[GRASS-SVN] r61849 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Tue Sep 9 17:48:15 PDT 2014
Author: annakrat
Date: 2014-09-09 17:48:15 -0700 (Tue, 09 Sep 2014)
New Revision: 61849
grass/trunk/gui/wxpython/lmgr/datacatalog.py
wxGUI/catalog: fix using text entry dialog
Modified: grass/trunk/gui/wxpython/lmgr/datacatalog.py
--- grass/trunk/gui/wxpython/lmgr/datacatalog.py 2014-09-09 21:21:26 UTC (rev 61848)
+++ grass/trunk/gui/wxpython/lmgr/datacatalog.py 2014-09-10 00:48:15 UTC (rev 61849)
@@ -309,7 +309,7 @@
"""Rename levent with dialog"""
if (self.selected_layer):
self.old_name = self.GetItemText(self.selected_layer)
- self._textDialog(_('New name'), _('Rename map'), self.old_name)
+ self.new_name = self._getUserEntry(_('New name'), _('Rename map'), self.old_name)
self.rename()
def OnStartEditLabel(self, event):
@@ -336,7 +336,7 @@
def rename(self):
"""Rename layer"""
- if (self.selected_layer):
+ if self.selected_layer and self.new_name:
string = self.old_name+','+self.new_name
self.ChangeEnvironment(self.GetItemText(self.selected_location), self.GetItemText(self.selected_mapset))
renamed = 0
@@ -365,7 +365,10 @@
if (self.GetItemText(self.copy_type) != self.GetItemText(self.selected_type)): # copy raster to vector or vice versa
GError(_("Failed to copy layer: invalid type."), parent = self)
return
- self._textDialog(_('New name'), _('Copy map'), self.GetItemText(self.copy_layer)+'_copy')
+ self.new_name = self._getUserEntry(_('New name'), _('Copy map'),
+ self.GetItemText(self.copy_layer) + '_copy')
+ if not self.new_name:
+ return
if (self.GetItemText(self.copy_layer) == self.new_name):
GMessage(_("Layer was not copied: new layer has the same name"), parent=self)
return
@@ -474,14 +477,18 @@
else:
event.Veto()
- def _textDialog(self, message, title, value):
+ def _getUserEntry(self, message, title, value):
"""Dialog for simple text entry"""
dlg = TextEntryDialog(self, message, title)
dlg.SetValue(value)
- res = dlg.ShowModal()
- self.new_name = dlg.GetValue()
+ if dlg.ShowModal() == wx.ID_OK:
+ name = dlg.GetValue()
+ else:
+ name = None
dlg.Destroy()
+ return name
def _confirmDialog(self, question, title):
"""Confirm dialog"""
dlg = wx.MessageDialog(self, question, title, wx.YES_NO)
