[GRASS-SVN] r62385 - in grass-addons/grass7: gui/wxpython/wx.metadata/r.info.iso gui/wxpython/wx.metadata/v.info.iso imagery/i.segment.hierarchical raster/r.modis/r.modis.download raster/r.modis/r.modis.import vector/v.class.ml vector/v.stats vector/v.what.strds
svn_grass at osgeo.org
Sun Oct 26 10:18:34 PDT 2014
Author: zarch
Date: 2014-10-26 10:18:34 -0700 (Sun, 26 Oct 2014)
New Revision: 62385
grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py
grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py
grass-addons/grass7/imagery/i.segment.hierarchical/i.segment.hierarchical.py
grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
grass-addons/grass7/vector/v.class.ml/v.class.ml.py
grass-addons/grass7/vector/v.stats/v.stats.py
grass-addons/grass7/vector/v.what.strds/v.what.strds.py
update import pygrass.functions to pygrass.utils
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py 2014-10-26 17:18:06 UTC (rev 62384)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/r.info.iso/r.info.iso.py 2014-10-26 17:18:34 UTC (rev 62385)
@@ -36,14 +36,14 @@
import sys
from grass.script import parser, fatal
-from grass.pygrass.functions import get_lib_path
+from grass.pygrass.utils import get_lib_path
def load_mdlib():
path = get_lib_path(modname='wx.metadata', libname='mdgrass')
if path is None:
fatal("Not able to find the metadata library directory")
sys.path.append(path)
def main():
# load metadata library
load_mdlib()
@@ -61,7 +61,7 @@
xml_file = md.saveXML(path=destination,
xml_out_name=name,
overwrite=os.getenv('GRASS_OVERWRITE', False))
if xml_file is not False:
md.readXML(xml_file)
print md.validate_inspire()
@@ -71,7 +71,7 @@
xml_out_name=name,
print md.validate_basic()
Modified: grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py
--- grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py 2014-10-26 17:18:06 UTC (rev 62384)
+++ grass-addons/grass7/gui/wxpython/wx.metadata/v.info.iso/v.info.iso.py 2014-10-26 17:18:34 UTC (rev 62385)
@@ -35,7 +35,7 @@
import sys
def load_mdlib():
@@ -60,7 +60,7 @@
xml_out_name=name,
@@ -70,7 +70,7 @@
xml_out_name=name,
Modified: grass-addons/grass7/imagery/i.segment.hierarchical/i.segment.hierarchical.py
--- grass-addons/grass7/imagery/i.segment.hierarchical/i.segment.hierarchical.py 2014-10-26 17:18:06 UTC (rev 62384)
+++ grass-addons/grass7/imagery/i.segment.hierarchical/i.segment.hierarchical.py 2014-10-26 17:18:34 UTC (rev 62385)
@@ -148,7 +148,7 @@
from grass.pygrass.modules.grid.split import split_region_tiles
from grass.pygrass.gis import Location
path = get_lib_path("i.segment.hierarchical", "")
if path is None:
Modified: grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
--- grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2014-10-26 17:18:06 UTC (rev 62384)
+++ grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2014-10-26 17:18:34 UTC (rev 62385)
@@ -5,7 +5,7 @@
# MODULE: r.in.modis.download
# AUTHOR(S): Luca Delucchi
-# PURPOSE: r.in.modis.download is an interface to pyModis for download
+# PURPOSE: r.in.modis.download is an interface to pyModis for download
# several tiles of MODIS produts from NASA ftp
# COPYRIGHT: (C) 2011 by Luca Delucchi
@@ -78,7 +78,7 @@
import sys
from datetime import *
import grass.script as grass
path = get_lib_path(modname='r.modis', libname='libmodis')
Modified: grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py
--- grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2014-10-26 17:18:06 UTC (rev 62384)
+++ grass-addons/grass7/raster/r.modis/r.modis.import/r.modis.import.py 2014-10-26 17:18:34 UTC (rev 62385)
@@ -5,7 +5,7 @@
# MODULE: r.modis.import
-# PURPOSE: r.modis.import is an interface to pyModis for import into
+# PURPOSE: r.modis.import is an interface to pyModis for import into
# GRASS GIS level 3 MODIS produts
@@ -90,7 +90,7 @@
import shutil
from datetime import date
if path is None:
Modified: grass-addons/grass7/vector/v.class.ml/v.class.ml.py
--- grass-addons/grass7/vector/v.class.ml/v.class.ml.py 2014-10-26 17:18:06 UTC (rev 62384)
+++ grass-addons/grass7/vector/v.class.ml/v.class.ml.py 2014-10-26 17:18:34 UTC (rev 62385)
@@ -146,7 +146,7 @@
#% multiple: no
#% description: choose a decomposition method (PCA, KernelPCA, ProbabilisticPCA, RandomizedPCA, FastICA, TruncatedSVD) and set the parameters using the | to separate the decomposition method from the parameters like: PCA|n_components=98
#% required: no
-#% answer:
+#% answer:
#%end
#%option
#% key: n_training
@@ -359,7 +359,7 @@
from sklearn.preprocessing import StandardScaler
from sklearn.svm import SVC
from grass.pygrass.messages import get_msgr
from grass.pygrass.vector import Vector
from grass.pygrass.modules import Module
@@ -509,8 +509,8 @@
with_std='with_std' in scapar)
if opt['decomposition']:
- decmp, params = (opt['decomposition'].split('|')
- if '|' in opt['decomposition']
+ decmp, params = (opt['decomposition'].split('|')
+ if '|' in opt['decomposition']
else (opt['decomposition'], ''))
kwargs = ({k: v for k, v in (p.split('=') for p in params.split(','))}
if params else {})
Modified: grass-addons/grass7/vector/v.stats/v.stats.py
--- grass-addons/grass7/vector/v.stats/v.stats.py 2014-10-26 17:18:06 UTC (rev 62384)
+++ grass-addons/grass7/vector/v.stats/v.stats.py 2014-10-26 17:18:34 UTC (rev 62385)
@@ -132,7 +132,7 @@
from grass.script.core import parser
-from grass.pygrass.functions import get_lib_path, get_mapset_raster
+from grass.pygrass.utils import get_lib_path, get_mapset_raster
from grass.pygrass.vector import VectorTopo, Vector
from grass.pygrass.vector.table import Link
Modified: grass-addons/grass7/vector/v.what.strds/v.what.strds.py
--- grass-addons/grass7/vector/v.what.strds/v.what.strds.py 2014-10-26 17:18:06 UTC (rev 62384)
+++ grass-addons/grass7/vector/v.what.strds/v.what.strds.py 2014-10-26 17:18:34 UTC (rev 62385)
@@ -43,7 +43,7 @@
import grass.temporal as tgis
-from grass.pygrass.functions import copy as gcopy
+from grass.pygrass.utils import copy as gcopy
from grass.pygrass.messages import Messenger
@@ -139,7 +139,7 @@
"type_b":dataset.get_temporal_type()}))
mapmatrizes = tgis.sample_stds_by_stds_topology("strds", "strds",
- strds_names,
+ strds_names,
strds_names[0], False,
None, "equal", False,
False)
