[GRASS-SVN] r61850 - grass/trunk/vector/v.distance
svn_grass at osgeo.org
Wed Sep 10 11:46:24 PDT 2014
Author: mmetz
Date: 2014-09-10 11:46:24 -0700 (Wed, 10 Sep 2014)
New Revision: 61850
grass/trunk/vector/v.distance/distance.c
grass/trunk/vector/v.distance/main.c
grass/trunk/vector/v.distance/v.distance.html
v.distance: use geodesic distance for latlong
Modified: grass/trunk/vector/v.distance/distance.c
--- grass/trunk/vector/v.distance/distance.c 2014-09-10 00:48:15 UTC (rev 61849)
+++ grass/trunk/vector/v.distance/distance.c 2014-09-10 18:46:24 UTC (rev 61850)
@@ -56,9 +56,12 @@
double tmp_dist, tmp_x, tmp_y, tmp_z, tmp_along;
int ret = 1;
static struct line_pnts *iPoints = NULL;
+ static struct line_pnts *LPoints = NULL;
- if (!iPoints)
+ if (!iPoints) {
iPoints = Vect_new_line_struct();
+ LPoints = Vect_new_line_struct();
*dist = PORT_DOUBLE_MAX;
@@ -80,7 +83,6 @@
Vect_line_distance(TPoints, FPoints->x[0], FPoints->y[0],
FPoints->z[0], with_z, tx, ty,tz, dist,
NULL, talong);
/* point -> line and line -> line */
@@ -176,6 +178,45 @@
+ if (geodesic) {
+ if (*fx != *tx || *fy != *ty || (with_z && *fz != *tz)) {
+ Vect_reset_line(LPoints);
+ Vect_append_point(LPoints, *fx, *fy, *fz);
+ Vect_append_point(LPoints, *tx, *ty, *tz);
+ *dist = Vect_line_geodesic_length(LPoints);
+ /* falong */
+ if (FPoints->x[0] != *fx || FPoints->y[0] != *fy ||
+ (with_z && FPoints->z[0] != *fz)) {
+ fseg = Vect_line_distance(FPoints, *tx, *ty, *tz,
+ with_z, &tmp_x, &tmp_y, &tmp_z,
+ &tmp_dist, NULL, &tmp_along);
+ for (i = 0; i < fseg; i++)
+ Vect_append_point(LPoints, FPoints->x[i], FPoints->y[i],
+ FPoints->z[i]);
+ *falong = Vect_line_geodesic_length(LPoints);
+ /* talong */
+ if (TPoints->x[0] != *tx || TPoints->y[0] != *ty ||
+ (with_z && TPoints->z[0] != *tz)) {
+ tseg = Vect_line_distance(TPoints, *fx, *fy, *fz,
+ for (i = 0; i < tseg; i++)
+ Vect_append_point(LPoints, TPoints->x[i], TPoints->y[i],
+ TPoints->z[i]);
+ *talong = Vect_line_geodesic_length(LPoints);
return ret;
Modified: grass/trunk/vector/v.distance/main.c
--- grass/trunk/vector/v.distance/main.c 2014-09-10 00:48:15 UTC (rev 61849)
+++ grass/trunk/vector/v.distance/main.c 2014-09-10 18:46:24 UTC (rev 61850)
@@ -66,6 +66,7 @@
double fx, fy, fz, falong, fangle, tx, ty, tz, talong, tangle, dist;
double tmp_fx, tmp_fy, tmp_fz, tmp_falong, tmp_fangle, tmp_dist;
double tmp_tx, tmp_ty, tmp_tz, tmp_talong, tmp_tangle;
+ int geodesic;
struct field_info *Fi, *toFi;
dbString stmt, dbstr;
dbDriver *driver, *to_driver;
@@ -236,6 +237,8 @@
if (flag.all->answer)
do_all = TRUE;
+ geodesic = G_projection() == PROJECTION_LL;
/* Read upload and column options */
/* count */
i = 0;
@@ -689,7 +692,7 @@
line2line(FPoints, ftype, TPoints, ttype,
&tmp_fx, &tmp_fy, &tmp_fz, &tmp_falong, &tmp_fangle,
&tmp_tx, &tmp_ty, &tmp_tz, &tmp_talong, &tmp_tangle,
- &tmp_dist, with_z, 0);
+ &tmp_dist, with_z, geodesic);
if (tmp_dist > max || tmp_dist < min)
continue; /* not in threshold */
@@ -763,7 +766,7 @@
line2area(&To, FPoints, ftype, aList->id[i], &aList->box[i],
@@ -962,7 +965,7 @@
line2area(&From, TPoints, ttype, area, &fbox,
@@ -1048,7 +1051,7 @@
poly = line2area(&From, TPoints, ttype, area, &fbox,
if (poly == 3) {
/* 'to' outer ring is outside 'from' area,
@@ -1072,7 +1075,7 @@
poly = line2area(&To, FPoints, ttype, tarea, &aList->box[i],
/* inside isle ? */
poly = poly == 2;
@@ -1092,7 +1095,7 @@
&tmp2_tx, &tmp2_ty, &tmp2_tz, &tmp2_talong, &tmp2_tangle,
&tmp2_fx, &tmp2_fy, &tmp2_fz, &tmp2_falong, &tmp2_fangle,
- &tmp2_dist, with_z, 0);
+ &tmp2_dist, with_z, geodesic);
if (tmp2_dist < tmp_dist) {
tmp_dist = tmp2_dist;
Modified: grass/trunk/vector/v.distance/v.distance.html
--- grass/trunk/vector/v.distance/v.distance.html 2014-09-10 00:48:15 UTC (rev 61849)
+++ grass/trunk/vector/v.distance/v.distance.html 2014-09-10 18:46:24 UTC (rev 61850)
@@ -53,11 +53,9 @@
<p>The upload <b>column</b>(s) must already exist. Create one with
<em><a href="v.db.addcolumn.html">v.db.addcolumn</a></em>.
-<!-- needs Vect_line_geodesic_distance()
<p>In lat-long locations <em>v.distance</em> gives distances
-(<em>dist</em> and <em>to_along</em>) not in degrees but in meters
-calculated as geodesic distances on a sphere.
+(<em>dist</em>, <em>from_along</em>, and <em>to_along</em>) not in
+degrees but in meters calculated as geodesic distances on a sphere.
<h2>EXAMPLES</h2>
