[GRASS-SVN] r61852 - in grass/trunk/lib/gis: . colors
svn_grass at osgeo.org
Wed Sep 10 12:29:17 PDT 2014
Author: mmetz
Date: 2014-09-10 12:29:17 -0700 (Wed, 10 Sep 2014)
New Revision: 61852
grass/trunk/lib/gis/colors/ndvi
grass/trunk/lib/gis/flate.c
grass/trunk/lib/gis/getl.c
grass/trunk/lib/gis/gisinit.c
grass/trunk/lib/gis/ll_scan.c
grass/trunk/lib/gis/wind_format.c
libgis: partially revert r61851
Modified: grass/trunk/lib/gis/colors/ndvi
--- grass/trunk/lib/gis/colors/ndvi 2014-09-10 19:14:55 UTC (rev 61851)
+++ grass/trunk/lib/gis/colors/ndvi 2014-09-10 19:29:17 UTC (rev 61852)
@@ -1,12 +1,21 @@
--200 white
--1.0000 white
--0.3000 0:0:100
--0.2000 205:193:173
- 0.0000 150:150:150
- 0.1000 120:100:51
- 0.3000 120:200:100
- 0.4000 28:144:3
- 0.6000 6:55:0
- 0.8000 10:30:25
- 1.0000 100:0:60
- 200 100:0:60
+-1.000 5 24 82
+-0.300 5 24 82
+-0.180 255 255 255
+ 0.000 255 255 255
+ 0.025 206 197 180
+ 0.075 191 163 124
+ 0.125 179 174 96
+ 0.150 163 181 80
+ 0.175 144 170 60
+ 0.233 166 195 29
+ 0.266 135 183 3
+ 0.333 121 175 1
+ 0.366 101 163 0
+ 0.433 78 151 0
+ 0.466 43 132 4
+ 0.550 0 114 0
+ 0.650 0 90 1
+ 0.750 0 73 0
+ 0.850 0 56 0
+ 0.950 0 31 0
+ 1.000 0 0 0
Modified: grass/trunk/lib/gis/flate.c
--- grass/trunk/lib/gis/flate.c 2014-09-10 19:14:55 UTC (rev 61851)
+++ grass/trunk/lib/gis/flate.c 2014-09-10 19:29:17 UTC (rev 61852)
@@ -333,7 +333,7 @@
/* zlib default: Z_DEFAULT_COMPRESSION = -1, equivalent to 6
* as used here, 1 gives the best compromise between speed and compression */
err = deflateInit(&c_stream,
- (G__.compression_level < -1 || G__.compression_level > 9)
+ (G__.compression_level < -1 || G__.compression_level > 9)
? 1 : G__.compression_level);
/* If there was an error initializing, return -1 */
Modified: grass/trunk/lib/gis/getl.c
--- grass/trunk/lib/gis/getl.c 2014-09-10 19:14:55 UTC (rev 61851)
+++ grass/trunk/lib/gis/getl.c 2014-09-10 19:29:17 UTC (rev 61852)
@@ -55,7 +55,7 @@
* must be allocated for the string buffer.
* \param buf: string buffer to receive read data, at least <i>n</i> must be allocated
- * \param n: number of bytes allocated for buf, at most <i>n - 1</i> are read
+ * \param n: maximum number of bytes to read
* \param fd: file descriptor structure
* \return 1 on success
@@ -67,7 +67,7 @@
int c;
int ret = 1;
- while (i < n) {
+ while (i < n - 1) {
c = fgetc(fd);
if (c == EOF) {
@@ -88,20 +88,12 @@
break;
- if (i < n - 1) {
- buf[i] = c;
+ buf[i] = c;
i++;
+ buf[i] = '\0';
- if (i < n)
- buf[i] = '\0';
- else {
- buf[n - 1] = '\0';
- ret = -1;
return ret;
Modified: grass/trunk/lib/gis/gisinit.c
--- grass/trunk/lib/gis/gisinit.c 2014-09-10 19:14:55 UTC (rev 61851)
+++ grass/trunk/lib/gis/gisinit.c 2014-09-10 19:29:17 UTC (rev 61852)
@@ -117,13 +117,8 @@
/* byte order */
G__.little_endian = G_is_little_endian();
- /* zlib compression level for raster maps */
zlib = getenv("GRASS_ZLIB_LEVEL");
- G__.compression_level = (zlib && *zlib) ? atoi(zlib) : 1;
- if (zlib && G__.compression_level == 0) {
- G_warning(_("Raster compression disabled with %s=%s"),
- "GRASS_ZLIB_LEVEL", zlib);
+ G__.compression_level = (zlib && *zlib && isdigit(*zlib)) ? atoi(zlib) : -2;
initialized = 1;
Modified: grass/trunk/lib/gis/ll_scan.c
--- grass/trunk/lib/gis/ll_scan.c 2014-09-10 19:14:55 UTC (rev 61851)
+++ grass/trunk/lib/gis/ll_scan.c 2014-09-10 19:29:17 UTC (rev 61852)
@@ -48,7 +48,7 @@
int G_lon_scan(const char *buf, double *lon)
- return scan_ll(buf, "we", lon, 360);
+ return scan_ll(buf, "we", lon, 180);
int G_llres_scan(const char *buf, double *res)
Modified: grass/trunk/lib/gis/wind_format.c
--- grass/trunk/lib/gis/wind_format.c 2014-09-10 19:14:55 UTC (rev 61851)
+++ grass/trunk/lib/gis/wind_format.c 2014-09-10 19:29:17 UTC (rev 61852)
@@ -87,7 +87,7 @@
if (full_prec)
sprintf(buf, "%.15g", value);
else
- sprintf(buf, "%.8g", value);
+ sprintf(buf, "%.8f", value);
G_trim_decimal(buf);
