[GRASS-SVN] r61884 - in grass/trunk/lib/python/pygrass/modules: . grid
svn_grass at osgeo.org
Fri Sep 12 09:11:53 PDT 2014
Author: zarch
Date: 2014-09-12 09:11:53 -0700 (Fri, 12 Sep 2014)
New Revision: 61884
grass/trunk/lib/python/pygrass/modules/grid/grid.py
grass/trunk/lib/python/pygrass/modules/shortcuts.py
pygrass: Fix doctest
Modified: grass/trunk/lib/python/pygrass/modules/grid/grid.py
--- grass/trunk/lib/python/pygrass/modules/grid/grid.py 2014-09-12 16:10:14 UTC (rev 61883)
+++ grass/trunk/lib/python/pygrass/modules/grid/grid.py 2014-09-12 16:11:53 UTC (rev 61884)
@@ -36,7 +36,7 @@
... elevation='ele', slope='slp', aspect='asp',
... run_=False)
>>> for rast in select(slp.outputs, 'raster'):
- ... print rast
+ ... print(rast)
slp
asp
@@ -86,8 +86,8 @@
[u'PERMANENT', u'user1']
>>> sorted(os.listdir(os.path.join(path, 'PERMANENT')))
[u'DEFAULT_WIND', u'PROJ_INFO', u'PROJ_UNITS', u'VAR', u'WIND']
- >>> sorted(os.listdir(os.path.join(path, 'user1')))
- [u'CURGROUP', u'SEARCH_PATH', u'VAR', u'WIND']
+ >>> sorted(os.listdir(os.path.join(path, 'user1'))) # doctest: +ELLIPSIS
+ [...u'SEARCH_PATH', u'VAR', u'WIND']
>>> import shutil
>>> shutil.rmtree(path)
@@ -308,7 +308,7 @@
... overwrite=True, run_=False)
>>> get_cmd(slp.get_dict()) # doctest: +ELLIPSIS
- ['r.slope.aspect', 'elevation=ele', 'format=degrees', ..., '--o']
+ ['r.slope.aspect', u'elevation=ele', u'format=degrees', ..., u'--o']
cmd = [cmdd['name'], ]
cmd.extend(("%s=%s" % (k, v) for k, v in cmdd['inputs']
@@ -391,7 +391,7 @@
:param run_: if False only instantiate the object
:type run_: bool
:param args: give all the parameters to the command
- :param kargs: give all the parameters to the command
+ :param kargs: give all the parameters to the command
>>> grd = GridModule('r.slope.aspect',
... width=500, height=500, overlap=2,
Modified: grass/trunk/lib/python/pygrass/modules/shortcuts.py
--- grass/trunk/lib/python/pygrass/modules/shortcuts.py 2014-09-12 16:10:14 UTC (rev 61883)
+++ grass/trunk/lib/python/pygrass/modules/shortcuts.py 2014-09-12 16:11:53 UTC (rev 61884)
@@ -28,8 +28,9 @@
>>> g_mlist.inputs.type = 'rast'
>>> g_mlist.stdout_ = -1
>>> g_mlist.run()
+ Module('g.mlist')
>>> g_mlist.outputs.stdout # doctest: +ELLIPSIS
- 'basins...soils...'
+ '...basins...soils...'
>>> r = MetaModule('r')
>>> what = r.what
>>> what.description
