[GRASS-SVN] r61898 - in grass/trunk: lib/python/script scripts/db.droptable
svn_grass at osgeo.org
Sat Sep 13 10:12:53 PDT 2014
Author: lucadelu
Date: 2014-09-13 10:12:53 -0700 (Sat, 13 Sep 2014)
New Revision: 61898
grass/trunk/lib/python/script/db.py
grass/trunk/scripts/db.droptable/db.droptable.py
python db: fix output of db_table_in_vector and changed db.droptable.py behaviour; some pep8 and doctest fix
Modified: grass/trunk/lib/python/script/db.py
--- grass/trunk/lib/python/script/db.py 2014-09-13 17:07:10 UTC (rev 61897)
+++ grass/trunk/lib/python/script/db.py 2014-09-13 17:12:53 UTC (rev 61898)
@@ -1,4 +1,4 @@
-"""!@package grass.script.db
+"""@package grass.script.db
@brief GRASS Python scripting module (database functions)
@@ -6,13 +6,13 @@
Usage:
- at code
-from grass.script import db as grass
-grass.db_describe(table)
- at endcode
+ from grass.script import db as grass
+ grass.db_describe(table)
(C) 2008-2009, 2012 by the GRASS Development Team
This program is free software under the GNU General Public
License (>=v2). Read the file COPYING that comes with GRASS
@@ -22,33 +22,26 @@
@author Martin Landa <landa.martin gmail.com>
-import tempfile as pytempfile # conflict with core.tempfile
from core import *
from utils import try_remove
def db_describe(table, **args):
- """!Return the list of columns for a database table
+ """Return the list of columns for a database table
(interface to `db.describe -c'). Example:
- \code
- >>> grass.db_describe('lakes')
- {'nrows': 15279, 'cols': [['cat', 'INTEGER', '11'], ['AREA', 'DOUBLE PRECISION', '20'],
- ['PERIMETER', 'DOUBLE PRECISION', '20'], ['FULL_HYDRO', 'DOUBLE PRECISION', '20'],
- ['FULL_HYDR2', 'DOUBLE PRECISION', '20'], ['FTYPE', 'CHARACTER', '24'],
- ['FCODE', 'INTEGER', '11'], ['NAME', 'CHARACTER', '99']], 'ncols': 8}
- \endcode
+ >>> db_describe('firestations') # doctest: +ELLIPSIS
+ {'nrows': 71, 'cols': [['cat', 'INTEGER', '20'], ... 'ncols': 22}
- @param table table name
- @param args
+ :param str table: table name
+ :param list args:
- @return parsed module output
+ :return: parsed module output
- s = read_command('db.describe', flags = 'c', table = table, **args)
+ s = read_command('db.describe', flags='c', table=table, **args)
if not s:
fatal(_("Unable to describe table <%s>") % table)
cols = []
result = {}
for l in s.splitlines():
@@ -63,77 +56,67 @@
else:
result[key] = f[1:]
result['cols'] = cols
return result
-# run "db.connect -g" and parse output
def db_table_exist(table, **args):
- """!Check if table exists.
+ """Check if table exists.
If no driver or database are given, then default settings is used
(check db_connection()).
- @param driver DB driver
- @param database DB to check
+ >>> db_table_exist('firestations')
+ True
- @return True for success, False otherwise
+ :param args:
+ :return: True for success, False otherwise
nuldev = file(os.devnull, 'w+')
- ret = run_command('db.describe', flags = 'c', table = table,
- stdout = nuldev, stderr = nuldev, **args)
+ ret = run_command('db.describe', flags='c', table=table,
+ stdout=nuldev, stderr=nuldev, **args)
nuldev.close()
if ret == 0:
return True
return False
def db_connection():
- """!Return the current database connection parameters
+ """Return the current database connection parameters
(interface to `db.connect -g'). Example:
- \code
- >>> grass.db_connection()
- {'group': 'x', 'schema': '', 'driver': 'dbf', 'database': '$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/'}
- \endcode
+ >>> db_connection()
+ {'group': '', 'schema': '', 'driver': 'sqlite', 'database': '$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite/sqlite.db'}
- @return parsed output of db.connect
+ :return: parsed output of db.connect
- return parse_command('db.connect', flags = 'g')
+ return parse_command('db.connect', flags='g')
-def db_select(sql = None, filename = None, table = None, **args):
- """!Perform SQL select statement
+def db_select(sql=None, filename=None, table=None, **args):
+ """Perform SQL select statement
Note: one of <em>sql</em>, <em>filename</em>, or <em>table</em>
arguments must be provided.
Examples:
- \code
- grass.db_select(sql = 'SELECT cat,CAMPUS FROM busstopsall WHERE cat < 4')
+ >>> db_select(sql = 'SELECT cat,CITY FROM firestations WHERE cat < 4')
(('1', 'Vet School'), ('2', 'West'), ('3', 'North'))
- \endcode
- \code
- grass.db_select(filename = '/path/to/sql/file')
- \endcode
- Simplyfied usage
- \code
- grass.db_select(table = 'busstopsall')
- \endcode
+ Simplyfied usage (it performs <tt>SELECT * FROM busstopsall</tt>.)
- performs <tt>SELECT * FROM busstopsall</tt>.
+ >>> db_select(table = 'firestations')
- @param sql SQL statement to perform (or None)
- @param filename name of file with SQL statements (or None)
- @param table name of table to query (or None)
- @param args see \gmod{db.select} arguments
+ :param str sql: SQL statement to perform (or None)
+ :param str filename: name of file with SQL statements (or None)
+ :param str table: name of table to query (or None)
+ :param str args: see \gmod{db.select} arguments
- fname = tempfile(create = False)
+ fname = tempfile(create=False)
if sql:
args['sql'] = sql
elif filename:
@@ -143,35 +126,37 @@
else:
fatal(_("Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided") %
{'sql': 'sql', 'filename': 'filename', 'table': 'table'} )
if 'sep' not in args:
args['sep'] = '|'
- ret = run_command('db.select', quiet = True,
- flags = 'c',
- output = fname,
- **args)
+ ret = run_command('db.select', quiet=True, flags='c',
+ output=fname, **args)
if ret != 0:
fatal(_("Fetching data failed"))
ofile = open(fname)
result = map(lambda x: tuple(x.rstrip(os.linesep).split(args['sep'])),
ofile.readlines())
ofile.close()
try_remove(fname)
return tuple(result)
def db_table_in_vector(table):
"""Return the name of vector connected to the table.
- It returns False if no vectors are connected to the table.
+ It returns None if no vectors are connected to the table.
- Example
+ >>> db_table_in_vector('geology')
+ ['geology at PERMANENT']
+ >>> db_table_in_vector('geologies')
- @params table name of table to query
from vector import vector_db
nuldev = file(os.devnull, 'w')
@@ -184,4 +169,7 @@
if f['table'] == table:
used.append(vect)
break
- return used
+ if len(used) > 0:
+ return used
+ else:
+ return None
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py 2014-09-13 17:07:10 UTC (rev 61897)
+++ grass/trunk/scripts/db.droptable/db.droptable.py 2014-09-13 17:12:53 UTC (rev 61898)
@@ -75,7 +75,7 @@
# check if table is used somewhere (connected to vector map)
used = grass.db.db_table_in_vector(table)
- if len(used) > 0:
+ if used:
grass.warning(_("Deleting table <%s> which is attached to following map(s):") % table)
for vect in used:
grass.warning("%s" % vect)
