[GRASS-SVN] r61874 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Fri Sep 12 06:35:27 PDT 2014
Author: zarch
Date: 2014-09-12 06:35:27 -0700 (Fri, 12 Sep 2014)
New Revision: 61874
grass/trunk/lib/python/pygrass/vector/geometry.py
pygrass: Fix negative indexes to select geometry features and fix get_centroid
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2014-09-12 13:27:33 UTC (rev 61873)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2014-09-12 13:35:27 UTC (rev 61874)
@@ -278,7 +278,7 @@
if table is not None:
self.attrs = Attrs(self.cat, table, writable)
- if self.id is not None and self.c_mapinfo is not None and read:
+ if self.id and self.c_mapinfo is not None and read:
self.read()
@property
@@ -295,8 +295,9 @@
def read(self):
"""Read and set the coordinates of the centroid from the vector map,
using the centroid_id and calling the Vect_read_line C function"""
- ftype, c_points, c_cats = c_read_line(self.id, self.c_mapinfo,
- self.c_points, self.c_cats)
+ self.id, ftype, c_points, c_cats = c_read_line(self.id, self.c_mapinfo,
+ self.c_points,
+ self.c_cats)
class Point(Geo):
@@ -1368,12 +1369,13 @@
:type centroid: a Centroid object
centroid_id = libvect.Vect_get_area_centroid(self.c_mapinfo, self.id)
- if centroid:
- centroid.id = centroid_id
- centroid.read()
- return centroid
- return Centroid(v_id=centroid_id, c_mapinfo=self.c_mapinfo,
- area_id=self.id)
+ if centroid_id:
+ if centroid:
+ centroid.id = centroid_id
+ centroid.read()
+ return centroid
+ return Centroid(v_id=centroid_id, c_mapinfo=self.c_mapinfo,
+ area_id=self.id)
def num_isles(self):
return libvect.Vect_get_area_num_isles(self.c_mapinfo, self.id)
@@ -1502,8 +1504,9 @@
self.boundary = self.get_points(line)
self.centroid = self.get_centroid(centroid)
#self.isles = self.get_isles(isles)
- libvect.Vect_read_line(self.c_mapinfo, None, self.c_cats,
- self.centroid.id)
+ if self.centroid:
+ libvect.Vect_read_line(self.c_mapinfo, None, self.c_cats,
+ self.centroid.id)
@@ -1563,7 +1566,7 @@
raise IndexError('Index out of range')
if feature_id > 0:
ftype = libvect.Vect_read_line(c_mapinfo, c_points, c_cats, feature_id)
- return ftype, c_points, c_cats
+ return feature_id, ftype, c_points, c_cats
else:
raise ValueError('The index must be >0, %r given.' % feature_id)
@@ -1574,8 +1577,8 @@
c_points = c_points if c_points else ctypes.pointer(libvect.line_pnts())
c_cats = c_cats if c_cats else ctypes.pointer(libvect.line_cats())
- ftype, c_points, c_cats = c_read_line(feature_id, c_mapinfo,
- c_points, c_cats)
+ feature_id, ftype, c_points, c_cats = c_read_line(feature_id, c_mapinfo,
+ c_points, c_cats)
if GV_TYPE[ftype]['obj'] is not None:
return GV_TYPE[ftype]['obj'](v_id=feature_id, c_mapinfo=c_mapinfo,
c_points=c_points, c_cats=c_cats,
