>
 means: select all parts of space time time dataset A that are not equal to B
-and store it in space time dataset (STDS) C. <br>
-<br>
+and store it in space time dataset (STDS) C.
+<p>
 To select parts of a STDS by different topological relations to other STDS,
 the temporal topology selection operator can be used. The operator consists of
 topological relations, that must be separated by the logical OR operator
 <b>||</b> and the temporal selection operator. Both parts are separated by
 comma and surrounded by curly braces:
-{"topological relations", "temporal selection operator"}  <br>
-<br>
+{"topological relations", "temporal selection operator"}
+<p>
 Examples:
 C = A {equals,:} B
@@ -133,8 +139,8 @@
 C = A {equals|during|overlaps,:} B
 </pre></div>
-Select all parts of A that are equal to B, during B or overlaps B. <br>
-<br>
+Select all parts of A that are equal to B, during B or overlaps B.
+<p>
 The selection operator is implicitly contained in the temporal topology
 selection operator, so that the following statements are exactly the same:
@@ -167,8 +173,7 @@
 The conditions are comparison expressions that are used to evaluate
 space time datasets. Specific values of temporal variables are
 compared by logical operators and evaluated for each map of the STDS.
-<br>
-<br>
+<p>
 The supported logical operators:
 Symbol  description
@@ -183,7 +188,8 @@
   ||    or
 </pre></div>
-Temporal functions: <br>
+Temporal functions:
+<br>
 td(A)                   Returns a list of time intervals of STDS A
@@ -226,12 +232,13 @@
 time dataset B which are during the time intervals of maps from
 space time dataset A.<br>
 A list of integers (scalars) corresponding to the maps of A
-that contain maps from B will be returned. <br>
-<br>
+that contain maps from B will be returned.
+<p>
 Furthermore the temporal algebra allows temporal buffering, shifting
 and snapping with the functions buff_t(), tshift() and tsnap()
 respectively.
 buff_t(A, size)         Buffer STDS A with granule ("1 month" or 5)
 tshift(A, size)         Shift STDS A with granule ("1 month" or 5)
@@ -243,6 +250,7 @@
 Select all maps from space time dataset A which have equal time stamps
 with space time dataset B and C and are ealier that Jan. 1. 2005 and
 store them in space time dataset D.
 D = if(start_date() < "2005-01-01", A : B : C)
 </pre></div>
Modified: grass/trunk/temporal/t.shift/t.shift.html
--- grass/trunk/temporal/t.shift/t.shift.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.shift/t.shift.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -168,7 +168,6 @@
 prec_4  soeren  2012-01-04 12:00:00 2012-01-05 12:00:00
 prec_5  soeren  2012-01-05 12:00:00 2012-01-06 12:00:00
 prec_6  soeren  2012-01-06 12:00:00 2012-01-07 12:00:00
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.snap/t.snap.html
--- grass/trunk/temporal/t.snap/t.snap.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.snap/t.snap.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,14 +1,17 @@
 <h2>DESCRIPTION</h2>
-<em>t.snap</em> is designed to convert time instances of maps into time intervals or to
-create valid temporal topologies for space time datasets. Raster, 3D raster and vector space time datasets are supported
-with absolute and relative time.
+<em>t.snap</em> is designed to convert time instances of maps into time
+intervals or to create valid temporal topologies for space time
+datasets. Raster, 3D raster and vector space time datasets are
+supported with absolute and relative time.
 <p>
-This module "snaps" the end time of each registered map of a space time dataset to the start time
-of the map that is the temporal nearest neighbour in the future. Maps with equal time stamps
-are not modified and must be removed or modified to create a valid temporal topology.
-In case the last map in the space time dataset is a time instance, the granularity of the space time
-dataset will be used to create the time interval.
+This module "snaps" the end time of each registered map of a space time
+dataset to the start time of the map that is the temporal nearest
+neighbour in the future. Maps with equal time stamps are not modified
+and must be removed or modified to create a valid temporal topology. In
+case the last map in the space time dataset is a time instance, the
+granularity of the space time dataset will be used to create the time
+interval.
 <h2>EXAMPLE</h2>
@@ -157,7 +160,6 @@
 prec_4  soeren  2012-01-04 00:00:00 2012-01-05 00:00:00
 prec_5  soeren  2012-01-05 00:00:00 2012-01-06 00:00:00
 prec_6  soeren  2012-01-06 00:00:00 2012-01-07 00:00:00
 </pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.support/t.support.html
--- grass/trunk/temporal/t.support/t.support.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.support/t.support.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.topology/t.topology.html
--- grass/trunk/temporal/t.topology/t.topology.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.topology/t.topology.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.unregister/t.unregister.html
--- grass/trunk/temporal/t.unregister/t.unregister.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.unregister/t.unregister.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,10 +1,14 @@
-This module is designed to unregister raster, 3d raster and vector map layers from space time datasets and the temporal database.
+This module is designed to unregister raster, 3d raster and vector map
+layers from space time datasets and the temporal database.
 <p>
-Map layer that should be unregistered from the temporal database can be specified as a list of comma separated map names or
-using a text file, that contains one map layer name per line. By default the map type that should be unregistered is set to raster.
-The option<em>type</em> must be used to specify 3d raster or vector map layer types.
+Map layer that should be unregistered from the temporal database can be
+specified as a list of comma separated map names or using a text file,
+that contains one map layer name per line. By default the map type that
+should be unregistered is set to raster. The option<em>type</em> must
+be used to specify 3d raster or vector map layer types.
@@ -20,9 +24,10 @@
 <h2>EXAMPLE</h2>
-In this example we create 2 raster map layers that will be registered in a space time
-We use t.unregister to unregister a map layer from the space time dataset and from the temporal database.
+In this example we create 2 raster map layers that will be registered
+in a space time raster dataset named <em>precip_abs</em> using a
+monthly temporal granularity. We use t.unregister to unregister a map
+layer from the space time dataset and from the temporal database.
@@ -44,7 +49,6 @@
 # We unregister raster map prec_2 from the temporal database, hence
 # the time stamp is removed
 t.unregister type=rast maps=prec_2
 </pre></div>
Modified: grass/trunk/temporal/t.vect.db.select/t.vect.db.select.html
--- grass/trunk/temporal/t.vect.db.select/t.vect.db.select.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.vect.db.select/t.vect.db.select.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.vect.export/t.vect.export.html
--- grass/trunk/temporal/t.vect.export/t.vect.export.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.vect.export/t.vect.export.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -21,6 +21,7 @@
 with <em><a href="t.vect.import.html">t.vect.import</a></em>.
 <h2>EXAMPLE</h2>
 In this example 5 vector maps are created and
 registered in a single space time vector dataset named <em>random_locations</em>.
 Each vector map represents random locations
Modified: grass/trunk/temporal/t.vect.extract/t.vect.extract.html
--- grass/trunk/temporal/t.vect.extract/t.vect.extract.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.vect.extract/t.vect.extract.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.vect.import/t.vect.import.html
--- grass/trunk/temporal/t.vect.import/t.vect.import.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.vect.import/t.vect.import.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -7,6 +7,7 @@
 <h2>EXAMPLE</h2>
 In this example 5 vector maps are created and registered in a single space time
 vector dataset named <em>random_locations</em>. Each vector map represents
 random locations within the boundary of the state taken at 1 month intervals.
@@ -43,8 +44,7 @@
 new_map_3 at user1|new_map_3|None|user1|2012-03-01 00:00:00|2012-04-01 00:00:00
 new_map_4 at user1|new_map_4|None|user1|2012-04-01 00:00:00|2012-05-01 00:00:00
 new_map_5 at user1|new_map_5|None|user1|2012-05-01 00:00:00|2012-06-01 00:00:00
-</pre>
-</div>
+</pre></div>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.vect.list/t.vect.list.html
--- grass/trunk/temporal/t.vect.list/t.vect.list.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.vect.list/t.vect.list.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,8 +1,18 @@
-the only difference is the vector map layer metadata. Please refer to the manpage of <a href="t.rast.list.html">t.rast.list</a>.
+vector map layer metadata. Please refer to the manual page of
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.html
--- grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.vect.mapcalc/t.vect.mapcalc.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -1,32 +1,39 @@
-t.vect.mapcalc performs temporal and spatial overlay and buffer functions on space time vector datasets (STVDS)
-by using the temporal vector algebra. New STVDS can be created, which are expressions of existing STVDS.
+<em>t.vect.mapcalc</em> performs temporal and spatial overlays and buffer
+functions on space time vector datasets (STVDS) by using the temporal
+vector algebra. New STVDS can be created, which are expressions of
+existing STVDS.
+<h3>NOTES</h3>
 <br>
 <br>
 <br>
-The statement structure is similar to r.mapcalc, see <a href="r.mapcalc.html">r.mapcalc</a>.
-Where <b>result</b> represents the name of a space time vector dataset (STVDS)that will
-contain the result of the calculation that is given as <b>expression</b>
-on the right side of the equality sign.
-These expression can be any valid or nested combination of temporal
-operations and spatial overlay or buffer functions that are provided by the temporal algebra.  <br>
-The temporal vector algebra works with space time vector datasets only (STVDS).
-The algebra provides methods for map selection from STVDS based on their temporal relations.
-number of maps per time interval to build up conditions. In addition the algebra provides
-the spatial operations for vector overlay and buffering. All these operations can be assigned
-to STVDS or to the resulting map lists of operations between STVDS.
+The statement structure is similar to r.mapcalc, see <a
+href="r.mapcalc.html">r.mapcalc</a>. Where <b>result</b> represents the
+name of a space time vector dataset (STVDS)that will contain the result
+of the calculation that is given as <b>expression</b> on the right side
+of the equality sign. These expression can be any valid or nested
+combination of temporal operations and spatial overlay or buffer
+functions that are provided by the temporal algebra.
 <br>
+The temporal vector algebra works with space time vector datasets only
+(STVDS). The algebra provides methods for map selection from STVDS
+based on their temporal relations. It is also possible to temporally
+shift maps, to create temporal buffer and to snap time instances to
+create a valid temporal topology. Furthermore expressions can be nested
+and evaluated in conditional statements (if, else statements). Within
+if-statements the algebra provides temporal variables like start time,
+end time, day of year, time differences or number of maps per time
+interval to build up conditions. In addition the algebra provides the
+spatial operations for vector overlay and buffering. All these
+operations can be assigned to STVDS or to the resulting map lists of
+operations between STVDS.
 <br>
+<br>
 additionally evaluate the spatial topology based on the spatial extents of maps.
@@ -279,14 +286,19 @@
 <p>
 <h3>Combinations of temporal, vector and select operators</h3>
-We combine the temporal topology relations, the temporal operators and the spatial/select operators to create spatio-temporal operators:
+We combine the temporal topology relations, the temporal operators and
+the spatial/select operators to create spatio-temporal operators:
-<pre class="code">
+<div class="code"> <pre>
 {"list of temporal relations", "temporal operator" "spatial or select operator"}
-</pre><p>
-The spatial and the select operators can be used stand-alone. In this case the temporal topology relation "equal" and the temporal operator "left reference =" is assumed and used as default. This allows the convenient use of the spatial and select
-operators in case of space time vector datasets with equal time stamps.
-</p>
+</pre></div>
+The spatial and the select operators can be used stand-alone. In this
+case the temporal topology relation "equal" and the temporal operator
+"left reference =" is assumed and used as default. This allows the
+convenient use of the spatial and select operators in case of space
+time vector datasets with equal time stamps.
@@ -300,9 +312,10 @@
 <h3>Examples: </h3>
-Spatio-temporal intersect all maps from space time dataset A with all maps from space time dataset
-B which have equal time stamps and are temporary before Jan. 1. 2005 and
-store them in space time dataset D.
+Spatio-temporal intersect all maps from space time dataset A with all
+maps from space time dataset B which have equal time stamps and are
+temporary before Jan. 1. 2005 and store them in space time dataset D.
 D = if(start_date() < "2005-01-01", A & B)
 </pre></div>
@@ -323,7 +336,7 @@
 <h2>REFERENCES</h2>
-<tt><a href="http://www.dabeaz.com/ply/">PLY(Python-Lex-Yacc)</a></tt>
+<a href="http://www.dabeaz.com/ply/">PLY(Python-Lex-Yacc)</a>
 <h2>SEE ALSO</h2>
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.vect.univar/t.vect.univar.html
--- grass/trunk/temporal/t.vect.univar/t.vect.univar.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.vect.univar/t.vect.univar.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,6 +2,14 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -2,9 +2,28 @@
 TBD.
+<h2>EXAMPLE</h2>
+TBD
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
+<a href="r.univar.html">r.univar</a>,
+<a href="v.univar.html">v.univar</a>,
+<a href="v.what.rast.html">v.what.rast</a>,
+<a href="v.what.rast3.html">v.what.rast3</a>,
+<a href="v.what.vect.html">v.what.vect</a>
+</em>
+<h2>SEE ALSO</h2>
+<em>
 <a href="t.create.html">t.create</a>,
 <a href="t.info.html">t.info</a>
 </em>
Modified: grass/trunk/temporal/temporalintro.html
--- grass/trunk/temporal/temporalintro.html	2014-10-24 09:50:38 UTC (rev 62374)
+++ grass/trunk/temporal/temporalintro.html	2014-10-24 11:13:20 UTC (rev 62375)
@@ -38,7 +38,7 @@
 Space time datasets are stored in a temporal database. SQLite3 or
 PostgreSQL are supported as SQL database back end.
 Connection settings are performed with <a href="t.connect.html">t.connect</a>.
-<!-- todo: really always PERMANENT? -> Yes thats the default that can be modified -->
+<!-- todo: really always PERMANENT? -> see http://trac.osgeo.org/grass/ticket/2258 -->
 As default a sqlite3 database will be created in the PERMANENT mapset that
 stores all space time datasets and registered time series maps from all
 mapsets in the location.
