[GRASS-SVN] r61875 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Fri Sep 12 06:36:23 PDT 2014
Author: zarch
Date: 2014-09-12 06:36:23 -0700 (Fri, 12 Sep 2014)
New Revision: 61875
grass/trunk/lib/python/pygrass/vector/__init__.py
grass/trunk/lib/python/pygrass/vector/find.py
pygrass: Fix and update doctest
Modified: grass/trunk/lib/python/pygrass/vector/__init__.py
--- grass/trunk/lib/python/pygrass/vector/__init__.py 2014-09-12 13:35:27 UTC (rev 61874)
+++ grass/trunk/lib/python/pygrass/vector/__init__.py 2014-09-12 13:36:23 UTC (rev 61875)
@@ -72,12 +72,12 @@
def __iter__(self):
- >>> mun = Vector('census')
- >>> mun.open()
- >>> features = [feature for feature in mun]
+ >>> cens = Vector('census')
+ >>> cens.open(mode='r')
+ >>> features = [feature for feature in cens]
>>> features[:3]
[Boundary(v_id=None), Boundary(v_id=None), Boundary(v_id=None)]
- >>> mun.close()
+ >>> cens.close()
@@ -88,13 +88,13 @@
def next(self):
- >>> mun.open()
- >>> mun.next()
+ >>> cens.next()
Boundary(v_id=None)
- >>> mun.next()
+ >>> cens.next()
Boundary(v_id=None)
- >>> mun.close()
+ >>> cens.close()
@@ -152,6 +152,12 @@
>>> new.write(point0, ('pub', ))
>>> new.write(point1, ('resturnat', ))
+ commit the db changes ::
+ >>> new.table.conn.commit()
+ >>> new.table.execute().fetchall()
+ [(1, u'pub'), (2, u'resturnat')]
close the vector map ::
>>> new.close()
@@ -160,15 +166,15 @@
then play with the map ::
- >>> new.open()
+ >>> new.open(mode='r')
>>> new.read(1)
Point(636981.336043, 256517.602235)
>>> new.read(2)
Point(637209.083058, 257970.129540)
>>> new.read(1).attrs['name']
u'pub'
- >>> new.read(2).attrs['cat', 'name']
- (2, u'resturnat')
+ >>> new.read(2).attrs['name']
+ u'resturnat'
>>> new.close()
>>> new.remove()
@@ -205,7 +211,7 @@
Color table stored in the vector's attribute table well be not checked
- >>> cens.open()
>>> cens.has_color_table()
False
@@ -214,9 +220,9 @@
>>> copy('census','mycensus','vect')
>>> from grass.pygrass.modules.shortcuts import vector as v
>>> v.colors(map='mycensus', color='population', column='TOTAL_POP')
+ Module('v.colors')
>>> mycens = Vector('mycensus')
- >>> mycens.open()
+ >>> mycens.open(mode='r')
>>> mycens.has_color_table()
True
>>> mycens.close()
@@ -236,7 +242,7 @@
Open a vector map using the *with statement*: ::
- >>> with VectorTopo('schools') as schools:
+ >>> with VectorTopo('schools', mode='r') as schools:
... for school in schools[:3]:
... print school.attrs['NAMESHORT']
@@ -259,11 +265,11 @@
def __getitem__(self, key):
- >>> mun = VectorTopo('census')
- >>> mun.open()
- >>> mun[:3]
+ >>> cens = VectorTopo('census')
+ >>> cens[:3]
[Boundary(v_id=1), Boundary(v_id=2), Boundary(v_id=3)]
- >>> mun.close()
+ >>> cens.close()
@@ -296,16 +302,16 @@
- >>> cens = VectorTopo('boundary_municp_sqlite')
- >>> cens.open()
>>> cens.num_primitive_of('point')
0
>>> cens.num_primitive_of('line')
0
>>> cens.num_primitive_of('centroid')
- 3579
+ 2537
>>> cens.num_primitive_of('boundary')
- 5128
+ 6383
>>> cens.close()
@@ -323,26 +329,23 @@
*update_lines*, *update_nodes*, *volumes*
:type vtype: str
- >>> cens.open()
>>> cens.number_of("areas")
- 3579
+ 2547
>>> cens.number_of("islands")
- 2629
+ 49
>>> cens.number_of("holes")
0
>>> cens.number_of("lines")
- 8707
+ 8920
>>> cens.number_of("nodes")
- 4178
+ 3885
>>> cens.number_of("pizza")
... # doctest: +ELLIPSIS +NORMALIZE_WHITESPACE
- ValueError: vtype not supported, use one of:
- 'areas', 'dblinks', 'faces', 'holes', 'islands', 'kernels',
- 'line_points', 'lines', 'nodes', 'updated_lines', 'updated_nodes',
- 'volumes'
+ ValueError: vtype not supported, use one of: 'areas', ...
>>> cens.close()
@@ -376,23 +379,23 @@
full features
:type idonly: bool
- >>> cens = VectorTopo('census')
- >>> cens.open()
+ >>> cens = VectorTopo('census', mode='r')
>>> big = [area for area in cens.viter('areas')
- ... if area.alive() and area.area >= 10000]
+ ... if area.alive() and area.area() >= 10000]
>>> big[:3]
- [Area(1), Area(2), Area(3)]
+ [Area(5), Area(6), Area(13)]
to sort the result in a efficient way, use: ::
>>> from operator import methodcaller as method
- >>> big.sort(key = method('area'), reverse = True) # sort the list
+ >>> big.sort(key=method('area'), reverse=True) # sort the list
>>> for area in big[:3]:
... print area, area.area()
- Area(3102) 697521857.848
- Area(2682) 320224369.66
- Area(2552) 298356117.948
+ Area(2099) 5392751.5304
+ Area(2171) 4799921.30863
+ Area(495) 4055812.49695
>>> cens.close()
@@ -413,18 +416,18 @@
def rewind(self):
"""Rewind vector map to cause reads to start at beginning. ::
- >>> mun = VectorTopo('boundary_municp_sqlite')
- >>> mun.open()
- >>> mun.next()
+ >>> cens.next()
Boundary(v_id=1)
- >>> mun.next()
+ >>> cens.next()
Boundary(v_id=2)
- >>> mun.next()
+ >>> cens.next()
Boundary(v_id=3)
- >>> mun.rewind()
- >>> mun.next()
+ >>> cens.rewind()
+ >>> cens.next()
Boundary(v_id=1)
- >>> mun.close()
+ >>> cens.close()
@@ -472,28 +475,28 @@
:type feature_id: int
- >>> mun.open()
- >>> feature1 = mun.read(0) #doctest: +ELLIPSIS
+ >>> feature1 = cens.read(0) #doctest: +ELLIPSIS
ValueError: The index must be >0, 0 given.
- >>> feature1 = mun.read(1)
+ >>> feature1 = cens.read(1)
>>> feature1
Boundary(v_id=1)
>>> feature1.length()
- 1415.3348048582038
- >>> mun.read(-1)
- Centoid(649102.382010, 15945.714502)
- >>> len(mun)
- 8707
- >>> mun.read(8707)
- >>> mun.read(8708) #doctest: +ELLIPSIS
+ 444.54490917696944
+ >>> cens.read(-1)
+ Centoid(642963.159711, 214994.016279)
+ >>> len(cens)
+ 8920
+ >>> cens.read(8920)
+ >>> cens.read(8921) #doctest: +ELLIPSIS
IndexError: Index out of range
- >>> mun.close()
+ >>> cens.close()
return read_line(feature_id, self.c_mapinfo, self.table, self.writable,
Modified: grass/trunk/lib/python/pygrass/vector/find.py
--- grass/trunk/lib/python/pygrass/vector/find.py 2014-09-12 13:35:27 UTC (rev 61874)
+++ grass/trunk/lib/python/pygrass/vector/find.py 2014-09-12 13:36:23 UTC (rev 61875)
@@ -16,7 +16,7 @@
def __init__(self, c_mapinfo, table=None, writable=False):
"""AbstractFinder
Find geometry feature around a point.
self.c_mapinfo = c_mapinfo
@@ -46,9 +46,9 @@
>>> schools.open('r')
>>> result = []
>>> for school in schools:
- ... zipcode = zipcodes.find.area(school)
- ... result.append((school.attrs['NAMESHORT'],
- ... zipcode.attrs['ZIPCODE']))
+ ... zipcode = zipcodes.find['by_point'].area(school)
+ ... result.append((school.attrs['NAMESHORT'],
+ ... zipcode.attrs['ZIPCODE']))
>>> result[0]
(u'SWIFT CREEK', u'RALEIGH 27606')
@@ -58,10 +58,10 @@
(u'FARMINGTON WOODS', u'CARY 27511')
>>> from grass.pygrass.vector.geometry import Point
>>> pnt = Point(631213.349291, 224684.900084)
- >>> school = schools.find.geo(pnt, maxdist=300.)
+ >>> school = schools.find['by_point'].geo(pnt, maxdist=300.)
>>> school.attrs['NAMELONG']
u'ADAMS ELEMENTARY'
- >>> for school in schools.find.geos(pnt, maxdist=1000.):
+ >>> for school in schools.find['by_point'].geos(pnt, maxdist=1000.):
... print school.attrs['NAMELONG']
CARY HIGH
