[GRASS-SVN] r61848 - grass/trunk/temporal/t.unregister
svn_grass at osgeo.org
Tue Sep 9 14:21:26 PDT 2014
Author: huhabla
Date: 2014-09-09 14:21:26 -0700 (Tue, 09 Sep 2014)
New Revision: 61848
grass/trunk/temporal/t.unregister/t.unregister.html
temporal modules: Manual page update of r.unregister
Modified: grass/trunk/temporal/t.unregister/t.unregister.html
--- grass/trunk/temporal/t.unregister/t.unregister.html 2014-09-09 18:30:38 UTC (rev 61847)
+++ grass/trunk/temporal/t.unregister/t.unregister.html 2014-09-09 21:21:26 UTC (rev 61848)
@@ -1,7 +1,53 @@
<h2>DESCRIPTION</h2>
-TBD.
+This module is designed to unregister raster, 3d raster and vector map layers from space time datasets and the temporal database.
+<p>
+Map layer that should be unregistered from the temporal database can be specified as a list of comma separated map names or
+using a text file, that contains one map layer name per line. By default the map type that should be unregistered is set to raster.
+The option<em>type</em> must be used to specify 3d raster or vector map layer types.
+<h2>INPUT FILE FORMAT</h2>
+Specification of map names:
+<div class="code"><pre>
+prec_1
+prec_2
+prec_3
+prec_4
+prec_5
+prec_6
+</pre></div>
+<h2>EXAMPLE</h2>
+In this example we create 2 raster map layers that will be registered in a space time
+raster dataset named <em>precip_abs</em> using a monthly temporal granularity.
+We use t.unregister to unregister a map layer from the space time dataset and from the temporal database.
+r.mapcalc expr="prec_1 = 100"
+r.mapcalc expr="prec_2 = 200"
+r.mapcalc expr="prec_3 = 300"
+t.create type=strds temporaltype=absolute \
+ output=precip_abs title="Example" \
+ descr="Example"
+t.register -i type=rast input=precip_abs \
+ maps=prec_1,prec_2,prec_3 \
+ start="2001-01-01" increment="1 month"
+# We unregister raster map prec_1 from a space time dataset,
+# the raster map is still present in the temporal database
+t.unregister type=rast input=precip_abs maps=prec_1
+# We unregister raster map prec_2 from the temporal database, hence
+# the time stamp is removed
+t.unregister type=rast maps=prec_2
+</pre></div>
<h2>SEE ALSO</h2>
<em>
@@ -14,4 +60,3 @@
Sören Gebbert
<p><i>Last changed: $Date$</i>
