[GRASS-SVN] r62379 - in grass/branches/releasebranch_7_0: gui/wxpython lib/python lib/python/exceptions lib/python/pygrass lib/python/pygrass/messages lib/python/pygrass/modules/interface lib/python/script lib/python/temporal
svn_grass at osgeo.org
Sun Oct 26 08:48:02 PDT 2014
Author: zarch
Date: 2014-10-26 08:48:02 -0700 (Sun, 26 Oct 2014)
New Revision: 62379
Added:
grass/branches/releasebranch_7_0/lib/python/exceptions/
grass/branches/releasebranch_7_0/lib/python/exceptions/testsuite/
grass/branches/releasebranch_7_0/gui/wxpython/wxgui.py
grass/branches/releasebranch_7_0/lib/python/Makefile
grass/branches/releasebranch_7_0/lib/python/exceptions/__init__.py
grass/branches/releasebranch_7_0/lib/python/pygrass/errors.py
grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
grass/branches/releasebranch_7_0/lib/python/script/core.py
grass/branches/releasebranch_7_0/lib/python/temporal/abstract_dataset.py
grass/branches/releasebranch_7_0/lib/python/temporal/temporal_algebra.py
Add exceptions module in python library, commit backported: r61187, r61220, r61959, r62358
Modified: grass/branches/releasebranch_7_0/gui/wxpython/wxgui.py
--- grass/branches/releasebranch_7_0/gui/wxpython/wxgui.py 2014-10-24 22:48:44 UTC (rev 62378)
+++ grass/branches/releasebranch_7_0/gui/wxpython/wxgui.py 2014-10-26 15:48:02 UTC (rev 62379)
@@ -1,4 +1,4 @@
@package wxgui
@brief Main Python application for GRASS wxPython GUI
@@ -25,6 +25,8 @@
from core import globalvar
from core.utils import _
+from grass.exceptions import Usage
import wx
try:
import wx.lib.agw.advancedsplash as SC
@@ -33,6 +35,7 @@
from lmgr.frame import GMFrame
class GMApp(wx.App):
def __init__(self, workspace = None):
"""!Main GUI class.
@@ -40,28 +43,28 @@
@param workspace path to the workspace file
self.workspaceFile = workspace
# call parent class initializer
wx.App.__init__(self, False)
self.locale = wx.Locale(language = wx.LANGUAGE_DEFAULT)
def OnInit(self):
"""!Initialize all available image handlers
@return True
if not globalvar.CheckWxVersion([2, 9]):
wx.InitAllImageHandlers()
# create splash screen
introImagePath = os.path.join(globalvar.IMGDIR, "silesia_splash.png")
introImage = wx.Image(introImagePath, wx.BITMAP_TYPE_PNG)
introBmp = introImage.ConvertToBitmap()
if SC and sys.platform != 'darwin':
- # AdvancedSplash is buggy on the Mac as of 2.8.12.1
+ # AdvancedSplash is buggy on the Mac as of 2.8.12.1
# and raises annoying (though seemingly harmless) errors everytime the GUI is started
- splash = SC.AdvancedSplash(bitmap = introBmp,
+ splash = SC.AdvancedSplash(bitmap = introBmp,
timeout = 2000, parent = None, id = wx.ID_ANY)
splash.SetText(_('Starting GRASS GUI...'))
splash.SetTextColour(wx.Colour(45, 52, 27))
@@ -71,21 +74,18 @@
else:
wx.SplashScreen (bitmap = introBmp, splashStyle = wx.SPLASH_CENTRE_ON_SCREEN | wx.SPLASH_TIMEOUT,
milliseconds = 2000, parent = None, id = wx.ID_ANY)
wx.Yield()
# create and show main frame
mainframe = GMFrame(parent = None, id = wx.ID_ANY,
workspace = self.workspaceFile)
mainframe.Show()
self.SetTopWindow(mainframe)
return True
-class Usage(Exception):
- def __init__(self, msg):
- self.msg = msg
def printHelp():
"""!Print program help"""
@@ -95,13 +95,14 @@
print >> sys.stderr, " -w\t--workspace file\tWorkspace file to load"
sys.exit(1)
def process_opt(opts, args):
"""!Process command-line arguments"""
workspaceFile = None
for o, a in opts:
if o in ("-h", "--help"):
printHelp()
if o in ("-w", "--workspace"):
if a != '':
workspaceFile = str(a)
@@ -110,8 +111,9 @@
return (workspaceFile,)
def main(argv = None):
if argv is None:
argv = sys.argv
try:
@@ -120,19 +122,19 @@
["help", "workspace"])
except getopt.error as msg:
raise Usage(msg)
except Usage as err:
print >> sys.stderr, err.msg
print >> sys.stderr, "for help use --help"
printHelp()
workspaceFile = process_opt(opts, args)[0]
app = GMApp(workspaceFile)
# suppress wxPython logs
q = wx.LogNull()
app.MainLoop()
if __name__ == "__main__":
sys.exit(main())
Modified: grass/branches/releasebranch_7_0/lib/python/Makefile
--- grass/branches/releasebranch_7_0/lib/python/Makefile 2014-10-24 22:48:44 UTC (rev 62378)
+++ grass/branches/releasebranch_7_0/lib/python/Makefile 2014-10-26 15:48:02 UTC (rev 62379)
@@ -5,7 +5,7 @@
PYDIR = $(ETC)/python/grass
-SUBDIRS = script ctypes temporal pygrass pydispatch imaging
+SUBDIRS = exceptions script ctypes temporal pygrass pydispatch imaging
default: $(PYDIR)/__init__.py
$(MAKE) subdirs
Modified: grass/branches/releasebranch_7_0/lib/python/exceptions/__init__.py
--- grass/trunk/lib/python/exceptions/__init__.py 2014-07-08 12:09:32 UTC (rev 61187)
+++ grass/branches/releasebranch_7_0/lib/python/exceptions/__init__.py 2014-10-26 15:48:02 UTC (rev 62379)
@@ -1,4 +1,6 @@
# -*- coding: utf-8 -*-
+"""GRASS GIS interface to Python exceptions"""
+import subprocess
class DBError(Exception):
@@ -30,8 +32,46 @@
class ScriptError(Exception):
- pass
+ """Raised during script execution. ::
+ >>> error = ScriptError('My error message!')
+ >>> error.value
+ 'My error message!'
+ >>> print(error)
+ My error message!
+ def __init__(self, value):
+ self.value = value
+ def __str__(self):
+ return str(self.value)
pass
+# TODO: we inherit from subprocess to be aligned with check_call but it is needed?
+class CalledModuleError(subprocess.CalledProcessError):
+ """Raised when a called module ends with error (non-zero return code)
+ :param module: module name
+ :param code: some code snipped which contains parameters
+ :param rc: process returncode
+ :param error: errors provided by the module (stderr)
+ def __init__(self, module, code, returncode, errors=None):
+ super(CalledModuleError, self).__init__(returncode, module)
+ msg = _("Module run %s %s ended with error") % (module, code)
+ msg += _("\nProcess ended with non-zero return code %s") % returncode
+ if errors:
+ msg += _(". See the following errors:\n%s") % errors
+ else:
+ # here could be written "above" but it wouldn't work in some cases
+ # e.g., for testing framework
+ msg += _(". See errors in the (error) output.")
+ self.msg = msg
+ # TODO: handle other parameters
+ return self.msg
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/errors.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/errors.py 2014-10-24 22:48:44 UTC (rev 62378)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/errors.py 2014-10-26 15:48:02 UTC (rev 62379)
@@ -5,37 +5,13 @@
@author: pietro
from functools import wraps
-from grass.pygrass.messages import get_msgr
+from grass.exceptions import (FlagError, ParameterError, DBError,
+ GrassError, OpenError)
-class AbstractError(Exception):
- def __init__(self, value):
- self.value = value
+from grass.pygrass.messages import get_msgr
- def __str__(self):
- return repr(self.value)
-class ParameterError(Exception):
- pass
-class FlagError(Exception):
- pass
-class DBError(AbstractError):
- pass
-class GrassError(AbstractError):
- pass
-class OpenError(AbstractError):
- pass
def must_be_open(method):
@wraps(method)
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py 2014-10-24 22:48:44 UTC (rev 62378)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py 2014-10-26 15:48:02 UTC (rev 62379)
@@ -14,21 +14,12 @@
@author Soeren Gebbert
import sys
-import grass.lib.gis as libgis
from multiprocessing import Process, Lock, Pipe
+import grass.lib.gis as libgis
+from grass.exceptions import FatalError
-class FatalError(Exception):
- """This error will be raised in case raise_on_error was set True
- when creating the messenger object.
- self.value = msg
- return self.value
def message_server(lock, conn):
"""The GRASS message server function designed to be a target for
multiprocessing.Process
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py 2014-10-24 22:48:44 UTC (rev 62378)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py 2014-10-26 15:48:02 UTC (rev 62379)
@@ -361,25 +361,21 @@
for flg in kargs['flags']:
self.flags[flg].value = True
del(kargs['flags'])
- if 'run_' in kargs:
- self.run_ = kargs['run_']
- del(kargs['run_'])
- if 'stdin_' in kargs:
- self.inputs['stdin'].value = kargs['stdin_']
- del(kargs['stdin_'])
- if 'stdout_' in kargs:
- self.stdout_ = kargs['stdout_']
- del(kargs['stdout_'])
- if 'stderr_' in kargs:
- self.stderr_ = kargs['stderr_']
- del(kargs['stderr_'])
- if 'env_' in kargs:
- self.env_ = kargs['env_']
- del(kargs['env_'])
- if 'finish_' in kargs:
- self.finish_ = kargs['finish_']
- del(kargs['finish_'])
+ # set attributs
+ for key in ('run_', 'env_', 'finish_'):
+ if key in kargs:
+ setattr(self, key, kargs.pop(key))
+ # set inputs
+ for key in ('stdin_', ):
+ if key in kargs:
+ self.inputs[key].value = kargs.pop(key)
+ # set outputs
+ for key in ('stdout_', 'stderr_'):
+ if key in kargs:
+ self.outputs[key].value = kargs.pop(key)
# check args
@@ -527,6 +523,9 @@
self.outputs['stdout'].value = stdout if stdout else ''
self.outputs['stderr'].value = stderr if stderr else ''
self.time = time.time() - start
+ #if self.popen.poll():
+ # raise CalledModuleError(self.popen.returncode, self.get_bash(),
+ # {}, stderr)
return self
Modified: grass/branches/releasebranch_7_0/lib/python/script/core.py
--- grass/branches/releasebranch_7_0/lib/python/script/core.py 2014-10-24 22:48:44 UTC (rev 62378)
+++ grass/branches/releasebranch_7_0/lib/python/script/core.py 2014-10-26 15:48:02 UTC (rev 62379)
@@ -34,6 +34,8 @@
from utils import KeyValue, parse_key_val, basename, encode
+from grass.exceptions import ScriptError
# i18N
import gettext
gettext.install('grasslibs', os.path.join(os.getenv("GISBASE"), 'locale'))
@@ -68,13 +70,6 @@
STDOUT = subprocess.STDOUT
-class ScriptError(Exception):
- self.value = msg
- return self.value
raise_on_error = False # raise exception instead of calling fatal()
@@ -873,9 +868,25 @@
return False
return True
-# interface to g.gisenv
+def diff_files(filename_a, filename_b):
+ """!Diffs two text files and returns difference.
+ @param filename_a first file path
+ @param filename_b second file path
+ @return list of strings
+ import difflib
+ differ = difflib.Differ()
+ fh_a = open(filename_a, 'r')
+ fh_b = open(filename_b, 'r')
+ result = list(differ.compare(fh_a.readlines(),
+ fh_b.readlines()))
+ return result
+# interface to g.gisenv
def gisenv():
"""!Returns the output from running g.gisenv (with no arguments), as a
dictionary. Example:
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/abstract_dataset.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/abstract_dataset.py 2014-10-24 22:48:44 UTC (rev 62378)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/abstract_dataset.py 2014-10-26 15:48:02 UTC (rev 62379)
@@ -22,16 +22,8 @@
from temporal_topology_dataset_connector import *
from spatial_topology_dataset_connector import *
+from grass.exceptions import ImplementationError
-class ImplementationError(Exception):
- """!Exception raised for the calling of methods that should be implemented in
- sub classes.
- self.msg = msg
- return repr(self.msg)
class AbstractDataset(SpatialTopologyDatasetConnector, TemporalTopologyDatasetConnector):
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/temporal_algebra.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/temporal_algebra.py 2014-10-24 22:48:44 UTC (rev 62378)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/temporal_algebra.py 2014-10-26 15:48:02 UTC (rev 62379)
@@ -396,6 +396,8 @@
from open_stds import *
import copy
class TemporalAlgebraLexer(object):
@@ -650,17 +652,10 @@
def __str__(self):
return str(self.tfunc) + str(self.compop) + str(self.value)
- self.value = msg
- return self.value
class TemporalAlgebraParser(object):
"""The temporal algebra class"""
