[GRASS-SVN] r61900 - in grass/branches/releasebranch_7_0: . gui/wxpython/mapdisp scripts scripts/d.what.rast scripts/d.what.vect
Sat Sep 13 11:21:59 PDT 2014
Author: annakrat
Date: 2014-09-13 11:21:59 -0700 (Sat, 13 Sep 2014)
New Revision: 61900
Added:
   grass/branches/releasebranch_7_0/scripts/d.what.rast/
   grass/branches/releasebranch_7_0/scripts/d.what.rast/Makefile
   grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.html
   grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.py
   grass/branches/releasebranch_7_0/scripts/d.what.vect/
   grass/branches/releasebranch_7_0/scripts/d.what.vect/Makefile
   grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.html
   grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.py
Removed:
   grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
   grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/main.py
d.mon: implement d.what.vect, d.what.rast (merge from trunk, r60696)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60289,61380,61420,61422,61480,61500,61764
   + /grass/trunk:60289,60696,61380,61420,61422,61480,61500,61764
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py	2014-09-13 17:50:42 UTC (rev 61899)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/frame.py	2014-09-13 18:21:59 UTC (rev 61900)
@@ -232,6 +232,10 @@
         self.dialogs['vnet'] = None
         self.dialogs['query'] = None
+        # initialize layers to query (d.what.vect/rast)
+        self._vectQueryLayers = []
+        self._rastQueryLayers = []
         self.measureController = None
     def GetMapWindow(self):
@@ -712,31 +716,35 @@
         @param x,y coordinates
         @param layers selected tree item layers
-        layers = self._giface.GetLayerList().GetSelectedLayers(checkedOnly=False)
-        rast = []
-        vect = []
-        for layer in layers:
-            name, found = GetLayerNameFromCmd(layer.cmd)
-            if not found:
-                continue
-            ltype = layer.maplayer.GetType()
-            if ltype == 'raster':
-                rast.append(name)
-            elif ltype in ('rgb', 'his'):
-                for iname in name.split('\n'):
-                    rast.append(iname)
-            elif ltype in ('vector', 'thememap', 'themechart'):
-                vect.append(name)
-        if vect:
-            # check for vector maps open to be edited
-            digitToolbar = self.GetToolbar('vdigit')
-            if digitToolbar:
-                lmap = digitToolbar.GetLayer().GetName()
-                for name in vect:
-                    if lmap == name:
-                        self._giface.WriteWarning(_("Vector map <%s> "
-        "opened for editing - skipped.") % lmap)
-                        vect.remove(name)
+        if self._vectQueryLayers or self._rastQueryLayers:
+            rast = self._rastQueryLayers
+            vect = self._vectQueryLayers
+        else:
+            layers = self._giface.GetLayerList().GetSelectedLayers(checkedOnly=False)
+            rast = []
+            vect = []
+            for layer in layers:
+                name, found = GetLayerNameFromCmd(layer.cmd)
+                if not found:
+                    continue
+                ltype = layer.maplayer.GetType()
+                if ltype == 'raster':
+                    rast.append(name)
+                elif ltype in ('rgb', 'his'):
+                    for iname in name.split('\n'):
+                        rast.append(iname)
+                elif ltype in ('vector', 'thememap', 'themechart'):
+                    vect.append(name)
+            if vect:
+                # check for vector maps open to be edited
+                digitToolbar = self.GetToolbar('vdigit')
+                if digitToolbar:
+                    lmap = digitToolbar.GetLayer().GetName()
+                    for name in vect:
+                        if lmap == name:
+                            self._giface.WriteWarning(_("Vector map <%s> "
+        "opened for editing - skipped.") % lmap)
+                            vect.remove(name)
         if not (rast + vect):
             GMessage(parent = self,
@@ -760,6 +768,15 @@
             if vect:
                 self.QueryMap(east, north, qdist, rast = [], vect = vect)
+    def SetQueryLayersAndActivate(self, ltype, maps):
+        """!Activate query mode and set layers to query.
+        This method is used for querying in d.mon using d.what.rast/vect"""
+        self.toolbars['map'].SelectTool(self.toolbars['map'].query)
+        if ltype == 'vect':
+            self._vectQueryLayers = maps
+        elif ltype == 'rast':
+            self._rastQueryLayers = maps
     def QueryMap(self, east, north, qdist, rast, vect):
         """!Query raster or vector map layers by r/v.what
@@ -798,6 +815,8 @@
     def _oncloseQueryDialog(self, event):
         event.Skip()
     def _onRedirectQueryOutput(self, output, style='log'):
Modified: grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/main.py
--- grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/main.py	2014-09-13 17:50:42 UTC (rev 61899)
+++ grass/branches/releasebranch_7_0/gui/wxpython/mapdisp/main.py	2014-09-13 18:21:59 UTC (rev 61900)
@@ -81,6 +81,8 @@
         self.mapfile = monFile['map'] + '.ppm'
         # signal sent when d.out.file appears in cmd file, attribute is cmd
         self.saveToFile = Signal('DMonMap.saveToFile')
+        # signal sent when d.what.rast/vect appears in cmd file, attribute is cmd
+        self.query = Signal('DMonMap.query')
     def GetLayersFromCmdFile(self):
         """!Get list of map layers from cmdfile
@@ -95,13 +97,25 @@
             lines = fd.readlines()
             fd.close()
             # detect d.out.file, delete the line from the cmd file and export graphics
-            if len(lines) > 0 and lines[-1].startswith('d.out.file'):
-                dOutFileCmd = lines[-1].strip()
-                fd = open(self.cmdfile, 'w')
-                fd.writelines(lines[:-1])
-                fd.close()
-                self.saveToFile.emit(cmd=utils.split(dOutFileCmd))
-                return
+            if len(lines) > 0:
+                if lines[-1].startswith('d.out.file'):
+                    dOutFileCmd = lines[-1].strip()
+                    fd = open(self.cmdfile, 'w')
+                    fd.writelines(lines[:-1])
+                    fd.close()
+                    self.saveToFile.emit(cmd=utils.split(dOutFileCmd))
+                    return
+                if lines[-1].startswith('d.what'):
+                    dWhatCmd = lines[-1].strip()
+                    fd.close()
+                    if '=' in utils.split(dWhatCmd)[1]:
+                        maps = utils.split(dWhatCmd)[1].split('=')[1].split(',')
+                    else:
+                        maps = utils.split(dWhatCmd)[1].split(',')
+                    self.query.emit(ltype=utils.split(dWhatCmd)[0].split('.')[-1], maps=maps)
+                    return
             existingLayers = self.GetListOfLayers()
@@ -345,6 +359,7 @@
         # self.SetTopWindow(Map)
         self.mapFrm.GetMapWindow().SetAlwaysRenderEnabled(True)
         self.Map.saveToFile.connect(lambda cmd: self.mapFrm.DOutFile(cmd))
+        self.Map.query.connect(lambda ltype, maps: self.mapFrm.SetQueryLayersAndActivate(ltype=ltype, maps=maps))
         self.mapFrm.Show()
         if __name__ == "__main__":
Deleted: grass/branches/releasebranch_7_0/scripts/d.what.rast/Makefile
--- grass/trunk/scripts/d.what.rast/Makefile	2014-06-04 02:40:24 UTC (rev 60696)
+++ grass/branches/releasebranch_7_0/scripts/d.what.rast/Makefile	2014-09-13 18:21:59 UTC (rev 61900)
@@ -1,7 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = d.what.rast
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
Copied: grass/branches/releasebranch_7_0/scripts/d.what.rast/Makefile (from rev 60696, grass/trunk/scripts/d.what.rast/Makefile)
--- grass/branches/releasebranch_7_0/scripts/d.what.rast/Makefile	                        (rev 0)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = d.what.rast
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Deleted: grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.html
--- grass/trunk/scripts/d.what.rast/d.what.rast.html	2014-06-04 02:40:24 UTC (rev 60696)
+++ grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.html	2014-09-13 18:21:59 UTC (rev 61900)
@@ -1,22 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>d.what.rast</em> d.what.rast outputs the category value(s)
-associated with user-specified location(s) in user-specified raster map layer(s).
-The active monitor can be selected with <em>d.mon</em>.
-<h2>SEE ALSO</h2>
-<em>
-  <a href="d.what.vect.html">d.what.vect</a>,
-  <a href="d.redraw.html">d.redraw</a>,
-  <a href="d.erase.html">d.erase</a>,
-  <a href="d.rast.html">d.rast</a>,
-  <a href="d.vect.html">d.vect</a>,
-  <a href="d.mon.html">d.mon</a>
-</em>
-<h2>AUTHOR</h2>
-Anna Petrasova, <a href="http://gis.ncsu.edu/osgeorel/">NCSU OSGeoREL</a>
-<p><i>Last changed: $Date: 2014-03-26 11:49:20 -0400 (Wed, 26 Mar 2014) $</i>
Copied: grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.html (from rev 60696, grass/trunk/scripts/d.what.rast/d.what.rast.html)
--- grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.html	                        (rev 0)
@@ -0,0 +1,22 @@
+<h2>DESCRIPTION</h2>
+<em>d.what.rast</em> d.what.rast outputs the category value(s)
+associated with user-specified location(s) in user-specified raster map layer(s).
+The active monitor can be selected with <em>d.mon</em>.
+<h2>SEE ALSO</h2>
+<em>
+  <a href="d.what.vect.html">d.what.vect</a>,
+  <a href="d.redraw.html">d.redraw</a>,
+  <a href="d.erase.html">d.erase</a>,
+  <a href="d.rast.html">d.rast</a>,
+  <a href="d.vect.html">d.vect</a>,
+  <a href="d.mon.html">d.mon</a>
+</em>
+<h2>AUTHOR</h2>
+Anna Petrasova, <a href="http://gis.ncsu.edu/osgeorel/">NCSU OSGeoREL</a>
+<p><i>Last changed: $Date: 2014-03-26 11:49:20 -0400 (Wed, 26 Mar 2014) $</i>
Deleted: grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.py
--- grass/trunk/scripts/d.what.rast/d.what.rast.py	2014-06-04 02:40:24 UTC (rev 60696)
+++ grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.py	2014-09-13 18:21:59 UTC (rev 61900)
@@ -1,44 +0,0 @@
-#!/usr/bin/env python
-# MODULE: d.what.rast
-# AUTHOR(S): Anna Petrasova <kratochanna gmail.com>
-# PURPOSE:   Script for querying raster maps in d.mon
-# COPYRIGHT: (C) 2014 by the GRASS Development Team
-#		This program is free software under the GNU General
-#		Public License (>=v2). Read the file COPYING that
-#		comes with GRASS for details.
-#%module
-#% description: Allows the user to interactively query raster map layers at user-selected locations.
-#% keywords: display
-#% keywords: vector
-#%end
-#%option G_OPT_R_INPUTS
-#% key: map
-#%end
-from grass.script import core as gcore
-def main():
-    options, flags = gcore.parser()
-    gisenv = gcore.gisenv()
-    if 'MONITOR' in gisenv:
-        cmd_file = gisenv['MONITOR_{monitor}_CMDFILE'.format(monitor=gisenv['MONITOR'].upper())]
-        dout_cmd = 'd.what.rast'
-        for param, val in options.iteritems():
-            if val:
-                dout_cmd += " {param}={val}".format(param=param, val=val)
-        with open(cmd_file, "a") as file_:
-            file_.write(dout_cmd)
-    else:
-        gcore.fatal(_("No graphics device selected. Use d.mon to select graphics device."))
-if __name__ == "__main__":
-    main()
Copied: grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.py (from rev 60696, grass/trunk/scripts/d.what.rast/d.what.rast.py)
--- grass/branches/releasebranch_7_0/scripts/d.what.rast/d.what.rast.py	                        (rev 0)
@@ -0,0 +1,44 @@
+#!/usr/bin/env python
+# MODULE: d.what.rast
+# AUTHOR(S): Anna Petrasova <kratochanna gmail.com>
+# PURPOSE:   Script for querying raster maps in d.mon
+# COPYRIGHT: (C) 2014 by the GRASS Development Team
+#		This program is free software under the GNU General
+#		Public License (>=v2). Read the file COPYING that
+#		comes with GRASS for details.
+#%module
+#% description: Allows the user to interactively query raster map layers at user-selected locations.
+#% keywords: display
+#% keywords: vector
+#%end
+#%option G_OPT_R_INPUTS
+#% key: map
+#%end
+from grass.script import core as gcore
+def main():
+    options, flags = gcore.parser()
+    gisenv = gcore.gisenv()
+    if 'MONITOR' in gisenv:
+        cmd_file = gisenv['MONITOR_{monitor}_CMDFILE'.format(monitor=gisenv['MONITOR'].upper())]
+        dout_cmd = 'd.what.rast'
+        for param, val in options.iteritems():
+            if val:
+                dout_cmd += " {param}={val}".format(param=param, val=val)
+        with open(cmd_file, "a") as file_:
+            file_.write(dout_cmd)
+    else:
+        gcore.fatal(_("No graphics device selected. Use d.mon to select graphics device."))
+if __name__ == "__main__":
+    main()
Deleted: grass/branches/releasebranch_7_0/scripts/d.what.vect/Makefile
--- grass/trunk/scripts/d.what.vect/Makefile	2014-06-04 02:40:24 UTC (rev 60696)
+++ grass/branches/releasebranch_7_0/scripts/d.what.vect/Makefile	2014-09-13 18:21:59 UTC (rev 61900)
@@ -1,7 +0,0 @@
-PGM = d.what.vect
-default: script
Copied: grass/branches/releasebranch_7_0/scripts/d.what.vect/Makefile (from rev 60696, grass/trunk/scripts/d.what.vect/Makefile)
--- grass/branches/releasebranch_7_0/scripts/d.what.vect/Makefile	                        (rev 0)
@@ -0,0 +1,7 @@
+PGM = d.what.vect
+default: script
Deleted: grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.html
--- grass/trunk/scripts/d.what.vect/d.what.vect.html	2014-06-04 02:40:24 UTC (rev 60696)
+++ grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.html	2014-09-13 18:21:59 UTC (rev 61900)
@@ -1,22 +0,0 @@
-<em>d.what.vect</em> d.what.vect outputs the category value(s)
-associated with user-specified location(s) in user-specified vector map layer(s).
-<h2>SEE ALSO</h2>
-<em>
-  <a href="d.what.rast.html">d.what.rast</a>,
-</em>
-<h2>AUTHOR</h2>
Copied: grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.html (from rev 60696, grass/trunk/scripts/d.what.vect/d.what.vect.html)
--- grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.html	                        (rev 0)
@@ -0,0 +1,22 @@
+<em>d.what.vect</em> d.what.vect outputs the category value(s)
+associated with user-specified location(s) in user-specified vector map layer(s).
+<h2>SEE ALSO</h2>
+<em>
+  <a href="d.what.rast.html">d.what.rast</a>,
+</em>
+<h2>AUTHOR</h2>
Deleted: grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.py
--- grass/trunk/scripts/d.what.vect/d.what.vect.py	2014-06-04 02:40:24 UTC (rev 60696)
+++ grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.py	2014-09-13 18:21:59 UTC (rev 61900)
@@ -1,44 +0,0 @@
-# MODULE: d.what.vect
-# PURPOSE:	Script for querying vector maps in d.mon
-#%module
-#% description: Allows the user to interactively query vector map layers at user-selected locations.
-#%end
-#%option G_OPT_V_INPUTS
-#% key: map
-#%end
-def main():
-        dout_cmd = 'd.what.vect'
-            if val:
-    else:
-    main()
Copied: grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.py (from rev 60696, grass/trunk/scripts/d.what.vect/d.what.vect.py)
--- grass/branches/releasebranch_7_0/scripts/d.what.vect/d.what.vect.py	                        (rev 0)
@@ -0,0 +1,44 @@
+# MODULE: d.what.vect
+# PURPOSE:	Script for querying vector maps in d.mon
+#%module
+#% description: Allows the user to interactively query vector map layers at user-selected locations.
+#%end
+#%option G_OPT_V_INPUTS
+#% key: map
+#%end
+def main():
+        dout_cmd = 'd.what.vect'
+            if val:
+    else:
+    main()
