[GRASS-SVN] r62384 - in grass/trunk/lib/python/pygrass: raster vector vector/testsuite
Sun Oct 26 10:18:06 PDT 2014
Author: zarch
Date: 2014-10-26 10:18:06 -0700 (Sun, 26 Oct 2014)
New Revision: 62384
   grass/trunk/lib/python/pygrass/raster/__init__.py
   grass/trunk/lib/python/pygrass/raster/abstract.py
   grass/trunk/lib/python/pygrass/vector/__init__.py
   grass/trunk/lib/python/pygrass/vector/abstract.py
   grass/trunk/lib/python/pygrass/vector/geometry.py
   grass/trunk/lib/python/pygrass/vector/table.py
   grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py
pygrass: fix other import after functions has been renamed
Modified: grass/trunk/lib/python/pygrass/raster/__init__.py
--- grass/trunk/lib/python/pygrass/raster/__init__.py	2014-10-26 17:00:51 UTC (rev 62383)
+++ grass/trunk/lib/python/pygrass/raster/__init__.py	2014-10-26 17:18:06 UTC (rev 62384)
@@ -22,7 +22,7 @@
 from grass.pygrass.errors import OpenError, must_be_open
 from grass.pygrass.gis.region import Region
-from grass.pygrass import functions
+from grass.pygrass import utils
 # import raster classes
@@ -664,7 +664,7 @@
         if not region:
             region = Region()
-        x, y = functions.coor2pixel(point.coords(), region)
+        x, y = utils.coor2pixel(point.coords(), region)
         return self[x][y]
Modified: grass/trunk/lib/python/pygrass/raster/abstract.py
--- grass/trunk/lib/python/pygrass/raster/abstract.py	2014-10-26 17:00:51 UTC (rev 62383)
+++ grass/trunk/lib/python/pygrass/raster/abstract.py	2014-10-26 17:18:06 UTC (rev 62384)
@@ -18,7 +18,7 @@
 # import pygrass modules
 from grass.pygrass.errors import must_be_open
 from grass.pygrass.shell.conversion import dict2html
@@ -294,7 +294,7 @@
     def _set_name(self, newname):
         """Private method to change the Raster name"""
-        if not functions.is_clean_name(newname):
+        if not utils.is_clean_name(newname):
             str_err = _("Map name {0} not valid")
             raise ValueError(str_err.format(newname))
         if self.exist():
@@ -347,7 +347,7 @@
         return (self.__getitem__(irow) for irow in range(self._rows))
     def _repr_png_(self):
-        return raw_figure(functions.r_export(self))
+        return raw_figure(utils.r_export(self))
     def exist(self):
         """Return True if the map already exist, and
@@ -361,10 +361,10 @@
         if self.name:
             if self.mapset == '':
-                mapset = functions.get_mapset_raster(self.name, self.mapset)
+                mapset = utils.get_mapset_raster(self.name, self.mapset)
                 self.mapset = mapset if mapset else ''
                 return True if mapset else False
-            return bool(functions.get_mapset_raster(self.name, self.mapset))
+            return bool(utils.get_mapset_raster(self.name, self.mapset))
         else:
             return False
@@ -391,7 +391,7 @@
         """Remove the map"""
         if self.is_open():
             self.close()
-        functions.remove(self.name, 'rast')
+        utils.remove(self.name, 'rast')
     def fullname(self):
         """Return the full name of a raster map: name at mapset"""
@@ -421,7 +421,7 @@
     def rename(self, newname):
         """Rename the map"""
         if self.exist():
-            functions.rename(self.name, newname, 'rast')
+            utils.rename(self.name, newname, 'rast')
         self._name = newname
     def set_from_rast(self, rastname='', mapset=''):
@@ -452,7 +452,7 @@
         if not region:
             region = Region()
-        row, col = functions.coor2pixel(point.coords(), region)
+        row, col = utils.coor2pixel(point.coords(), region)
         if col < 0 or col > region.cols or row < 0 or row > region.rows:
             return None
         line = self.get_row(int(row))
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py	2014-10-26 17:00:51 UTC (rev 62383)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py	2014-10-26 17:18:06 UTC (rev 62384)
@@ -212,7 +212,7 @@
         False
         >>> cens.close()
-        >>> from grass.pygrass.functions import copy, remove
+        >>> from grass.pygrass.utils import copy, remove
         >>> copy('census','mycensus','vect')
         >>> from grass.pygrass.modules.shortcuts import vector as v
         >>> v.colors(map='mycensus', color='population', column='TOTAL_POP')
Modified: grass/trunk/lib/python/pygrass/vector/abstract.py
--- grass/trunk/lib/python/pygrass/vector/abstract.py	2014-10-26 17:00:51 UTC (rev 62383)
+++ grass/trunk/lib/python/pygrass/vector/abstract.py	2014-10-26 17:18:06 UTC (rev 62384)
@@ -9,7 +9,7 @@
 import grass.lib.vector as libvect
 from grass.pygrass.vector.vector_type import MAPTYPE
 from grass.pygrass.errors import GrassError, OpenError, must_be_open
 from grass.pygrass.vector.table import DBlinks, Link
 from grass.pygrass.vector.find import PointFinder, BboxFinder, PolygonFinder
@@ -104,7 +104,7 @@
         """Private method to change the Vector name"""
         if self.exist():
@@ -268,7 +268,7 @@
         if self.exist():
             if not self.is_open():
-                functions.rename(self.name, newname, 'vect')
+                utils.rename(self.name, newname, 'vect')
             else:
                 raise GrassError("The map is open, not able to renamed it.")
@@ -281,10 +281,10 @@
         """Return if the Vector exists or not"""
         if self.name:
-                mapset = functions.get_mapset_vector(self.name, self.mapset)
+                mapset = utils.get_mapset_vector(self.name, self.mapset)
-            return bool(functions.get_mapset_vector(self.name, self.mapset))
+            return bool(utils.get_mapset_vector(self.name, self.mapset))
         else:
             return False
@@ -388,7 +388,7 @@
             self.layer = self.dblinks.by_layer(layer).layer
             self.table = self.dblinks.by_layer(layer).table()
             self.n_lines = self.table.n_rows()
-        self.writable = self.mapset == functions.getenv("MAPSET")
+        self.writable = self.mapset == utils.getenv("MAPSET")
         self.find = {'by_point': PointFinder(self.c_mapinfo, self.table,
                                              self.writable),
                      'by_box': BboxFinder(self.c_mapinfo, self.table,
@@ -417,7 +417,7 @@
         """Remove vector map"""
         if self.is_open():
             self.close()
-        functions.remove(self.name, 'vect')
+        utils.remove(self.name, 'vect')
     def build(self):
         """Close the vector map and build vector Topology"""
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py	2014-10-26 17:00:51 UTC (rev 62383)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py	2014-10-26 17:18:06 UTC (rev 62384)
@@ -176,7 +176,7 @@
         """Set value of a given column of a table attribute.
         >>> from grass.pygrass.vector import VectorTopo
         >>> copy('schools', 'myschools', 'vect')
         >>> schools = VectorTopo('myschools')
         >>> schools.open('r')
Modified: grass/trunk/lib/python/pygrass/vector/table.py
--- grass/trunk/lib/python/pygrass/vector/table.py	2014-10-26 17:00:51 UTC (rev 62383)
+++ grass/trunk/lib/python/pygrass/vector/table.py	2014-10-26 17:18:06 UTC (rev 62384)
@@ -25,7 +25,7 @@
 from grass.pygrass.gis import Mapset
 from grass.pygrass.errors import DBError
-from grass.pygrass.functions import table_exist
+from grass.pygrass.utils import table_exist
 from grass.script.db import db_table_in_vector
 from grass.script.core import warning
@@ -382,7 +382,7 @@
         >>> import sqlite3
         >>> path = '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'
         >>> cols_sqlite = Columns('mycensus',
         ...                       sqlite3.connect(get_path(path)))
@@ -441,7 +441,7 @@
         >>> import sqlite3
@@ -495,7 +495,7 @@
         >>> import sqlite3
@@ -536,7 +536,7 @@
         >>> import sqlite3
Modified: grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py	2014-10-26 17:00:51 UTC (rev 62383)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_vector3d.py	2014-10-26 17:18:06 UTC (rev 62384)
@@ -13,7 +13,7 @@
 from grass.pygrass.vector.geometry import Point
-from grass.pygrass.functions import get_mapset_vector
+from grass.pygrass.utils import get_mapset_vector
 def generate_coordinates(number, bbox=None, with_z=False):
