[GRASS-SVN] r61846 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Tue Sep 9 11:28:57 PDT 2014
Author: neteler
Date: 2014-09-09 11:28:57 -0700 (Tue, 09 Sep 2014)
New Revision: 61846
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/lib/python/temporal/register.py
temporal: more clear user messages
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2014-09-09 16:59:52 UTC (rev 61845)
+++ grass/trunk/lib/python/temporal/aggregation.py 2014-09-09 18:28:57 UTC (rev 61846)
@@ -123,7 +123,7 @@
msgr = get_tgis_message_interface()
- msgr.verbose(_("Aggregate %s raster maps") % (len(inputs)))
+ msgr.verbose(_("Aggregating %s raster maps") % (len(inputs)))
output = "%s_%i" % (base, int(offset) + count)
mapset = get_current_mapset()
@@ -141,7 +141,7 @@
"use overwrite flag to overwrite"%({"name":new_map.get_name()})))
return
- msgr.verbose(_("Compute aggregation of maps between %(st)s - %(end)s" % {
+ msgr.verbose(_("Computing aggregation of maps between %(st)s - %(end)s" % {
'st': str(start), 'end': str(end)}))
# Create the r.series input file
@@ -166,7 +166,7 @@
if ret != 0:
dbif.close()
- msgr.fatal(_("Error while r.series computation"))
+ msgr.fatal(_("Error occurred in r.series computation"))
# Read the raster map data
new_map.load()
@@ -266,7 +266,7 @@
aggregation_list.append(map_layer.get_name())
if aggregation_list:
- msgr.verbose(_("Aggregate %(len)i raster maps from %(start)s to %(end)s") \
+ msgr.verbose(_("Aggregating %(len)i raster maps from %(start)s to %(end)s") \
%({"len":len(aggregation_list),
"start":str(granule.temporal_extent.get_start_time()),
"end":str(granule.temporal_extent.get_end_time())}))
@@ -284,7 +284,7 @@
if map_layer.map_exists() is True and overwrite is False:
msgr.fatal(_("Unable to perform aggregation. Output raster map <%(name)s> "\
- "exists and overwrite flag is not set"%({"name":output_name})))
+ "exists and overwrite flag was not set"%({"name":output_name})))
output_list.append(map_layer)
Modified: grass/trunk/lib/python/temporal/register.py
--- grass/trunk/lib/python/temporal/register.py 2014-09-09 16:59:52 UTC (rev 61845)
+++ grass/trunk/lib/python/temporal/register.py 2014-09-09 18:28:57 UTC (rev 61846)
@@ -174,7 +174,7 @@
if map.map_exists() is not True:
msgr.fatal(_("Unable to update %(t)s map <%(id)s>. "
- "The map does not exists.") %
+ "The map does not exist.") %
{'t': map.get_type(),
'id': map.get_map_id()})
@@ -388,12 +388,12 @@
start_time = increment_datetime_by_string(
start_time, increment, mult)
if start_time is None:
- msgr.fatal(_("Error in increment computation"))
+ msgr.fatal(_("Error occurred in increment computation"))
if interval:
end_time = increment_datetime_by_string(
start_time, increment, 1)
if end_time is None:
if map.get_layer():
msgr.debug(1, _("Set absolute valid time for map <%(id)s> with "
