[GRASS-SVN] r61845 - grass/branches/releasebranch_7_0/lib/python/temporal
svn_grass at osgeo.org
Tue Sep 9 09:59:53 PDT 2014
Author: neteler
Date: 2014-09-09 09:59:52 -0700 (Tue, 09 Sep 2014)
New Revision: 61845
grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py
grass/branches/releasebranch_7_0/lib/python/temporal/register.py
temporal: more clear user messages
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py 2014-09-09 16:59:24 UTC (rev 61844)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/mapcalc.py 2014-09-09 16:59:52 UTC (rev 61845)
@@ -102,9 +102,9 @@
# Sample all inputs by the first input and create a sample matrix
if spatial:
- msgr.message(_("Start spatio-temporal sampling"))
+ msgr.message(_("Starting spatio-temporal sampling..."))
else:
- msgr.message(_("Start temporal sampling"))
+ msgr.message(_("Starting temporal sampling..."))
map_matrix = []
id_list = []
sample_map_list = []
@@ -166,7 +166,7 @@
if list is None:
dbif.close()
- msgr.message(_("No maps in input dataset"))
+ msgr.message(_("No maps registered in input dataset"))
return 0
map_name_list = []
@@ -182,7 +182,7 @@
if len(map_matrix) > 0:
- msgr.message(_("Start mapcalc computation"))
+ msgr.message(_("Starting mapcalc computation..."))
count = 0
# Get the number of samples
@@ -277,7 +277,7 @@
proc_list = []
# Register the new maps in the output space time dataset
- msgr.message(_("Start map registration in temporal database"))
+ msgr.message(_("Starting map registration in temporal database..."))
temporal_type, semantic_type, title, description = first_input.get_initial_values()
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/register.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/register.py 2014-09-09 16:59:24 UTC (rev 61844)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/register.py 2014-09-09 16:59:52 UTC (rev 61845)
@@ -166,7 +166,7 @@
# Store the ids of datasets that must be updated
datatsets_to_modify = {}
- msgr.message(_("Gathering map informations"))
+ msgr.message(_("Gathering map information..."))
for count in range(len(maplist)):
if count % 50 == 0:
@@ -291,7 +291,7 @@
# Gather the SQL insert statement
statement += map.insert(dbif=dbif, execute=False)
- # Sqlite3 performace better for huge datasets when committing in
+ # Sqlite3 performance is better for huge datasets when committing in
# small chunks
if dbif.dbmi.__name__ == "sqlite3":
if count % 100 == 0:
@@ -306,14 +306,14 @@
msgr.percent(num_maps, num_maps, 1)
if statement is not None and statement != "":
- msgr.message(_("Register maps in the temporal database"))
+ msgr.message(_("Registering maps in the temporal database..."))
dbif.execute_transaction(statement)
# Finally Register the maps in the space time dataset
if name and map_object_list:
count = 0
num_maps = len(map_object_list)
- msgr.message(_("Register maps in the space time raster dataset"))
+ msgr.message(_("Registering maps in the space time raster dataset..."))
for map in map_object_list:
if count % 50 == 0:
msgr.percent(count, num_maps, 1)
@@ -322,7 +322,7 @@
# Update the space time tables
- msgr.message(_("Update space time raster dataset"))
+ msgr.message(_("Updating space time raster dataset..."))
sp.update_from_registered_maps(dbif)
if update_cmd_list is True:
sp.update_command_string(dbif=dbif)
