[GRASS-SVN] r61883 - grass/trunk/lib/python/pygrass/modules/interface
svn_grass at osgeo.org
Fri Sep 12 09:10:14 PDT 2014
Author: zarch
Date: 2014-09-12 09:10:14 -0700 (Fri, 12 Sep 2014)
New Revision: 61883
grass/trunk/lib/python/pygrass/modules/interface/module.py
pygrass: Return always the Module instance and rename max_num_procs to nprocs to be more consistent with other GRASS libraries
Modified: grass/trunk/lib/python/pygrass/modules/interface/module.py
--- grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-09-12 16:04:44 UTC (rev 61882)
+++ grass/trunk/lib/python/pygrass/modules/interface/module.py 2014-09-12 16:10:14 UTC (rev 61883)
@@ -2,6 +2,7 @@
from __future__ import (nested_scopes, generators, division, absolute_import,
with_statement, print_function, unicode_literals)
import sys
+from multiprocessing import cpu_count
if sys.version_info[0] == 2:
from itertools import izip_longest as zip_longest
@@ -39,12 +40,18 @@
>>> from grass.pygrass.modules import Module, ParallelModuleQueue
>>> mapcalc_list = []
>>> mapcalc = Module("r.mapcalc", overwrite=True, run_=False)
- >>> queue = ParallelModuleQueue(max_num_procs=3)
+ >>> queue = ParallelModuleQueue(nprocs=3)
>>> for i in xrange(5):
... new_mapcalc = copy.deepcopy(mapcalc)
... mapcalc_list.append(new_mapcalc)
... new_mapcalc(expression="test_pygrass_%i = %i"%(i, i))
... queue.put(new_mapcalc)
+ Module('r.mapcalc')
>>> queue.wait()
>>> for mapcalc in mapcalc_list:
... print(mapcalc.popen.returncode)
@@ -55,15 +62,17 @@
0
- def __init__(self, max_num_procs=1):
+ def __init__(self, nprocs=1):
"""Constructor
- :param max_num_procs: The maximum number of Module processes that
- can be run in parallel
- :type max_num_procs: int
+ :param nprocs: The maximum number of Module processes that
+ can be run in parallel, defualt is 1, if None
+ then use all the available CPUs.
+ :type nprocs: int
- self._num_procs = int(max_num_procs)
- self._list = int(max_num_procs) * [None]
+ nprocs = int(nprocs) if nprocs else cpu_count()
+ self._num_procs = nprocs
+ self._list = nprocs * [None]
self._proc_count = 0
def put(self, module):
@@ -111,15 +120,15 @@
return self._num_procs
- def set_max_num_procs(self, max_num_procs):
+ def set_max_num_procs(self, nprocs):
"""Set the maximum number of Module processes that should run
in parallel
+ :type nprocs: int
+ self._num_procs = int(nprocs)
self.wait()
def wait(self):
@@ -178,6 +187,7 @@
>>> new_neighbors2 = copy.deepcopy(neighbors)
>>> new_neighbors2(input="mapD", size=3, run_=False)
+ Module('r.neighbors')
>>> new_neighbors2.get_bash()
u'r.neighbors input=mapD method=average size=3 quantile=0.5 output=mapB'
@@ -187,6 +197,7 @@
>>> new_neighbors3 = copy.deepcopy(neighbors)
>>> new_neighbors3(input="mapA", size=3, output="mapB", run_=False)
>>> new_neighbors3.get_bash()
u'r.neighbors input=mapA method=average size=3 output=mapB'
@@ -249,16 +260,21 @@
>>> colors.run()
Module('r.colors')
>>> colors(color="gyr")
+ Module('r.colors')
>>> colors.run()
Module('r.colors')
>>> colors(color="ryg")
>>> colors(stderr_=PIPE)
>>> colors.run()
Module('r.colors')
>>> print(colors.outputs["stderr"].value.strip())
Color table for raster map <test_a> set to 'ryg'
>>> colors(color="byg")
>>> colors(stdout_=PIPE)
>>> colors.run()
Module('r.colors')
@@ -403,7 +419,7 @@
if not args and not kargs:
self.run()
- return
+ return self
# check for extra kargs, set attribute and remove from dictionary
@@ -452,6 +468,7 @@
msg = "Required parameter <%s> not set."
raise ParameterError(msg % k)
return self.run()
+ return self
def get_bash(self):
"""Return a BASH rapresentation of the Module."""
