[GRASS-SVN] r62381 - sandbox/krejcmat/src
svn_grass at osgeo.org
Sun Oct 26 09:12:08 PDT 2014
Author: krejcmat
Date: 2014-10-26 09:12:08 -0700 (Sun, 26 Oct 2014)
New Revision: 62381
Removed:
sandbox/krejcmat/src/editor3.py
sandbox/krejcmat/src/g.gui.metadata.py
sandbox/krejcmat/src/jinjainfo.py
sandbox/krejcmat/src/mdgrass.py
sandbox/krejcmat/src/mdutil.py
sandbox/krejcmat/src/metadata/
sandbox/krejcmat/src/r.info.iso.py
sandbox/krejcmat/src/templates/
sandbox/krejcmat/src/v.info.iso.py
remove old files
Deleted: sandbox/krejcmat/src/editor3.py
--- sandbox/krejcmat/src/editor3.py 2014-10-26 16:02:57 UTC (rev 62380)
+++ sandbox/krejcmat/src/editor3.py 2014-10-26 16:12:08 UTC (rev 62381)
@@ -1,1206 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8
-import copy,re,os,sys,contextlib
-from lxml import etree
-import wx
-from wx import ID_ANY
-from wx import EVT_BUTTON
-import wx.lib.scrolledpanel as scrolled
-from owslib.iso import *
-from jinjainfo import JinjaTemplateInfo
-from jinja2 import Environment, FileSystemLoader
-from core.gcmd import RunCommand, GError, GMessage
-from gui_core.widgets import IntegerValidator, NTCValidator,SimpleValidator,\
- TimeISOValidator, EmailValidator#,EmptyValidator
-import mdutil
-# MD filework
-class MdFileWork():
- def __init__(self, pathToXml=None):
- self.path = pathToXml
- self.owslibInfo = None
- def initMD(self, path=None):
- if path is None:
- self.md = MD_Metadata(md=None)
- return self.md
- else:
- io=open(path,'r')
- str1=''
- for line in io.readlines():
- str1+=mdutil.removeNonAscii(line)
- io.close()
- io1=open(path,'w')
- io1.write(str1)
- io1.close()
- try:
- tree = etree.parse(path)
- root = tree.getroot()
- self.md = MD_Metadata(root)
- return self.md
- except Exception, e:
- GError('Error loading xml:\n'+str(e))
- def saveToXML(self, md,owsTagList, jinjaPath, outPath=None, xmlOutName=None,msg=True,rmTeplate=False):
- # if output file name is None, use map name and add postfix
- self.dirpath = os.path.dirname(os.path.realpath(__file__))
- self.md = md
- self.owsTagList=owsTagList
- if xmlOutName is None:
- xmlOutName = 'RANDExportMD' # TODO change to name of map
- if not xmlOutName.lower().endswith('.xml'):
- xmlOutName += '.xml'
- # if path is None, use lunch. dir
- # TODO change default folder to mapset location
- if not outPath:
- outPath = os.path.join(self.dirpath, xmlOutName)
- else:
- outPath = os.path.join(outPath, xmlOutName)
- xml=open(jinjaPath,'r')
- str1=''
- for line in xml.readlines():
- line==mdutil.removeNonAscii(line)
- str1+=line
- xml.close
- io=open(jinjaPath,'w')
- io.write(str1)
- io.close()
- # generate xml using jinja tempaltes
- head, tail = os.path.split(jinjaPath)
- env = Environment(loader=FileSystemLoader(head))
- env.globals.update(zip=zip)
- template = env.get_template(tail)
- if self.owsTagList is None:
- iso_xml = template.render(md=self.md)
- else:
- iso_xml = template.render(md=self.md,owsTagList=self.owsTagList)
- xml_file = xmlOutName
- try:
- xml_file = open(outPath, "w")
- xml_file.write(iso_xml)
- xml_file.close()
- if msg:
- GMessage('File exported to: %s'% outPath)
- if rmTeplate:
- os.remove(jinjaPath)
- return outPath
- GError('Error writing xml:\n'+str(e))
-# CREATE BOX (staticbox+button(optional)
-class MdBox(wx.Panel):
- def __init__(self, parent, label='label'):
- wx.Panel.__init__(self, parent=parent, id=wx.ID_ANY)
- self.label = label
- self.mdItems = list()
- self.stbox = wx.StaticBox(self,label=label,id=ID_ANY,style=wx.RAISED_BORDER)
- self.stbox.SetForegroundColour((0, 0, 0))
- self.stbox.SetBackgroundColour((200, 200, 200))
- self.stbox.SetFont(wx.Font(12, wx.NORMAL, wx.NORMAL, wx.NORMAL))
- def addItems(self, items, multi=None, rmMulti=False, isFirstNum=-1):
- if isFirstNum != 1:
- multi = False
- rmMulti = True
- # if not initialize in jinja template (default is true)
- if multi is None:
- multi = True
- self.panelSizer = wx.BoxSizer(wx.VERTICAL)
- self.SetSizer(self.panelSizer)
- self.boxButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
- self.panelSizer.AddSpacer(10, 10, 1, wx.EXPAND)
- self.panelSizer.Add(self.boxButtonSizer, flag=wx.EXPAND, proportion=1)
- self.stBoxSizer = wx.StaticBoxSizer(self.stbox, orient=wx.VERTICAL)
- self.boxButtonSizer.Add(self.stBoxSizer, flag=wx.EXPAND, proportion=1)
- for item in items:
- self.mdItems.append(item)
- self.stBoxSizer.Add(item, flag=wx.EXPAND, proportion=1)
- self.stBoxSizer.AddSpacer(5, 5, 1, wx.EXPAND)
- if multi:
- self.addBoxButt = wx.Button(self,id=ID_ANY,size=(30,30),label='+')
- self.boxButtonSizer.Add(self.addBoxButt, 0)
- self.addBoxButt.Bind(EVT_BUTTON, self.duplicateBox)
- if rmMulti:
- self.rmBoxButt = wx.Button(self,id=ID_ANY,size=(30,30),label='-')
- self.boxButtonSizer.Add(self.rmBoxButt, 0)
- self.rmBoxButt.Bind(EVT_BUTTON, self.removeBox)
- def addDuplicatedItem(self, item, id):
- #self.mdItems.append(item)
- self.GetParent().Layout()
- def getCtrlID(self):
- return self.GetId()
- def removeBox(self, evt):
- for item in self.mdItems:
- item.mdDescription.removeMdItem(item)
- self.GetParent().removeBox(self)
- def removeMdItem(self, mdDes, items):
- mdDes.mdDescription.removeMdItem(mdDes)
- try:
- item.Destroy()
- except:
- pass
- self.stBoxSizer.RemovePos(-1)
- self.stBoxSizer.Remove(mdDes)
- def duplicateBox(self, evt):
- parent = self.GetParent()
- duplicator = MdWxDuplicator(self.mdItems, parent, self.label)
- clonedBox = duplicator.mdBox
- self.GetParent().addDuplicatedItem(clonedBox, self.GetId())
-# DUPLICATOR OF WIDGETS-mditem
-class MdWxDuplicator():
- def __init__(self, mdItems, parent, boxlabel=None, mdItemOld=None,template=None):
- if boxlabel:
- itemList = list()
- self.mdBox = MdBox(parent, boxlabel)
- for i in mdItems:#check if item has multiple button
- try:
- i.addItemButt.GetLabel()
- multi=True
- except:
- multi=False
- try:
- i.chckBoxEdit.GetValue()
- template=True
- except:
- template=False
- i = i.mdDescription
- mdItem1 = MdItem(parent=self.mdBox,
- item= i,
- multiplicity=multi,
- isFirstNum=1,
- chckBox=template)
- itemList.append(mdItem1)
- i.addMdItem(mdItem1)
- self.mdBox.addItems(itemList, False, True)
- else:
- self.mdItem = MdItem(parent=parent,
- item= mdItems,
- multiplicity=False,
- rmMulti=True,
- isFirstNum=-1,
- chckBox=template)
- try:#TODO rm try
- if mdItems.inbox is not None:
- #print self.mdItem
- #print mdItemOld
- #print parent
- mdItems.addMdItem(self.mdItem, mdItemOld)
- else:
- mdItems.addMdItem(self.mdItem)
- except:
-# METADATA ITEM (label+ctrlText+button(optional)+chckbox(template)
-class MdItem(wx.BoxSizer):
- def __init__(self,parent,item,multiplicity=None,rmMulti=False,isFirstNum=-1,chckBox=False):
- wx.BoxSizer.__init__(self, wx.VERTICAL)
- self.isValid=False
- self.isChecked=False
- self.mdDescription = item
- self.chckBox=chckBox
- self.multiple=multiplicity
- if multiplicity is None:
- self.multiple = item.multiplicity
- self.multiple = False
- if isFirstNum != 1 and item.multiplicity:
- rmMulti = True
- self.tagText = wx.StaticText(parent=parent, id=ID_ANY, label=item.name)
- if self.chckBox ==False:
- if item.multiline is True:
- self.valueCtrl = wx.TextCtrl(parent, id=ID_ANY, size=(0, 70),
- validator=self.validators(item.type),
- style=wx.VSCROLL |
- wx.TE_MULTILINE | wx.TE_WORDWRAP |
- wx.TAB_TRAVERSAL | wx.RAISED_BORDER )
- else:
- self.valueCtrl = wx.TextCtrl(parent, id=wx.ID_ANY,
- style=wx.VSCROLL | wx.TE_DONTWRAP |
- wx.TAB_TRAVERSAL | wx.RAISED_BORDER | wx.HSCROLL)
- else:
- else:
- self.valueCtrl.Bind(wx.EVT_MOTION, self.onMove)
- self.valueCtrl.SetExtraStyle(wx.WS_EX_VALIDATE_RECURSIVELY)
- if self.multiple:
- self.addItemButt = wx.Button(parent, -1, size=(30, 30), label='+')
- self.addItemButt.Bind(EVT_BUTTON, self.duplicateItem)
- if rmMulti:
- self.rmItemButt = wx.Button(parent, -1, size=(30, 30), label='-')
- self.rmItemButt.Bind(EVT_BUTTON, self.removeItem)
- if self.chckBox:
- self.chckBoxEdit=wx.CheckBox(parent, -1, size=(30, 30))
- self.chckBoxEdit.Bind(wx.EVT_CHECKBOX,self.onChangeChckBox)
- self.chckBoxEdit.SetValue(False)
- self.valueCtrl.Disable()
- self.createInfo()
- self.tip = wx.ToolTip(self.infoTip)
- self._addItemLay(item.multiline, rmMulti)
- def validators(self,validationStyle):
- if validationStyle=='email':
- return EmailValidator()
- if validationStyle=='integer':
- return NTCValidator('DIGIT_ONLY')
- if validationStyle=='decimal':
- if validationStyle=='date':
- return TimeISOValidator()
- #return EmptyValidator()
- return SimpleValidator('')
- def onChangeChckBox(self,evt):
- if self.mdDescription.inbox:
- try:
- items=self.valueCtrl.GetParent().mdItems
- if self.isChecked:
- else:
- self.valueCtrl.Enable()
- self.isChecked=True
- item.valueCtrl.Enable()
- item.chckBoxEdit.SetValue(True)
- item.isChecked=True
- else:
- item.valueCtrl.Disable()
- item.chckBoxEdit.SetValue(False)
- item.isChecked=False
- except:
- pass
- else:
- else:
- def onMove(self, evt=None):
- self.valueCtrl.SetToolTip(self.tip)
- def createInfo(self):
- string = ''
- if self.mdDescription.ref is not None:
- string += self.mdDescription.ref+'\n\n'
- if self.mdDescription.name is not None:
- string += 'NAME: \n'+self.mdDescription.name+'\n\n'
- if self.mdDescription.desc is not None:
- string += 'DESCRIPTION: \n'+self.mdDescription.desc+'\n\n'
- if self.mdDescription.example is not None:
- string += 'EXAMPLE: \n'+self.mdDescription.example+'\n\n'
- if self.mdDescription.type is not None:
- string += 'DATA TYPE: \n'+self.mdDescription.type+'\n\n'
- string += '- -'*30+'\n'
- if self.mdDescription.statements is not None:
- string += 'Jinja template info: \n'+self.mdDescription.statements+'\n'
- if self.mdDescription.statements1 is not None:
- string += self.mdDescription.statements1+'\n'
- string += 'OWSLib info:\n'+self.mdDescription.tag
- self.infoTip = string
- def removeItem(self, evt):
- list = [self.valueCtrl, self.tagText]
- try:
- list.append(self.rmItemButt)
- except:
- pass
- try:
- list.append(self.chckBoxEdit)
- except:
- pass
- self.valueCtrl.GetParent().removeMdItem(self, list)
- #self.SetSizerAndFit(self.panelSizer)
- def duplicateItem(self, evt):
- '''add Md item to parent(box or notebook page)
- parent = self.valueCtrl.GetParent()
- # if parent box
- duplicator = MdWxDuplicator( mdItems=self.mdDescription,parent=parent,mdItemOld=self,template=self.chckBox)
- else:
- duplicator = MdWxDuplicator(mdItems=self.mdDescription,parent= parent,template=self.chckBox)
- clonedMdItem = duplicator.mdItem
- # call parent "add" function
- self.valueCtrl.GetParent().addDuplicatedItem(
- clonedMdItem,
- self.valueCtrl.GetId())
- def setValue(self, value):
- if value is None or value is '':
- if self.chckBox:
- self.chckBoxEdit.SetValue(True)
- try:
- self.onChangeChckBox(None)
- except:
- pass
- self.valueCtrl.SetBackgroundColour((245,204,230))#red
- self.valueCtrl.SetValue('')
- elif self.chckBox and value=='$NULL':
- self.valueCtrl.SetBackgroundColour((255,255,82))#yellow
- if self.chckBox:
- try:
- except:
- pass
- elif value=='$NULL':
- else:
- value=value.replace('"','')
- value=value.replace("'",'')
- self.isValid=True
- self.valueCtrl.SetValue(value)
- def getValue(self):
- return mdutil.replaceXMLReservedChar(self.valueCtrl.GetValue())
- return self.valueCtrl.GetId()
- def getButtonID(self):
- if self.multiple:
- return self.addItemButt.GetId()
- else:
- return None
- def _addItemLay(self, multiline, rmMulti):
- self.textFieldSizer = wx.BoxSizer(wx.HORIZONTAL)
- if multiline is True:
- self.textFieldSizer.Add(self.valueCtrl,proportion=1,flag=wx.EXPAND)
- else:
- self.textFieldSizer.Add(self.valueCtrl, proportion=1)
- if self.multiple:
- self.textFieldSizer.Add(self.addItemButt, 0)
- if rmMulti:
- self.textFieldSizer.Add(self.rmItemButt, 0)
- if self.chckBox:
- self.textFieldSizer.Add(self.chckBoxEdit, 0)
- self.Add(item=self.tagText, proportion=0)
- self.Add(item=self.textFieldSizer, proportion=0, flag=wx.EXPAND)
-# ADD NOTEBOOK PAGE
-class MdNotebookPage(scrolled.ScrolledPanel):
- def __init__(self, parent):
- scrolled.ScrolledPanel.__init__(self, parent=parent, id=wx.ID_ANY)
- self.items = []
- self.SetupScrolling()
- self._addNotebookPageLay()
- self.sizerIndexDict = {}
- self.sizerIndex = 0
- def _addNotebookPageLay(self):
- self.mainSizer = wx.BoxSizer(wx.VERTICAL)
- self.SetSizer(self.mainSizer)
- def _getIndex(self):
- self.sizerIndex += 1
- return self.sizerIndex
- def addItem(self, item):
- if isinstance(item, list):
- for i in item:
- if isinstance(i, list):
- for ii in i:
- self.sizerIndexDict[ii.getCtrlID()] = self._getIndex()
- self.mainSizer.Add(ii, proportion=0, flag=wx.EXPAND)
- else:
- self.sizerIndexDict[i.getCtrlID()] = self._getIndex()
- self.mainSizer.Add(i, proportion=0, flag=wx.EXPAND)
- else:
- self.sizerIndexDict[item.getCtrlID()] = self._getIndex()
- self.mainSizer.Add(item, proportion=0, flag=wx.EXPAND)
- self.items.append(item)
- posIndex = self.sizerIndexDict[id]
- self.mainSizer.Insert(posIndex, item, proportion=0, flag=wx.EXPAND)
- self.SetSizerAndFit(self.mainSizer)
- self.GetParent().Refresh()
- def removeBox(self, box):
- box.Destroy()
- item.Destroy()
-# MAIN FRAME
-class MdMainEditor(wx.Panel):
- def __init__(self, parent, templatePath, mdISOXML,templateEditor=False):
- self.mdo = MdFileWork()
- self.md = self.mdo.initMD(mdISOXML)
- self.templateEditor=templateEditor
- self.templatePath = templatePath
- self.jinj = JinjaTemplateInfo(self.templatePath)
- # list of object MdDescription
- self.mdDescription = self.jinj.mdDescription
- # string of tags from jinja template (loops and OWSLib objects)
- self.mdOWSTagStr = self.jinj.mdOWSTagStr
- self.mdOWSTagStrList = self.jinj.mdOWSTagStrList #
- self.generateGUI()
- self._layout()
-#----------------------------------------------------------- GUI GENERATOR START
- def executeStr(self, stri, mdDescrObj):
- #print stri
- exec stri
- def plusC(self, num=None):
- if num is None:
- num = 1
- self.c += num
- if self.c >= self.max:
- self.c -= 1
- self.stop = True
- def minusC(self, num=None):
- if num is None:
- num = 1
- self.c -= num
- if self.c <= self.max:
- self.stop = False
- def generateGUI(self):
- @var var: self.c: index of tagStringLst and self.mdDescription
- tagStringLst: tagStringLst is self.mdOWSTagStr in list. \
- Item=line from jinja template(only lines\
- with owslib objects and loops)
- mdDescrObj: list of MdDescription() objects inicialized\
- by information from jinja t.
- markgroup: markers of created list in GUI notebook
- self.max: length of tagStringLst and mdDescrObj
- self.stop: index self.c is increasing by function plusC(),\
- that care about not exceeding the index
- def prepareStatements():
- @note:
- for c in range(self.max):
- if '|length' in str(tagStringLst[c]):
- a = tagStringLst[c]
- a = a.replace('|length',')').replace('if ','if len(self.')
- tagStringLst[c] = a
- if 'zip(' in tagStringLst[c]:
- sta = tagStringLst[c]
- tagStringLst[c] = sta.replace('md.', 'self.md.')
- def chckIfJumpToLoop(sta):
- self.isValidS=False
- staTMP=sta
- if not '\t'in staTMP:
- tab='\t'
- tab1=''
- staTMP=staTMP+":\n"+tab+'self.isValidS=True'
- else:
- tab='\t'
- tab1='\t'
- staTMP=staTMP.replace('\t','')+":\n"+tab+'self.isValidS=True'
- try:#if loop for in for
- self.executeStr(staTMP, False)
- except:
- staTMP=self.staTMP.replace('self.isValidS=True','')+'\n\t'+ staTMP.replace('\t','\t\t')
- self.staTMP= staTMP
- if self.isValidS:
- return sta
- else:
- return tab1+'for n in range(1)'
- def inBlock():
- @note:
- IFStatements = False
- statements = tagStringLst[self.c - 1]
- if 'if' in statements.split():
- IFStatements = True
- loop=statements.replace(' md.', ' self.md.')
- looptmp=chckIfJumpToLoop(loop)
- str2 = 'numOfSameBox=0\n'
- str2 += looptmp
- str2 += ':\n'
- str2 += '\t'+'self.ItemList=list()\n' # initialize list
- str2 += '\t'+'numOfSameBox+=1\n'
- box = False
- if self.mdDescription[self.c].inbox:
- box = True
- str2 += '\t'+'box=MdBox(self.nbPage,mdDescrObj['+str(self.c)+'].inbox)\n' # add box
- str1 = str2
- while '\t' in tagStringLst[self.c] and self.stop is False:
- if 'for' not in str(tagStringLst[self.c]).split()\
- and 'if' not in str(tagStringLst[self.c]).split():
- value = str(self.mdOWSTagStrList[self.c])
- str1 +='\t'+'self.mdDescription['+str(self.c)+"].addStatements('"+loop+"')\n"
- if box:
- str1 += '\t'+'it=MdItem(parent=box,item=mdDescrObj['+str(self.c)+'],isFirstNum=numOfSameBox,chckBox=self.templateEditor)\n'
- else:
- str1 += '\t'+ 'it=MdItem(parent=self.nbPage,item=mdDescrObj['+str(self.c)+'],isFirstNum=numOfSameBox,chckBox=self.templateEditor)\n'
- if self.isValidS: #if metatdata are loaded to owslib
- if IFStatements:
- str1 += '\t'+'it.setValue(self.'+str(value)+')\n'
- else:
- str1 += '\t'+'it.setValue('+str(value)+')\n'
- else:
- if IFStatements:
- str1 += '\t'+'it.setValue("")\n'
- else:
- str1 += '\t'+'self.mdDescription['+str(self.c)+'].addMdItem(it)\n'
- str1 += '\t'+'self.ItemList.append(it)\n'
- tab = '\t'
- self.plusC()
- else: # if statements in statements
- statements = tagStringLst[self.c]
- str2 = ''
- keyword = False
- if '["keywords"]' in statements:
- keyword = True
- str2 += '\t'+'self.keywordsList=[]\n'
- str2 += '\t'+'numOfSameItem=0\n'
- loop2=statements.replace(' md.', ' self.md.')
- looptmp1=chckIfJumpToLoop(loop2)
- str2 += looptmp1+':\n'
- self.plusC()
- str1 += str2
- while '\t\t' in tagStringLst[self.c] and self.stop is False:
- # save information about loops
- str1 += '\t\t'+'numOfSameItem+=1\n'
- str1 += '\t\t'+'self.mdDescription['+str(self.c)+"].addStatements('"+loop+"')\n"
- str1 += '\t\t'+'self.mdDescription['+str(self.c)+"].addStatements1('"+loop2+"')\n"
- if box:
- str1 += '\t\t'+'it=MdItem(parent=box,item=mdDescrObj['+str(self.c)+'],isFirstNum=numOfSameItem,chckBox=self.templateEditor)\n'
- else:
- str1 += '\t\t'+'it=MdItem(self.nbPage,mdDescrObj['+str(self.c)+'],isFirstNum=numOfSameItem,chckBox=self.templateEditor)\n'
- if self.isValidS:
- str1 += '\t\t'+'it.setValue('+str(value)+')\n'
- else:
- str1 += '\t\t'+'it.setValue("")\n'
- str1 += '\t\t'+'self.ItemList.append(it)\n'
- if keyword:
- str1 += '\t\t'+'self.keywordsList.append(it)\n'
- str1 += '\t' +'self.mdDescription['+str(self.c)+'].addMdItem(self.keywordsList)\n'
- else:
- str1 += '\t\t'+'self.mdDescription['+str(self.c)+'].addMdItem(it)\n'
- tab = '\t\t'
- self.plusC()
- if box:
- str1 += tab+\
- 'box.addItems(items=self.ItemList,multi=mdDescrObj[self.c].inboxmulti,isFirstNum=numOfSameBox)\n'
- str1 += tab+'self.nbPage.addItem(box)\n'
- else:
- str1 += tab+'self.nbPage.addItem(self.ItemList)\n'
- self.executeStr(str1, mdDescrObj)
-#--------------------------------------------------------------------- INIT VARS
- self.notebook = wx.Notebook(self)
- markgroup = [] # notebok panel marker
- tagStringLst = self.mdOWSTagStrList
- mdDescrObj = self.mdDescription # from jinja
- self.c = 0
- self.stop = False
- self.max = len(mdDescrObj)
- prepareStatements()
- self.notebokDict={}
-# --------------------------------------------- #START of the looop of genereator
- while self.stop is False: # self.stop is managed by def plusC(self):
- group = mdDescrObj[self.c].group
- if group not in markgroup: # if group is not created
- markgroup.append(group) # mark group
- self.nbPage = MdNotebookPage(self.notebook)
- self.notebook.AddPage(self.nbPage, mdDescrObj[self.c].group)
- self.notebokDict[mdDescrObj[self.c].group]=self.nbPage
- else:
- self.nbPage=self.notebokDict[mdDescrObj[self.c].group]
- # if starting the statements
- if '\t' in tagStringLst[self.c] and self.stop is False:
- inBlock()
- # if just singe item without statements
- elif 'for' not in str(tagStringLst[self.c]).split() and 'if' not in str(tagStringLst[self.c]).split():
- it = MdItem(parent=self.nbPage, item=mdDescrObj[self.c],chckBox=self.templateEditor)
- value = 'self.'+str(self.mdOWSTagStrList[self.c]).replace('\n', '')
- value = eval(value)
- if value is None:
- value=''
- it.setValue(value)
- self.mdDescription[self.c].addMdItem(it)
- self.nbPage.addItem(it)
- self.plusC()
- else:
- self.plusC()
- if self.templateEditor:
- self.refreshChkboxes()
- def refreshChkboxes(self):
- for item in self.mdDescription:
- for i in item.mdItem:
- try:
- i.onChangeChckBox(None)
- except:
- pass
-#----------------------------------------------------------- GUI GENERATOR END
- def defineTemplate(self):
- try:
- template=open(self.templatePath,'r')
- GError('Error loading template:\n'+str(e))
- owsTagList=list()
- indexowsTagList=0
- finalTemplate=''
- chcked=False
- forST=0
- ifST=0
- forSTS=False
- ifSTS=False
- for line in template.readlines():
- if '{% for' in line:
- forSTS=True
- forST+=1
- if '{% if' in line:
- ifSTS=True
- ifST+=1
- for r,item in enumerate(self.mdDescription):
- str1=item.selfInfoString
- if str1 in line: #owslib definition in line
- try:
- if item.mdItem[0].isChecked==False:
- chcked=True
- except:
- try:
- if self.mdDescription[r+1].mdItem[0].isChecked==False:
- chcked=True
- except:
- try:
- if self.mdDescription[r+2].mdItem[0].isChecked==False:
- chcked=True
- except :
- try:
- if self.mdDescription[r+3].mdItem[0].isChecked==False:
- chcked=True
- except:
- pass
- if chcked: #chckbox in gui
- if forSTS:
- forSTS=False
- forST-=1
- if ifSTS:
- ifSTS=False
- ifST-=1
- owsTagList.append(str1)
- templateStr= '{{ owsTagList['+str(indexowsTagList)+'] }}'
- indexowsTagList+=1
- line=line.replace(str1,templateStr)
- tag='{{ '+item.tag+' }}'
- line=line.replace(tag,templateStr)
- finalTemplate+=line
- continue
- if chcked==False:
- if '{% endfor -%}' in line and forST==0:
- str1='{% endfor -%}'
- tag='{{'+item.tag+'}}'
- elif '{% endif -%}' in line and ifSTS==0:
- str1= '{% endif -%}'
- else:
- chcked=False
- head, tail = os.path.split(self.templatePath)
- tail='EXPT'+tail
- self.templatePath=os.path.join(head,tail)
- templateOut=open(self.templatePath,'w')
- templateOut.write(finalTemplate)
- templateOut.close()
- return owsTagList
-#----------------------------------------- FILL OWSLib BY EDITED METADATA IN GUI
- def executeStr1(self, stri, item):
- #print stri
- exec stri
- def createNewMD(self, evt=None):
- '''Fill owslib by metadata from gui
- @note:
- if '|length' in str(mdDes[c].tag):
- a = mdDes[c].tag
- mdDes[c].tag = a
- if '|length' in str(mdDes[c].statements):
- a = mdDes[c].statements
- mdDes[c].statements = a
- if '|length' in str(mdDes[c].statements1):
- a = mdDes[c].statements1
- mdDes[c].statements1 = a
- def chckIf1Statements():
- try:
- if md[self.c+1].statement:
- return True
- else:
- return False
- except:
- return False
- def chckIf2xStatements():
- if 'if'in mdDes[
- self.c].tag.split() or 'for' in mdDes[ self.c].tag.split():
- try:
- if 'if'in mdDes[self.c+1].tag.split() or \
- 'for'in mdDes[self.c+1].tag.split():
- return True
- else:
- return False
- except:
- return False
- def noneStatements():
- '''Without condition or loop
- str1 = ''
- for wxCtrl in mdDes[self.c].mdItem:
- if wxCtrl.getValue() is not None:
- str1 += 'self.'+ mdDes[self.c].tag+'="'+str(wxCtrl.getValue())+'"\n'
- self.executeStr1(str1, mdDes[self.c])
- str1 = ''
- self.plusC()
- def inStatements():
- '''possible combinations of statements
- (1) IF
- item
- (2) for
- (2.1) item (with init OWSLib object)
- "or"
- (2.2) item (without init)
- item with ZIP
- cTmp = self.c
- tag = str(mdDes[cTmp].tag).split()
- tag1 = 'self.'+str(tag[-1])
- tag = 'self.'+str(tag[-1])+'.append(self.val)\n'
- self.plusC()
- # statements of current item
- stat = mdDes[self.c].statements
- str1 = ''
- leng = len(mdDes[self.c].mdItem)
- #print '-----'
- #print mdDes[cTmp].tag
- # (2.1) IF NECESSARY TO INITIALIZE OWSLIB OBJECT
- if mdDes[cTmp].object and 'if' not in mdDes[cTmp].tag.split():
- objStr = 'self.val='+mdDes[cTmp].object+'\n'
- for n in range(leng):
- numOfItems = 0
- str1 += objStr
- while mdDes[self.c].statements == stat and self.stop is False:
- metadata = re.split(r'[.]', mdDes[self.c].tag)
- metadata[0] = 'self.val.'
- str1 += ''.join(metadata)+"='"\
- +str(mdDes[self.c].mdItem[n].getValue())+"'\n"
- self.plusC()
- numOfItems += 1
- str1 += tag
- self.executeStr1(str1, False)
- str1 = ''
- self.minusC(numOfItems)
- self.plusC(numOfItems)
- # (2.2)no init and py ZIP'
- elif 'for' in mdDes[cTmp].tag.split() and mdDes[cTmp].object is None and ' zip(' in mdDes[cTmp].tag:
- #print 'noinit zip'
- #print tag1
- tag1 = self.jinj._findBetween(mdDes[cTmp].tag, 'zip(', ')').split(',')
- #print tag1,'--'
- numOfItems = 0
- #print tag1[numOfItems]
- str1 += 'self.'+tag1[numOfItems]+".append('"+mdDes[self.c].mdItem[n].getValue()+"')\n"
- self.plusC()
- numOfItems += 1
- str1 = ''
- # 'no init'
- elif 'for' in mdDes[cTmp].tag.split() and mdDes[cTmp].object is None:
- #print 'no init'
- numOfItems = 0
- numOfItems = 0
- str1 += tag1+".append('"+mdDes[self.c].mdItem[n].getValue()+"')\n"
- self.plusC()
- numOfItems += 1
- str1 = ''
- # (1)'no init IF'
- elif 'if' in mdDes[cTmp].tag.split():
- objStr = mdDes[cTmp].tag.replace(' md.', ' self.md.')+':\n'
- numOfItems = 0
- metadata = 'self.'+mdDes[self.c].tag
- self.plusC()
- numOfItems += 1
- str1 = ''
- def in2Statements():
- (1) IF:
- FOR:
- (1.1) item (with init OWSLib object)
- "or"
- (1.2) item (without init)
- (2) FOR:
- FOR:
- "or"
- cTmp = self.c
- cTmp1 = self.c+1
- tag1 = str(mdDes[cTmp1].tag).split()
- stat = mdDes[self.c+2].statements
- append = 'self.'+str(tag1[-1])+'.append(self.val)\n'
- appendNoInit = 'self.'+str(tag1[-1])
- # (1)
- # if 'if' in jinja=skip and do single loop
- if 'if' in tag and 'for' in tag1:
- leng = len(mdDes[self.c+2].mdItem)
- # (1.1)
- if mdDes[cTmp1].object:
- condition = mdDes[cTmp].tag.replace(
- ' md.',
- ' self.md.')+':\n'
- object = '\t'+'self.val='+mdDes[cTmp1].object+'\n'
- condition2 = '\t'+mdDes[cTmp1].tag.replace(' md.', ' self.md.')+':\n'
- self.plusC()
- self.plusC()
- numOfItems = 0
- str1 = condition+'\n'
- str1 += condition2+'\n'
- str1 += '\t'+object+'\n'
- metadata[0] = '\t\tself.val'
- str1 += ''.join(metadata)+"='"+ str(mdDes[self.c].mdItem[n].getValue())+"'\n"
- self.plusC()
- numOfItems += 1
- str1 += '\t\t'+append
- str1 = ''
- # (1.2)
- else:
- # "if and for "
- self.plusC()
- self.plusC()
- numOfItems = 0
- size = len(mdDes[self.c].mdItem)
- for n in range(size):
- numOfItems = 0
- str1 = ''
- str1 += appendNoInit+'.append("'+mdDes[self.c].mdItem[n].getValue()+'")\n'
- self.plusC()
- numOfItems += 1
- # (2) only keywords (dict)
- elif 'for' in tag and 'for' in tag1: #
- self.plusC() # skip staementes 2x
- self.plusC()
- loop2 = mdDes[self.c].statements1
- loop1 = mdDes[self.c].statements
- numOfkwGroup=len(mdDes[self.c+1].mdItem)
- for n in range(numOfkwGroup):
- kw = {}
- kw['keywords'] = []
- try:
- keyWordLen=len(mdDes[self.c].mdItem[n])
- for k in range(keyWordLen):
- #print mdDes[self.c].mdItem[n][k].getValue()
- kw['keywords'].append(mdDes[self.c].mdItem[n][k].getValue() )
- except:
- #print mdDes[self.c].mdItem[n].getValue()
- kw['keywords'].append(mdDes[self.c].mdItem[n].getValue() )
- kw['type'] = None
- kw['thesaurus'] = {}
- kw['thesaurus']['title'] = mdDes[self.c+1].mdItem[n].getValue()
- kw['thesaurus']['date'] = mdDes[self.c+2].mdItem[n].getValue()
- kw['thesaurus']['datetype'] = mdDes[self.c+3].mdItem[n].getValue()
- self.md.identification.keywords.append(kw)
- self.plusC()
- self.plusC()
- self.plusC()
- self.plusC()
-#------------------------------------------------------------------------------ next function
- # TODO define this in flat file
- self.md = self.mdo.initMD()
- dirpath = os.path.dirname(os.path.realpath(__file__))
- path=os.path.join(dirpath,'config','init_md')
- mdInitData=open(path,'r')
- mdEval=mdInitData.read()
- #print mdEval
- self.executeStr1(mdEval,None)
- statements = None
- subLoop = None
- initMDStr = None
- self.c = 0
- self.stop = False
- self.max = len(self.mdDescription)
- mdDes = self.mdDescription
- last=True
- # if no statements
- if mdDes[self.c].statements is None\
- and 'if' not in mdDes[self.c].tag.split()\
- and 'for' not in mdDes[self.c].tag.split():
- noneStatements()
- # if 2x statements
- elif chckIf2xStatements():
- in2Statements()
- elif chckIf1Statements: # if 1x statements
- inStatements()
- return self.md
-#------------------------------------ END- FILL OWSLib BY EDITED METADATA IN GUI
-#------------------------------------------------------------------------ LAYOUT
- def _layout(self):
- noteSizer = wx.BoxSizer(wx.VERTICAL)
- self.notebook.SetSizer(noteSizer)
- self.mainSizer.Add(self.notebook, proportion=1, flag=wx.EXPAND)
- self.Show()
- def exportToXml(self, jinjaPath, outPath, xmlOutName,msg):
- self.createNewMD()
- self.mdo.saveToXML(self.md,None, jinjaPath, outPath, xmlOutName,msg)
- def exportTemplate(self, jinjaPath, outPath, xmlOutName):
- self.templatePath=jinjaPath
- owsTagList=self.defineTemplate()
- self.mdo.saveToXML(self.md,owsTagList, self.templatePath, outPath, xmlOutName,msg=True,rmTeplate=True)
-if __name__ == "__main__":
- app = wx.App(False)
- frame = MdMainEditor()
- app.MainLoop()
Deleted: sandbox/krejcmat/src/g.gui.metadata.py
--- sandbox/krejcmat/src/g.gui.metadata.py 2014-10-26 16:02:57 UTC (rev 62380)
+++ sandbox/krejcmat/src/g.gui.metadata.py 2014-10-26 16:12:08 UTC (rev 62381)
@@ -1,1151 +0,0 @@
- at module g.gui.metadata
- at brief GUI components of metadata editor
-Classes:
- - g.gui.metadata::MdMainFrame
- - g.gui.metadata::MdDataCatalog
- - g.gui.metadata::NotebookRight
- - g.gui.metadata::MDHelp
- - g.gui.metadata::TreeBrowser
- - g.gui.metadata::MdValidator
- - g.gui.metadata::MdEditConfigPanel
- - g.gui.metadata::MdToolbar
-(C) 2014 by the GRASS Development Team
-This program is free software under the GNU General Public License
-(>=v2). Read the file COPYING that comes with GRASS for details.
- at author Matej Krejci <matejkrejci gmail.com> (GSoC 2014)
-import wx
-from wx.lib.buttons import ThemedGenBitmapTextButton as BitmapBtnTxt
-from wx import SplitterWindow, EVT_BUTTON
-from wx.lib.pubsub import setupkwargs, pub
-from editor import MdMainEditor
-import glob
-import os
-import sys
-import mdgrass
-import mdutil
-import grass.script as grass
-import grass.script.setup as gsetup
-from lmgr import datacatalog
-# MAIN FRAME
-class MdMainFrame(wx.Frame):
- '''Main frame of metadata editor
- def __init__(self, jinjaPath=None, xmlPath=None, init=False):
- @param jinjaPath: path to jinja template
- @param xmlPath: path to xml with will be read by editor
- @var first,firstAfterChoice,second,secondAfterChoice,secondMultiEdit: initMultipleEditor() and onInitEditor() handler
- @var self. initMultipleEditor() and onInitEditor() handler
- @var self.templateEditor: true= Editor is in mode 'Template creator(widgets with chkbox)'
- @var nameTMPtemplate: in case if 'template editor is on' this var holds name oof temporaly jinja template
- @var batch: if true multiple editing metadata of maps is ON
- wx.Frame.__init__(self, None, title="Metadata Editor", size=(650, 500))
- self.initDefaultPathStorageMetadata()
- self.jinjaPath = jinjaPath
- self.xmlPath = xmlPath
- self.first = True
- self.firstAfterChoice = False
- self.second = False
- self.secondAfterChoice = False
- self.secondMultiEdit = False
- self.templateEditor = False
- self.sb = self.CreateStatusBar()
- self.cres = 0 # resizeFrame
- self.nameTMPteplate = None
- self.batch = False
- self.onInitEditor()
- pub.subscribe(self.initNewMD, 'NEW_MD.create')
- pub.subscribe(self.onEditingMode, 'EDITING_MODE.update')
- pub.subscribe(self.setStatusbarText, 'STATUS_BAR_TEXT.update')
- pub.subscribe(self.onExportTemplate, 'EXPORT_TEMPLATE.create')
- pub.subscribe(self.onExportXML, 'EXPORT_XML.create')
- pub.subscribe(self.onEditMapMetadata, 'EDIT_MAP_METADATA.create')
- pub.subscribe(self.onInitEditor, 'INIT_EDITOR.create')
- pub.subscribe(self.onTemplateEditor, 'TEMPLATE_EDITOR_STATUS.update')
- pub.subscribe(self.onHideLeftPanel, 'HIDE_LEFT_PANEL.update')
- pub.subscribe(self.onRefreshTreeBrowser, 'REFRESH_TREE_BROWSER.update')
- pub.subscribe(self.onChangeEditMapProfile, 'ISO_PROFILE.update')
- pub.subscribe(self.onUpdateGrassMetadata, 'GRASS_METADATA.update')
- pub.subscribe(self.onSetJaX, 'MD_DESTINATION.update')
- pub.subscribe(self.onSetJaX, 'SET_JINJA_AND_XML.update')
- def onSetJaX(self, jinja, xml):
- '''Set template ad xml paths
- def setMdDestionation(self, value):
- '''Set md
- self.mdDestination = value
- def initDefaultPathStorageMetadata(self):
- '''set working folder
- self.mdDestination = os.path.join(mdutil.pathToMapset(), 'metadata')
- if not os.path.exists(self.mdDestination):
- os.makedirs(self.mdDestination)
- def onUpdateGrassMetadata(self):
- '''Update r.support and v.support
- md = self.editor.createNewMD()
- self.mdCreator.updateGrassMd(md)
- GMessage('Grass metadata has been updated')
- def onChangeEditMapProfile(self):
- '''Update vars
- self.templateChoice = self.configPanelLeft.comboBoxProfile.GetValue()
- self.ntbRight.profile = self.templateChoice
- def onExportTemplate(self, outPath, outFileName):
- '''Export defined(pre-filled) template
- self.editor.exportTemplate(self.jinjaPath,
- outPath=outPath,
- xmlOutName=outFileName)
- def onExportXML(self, outPath, outFileName):
- '''Save metadta xml file
- if outPath is None and outFileName is None:
- XMLhead, XMLtail = os.path.split(self.xmlPath)
- self.editor.exportToXml(self.jinjaPath,
- outPath=XMLhead,
- xmlOutName=XMLtail,
- msg=False)
- else:
- outPath=outPath,
- xmlOutName=outFileName,
- msg=True)
- def onRefreshTreeBrowser(self):
- '''Update changes from editor in tree browser
- path = os.path.dirname(os.path.realpath(__file__))
- name = 'refreshTreeBrowser.xml'
- outPath=path,
- xmlOutName=name,
- msg=False)
- pathName = os.path.join(path, name)
- self.ntbRight.refreshXmlBrowser(pathName)
- os.remove(pathName)
- def setStatusbarText(self, text):
- '''Set status text
- self.sb.SetStatusText(text)
- def onTemplateEditor(self, value, template=None):
- '''Update local var
- self.templateEditor = value
- if template == None:
- self.nameTMPteplate = 'TMPtemplate'
- if template == False:
- def initNewMD(self):
- '''Init new md OWSLib object
- self.editor.createNewMD()
- self.ntbRight.md = self.editor.md
- def resizeFrame(self, x1=1, y1=0):
- '''Some widgets need refresh frame for proper working
- self.cres += 1
- if (self.cres % 2 == 0) and x1 == 1 and y1 == 0:
- x1 = -1
- x, y = self.GetSize()
- self.SetSize((x + x1, y + y1))
- def onHideLeftPanel(self):
- '''in editing mode is config panel hidden
- self.toolbar.bttNew.Enable()
- self.Hsizer.Remove(self.leftPanel)
- self.Hsizer.Layout()
- self.leftPanel.SetSize((1, 1))
- def onEditingMode(self, editStatus):
- self.resizeFrame()
- self.Layout()
- if editStatus:
- self.MdDataCatalogPanelLeft.Show()
- self.toolbar.bttLoad.Disable()
- self.toolbar.bttLoadXml.Disable()
- else:
- self.MdDataCatalogPanelLeft.Hide()
- self.toolbar.bttEdit.Disable()
- self.toolbar.bttCreateTemplate.Disable()
- self.toolbar.bttLoad.Enable()
- self.toolbar.bttLoadXml.Enable()
- self.sb.SetStatusText('')
- self.MdDataCatalogPanelLeft.UnselectAll()
- def onEditMapMetadata(self, multipleEditing=False):
- '''Initialize editor by selection of grass map in data catalog
- @param multipleEditing: if user select more than one map mutlipleEditing=True
- @param numOfMap: hold information about number of selected maps for editing
- @param ListOfMapTypeDict: list of dict sttored names of selected maps in dict. dict['cell/vector']=nameofmaps
- if not multipleEditing:
- self.ListOfMapTypeDict = self.MdDataCatalogPanelLeft.ListOfMapTypeDict
- self.numOfMap = len(self.ListOfMapTypeDict)
- if self.numOfMap == 0 and multipleEditing is False:
- GMessage('Select map in data catalog...')
- return
- # if editing just one map
- if self.numOfMap == 1 and multipleEditing is False:
- self.mdCreator = mdgrass.GrassMD(self.ListOfMapTypeDict[-1][self.ListOfMapTypeDict[-1].keys()[0]],
- self.ListOfMapTypeDict[-1].keys()[0])
- if self.templateChoice == 'INSPIRE':
- self.mdCreator.createGrassInspireISO()
- self.jinjaPath = self.mdCreator.templatePathAbs
- self.xmlPath = self.mdCreator.saveXML(self.mdDestination, self.nameTMPteplate, self)
- elif self.templateChoice == 'GRASS BASIC':
- self.mdCreator.createGrassBasicISO()
- # if editing multiple maps or just one but with loading own custom template
- if self.templateChoice == 'Load Custom' and self.numOfMap != 0:
- # load template. IF for just one map ELSE for multiple editing
- if multipleEditing is False:
- dlg = wx.FileDialog(self, "Select template", os.getcwd(), "", "*.xml", wx.OPEN)
- if dlg.ShowModal() == wx.ID_OK:
- self.jinjaPath = dlg.GetPath()
- # if multiple map are selected
- if self.numOfMap > 1:
- self.toolbar.xmlPath = self.xmlPath
- self.toolbar.jinjaPath = self.jinjaPath
- self.batch = True
- self.ListOfMapTypeDict.pop()
- self.initMultipleEditor()
- else:
- else: # do nothing
- return False
- else:
- self.onHideLeftPanel()
- if self.numOfMap == 0 and multipleEditing is True:
- multipleEditing = False
- self.toolbar.onNewSession(None)
- GMessage('All selected maps are edited')
- self.secondMultiEdit = True
- if self.batch and multipleEditing:
- self.batch = mdutil.yesNo(self, 'Do you want to save metadata of : %s without editing ? ' % XMLtail, 'Multiple editing')
- if self.batch:
- self.toolbar.batch = True
- self.toolbar.onSaveXML()
- return True
- def initMultipleEditor(self):
- '''initialize multiple editing mode
- if self.firstAfterChoice and not self.secondMultiEdit:
- self.splitter = SplitterWindow(self, style=wx.SP_3D |
- wx.SP_LIVE_UPDATE | wx.SP_BORDER)
- self.Hsizer.Add(self.splitter, proportion=1, flag=wx.EXPAND)
- self.secondAfterChoice = True
- self.toolbar.bttsave.SetLabel('next')
- self.toolbar.hideMultipleEdit()
- self.mainSizer.Layout()
- self.editor = MdMainEditor(self.splitter,
- self.jinjaPath,
- self.xmlPath,
- self.templateEditor)
- self.ntbRight = NotebookRight(self.splitter, self.xmlPath)
- self.splitter.SplitVertically(self.editor, self.ntbRight, sashPosition=0.65)
- self.splitter.SetSashGravity(0.65)
- self.Show()
- elif self.secondAfterChoice or self.secondMultiEdit:
- if self.secondMultiEdit:
- def onInitEditor(self,):
- @var first: True= First initialize main frame
- @var firstAfterChoice: True=Init editor editor after set configuration and click onEdit in toolbar
- @var second: init editor after first initialize
- @var secondAfterChoice: init edito onemore time
- if self.first:
- self.first = False
- self.firstAfterChoice = True
- self.toolbar = MdToolbar(self,
- self.jinjaPath,
- self.xmlPath,
- self.sb,
- self.mdDestination)
- self.leftPanel = wx.Panel(self, id=wx.ID_ANY)
- self.configPanelLeft = MdEditConfigPanel(self.leftPanel)
- self.MdDataCatalogPanelLeft = MdDataCatalog(self.leftPanel)
- self._layout()
- self.Show()
- elif self.firstAfterChoice:
- self.splitter = SplitterWindow(self, style=wx.SP_3D | wx.SP_LIVE_UPDATE | wx.SP_BORDER)
- self.second = True
- self.editor = MdMainEditor(parent=self.splitter,
- templatePath=self.jinjaPath,
- xmlMdPath=self.xmlPath,
- templateEditor=self.templateEditor)
- self.splitter.SizeWindows()
- self.Show()
- elif self.second: # if next initializing of editor
- self.splitter.Hide()
- self.toolbar.bttNew.Disable()
- self.toolbar.bttsave.Disable()
- self.Hsizer.Insert(0, self.leftPanel, proportion=1, flag=wx.EXPAND)
- elif self.secondAfterChoice:
- self.splitter.Show()
- self.toolbar.bttsave.Enable()
- ntbRightBCK = self.ntbRight
- self.splitter.ReplaceWindow(ntbRightBCK, self.ntbRight)
- editorTMP = self.editor
- self.splitter.ReplaceWindow(editorTMP, self.editor)
- ntbRightBCK.Destroy()
- editorTMP.Destroy()
- self.Show()
- self.splitter.SetSashGravity(0.35)
- else:
- self.mainSizer.Add(self.toolbar)
- self.mainSizer.Add(wx.StaticLine(self, -1, style=wx.LI_HORIZONTAL, size=(10000, 5)))
- self.mainSizer.AddSpacer(5, 5, 1, wx.EXPAND)
- self.leftPanelSizer = wx.BoxSizer(wx.VERTICAL)
- self.leftPanel.SetSizer(self.leftPanelSizer)
- self.leftPanelSizer.Add(self.configPanelLeft, proportion=0, flag=wx.EXPAND)
- self.leftPanelSizer.AddSpacer(5, 5, 1, wx.EXPAND)
- self.leftPanelSizer.Add(self.MdDataCatalogPanelLeft, proportion=1, flag=wx.EXPAND)
- self.Hsizer = wx.BoxSizer(wx.HORIZONTAL)
- self.mainSizer.Add(self.Hsizer, proportion=1, flag=wx.EXPAND)
- self.Hsizer.Add(self.leftPanel, proportion=1, flag=wx.EXPAND)
- self.resizeFrame(300, 0)
- self.Layout()
-# DATA CATALOG
-class MdDataCatalog(datacatalog.LocationMapTree):
- '''Data catalog for selecting GRASS maps for editing
- """Test Tree constructor."""
- super(MdDataCatalog, self).__init__(parent=parent,
- style=wx.TR_MULTIPLE | wx.TR_HIDE_ROOT | wx.TR_HAS_BUTTONS |
- wx.TR_FULL_ROW_HIGHLIGHT | wx.TR_COLUMN_LINES)
- self.InitTreeItems()
- self.map = None
- self.mapType = None
- def InitTreeItems(self):
- """Add locations and layers to the tree."""
- gisenv = grass.gisenv()
- location = gisenv['LOCATION_NAME']
- self.mapset = gisenv['MAPSET']
- self._initTreeItems(locations=[location], mapsets=[self.mapset])
- self.ExpandAll()
- self.Bind(wx.EVT_TREE_SEL_CHANGED, self.onChanged)
- self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.onChanged)
- def onChanged(self, evt=None):
- @var ListOfMapTypeDict: list of dic with maps and map-type values
- @var MapTypeDict: keys= type of map(cell/vector), value=<map name>
- self.ListOfMapTypeDict = list()
- maps = list()
- if self.GetChildrenCount(evt.Item) == 0: # is selected map
- for item in self.GetSelections():
- MapTypeDict = {}
- maps.append(self.GetItemText(item))
- map = self.GetItemText(item) + '@' + self.mapset
- mapType = self.GetItemParent(item)
- mapType = self.GetItemText(mapType)
- if mapType == 'vect':
- mapType = 'vector'
- elif mapType == 'rast':
- mapType = 'cell'
- MapTypeDict[mapType] = map
- self.ListOfMapTypeDict.append(MapTypeDict)
- pub.sendMessage('bttEdit.enable')
- pub.sendMessage('bttCreateTemplate.enable')
- else:
- self.Unselect()
- GMessage('Please select map.')
- if len(maps) == 0:
- pub.sendMessage('bttEdit.disable')
- pub.sendMessage('bttCreateTemplate.disable')
- str1 = ''
- for map in maps:
- str1 += map + ' '
- if len(maps) > 1:
- pub.sendMessage('SET_PROFILE.update', profile='Load Custom')
- pub.sendMessage('comboBoxProfile.disable')
- else:
- pub.sendMessage('comboBoxProfile.enable')
- pub.sendMessage('STATUS_BAR_TEXT.update', text=str1)
-# NOTEBOOK ON THE RIGHT SIDE-xml browser+validator
-class NotebookRight(wx.Notebook):
- '''Include pages with xml tree browser and validator of metadata
- def __init__(self, parent, path):
- wx.Notebook.__init__(self, parent=parent, id=wx.ID_ANY)
- # first panel
- self.notebookValidator = wx.Panel(self, wx.ID_ANY)
- self.validator = MdValidator(self.notebookValidator)
- self.xmlPath = path
- self.profile = None
- self.buttValidate = wx.Button(self.notebookValidator,
- id=wx.ID_ANY,
- size=(70, 50),
- label='validate')
- self.notebook_panel1 = wx.Panel(self, wx.ID_ANY)
- self.tree = TreeBrowser(self.notebook_panel1, self.xmlPath)
- self.buttRefresh = wx.Button(
- self.notebook_panel1,
- id=wx.ID_ANY,
- size=(70, 50),
- label='refresh')
- self.AddPage(self.notebookValidator, "Validator")
- self.AddPage(self.notebook_panel1, "Tree browser")
- # self.AddPage(self.notebook_panel2, "Help")
- self.buttValidate.Bind(wx.EVT_BUTTON, self.validate)
- self.buttRefresh.Bind(wx.EVT_BUTTON, self.onRefreshXmlBrowser)
- self._layout()
- def onActive(self):
- pass
- def onRefreshXmlBrowser(self, evt=None):
- pub.sendMessage('REFRESH_TREE_BROWSER.update')
- def refreshXmlBrowser(self, path):
- treeBCK = self.tree
- self.tree = TreeBrowser(self.notebook_panel1, path)
- self.panelSizer1.Replace(treeBCK, self.tree)
- # self.panelSizer1.Add(self.tree, flag=wx.EXPAND, proportion=1)
- self.panelSizer1.Layout()
- treeBCK.Destroy()
- def validate(self, evt):
- self.md = None
- pub.sendMessage('NEW_MD.create')
- pub.sendMessage('ISO_PROFILE.update')
- self.validator.validate(self.md, self.profile)
- panelSizer0 = wx.BoxSizer(wx.VERTICAL)
- self.notebookValidator.SetSizer(panelSizer0)
- panelSizer0.Add(self.validator, flag=wx.EXPAND, proportion=1)
- panelSizer0.Add(self.buttValidate)
- self.panelSizer1 = wx.BoxSizer(wx.VERTICAL)
- self.notebook_panel1.SetSizer(self.panelSizer1)
- self.panelSizer1.Add(self.tree, flag=wx.EXPAND, proportion=1)
- self.panelSizer1.Add(self.buttRefresh)
- panelSizer2 = wx.BoxSizer(wx.VERTICAL)
- # self.notebook_panel2.SetSizer(panelSizer2)
- # panelSizer2.Add(self.notebook_panel2,flag=wx.EXPAND, proportion=1)
-# HELP
-class MDHelp(wx.Panel):
- class MyHtmlPanel inherits wx.Panel and adds a button and HtmlWindow
- self.html1 = wx.html.HtmlWindow(self, id=wx.ID_ANY)
- try:
- self.html1.LoadFile('help/help.html')
- # self.html1.LoadPage('http://inspire-geoportal.ec.europa.eu/EUOSME_GEOPORTAL/userguide/eurlex_en.htm')
- except:
- pass
- self.mainSizer.Add(self.html1, proportion=1, flag=wx.EXPAND)
-# TREE EDITOR
-class TreeBrowser(wx.TreeCtrl):
- '''Filling text tree by xml file.
- @note: to enable editing mode of init xml uncoment blocks below
- def __init__(self, parent, xmlPath=False, xmlEtree=False):
- wx.TreeCtrl.__init__(self, parent=parent, id=wx.ID_ANY,
- style=wx.TR_HAS_BUTTONS | wx.TR_FULL_ROW_HIGHLIGHT)
- tree = self
- if xmlPath:
- xml = etree.parse(xmlPath)
- self.xml = xml.getroot()
- self.root = tree.AddRoot(self.xml.tag)
- else:
- self.xml = xmlEtree
- self.root = xmlEtree.getroot()
- root = self.fillTree()
- self.Expand(root)
- # self.Bind(wx.EVT_CLOSE, self.OnClose)
- # self.Bind(wx.EVT_TREE_END_LABEL_EDIT, self.OnEdit)
- self.Bind(wx.EVT_TREE_ITEM_RIGHT_CLICK, self.OnRClickAllChildren)
- def fillTree(self):
- root = self.root
- xml = self.xml
- tree = self
- def add(parent, elem):
- for e in elem:
- if str(e).find("<!--") != -1: # skip comments
- continue
- tag = etree.QName(e)
- item = tree.AppendItem(parent, tag.localname, data=None)
- if self.GetChildrenCount(item) == 0:
- self.SetItemBackgroundColour(item, (242, 242, 242))
- if e.text:
- text = e.text.strip()
- else:
- text = e.text
- if text:
- val = tree.AppendItem(item, text)
- tree.SetPyData(val, e)
- add(item, e)
- add(root, xml)
- return root
- # def OnEdit(self, evt):
- # elm = self.GetPyData(evt.Item)
- # print evt.Label
- # if elm is not None:
- # elm.text = evt.Label
- # self.xml.write(self.fpath, encoding="UTF-8", xml_declaration=True)
- # self.validate()
- # def OnClose(self, evt):
- # self.Destroy()
- def OnRClickAllChildren(self, evt):
- if not self.IsExpanded(evt.Item):
- self.ExpandAllChildren(evt.Item)
- else:
- self.CollapseAllChildren(evt.Item)
-# INSPIRE VALIDATOR PANEL
-class MdValidator(wx.Panel):
- '''wx panel of notebook which support validating two natively implemented profiles
- self.text = wx.TextCtrl(parent, id=wx.ID_ANY, size=(0, 55),
- wx.TE_MULTILINE | wx.TE_NO_VSCROLL |
- self._layout()
- self.mainSizer.Add(self.text, proportion=1, flag=wx.EXPAND)
- def validate(self, md, profile):
- '''For externaly load xml file is by default inspire validator
- if profile == 'INSPIRE' or profile == 'Load Custom':
- result = mdutil.isnpireValidator(md)
- str1 = 'INSPIRE VALIDATOR\n'
- if profile == 'GRASS BASIC':
- result = mdutil.grassProfileValidator(md)
- str1 = 'GRASS BASIC PROFILE VALIDATOR\n'
- str1 += 'Status of validation: ' + result["status"] + '\n'
- str1 += 'Numbers of errors: ' + result["num_of_errors"] + '\n'
- if result["status"] != 'succeded':
- str1 += 'Errors:\n'
- for item in result["errors"]:
- str1 += '\t' + str(item) + '\n'
- self.text.SetValue(str1)
-# CONFIGURATION PANEL ON THE LEFT SIDE
-class MdEditConfigPanel(wx.Panel):
- '''Configuration pane for selection editing mode.
- @var mapGrassEdit: True = editing metadata of GRASS maps, false= editing externally loaded xml and template
- wx.Panel.__init__(self, parent, id=wx.ID_ANY)
- self.SetMinSize((240, -1))
- self.mapGrassEdit = True
- self.rbGrass = wx.RadioButton(self, id=wx.ID_ANY, label='Metadata map editor', style=wx.RB_GROUP)
- self.rbExternal = wx.RadioButton(self, id=wx.ID_ANY, label='Metadata external editor')
- self.comboBoxProfile = wx.ComboBox(self, choices=['INSPIRE', 'GRASS BASIC', 'Load Custom'])
- pub.subscribe(self.onComboboxDisable, "comboBoxProfile.disable")
- pub.subscribe(self.onComboboxEnable, "comboBoxProfile.enable")
- pub.subscribe(self.onSetProfile, "SET_PROFILE.update")
- self.comboBoxProfile.SetStringSelection('GRASS BASIC')
- self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbGrass.GetId())
- self.Bind(wx.EVT_RADIOBUTTON, self.onSetRadioType, id=self.rbExternal.GetId())
- self.comboBoxProfile.Bind(wx.EVT_COMBOBOX, self.onChangeComboBoxProfile)
- self._layout()
- def onChangeComboBoxProfile(self, evt):
- pass
- def onComboboxDisable(self):
- self.comboBoxProfile.Disable()
- def onComboboxEnable(self):
- self.comboBoxProfile.Enable()
- def onSetProfile(self, profile):
- self.comboBoxProfile.SetStringSelection(profile)
- def SetVal(self, event):
- state1 = str()
- state2 = str(self.rb2.GetValue())
- self.statusbar.SetStatusText(state1, 0)
- self.statusbar.SetStatusText(state2, 1)
- def onSetRadioType(self, evt=None):
- self.mapGrassEdit = self.rbGrass.GetValue()
- if self.mapGrassEdit == False:
- self.comboBoxProfile.Hide()
- else:
- self.comboBoxProfile.Show()
- pub.sendMessage('EDITING_MODE.update', editStatus=self.mapGrassEdit)
- self.mainsizer = wx.BoxSizer(wx.VERTICAL)
- self.SetSizer(self.mainsizer)
- self.mainsizer.Add(self.rbGrass)
- self.mainsizer.Add(self.rbExternal)
- self.mainsizer.Add(self.comboBoxProfile)
-# TOOLBAR
-class MdToolbar(wx.Panel):
- '''Main toolbar of editor
- def __init__(self, parent, jinjaPath, xmlPath, sb, mdDestionation):
- self.mdDestination = mdDestionation
- self.statusBar = sb
- self.extendEdit = False
- self.toolbar = wx.ToolBar(self, 1, wx.DefaultPosition, (-1, -1))
- bitmapSave = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'save.png'),
- wx.BITMAP_TYPE_PNG).ConvertToBitmap()
- bitmapNew = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'create.png'),
- bitmapLoad = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'open.png'),
- bitmaSettings = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'settings.png'),
-#-------------------------------------------------------------------- EDIT
- self.toolbar.AddSeparator()
- bitmapEdit = wx.Image(
- os.path.join(os.environ['GISBASE'], 'gui', 'icons', 'grass', 'edit.png'),
- self.bttEdit = BitmapBtnTxt(
- self.toolbar, -1, bitmapEdit, 'edit')
- self.toolbar.AddControl(control=self.bttEdit)
- self.bttEdit.Disable()
-#-------------------------------------------------------------------- NEW SESION
- self.bttNew = BitmapBtnTxt(self.toolbar, -1, bitmapNew, 'session')
- self.toolbar.AddControl(control=self.bttNew)
- self.bttNew.Disable()
-#-------------------------------------------------------------------------- SAVE
- self.bttsave = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "XML")
- self.bttsave.Disable()
- self.toolbar.AddControl(control=self.bttsave)
-#----------------------------------------------------------------- OPEN TEMPLATE
- self.bttLoad = BitmapBtnTxt(self.toolbar, -1, bitmapLoad, "template", size=(100, -1))
- self.toolbar.AddControl(control=self.bttLoad)
- self.bttLoad.Disable()
-#---------------------------------------------------------------------- OPEN XML
- self.bttLoadXml = BitmapBtnTxt(self.toolbar, -1, bitmapLoad, "XML")
- self.toolbar.AddControl(control=self.bttLoadXml)
- self.bttLoadXml.Disable()
-#-------------------------------------------------------------------- NEW TEMPLATE
- self.bttCreateTemplate = BitmapBtnTxt(self.toolbar, -1, bitmapNew, "template", size=(100, -1))
- self.toolbar.AddControl(control=self.bttCreateTemplate)
- self.bttCreateTemplate.Disable()
- self.bttSaveTemplate = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "template", size=(100, -1))
- self.bttSaveTemplate.Disable()
- self.toolbar.AddControl(control=self.bttSaveTemplate)
- self.bttUpdateGRASS = BitmapBtnTxt(self.toolbar, -1, bitmapSave, "GRASS", size=(100, -1))
- self.bttUpdateGRASS.Disable()
- self.toolbar.AddControl(control=self.bttUpdateGRASS)
-#-------------------------------------------------------------------------- Config
- self.bttConfig = BitmapBtnTxt(self.toolbar, -1, bitmaSettings, "workdir", size=(100, -1))
- self.toolbar.AddControl(control=self.bttConfig)
- self.toolbar.Realize()
- self._layout()
- self.bttLoad.Bind(wx.EVT_BUTTON, self.OnLoadTemplate)
- pub.subscribe(self.onBttSaveEnable, "bttLoad.enable")
- pub.subscribe(self.onBttSaveDisable, "bttLoad.disable")
- self.bttsave.Bind(wx.EVT_BUTTON, self.onSaveXML)
- pub.subscribe(self.onBttLoadEnable, "bttSave.enable")
- pub.subscribe(self.onBttLoadDisable, "bttSave.disable")
- self.bttLoadXml.Bind(wx.EVT_BUTTON, self.onLoadXml)
- pub.subscribe(self.onBttLoadXmlEnable, "bttLoadXml.enable")
- pub.subscribe(self.onBttLoadXmlDisable, "bttLoadXml.disable")
- self.bttNew.Bind(wx.EVT_BUTTON, self.onNewSession)
- pub.subscribe(self.onBttNewEnable, "bttNew.enable")
- pub.subscribe(self.onBttNewDisable, "bttNew.disable")
- self.bttEdit.Bind(wx.EVT_BUTTON, self.onEdit)
- pub.subscribe(self.onBtEditEnable, "bttEdit.enable")
- pub.subscribe(self.onBttEditDisable, "bttEdit.disable")
- self.bttCreateTemplate.Bind(wx.EVT_BUTTON, self.onCreateTemplate)
- pub.subscribe(self.onBttCreateTemplateEnable, "bttCreateTemplate.enable")
- pub.subscribe(self.onBttCreateTemplateDisable, "bttCreateTemplate.disable")
- self.bttSaveTemplate.Bind(wx.EVT_BUTTON, self.onSaveTemplate)
- pub.subscribe(self.onBttSaveTemplateEnable, "bttSaveTemplate.enable")
- pub.subscribe(self.onBttSaveTemplateDisable, "bttSaveTemplate.disable")
- self.bttUpdateGRASS.Bind(wx.EVT_BUTTON, self.onUpdateGRASS)
- pub.subscribe(self.onBttUpdateGRASSEnable, "bttSaveTemplate.enable")
- pub.subscribe(self.onBttUpdateGRASSDisable, "bttSaveTemplate.disable")
- self.bttConfig.Bind(wx.EVT_BUTTON, self.onSettings)
- def onBttSaveDisable(self):
- self.bttSave.Disable()
- def onBttSaveEnable(self):
- self.bttSave.Enable()
- def onBttLoadDisable(self):
- def onBttLoadEnable(self):
- self.bttLoad.Enable()
- def onBttLoadXmlDisable(self):
- def onBttLoadXmlEnable(self):
- self.bttLoadXml.Enable()
- def onBttNewDisable(self):
- def onBttNewEnable(self):
- self.bttNew.Enable()
- def onBttEditDisable(self):
- def onBtEditEnable(self):
- self.bttEdit.Enable()
- def onBttCreateTemplateDisable(self):
- def onBttCreateTemplateEnable(self):
- self.bttCreateTemplate.Enable()
- def onBttSaveTemplateDisable(self):
- def onBttSaveTemplateEnable(self):
- self.bttSaveTemplate.Enable()
- def onBttUpdateGRASSDisable(self):
- def onBttUpdateGRASSEnable(self):
- self.bttUpdateGRASS.Enable()
- def onUpdateGRASS(self, evt):
- pub.sendMessage('GRASS_METADATA.update')
- def onSettings(self, evt):
- dlg = wx.DirDialog(self,
- message="Select metadata working directory",
- defaultPath=self.mdDestination,
- style=wx.DD_DEFAULT_STYLE | wx.DD_NEW_DIR_BUTTON)
- self.mdDestination = dlg.GetPath()
- pub.sendMessage('MD_DESTINATION.update', value=self.mdDestination)
- dlg.Destroy()
- GMessage('Metadata destinatnion: %s' % self.mdDestination)
- def hideMultipleEdit(self):
- '''Multiple editor is off
- self.bttLoad.Hide()
- self.bttLoadXml.Hide()
- self.bttNew.Hide()
- self.bttEdit.Hide()
- self.bttCreateTemplate.Hide()
- self.bttSaveTemplate.Hide()
- self.bttUpdateGRASS.Hide()
- def showMultipleEdit(self):
- '''Multiple editor is on
- self.bttLoad.Show()
- self.bttLoadXml.Show()
- self.bttNew.Show()
- self.bttEdit.Show()
- self.bttCreateTemplate.Show()
- self.bttSaveTemplate.Show()
- self.bttUpdateGRASS.Show()
- def onCreateTemplate(self, evt):
- pub.sendMessage('TEMPLATE_EDITOR_STATUS.update', value=True)
- self.onEdit(evt=None)
- def onEdit(self, evt=None):
- @var : extendEdit if xml and jinja is loaded from file
- if self.extendEdit:
- pub.sendMessage('SET_JINJA_AND_XML.update', jinja=self.jinjaPath, xml=self.xmlPath)
- if self.GetParent().configPanelLeft.rbGrass.GetValue():
- ok = self.GetParent().onEditMapMetadata()
- if not ok:
- return
- else:
- pub.sendMessage('INIT_EDITOR.create')
- self.bttsave.Enable()
- if not self.extendEdit:
- try: # if multiediting mode ON
- if self.GetParent().numOfMap > 1:
- if self.batch:
- self.onSaveXML()
- except:
- pass
- def onNewSession(self, evt):
- pub.sendMessage('TEMPLATE_EDITOR_STATUS.update', value=False, template=False)
- # chck current editing mode(grass or external xml editor)
- if self.GetParent().configPanelLeft.rbGrass is False:
- self.jinjaPath = None
- self.xmlPath = None
- self.bttsave.SetLabel('XML')
- self.showMultipleEdit()
- def onChangeXmlorTemplate(self, evt=None):
- '''in case if path of template and xml path are initialized-> enable buttons for next step
- if self.jinjaPath is not None and self.xmlPath is not None:
- pub.sendMessage('HIDE_LEFT_PANEL.update')
- self.extendEdit = True
- def onLoadXml(self, evt=None):
- "Select xml metadata file",
- self.mdDestination,
- "*.xml",
- wx.OPEN)
- self.xmlPath = dlg.GetPath()
- tx = self.statusBar.GetStatusText()
- self.statusBar.SetStatusText(tx + ' Selected XML: ' + self.xmlPath)
- self.onChangeXmlorTemplate()
- dlg.Destroy()
- def onSaveTemplate(self, evt=None):
- "Select output file",
- "*.xml",
- wx.SAVE)
- pub.sendMessage('EXPORT_TEMPLATE.create',
- outPath=dlg.GetDirectory(),
- outFileName=dlg.GetFilename())
- def OnLoadTemplate(self, evt):
- "Select template of ISO profile",
- "*.xml",
- wx.OPEN)
- self.statusBar.SetStatusText(tx + ' Selected template: ' + self.jinjaPath)
- dlg.Destroy()
- def onSaveXML(self, evt=None):
- self.XMLhead, self.XMLtail = os.path.split(self.xmlPath)
- if not self.batch: # if normal saving with user-task-dialog
- message="Set output file",
- defaultDir=self.mdDestination,
- defaultFile=self.XMLtail,
- wildcard="*.xml",
- style=wx.SAVE | wx.FD_OVERWRITE_PROMPT)
- pub.sendMessage('EXPORT_XML.create', outPath=dlg.GetDirectory(), outFileName=dlg.GetFilename())
- if self.bttsave.GetLabelText() == 'next':
- pub.sendMessage('EDIT_MAP_METADATA.create', multipleEditing=True)
- else:
- ask = mdutil.yesNo(self, 'File is not saved. Do you want to save it? ', 'Save dialog')
- if ask:
- self.onSaveXML()
- else:
- GMessage('File not save.')
- dlg.Destroy()
- else:
- pub.sendMessage('EXPORT_XML.create', outPath=None, outFileName=None)
- self.mainsizer = wx.BoxSizer(wx.HORIZONTAL)
- self.mainsizer.Add(self.toolbar)
- frame = MdMainFrame()
- app.MainLoop()
Deleted: sandbox/krejcmat/src/jinjainfo.py
--- sandbox/krejcmat/src/jinjainfo.py 2014-10-26 16:02:57 UTC (rev 62380)
+++ sandbox/krejcmat/src/jinjainfo.py 2014-10-26 16:12:08 UTC (rev 62381)
@@ -1,192 +0,0 @@
- at package jinjainfo
- at brief Library for parsing informations from jinja template
-Classes:
- - jinjainfo::MdDescription
- - jinjainfo::JinjaTemplateParser
-from core.gcmd import GError
-from mdutil import findBetween
-class MdDescription():
- '''Object which is initialzed by jinja template in '{# #}'
- def __init__(self, tag=None, object=None, name='', desc=None,
- example=None, type=None, multi=0, inboxmulti=None,
- group=None, inbox=None, multiline=None, validator=None,
- num=None, ref=None, selfInfoString=None):
- @param tag: OWSLib object which will be replaced by value of object after jinja template system render new file
- @param object: some object in OWSLib is neecesarry to initialize temporaly in gui generator. Others are initialize by configure file
- @param name: label and tooltip name
- @param desc: description/definition of metadata item
- @param example: example of md item (tooltip)
- @param type: data type is neccesary to validet widgets
- @param multi: 0=only one instance of editor::MdItem widget can be, 1= multiple insctances of widgets can be
- @param inboxmulti: 0=static box of items has not button for duplicating self 1=has button
- @param group: this param initialize page in notebook in mani editor
- @param inbox: Every items in block of code in jinja template must have same value of inbox.
- The value of inbox representing label of static box in gui.
- @param multiline: If true- textCtrl widget will be init with multiline control
- @param validator: Not use currently
- @param ref: additional information about reference of metadata item (ISO reference)
- @param selfInfoString: string value representing all these information. (parsed from jinja template)
- @var mdItem: very important parametr which holds instances of widgets(editor::MdItem)
- on every index of list is one instance of widget. In case, if is in static box MdItem with duplicating button:
- index of list is represented by list of these items
- @var statements: hold information about first statement in block
- @var statements1: hold info about secont stetement in block of var: statement
- self.tag = tag
- self.object = object
- self.name = name
- self.desc = desc
- self.example = example
- self.type = type
- self.multiplicity = multi # multiplicity of MD item
- self.group = group
- self.inbox = inbox
- self.ref = ref
- self.selfInfoString = selfInfoString
- self.inboxmulti = inboxmulti
- self.multiline = multiline # type of ctrl text
- self.validator = validator
- # --info from jinja -end
- self.statements = None
- self.statements1 = None
- self.mdItem = list()
- def addMdItem(self, newMdItem, oldMdItem=None):
- '''care about integrity of var: self.mdItem
- # if new mditem is from box- need to hold information
- # about it.(list on the same index in self.mdItem)
- if oldMdItem is not None:
- for n, item in enumerate(self.mdItem):
- for i in item:
- if i == oldMdItem:
- self.mdItem[n].append(newMdItem)
- else:
- self.mdItem.append(newMdItem)
- def removeMdItem(self, item):
- try:
- for k, oldListItem in enumerate(self.mdItem):
- for i in oldListItem:
- if i == item:
- self.mdItem[k].remove(item)
- except:
- self.mdItem.remove(item)
- def addStatements(self, stat):
- if self.statements is None:
- self.statements = stat
- def addStatements1(self, stat):
- if self.statements1 is None:
- self.statements1 = stat
-class JinjaTemplateParser():
- '''Parser of OWSLib tag and init. values of jinjainfo::MdDescription from jinja template.
- def __init__(self, template):
- @var mdDescription: list of jinjainfo::mdDescription
- @var mdOWSTag: list of tags in jinja templates
- @var mdOWSTagStr: string representing OWSLib tags from template(per line)
- @var mdOWSTagStrList: on each index of list is one line with parsed OWSLib tag
- self.mdDescription = []
- self.mdOWSTag = []
- self.template = template
- self.mdOWSTagStr = ''
- self.mdOWSTagStrList = []
- self._readJinjaInfo()
- self._readJinjaTags()
- self._formatMdOWSTagStrToPythonBlocks()
- def _readJinjaTags(self):
- '''Parser of OWSLib tag from jinja template to list
- try:
- with open(self.template, "r") as f:
- for line in f:
- # if found start of comments
- if str(line).find("{{") != -1:
- obj = findBetween(line, "{{", "}}")
- self.mdOWSTag.append(obj)
- if str(line).find("{%") != -1:
- obj = findBetween(line, "{%", "-%}")
- except:
- GError('Cannot open jinja template')
- # print "I/O error({0}): {1}".format(e.errno, e.strerror)
- def _readJinjaInfo(self):
- '''Parser of 'comments'({# #}) in jinja template which are represented by jinjainfo::MdDescription
- parsed values initializing list of jinjainfo::MdDesctiption obect
- try:
- for line in f:
- if str(line).find("{#") != -1:
- values = findBetween(line, "{#", "#}")
- values1 = findBetween(line, "{%", "#}")
- values2 = findBetween(line, "{{", "#}")
- if values1 != '':
- values += ",selfInfoString='''{%" + values1 + "#}'''"
- else:
- values += ",selfInfoString='''{{" + values2 + "#}'''"
- exe_str = "self.mdDescription.append(MdDescription(%s))" % values
- exe_str = exe_str.decode("utf-8", 'ignore')
- eval(exe_str)
- except:
- def _formatMdOWSTagStrToPythonBlocks(self):
- '''Formating of parsed tags to pythonic blocks
- self.mdOWSTagStr = ""
- tab = 0
- for item in self.mdOWSTag:
- if str(item).find(" endfor ") != -1 or \
- str(item).find(" endif ") != -1:
- tab -= 1
- continue
- tabstr = '\t' * tab
- str1 = tabstr + item[1:] + '\n'
- self.mdOWSTagStr += str1
- self.mdOWSTagStrList.append(tabstr + item[1:])
- if str(item).find(" for ") != -1 \
- or str(item).find(" if ") != -1:
- tab += 1
Deleted: sandbox/krejcmat/src/mdgrass.py
--- sandbox/krejcmat/src/mdgrass.py 2014-10-26 16:02:57 UTC (rev 62380)
+++ sandbox/krejcmat/src/mdgrass.py 2014-10-26 16:12:08 UTC (rev 62381)
@@ -1,523 +0,0 @@
-#!/usr/bin/env python
-# -*- coding: utf-8
- at package mdgrass
- at module v.info.iso, r.info.iso, g.gui.metadata
- at brief Base class for import(r.info,v.info) and export(r/v.support)
- metadata with using OWSLib and jinja template.
-Classes:
- - mdgrass::MdDescription
-from owslib.iso import *
-from jinja2 import Environment, FileSystemLoader
-from lxml import etree
-import os
-import sys
-import re
-import StringIO
-import subprocess as sub
-import uuid
-import mdutil # metadata lib
-import getpass # whoami for linux and ms-win
-from grass.pygrass.modules.shortcuts import general as g
-from grass.pygrass.gis import Mapset
-from grass.pygrass import raster
-from grass.pygrass.modules import Module
-from grass.script import parse_key_val
-from subprocess import PIPE
-from datetime import date, datetime
-from grass.script import parser
-from grass.script import core as grass
-class GrassMD():
- @var self.map: name of choosen map by user
- @var self.type: typ of map representation(cell, vector, r3)
- @var md_grass: dict with metadata from r.info v.info except "r.info flag=h"
- def __init__(self, map, type):
- self.map = map
- self.type = type
- self.isMapExist() # function to check if map exist
- self.md_grass = {}
- self.md_abstract = ''
- self.md_vinfo_h = '' # v.info flag=h" - parse
- self.gisenv_grass = grass.gisenv() # dict with gisenv information
- # postfix of output xml file (variables)
- self.schema_type = '_basic.xml' # currently
- self.dirpath = os.path.dirname(os.path.realpath(__file__))
- # metadata object from OWSLIB ( for define md values)
- self.md = MD_Metadata(md=None)
- self.template = None # path to file with xml templates
- if self.type == "cell":
- self.parseRast()
- elif self.type == "vector":
- self.parseVect()
- elif self.type == "r3??":
- # TODO
- self.parseRast3D()
- def isMapExist(self):
- '''Check if is the map in working mapset'''
- self.mapset = grass.find_file(self.map, self.type)['mapset']
- if not self.mapset:
- grass.fatal(_("Map <%s> doesn't exist") % self.map)
- def parseRast3D(self):
- pass
- def parseVect(self):
- '''Read metadata from v.info
- @var self.md_grass dictionary of metadata from v.info
- # parse md from v.info flags=-g -e -t
- vinfo = Module(
- 'v.info',
- self.map,
- flags='get',
- quiet=True,
- stdout_=PIPE)
- self.md_grass = parse_key_val(vinfo.outputs.stdout)
- # parse md from v.info flag h (history of map in grass)
- rinfo_h = Module(
- 'v.info',
- self.map,
- flags='h',
- quiet=True,
- stdout_=PIPE)
- md_h_grass = rinfo_h.outputs.stdout
- buf = StringIO.StringIO(md_h_grass)
- line = buf.readline().splitlines()
- while str(line) != '[]':
- if str(line[0]).strip() != "":
- self.md_vinfo_h += line[0] + '\n'
- buf.close()
- # convert grass parsed date format to iso format
- # if date format is diverse from standard, use them
- self._createISODate('source_date')
- def _createISODate(self, key):
- '''Function for converting grass-generated date to iso format
- if the format of date is different to grass-generated format - use them and print warning
- try:
- date = datetime.strptime(self.md_grass[key], '%a %b %d %H:%M:%S %Y')
- self.md_grass['dateofcreation'] = date.strftime('%Y-%m-%d')
- except:
- grass.warning('date of creation: unknown date format')
- self.md_grass['dateofcreation'] = self.md_grass[key]
- def parseRast(self):
- '''Read metadata from r.info
- #self.md_grass dictionary of metadata from v.info
- #self.md_abstract string created by merge information from 'description' and 'source'
- rinfo = Module('r.info',
- self.map,
- flags='gre',
- quiet=True,
- stdout_=PIPE)
- self.md_grass = parse_key_val(rinfo.outputs.stdout)
- # convert date to iso format
- self._createISODate('date')
- # create abstract
- if self.md_grass['description'] != '""':
- self.md_abstract = self.md_grass['description'] + '; '
- if self.md_grass['source1'] != '""':
- self.md_abstract += self.md_grass['source1'] + '; '
- if self.md_grass['source2'] != '""':
- self.md_abstract += self.md_grass['source2'] + '; '
- self.md_abstract += 'Total cells: ' + self.md_grass['cells'] + '; '
- self.md_abstract += 'A range of values: min: ' + \
- self.md_grass['min'] + ' max: ' + self.md_grass['max']
- self.md_abstract.translate(None, """&<>"'""")
- def createGrassBasicISO(self, template=None):
- '''Create basic/essential profile based on ISO
- - unknown values are filling by n = '$NULL'
- try:
- self.md_grass['comments'] = self.md_grass['comments'].replace('\n', '; ')
- except:
- pass
- n = '$NULL'
- # jinja templates
- if template is None:
- self.template = os.path.join('templates', 'basicTemplate.xml')
- else:
- # OWSLib md object
- self.md.identification = MD_DataIdentification()
- self.md.dataquality = DQ_DataQuality()
- self.md.distribution = MD_Distribution()
- self.md.identification.extent = EX_Extent()
- self.md.identification.extent.boundingBox = EX_GeographicBoundingBox()
- # Metadata on metadata
- val = CI_ResponsibleParty()
- val.organization = n
- val.email = n
- val.role = n
- self.md.contact.append(val)
- # Identification/Resource Title
- self.md.identification.title = mdutil.replaceXMLReservedChar(self.md_grass['title'])
- self.md.datestamp = mdutil.replaceXMLReservedChar(date.today().isoformat())
- # Identification/Resource Type
- self.md.identification.identtype = 'dataset'
- # Identification/Unique Resource Identifier
- self.md.identifier = mdutil.replaceXMLReservedChar(str(uuid.uuid4()))
- self.md.identification.uricode.append(n)
- self.md.identification.uricodespace.append(n)
- # Geographic/BB
- self.md.identification.extent.boundingBox.minx = mdutil.replaceXMLReservedChar(self.md_grass['south'])
- self.md.identification.extent.boundingBox.maxx = mdutil.replaceXMLReservedChar(self.md_grass['north'])
- self.md.identification.extent.boundingBox.miny = mdutil.replaceXMLReservedChar(self.md_grass['west'])
- self.md.identification.extent.boundingBox.maxy = mdutil.replaceXMLReservedChar(self.md_grass['east'])
- # Conformity/Title
- self.md.dataquality.conformancetitle.append(
- 'GRASS basic metadata profile based on ISO 19115, 19139')
- # Conformity/Date:
- self.md.dataquality.conformancedate.append(mdutil.replaceXMLReservedChar(date.today().isoformat()))
- self.md.dataquality.conformancedatetype.append('publication')
- # Temporal/Date of creation
- val = CI_Date()
- val.date = self.md_grass['dateofcreation']
- val.type = 'creation'
- self.md.identification.date.append(val)
- self.md.identification.uom.append('m') # TODO
- # different metadata sources for vector and raster
- if self.type == 'cell':
- # Identification/Resource Abstract
- self.md.identification.abstract = mdutil.replaceXMLReservedChar(self.md_abstract)
- # Geographic/resolution
- self.md.identification.distance.append(mdutil.replaceXMLReservedChar(self.md_grass['nsres'])) # TODO for discuss
- # Quality/Lineage
- try:
- self.md.dataquality.lineage = mdutil.replaceXMLReservedChar(self.md_grass['comments']).replace('\n', '\\n')
- except:
- grass.warning('Native metadata *flag=comments* not found, dataquality.lineage filled by $NULL')
- self.md.dataquality.lineage = n
- self.md.identification.denominators.append(n)
- # Organisation/Responsible Party:
- val.organization = n # self.md_grass['creator']
- val.role = n
- val.email = n
- self.md.identification.contact.append(val)
- if self.type == 'vector':
- # TODO not enough sources for crate abstarce
- self.md.identification.abstract = mdutil.replaceXMLReservedChar(self.md_grass['name'])
- self.md.dataquality.lineage = mdutil.replaceXMLReservedChar(self.md_vinfo_h).replace('\n', '\\n')
- self.md.identification.denominators.append(self.md_grass['scale'])
- val.organization = n # mdutil.replaceXMLReservedChar(getpass.getuser())
- val.email = n
- val.role = n
- self.templatePathAbs = os.path.join(self.dirpath, self.template)
- def createGrassInspireISO(self, template=None):
- '''Create valid INSPIRE profile and fill it as much as possible by GRASS metadata. Missing values is $NULL
- -create basic md profile and add INSPIRE mandatory attributes
- self.schema_type = '_inspire.xml'
- # create basic profile
- self.createGrassBasicISO()
- self.template = os.path.join('templates', 'inspireTemplate.xml')
- else:
- n = '$NULL'
- if len(self.md.identification.distance) == 0:
- self.md.identification.distance.append(n) # TODO
- # Classification/Topic Category
- self.md.identification.topiccategory.append(n)
- self.md.identification.resourcelanguage.append(n)
- self.md.languagecode = n
- # Keyword/Keyword
- kw = {}
- kw['keywords'].append(n)
- kw['type'] = n
- kw['thesaurus']['date'] = n
- kw['thesaurus']['datetype'] = n
- kw['thesaurus']['title'] = n
- # remove value from basic profile
- self.md.dataquality.conformancetitle.pop()
- 'Commission Regulation (EU) No 1089/2010 of 23 November 2010 implementing Directive 2007/2/EC of the European Parliament and of the Council as regards interoperability of spatial data sets and services')
- # Identification/Resource Locator
- val = CI_OnlineResource()
- val.url = n
- self.md.distribution.online.append(val)
- # Conformity/Date
- self.md.dataquality.conformancedate.append(n)
- self.md.dataquality.conformancedatetype.append(n)
- # Conformity/Degree
- self.md.dataquality.conformancedegree.append('true')
- # Constraints/Limitations on public access
- self.md.identification.accessconstraints.append(n)
- self.md.identification.otherconstraints.append(n)
- # Constraints/Conditions for access and use-general
- self.md.identification.uselimitation.append(n)
- # Temporal/Temporal Extent
- self.md.identification.temporalextent_start = n
- self.md.identification.temporalextent_end = n
- # print self.templatePathAbs
- def readXML(self, xml_file):
- '''create instance of metadata(owslib) from xml file'''
- self.md = MD_Metadata(etree.parse(xml_file))
- def saveXML(self, path=None, xml_out_name=None, wxparent=None, overwrite=False):
- ''' Save init. record of OWSLib objects to ISO XML file'''
- # if output file name is None, use map name and add postfix
- if xml_out_name is None:
- xml_out_name = self.type + '_' + str(self.map).partition('@')[0] # + self.schema_type
- if not xml_out_name.lower().endswith('.xml'):
- xml_out_name += '.xml'
- if not path:
- path = os.path.join(mdutil.pathToMapset(), 'metadata')
- if not os.path.exists(path):
- print os.makedirs(path)
- path = os.path.join(path, xml_out_name)
- # generate xml using jinja tempaltes
- env = Environment(loader=FileSystemLoader(self.dirpath))
- env.globals.update(zip=zip)
- template = env.get_template(self.template)
- iso_xml = template.render(md=self.md)
- # write xml to flat file
- if wxparent != None:
- if os.path.isfile(path):
- if mdutil.yesNo(wxparent, 'Metadata file is exist. Do you want to overwrite file: %s?' % path, 'Overwrite dialog'):
- try:
- xml_file = open(path, "w")
- xml_file.write(iso_xml)
- xml_file.close()
- Module('g.message', message='metadata exported: \n\
- %s' % (str(path)))
- except IOError as e:
- print "I/O error({0}): {1}".format(e.errno, e.strerror)
- grass.fatal('error: cannot write xml to file')
- return path
- else:
- try:
- xml_file.close()
- # sys.exit()
- return path
- else:
- Module('g.message', message='Metadata file is exist: %s' % path)
- if overwrite:
- try:
- xml_file.close()
- Module('g.message', message='Metadata file has been overwritten')
- # sys.exit()
- return path
- else:
- Module('g.message', message='For overwriting use flag -o')
- return False
- def validate_inspire(self):
- return mdutil.isnpireValidator(self.md)
- def validate_basic(self):
- return mdutil.grassProfileValidator(self.md)
- def updateGrassMd(self, md):
- Update some parameters in r/v.support. This part need revision#TODO
- if self.type == "vector":
- if len(md.contact) > 0:
- _org = ''
- for co in md.contact:
- if co.organization != '':
- _org += co.organization + ', '
- if co.email != '':
- _org += co.email + ', '
- if co.role != '':
- _org += co.role + '; '
- Module('v.support',
- map=self.map,
- organization=_org,
- flags='r')
- if md.identification.date is not None:
- if len(md.identification.date) > 0:
- for d in md.identification.date:
- if d.type == 'creation':
- _date = d.date
- map=self.map,
- date=_date,
- flags='r')
- if md.identification.contact is not None:
- if len(md.identification.contact) > 0:
- _person = md.identification.contact.organization.pop()
- map=self.map,
- person=_person,
- flags='r')
- if md.identification.title is not (None or ''):
- _name = md.identification.title
- map=self.map,
- map_name=_name,
- flags='r')
- if len(md.identification.denominators) > 0:
- _scale = md.identification.denominators.pop()
- try:
- _scale = int(_scale)
- map=self.map,
- scale=_scale,
- flags='r')
- except:
- pass
- if md.identification.keywords is not None or len(md.identification.keywords) > 0:
- _comments = ''
- for k in md.identification.keywords:
- for kw in k["keywords"]:
- if kw != '':
- _comments += kw + ', '
- if k["thesaurus"]["title"] != '':
- _comments += k["thesaurus"]["title"] + ', '
- if k["thesaurus"]["date"] != '':
- _comments += k["thesaurus"]["date"] + ', '
- if k['thesaurus']['datetype'] != '':
- _comments += k['thesaurus']['datetype'] + ';'
- map=self.map,
- comment=_comments,
- flags='r')
-#------------------------------------------------------------------------ RASTER
- _title = md.identification.title
- Module('r.support',
- map=self.map,
- title=_title,
- overwrite=True)
- if md.dataquality.lineage is not (None or ''):
- _history = md.dataquality.lineage
- map=self.map, # append
- history=_history)
- _units = ''
- if len(md.identification.distance) > 0:
- _units += md.identification.distance.pop()
- if len(md.identification.uom) > 0:
- _units += md.identification.uom.pop()
- if _units != '':
- map=self.map,
- units=_units,
- overwrite=True)
- _comments = self.md_grass['description']
- if kw != '':
- map=self.map,
- description=_comments,
- overwrite=True)
Deleted: sandbox/krejcmat/src/mdutil.py
--- sandbox/krejcmat/src/mdutil.py 2014-10-26 16:02:57 UTC (rev 62380)
+++ sandbox/krejcmat/src/mdutil.py 2014-10-26 16:12:08 UTC (rev 62381)
@@ -1,387 +0,0 @@
- at brief Global methods for metadata management
-Methods:
--mdutil::removeNonAscii
--mdutil::yesNo
--mdutil::findBetween
--mdutil::replaceXMLReservedChar
--mdutil::pathToMapset
--mdutil::grassProfileValidator
--mdutil::isnpireValidator
-import string
-import os
-import wx
-def removeNonAscii(s):
- '''Removed non ascii char
- s = filter(lambda x: x in string.printable, s)
- return s
-def yesNo(parent, question, caption='Yes or no?'):
- dlg = wx.MessageDialog(parent, question, caption, wx.YES_NO | wx.ICON_QUESTION)
- result = dlg.ShowModal() == wx.ID_YES
- dlg.Destroy()
- return result
-def findBetween(s, first, last):
- try:
- start = s.index(first) + len(first)
- end = s.index(last, start)
- return s[start:end]
- except:
- return ""
-def replaceXMLReservedChar(inp):
- if inp:
- import re
- inp = re.sub('<', '<', inp)
- inp = re.sub('>', '>', inp)
- inp = re.sub('&', '&', inp)
- inp = re.sub('%', '%', inp)
- return inp
-def pathToMapset():
- gisenvDict = grass.gisenv()
- return os.path.join(gisenvDict['GISDBASE'], gisenvDict['LOCATION_NAME'], gisenvDict['MAPSET'])
-def grassProfileValidator(md):
- '''function for validation GRASS BASIC XML-OWSLib file-object'''
- result = {}
- result["status"] = "succeded"
- result["errors"] = []
- result["num_of_errors"] = "0"
- errors = 0
- if md.identification is None:
- result["errors"].append("gmd:CI_ResponsibleParty: Organization missing")
- result["errors"].append("gmd:CI_ResponsibleParty: E-mail missing")
- result["errors"].append("gmd:CI_ResponsibleParty: Role missing")
- result["errors"].append("gmd:md_DataIdentification: Title is missing")
- result["errors"].append("gmd:md_DataIdentification: Abstract is missing")
- result["errors"].append("gmd:md_ScopeCode: Resource Type is missing")
- result["errors"].append("gmd:RS_Identifier: Unique Resource Identifier is missing")
- result["errors"].append("gmd:EX_Extent: extent element is missing")
- result["errors"].append("gmd:EX_GeographicBoundingBox: bbox is missing")
- result["errors"].append("Both gmd:EX_TemporalExtent and gmd:CI_Date are missing")
- result["errors"].append("gmd:useLimitation is missing")
- errors += 20
- else:
- if len(md.identification.contact) < 1 or md.identification.contact is None:
- errors += 3
- else:
- if md.identification.contact[0].organization is (None or ''):
- errors += 1
- if md.identification.contact[0].email is (None or ''):
- errors += 1
- if md.identification.contact[0].role is (None or ''):
- errors += 1
- if md.identification.title is (None or ''):
- errors += 1
- if md.identification.abstract is (None or ''):
- errors += 1
- if md.identification.identtype is '':
- errors += 1
- if md.identification.extent is None:
- errors += 4
- else:
- if md.identification.extent.boundingBox is None:
- errors += 4
- else:
- if md.identification.extent.boundingBox.minx is (None or ''):
- result["errors"].append("gmd:westBoundLongitude: minx is missing")
- errors += 1
- if md.identification.extent.boundingBox.maxx is (None or ''):
- result["errors"].append("gmd:eastBoundLongitude: maxx is missing")
- errors += 1
- if md.identification.extent.boundingBox.miny is (None or ''):
- result["errors"].append("gmd:southBoundLatitude: miny is missing")
- errors += 1
- if md.identification.extent.boundingBox.maxy is (None or ''):
- result["errors"].append("gmd:northBoundLatitude: maxy is missing")
- errors += 1
- if len(md.identification.date) < 1 or (md.identification.temporalextent_start is (
- None or '') or md.identification.temporalextent_end is (None or '')):
- errors += 1
- if md.datestamp is (None or ''):
- result["errors"].append("gmd:dateStamp: Date is missing")
- errors += 1
- if md.identifier is (None or ''):
- result["errors"].append("gmd:identifier: Identifier is missing")
- errors += 1
- if md.contact is None:
- result["errors"].append("gmd:contact: Organization name is missing")
- result["errors"].append("gmd:contact: e-mail is missing")
- result["errors"].append("gmd:role: role is missing")
- errors += 3
- else:
- if md.contact[0].organization is (None or ''):
- errors += 1
- if md.contact[0].email is (None or ''):
- errors += 1
- if md.contact[0].role is (None or ''):
- errors += 1
- if errors > 0:
- result["status"] = "failed"
- result["num_of_errors"] = str(errors)
- return result
-def isnpireValidator(md):
- '''function for validation INSPIRE XML-OWSLib file-object'''
- result = {}
- errors = 0
- result["errors"].append("gmd:language: Resource Language is missing")
- result["errors"].append("gmd:topicCategory: TopicCategory is missing")
- result["errors"].append("gmd:md_Keywords: Keywords are missing")
- result["errors"].append("gmd:thesaurusName: Thesaurus Title is missing")
- result["errors"].append("gmd:thesaurusName: Thesaurus Date is missing")
- result["errors"].append("gmd:thesaurusName: Thesaurus Date Type is missing")
- result["errors"].append("gmd:accessConstraints is missing")
- result["errors"].append("gmd:otherConstraints is missing")
- errors += 20
- else:
- if md.identification.contact is None or len(md.identification.contact) < 1:
- errors += 3
- else:
- errors += 1
- errors += 1
- errors += 1
- errors += 1
- errors += 1
- if md.identification.identtype is (None or ''):
- errors += 1
- if md.identification.resourcelanguage is None:
- errors += 1
- else:
- if len(md.identification.resourcelanguage) < 1 or md.identification.resourcelanguage[0] == '':
- errors += 1
- if md.identification.uricode is None:
- errors += 1
- else:
- if len(md.identification.uricode) < 1 or md.identification.uricode[0] == '':
- errors += 1
- if md.identification.topiccategory is None:
- errors += 1
- else:
- if len(md.identification.topiccategory) < 1 or md.identification.topiccategory[0] == '':
- errors += 1
- if md.identification.keywords is None or len(md.identification.keywords) < 1:
- result["errors"].append("gmd:MD_Keywords: Keywords are missing")
- errors += 4
- else:
- if md.identification.keywords[0]['keywords'] is None or len(md.identification.keywords[0]['keywords']) < 1 \
- or str(md.identification.keywords[0]['keywords']) == "[u'']":
- errors += 1
- if md.identification.keywords[0]['thesaurus'] is None:
- errors += 3
- else:
- if md.identification.keywords[0]['thesaurus']['title'] is None \
- or len(md.identification.keywords[0]['thesaurus']['title']) < 1:
- errors += 1
- if md.identification.keywords[0]['thesaurus']['date'] is None \
- or len(md.identification.keywords[0]['thesaurus']['date']) < 1:
- errors += 1
- if md.identification.keywords[0]['thesaurus']['datetype'] is None \
- or len(md.identification.keywords[0]['thesaurus']['datetype']) < 1:
- errors += 1
- errors += 1
- else:
- "gmd:EX_GeographicBoundingBox: bbox is missing")
- errors += 1
- else:
- errors += 1
- errors += 1
- errors += 1
- errors += 1
- errors += 1
- if len(md.identification.uselimitation) < 1 or md.identification.uselimitation[0] == '':
- errors += 1
- if len(md.identification.accessconstraints) < 1 or md.identification.accessconstraints[0] == '':
- errors += 1
- if len(md.identification.otherconstraints) < 1 or md.identification.otherconstraints[0] == '':
- errors += 1
- if md.languagecode is (None or ''):
- result["errors"].append("gmd:LanguageCode: Language code missing")
- errors += 1
- errors += 1
- errors += 1
- if md.dataquality is (None or ''):
- result["errors"].append("gmd:LI_Lineage is missing")
- result["errors"].append("gmd:DQ_ConformanceResult: date is missing")
- result["errors"].append("gmd:DQ_ConformanceResult: date type is missing")
- # result["errors"].append("gmd:DQ_ConformanceResult: degree is missing")
- result["errors"].append("gmd:DQ_ConformanceResult: title is missing")
- errors += 4
- else:
- if md.dataquality.lineage is (None or ''):
- errors += 1
- if len(md.dataquality.conformancedate) < 1 or md.dataquality.conformancedate[0] == '':
- errors += 1
- if len(md.dataquality.conformancedatetype) < 1 or md.dataquality.conformancedatetype[0] == '':
- errors += 1
- # if len(md.dataquality.conformancedegree) < 1:
- # errors += 1
- if len(md.dataquality.conformancetitle) < 1 or md.dataquality.conformancetitle[0] == '':
- errors += 1
- if md.contact is None or len(md.contact) < 1:
- errors += 3
- else:
- errors += 1
- errors += 1
- errors += 1
- if errors > 0:
- return result
Deleted: sandbox/krejcmat/src/r.info.iso.py
--- sandbox/krejcmat/src/r.info.iso.py 2014-10-26 16:02:57 UTC (rev 62380)
+++ sandbox/krejcmat/src/r.info.iso.py 2014-10-26 16:12:08 UTC (rev 62381)
@@ -1,80 +0,0 @@
- at module r.info.iso
- at brief Module for creating metadata based on ISO from raster maps
-#%option G_OPT_R_MAP
-#% key: map
-#% label: Name of input raster map
-#% required: yes
-#%end
-#%flag
-#% key: o
-#% label: Allow to overwrite exist metadata
-#%end
-#%option
-#% key: profil
-#% label: Metadata profil based on ISO
-#% description: INSPIRE profile is not filled properly (unknown values are filled '$NULL')
-#% options: basic, inspire
-#% answer: basic
-#%end
-#% key: mdout
-#% label: Name of output metadata file
-#% required: no
-#%end
-#%option G_OPT_M_DIR
-#% key: destination
-#% label: Path to destination folder
-#% required: no
-#%end
-from mdgrass import *
-def main():
- if not options['destination']:
- destination = None
- else:
- destination = options['destination']
- if not options['mdout']:
- mdout = None
- else:
- mdout = options['mdout']
- md = GrassMD(options['map'], 'cell')
- if options['profil'] == 'inspire':
- md.createGrassInspireISO()
- xml_file = md.saveXML(path=destination,
- xml_out_name=mdout,
- overwrite=flags['o'])
- if xml_file is not False:
- md.readXML(xml_file)
- print md.validate_inspire()
- else:
- md.createGrassBasicISO()
- print md.validate_basic()
- options, flags = parser()
- main()
Deleted: sandbox/krejcmat/src/v.info.iso.py
--- sandbox/krejcmat/src/v.info.iso.py 2014-10-26 16:02:57 UTC (rev 62380)
+++ sandbox/krejcmat/src/v.info.iso.py 2014-10-26 16:12:08 UTC (rev 62381)
@@ -1,80 +0,0 @@
- at brief Module for creating metadata based on ISO from vector maps
-#%option G_OPT_V_MAP
-#% key: map
-#% label: Name of input vector map
-#% required: yes
-#%end
-#%flag
-#% key: o
-#%end
-#%option
-#% key: profil
-#% answer: basic
-#%end
-#% key: mdout
-#% required: no
-#%end
-#% required: no
-#%end
-def main():
- else:
- mdout = None
- else:
- md = GrassMD(options['map'], 'vector')
- else:
- main()
