[GRASS-SVN] r61896 - grass/branches/releasebranch_7_0/lib/init
svn_grass at osgeo.org
Sat Sep 13 10:02:59 PDT 2014
Author: martinl
Date: 2014-09-13 10:02:59 -0700 (Sat, 13 Sep 2014)
New Revision: 61896
grass/branches/releasebranch_7_0/lib/init/grass.py
grass.py: do not add scripts to the PATH on Windows (BAT files enabled)
Modified: grass/branches/releasebranch_7_0/lib/init/grass.py
--- grass/branches/releasebranch_7_0/lib/init/grass.py 2014-09-13 16:57:24 UTC (rev 61895)
+++ grass/branches/releasebranch_7_0/lib/init/grass.py 2014-09-13 17:02:59 UTC (rev 61896)
@@ -381,11 +381,13 @@
if not addon_base:
addon_base = os.path.join(grass_config_dir, 'addons')
os.environ['GRASS_ADDON_BASE'] = addon_base
- path_prepend(os.path.join(addon_base, 'scripts'), 'PATH')
+ if not windows:
+ path_prepend(os.path.join(addon_base, 'scripts'), 'PATH')
path_prepend(os.path.join(addon_base, 'bin'), 'PATH')
# standard installation
- path_prepend(gfile('scripts'), 'PATH')
+ if not windows:
+ path_prepend(gfile('scripts'), 'PATH')
path_prepend(gfile('bin'), 'PATH')
# Set PYTHONPATH to find GRASS Python modules
