[GRASS-SVN] r61851 - in grass/trunk/lib/gis: . colors
svn_grass at osgeo.org
Wed Sep 10 12:14:55 PDT 2014
Author: mmetz
Date: 2014-09-10 12:14:55 -0700 (Wed, 10 Sep 2014)
New Revision: 61851
grass/trunk/lib/gis/colors/ndvi
grass/trunk/lib/gis/flate.c
grass/trunk/lib/gis/getl.c
grass/trunk/lib/gis/gisinit.c
grass/trunk/lib/gis/intersect.c
grass/trunk/lib/gis/ll_scan.c
grass/trunk/lib/gis/wind_format.c
libgis: fix G_intersect_line_segments()
Modified: grass/trunk/lib/gis/colors/ndvi
--- grass/trunk/lib/gis/colors/ndvi 2014-09-10 18:46:24 UTC (rev 61850)
+++ grass/trunk/lib/gis/colors/ndvi 2014-09-10 19:14:55 UTC (rev 61851)
@@ -1,21 +1,12 @@
--1.000 5 24 82
--0.300 5 24 82
--0.180 255 255 255
- 0.000 255 255 255
- 0.025 206 197 180
- 0.075 191 163 124
- 0.125 179 174 96
- 0.150 163 181 80
- 0.175 144 170 60
- 0.233 166 195 29
- 0.266 135 183 3
- 0.333 121 175 1
- 0.366 101 163 0
- 0.433 78 151 0
- 0.466 43 132 4
- 0.550 0 114 0
- 0.650 0 90 1
- 0.750 0 73 0
- 0.850 0 56 0
- 0.950 0 31 0
- 1.000 0 0 0
+-200 white
+-1.0000 white
+-0.3000 0:0:100
+-0.2000 205:193:173
+ 0.0000 150:150:150
+ 0.1000 120:100:51
+ 0.3000 120:200:100
+ 0.4000 28:144:3
+ 0.6000 6:55:0
+ 0.8000 10:30:25
+ 1.0000 100:0:60
+ 200 100:0:60
Modified: grass/trunk/lib/gis/flate.c
--- grass/trunk/lib/gis/flate.c 2014-09-10 18:46:24 UTC (rev 61850)
+++ grass/trunk/lib/gis/flate.c 2014-09-10 19:14:55 UTC (rev 61851)
@@ -333,7 +333,7 @@
/* zlib default: Z_DEFAULT_COMPRESSION = -1, equivalent to 6
* as used here, 1 gives the best compromise between speed and compression */
err = deflateInit(&c_stream,
- (G__.compression_level < -1 || G__.compression_level > 9)
+ (G__.compression_level < -1 || G__.compression_level > 9)
? 1 : G__.compression_level);
/* If there was an error initializing, return -1 */
Modified: grass/trunk/lib/gis/getl.c
--- grass/trunk/lib/gis/getl.c 2014-09-10 18:46:24 UTC (rev 61850)
+++ grass/trunk/lib/gis/getl.c 2014-09-10 19:14:55 UTC (rev 61851)
@@ -55,7 +55,7 @@
* must be allocated for the string buffer.
* \param buf: string buffer to receive read data, at least <i>n</i> must be allocated
- * \param n: maximum number of bytes to read
+ * \param n: number of bytes allocated for buf, at most <i>n - 1</i> are read
* \param fd: file descriptor structure
* \return 1 on success
@@ -67,7 +67,7 @@
int c;
int ret = 1;
- while (i < n - 1) {
+ while (i < n) {
c = fgetc(fd);
if (c == EOF) {
@@ -88,12 +88,20 @@
break;
+ if (i < n - 1) {
+ buf[i] = c;
- buf[i] = c;
i++;
- buf[i] = '\0';
+ if (i < n)
+ buf[i] = '\0';
+ else {
+ buf[n - 1] = '\0';
+ ret = -1;
return ret;
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c 2014-09-10 18:46:24 UTC (rev 61850)
+++ grass/trunk/lib/gis/gisinit.c 2014-09-10 19:14:55 UTC (rev 61851)
@@ -117,8 +117,13 @@
/* byte order */
G__.little_endian = G_is_little_endian();
+ /* zlib compression level for raster maps */
zlib = getenv("GRASS_ZLIB_LEVEL");
- G__.compression_level = (zlib && *zlib && isdigit(*zlib)) ? atoi(zlib) : -2;
+ G__.compression_level = (zlib && *zlib) ? atoi(zlib) : 1;
+ if (zlib && G__.compression_level == 0) {
+ G_warning(_("Raster compression disabled with %s=%s"),
+ "GRASS_ZLIB_LEVEL", zlib);
initialized = 1;
Modified: grass/trunk/lib/gis/intersect.c
--- grass/trunk/lib/gis/intersect.c 2014-09-10 18:46:24 UTC (rev 61850)
+++ grass/trunk/lib/gis/intersect.c 2014-09-10 19:14:55 UTC (rev 61851)
@@ -75,7 +75,7 @@
#define D1 ((bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2))
#define D2 ((ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1))
-#define SWAP(x,y) {int t; t=x; x=y; y=t;}
+#define SWAP(x,y) {double t; t=x; x=y; y=t;}
int G_intersect_line_segments(double ax1, double ay1, double ax2, double ay2,
double bx1, double by1, double bx2, double by2,
@@ -83,6 +83,16 @@
double d;
+ if (ax1 > ax2 || (ax1 == ax2 && ay1 > ay2)) {
+ SWAP(ax1, ax2)
+ SWAP(ay1, ay2)
+ if (bx1 > bx2 || (bx1 == bx2 && by1 > by2)) {
+ SWAP(bx1, bx2)
+ SWAP(by1, by2)
d = D;
if (d) { /* lines are not parallel */
@@ -94,31 +104,74 @@
return (*ra >= 0.0 && *ra <= 1.0 && *rb >= 0.0 && *rb <= 1.0);
- if (D1 || D2)
- return -1; /* lines are parallel, not colinear */
+ /* lines are parallel */
+ if (D1 || D2) {
+ return 0;
- if (ax1 > ax2) {
- SWAP(ax1, ax2)
+ /* segments are colinear. check for overlap */
+ /* Collinear vertical */
+ if (ax1 == ax2) {
+ if (ay1 > by2)
+ return 0;
+ if (ay2 < by1)
+ return 0;
+ /* there is overlap */
+ if (ay1 == by2) {
+ *x = ax1;
+ *y = ay1;
+ return 1; /* endpoints only */
+ if (ay2 == by1) {
+ *x = ax2;
+ *y = ay2;
+ /* overlap, no single intersection point */
+ if (ay1 > by1 && ay1 < by2) {
+ *x = ax1;
+ *y = ay1;
+ else {
+ *x = ax2;
+ *y = ay2;
+ return -1;
- if (bx1 > bx2) {
- SWAP(bx1, bx2)
- if (ax1 > bx2)
+ else {
+ if (ax1 > bx2)
+ return 0;
+ if (ax2 < bx1)
+ return 0;
+ if (ax1 == bx2) {
+ *x = ax1;
+ *y = ay1;
+ if (ax2 == bx1) {
+ *x = ax2;
+ *y = ay2;
+ if (ax1 > bx1 && ax1 < bx2) {
+ *x = ax1;
+ *y = ay1;
+ else {
+ *x = ax2;
+ *y = ay2;
return -1;
- if (ax2 < bx1)
- return -1;
- /* there is overlap */
- if (ax1 == bx2) {
- *x = ax1;
- *y = ay1;
- return 1; /* at endpoints only */
- if (ax2 == bx1) {
- *x = ax2;
- *y = ay2;
- return 2; /* colinear with overlap on an interval, not just a single point */
+ return 0; /* should not be reached */
Modified: grass/trunk/lib/gis/ll_scan.c
--- grass/trunk/lib/gis/ll_scan.c 2014-09-10 18:46:24 UTC (rev 61850)
+++ grass/trunk/lib/gis/ll_scan.c 2014-09-10 19:14:55 UTC (rev 61851)
@@ -48,7 +48,7 @@
int G_lon_scan(const char *buf, double *lon)
- return scan_ll(buf, "we", lon, 180);
+ return scan_ll(buf, "we", lon, 360);
int G_llres_scan(const char *buf, double *res)
Modified: grass/trunk/lib/gis/wind_format.c
--- grass/trunk/lib/gis/wind_format.c 2014-09-10 18:46:24 UTC (rev 61850)
+++ grass/trunk/lib/gis/wind_format.c 2014-09-10 19:14:55 UTC (rev 61851)
@@ -87,7 +87,7 @@
if (full_prec)
sprintf(buf, "%.15g", value);
else
- sprintf(buf, "%.8f", value);
+ sprintf(buf, "%.8g", value);
G_trim_decimal(buf);
