[GRASS-SVN] r61897 - grass/trunk/gui/wxpython/dbmgr
svn_grass at osgeo.org
Sat Sep 13 10:07:10 PDT 2014
Author: annakrat
Date: 2014-09-13 10:07:10 -0700 (Sat, 13 Sep 2014)
New Revision: 61897
grass/trunk/gui/wxpython/dbmgr/base.py
grass/trunk/gui/wxpython/dbmgr/dialogs.py
grass/trunk/gui/wxpython/dbmgr/vinfo.py
wxGUI/dbmgr: attempt to fix unicode errors from #1681
Modified: grass/trunk/gui/wxpython/dbmgr/base.py
--- grass/trunk/gui/wxpython/dbmgr/base.py 2014-09-13 17:02:59 UTC (rev 61896)
+++ grass/trunk/gui/wxpython/dbmgr/base.py 2014-09-13 17:07:10 UTC (rev 61897)
@@ -850,7 +850,7 @@
if enc:
sqlFile.write(sql.encode(enc) + ';')
else:
- sqlFile.write(sql + ';')
+ sqlFile.write(sql.encode('utf-8') + ';')
sqlFile.write(os.linesep)
sqlFile.close()
@@ -1438,14 +1438,13 @@
try:
if tlist.columns[columnName[i]]['ctype'] == int:
# values[i] is stored as text.
- value = float(values[i])
- else:
- value = values[i]
- values[i] = tlist.columns[columnName[i]]['ctype'] (value)
+ values[i] = int(float(values[i]))
+ elif tlist.columns[columnName[i]]['ctype'] == float:
+ values[i] = float(values[i])
except:
- raise ValueError(_("Value '%(value)s' needs to be entered as %(type)s.") %
- {'value' : str(values[i]),
- 'type' : tlist.columns[columnName[i]]['type']})
+ raise ValueError(_("Value '%(value)s' needs to be entered as %(type)s.") %
+ {'value': values[i],
+ 'type': tlist.columns[columnName[i]]['type']})
columnsString += '%s,' % columnName[i]
if tlist.columns[columnName[i]]['ctype'] == str:
Modified: grass/trunk/gui/wxpython/dbmgr/dialogs.py
--- grass/trunk/gui/wxpython/dbmgr/dialogs.py 2014-09-13 17:02:59 UTC (rev 61896)
+++ grass/trunk/gui/wxpython/dbmgr/dialogs.py 2014-09-13 17:07:10 UTC (rev 61897)
@@ -242,7 +242,7 @@
if ctype != str:
updatedValues.append(str(newvalue))
else:
- updatedValues.append("'" + str(newvalue) + "'")
+ updatedValues.append("'" + newvalue + "'")
columns[name]['values'][idx] = newvalue
if self.action != "add" and len(updatedValues) == 0:
@@ -265,7 +265,7 @@
if self.action == "add":
sqlString += ") VALUES (%s," % cat
for value in updatedValues:
- sqlString += str(value) + ","
+ sqlString += value + ","
sqlString = sqlString[:-1] # remove last comma
sqlString += ")"
else:
@@ -327,6 +327,8 @@
continue
if enc:
sql = sql.encode(enc)
+ else:
+ sql = sql.encode('utf-8')
driver, database = self.mapDBInfo.GetDbSettings(layer)
Debug.msg(1, "SQL: %s" % sql)
Modified: grass/trunk/gui/wxpython/dbmgr/vinfo.py
--- grass/trunk/gui/wxpython/dbmgr/vinfo.py 2014-09-13 17:02:59 UTC (rev 61896)
+++ grass/trunk/gui/wxpython/dbmgr/vinfo.py 2014-09-13 17:07:10 UTC (rev 61897)
@@ -147,7 +147,6 @@
sql = "SELECT %s FROM %s WHERE %s" % (cols, table, where)
ret = RunCommand('db.select',
- parent = self,
read = True,
quiet = True,
flags = 'v',
