[GRASS-SVN] r61901 - in grass/branches/releasebranch_7_0: gui/wxpython/xml raster raster/r.horizon raster/r.viewshed
svn_grass at osgeo.org
Sat Sep 13 11:24:08 PDT 2014
Author: wenzeslaus
Date: 2014-09-13 11:24:08 -0700 (Sat, 13 Sep 2014)
New Revision: 61901
Removed:
grass/branches/releasebranch_7_0/raster/r.los/
grass/branches/releasebranch_7_0/raster/r.viewshed/testscript.sh
grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml
grass/branches/releasebranch_7_0/raster/Makefile
grass/branches/releasebranch_7_0/raster/r.horizon/r.horizon.html
grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html
r.los: move to addons (backport of r61899), remove links, remove r.los-r.viewshed test script (now in r.los addon)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml
--- grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml 2014-09-13 18:21:59 UTC (rev 61900)
+++ grass/branches/releasebranch_7_0/gui/wxpython/xml/toolboxes.xml 2014-09-13 18:24:08 UTC (rev 61901)
@@ -806,9 +806,6 @@
<module-item name="r.viewshed">
<label>Visibility</label>
</module-item>
- <module-item name="r.los">
- <label>Visibility [DEPRECATED]</label>
- </module-item>
<module-item name="r.grow.distance">
<label>Distance to features</label>
</module-item>
Modified: grass/branches/releasebranch_7_0/raster/Makefile
--- grass/branches/releasebranch_7_0/raster/Makefile 2014-09-13 18:21:59 UTC (rev 61900)
+++ grass/branches/releasebranch_7_0/raster/Makefile 2014-09-13 18:24:08 UTC (rev 61901)
@@ -43,7 +43,6 @@
r.latlong \
r.lake \
r.li \
- r.los \
r.mapcalc \
r.mfilter \
r.mode \
Modified: grass/branches/releasebranch_7_0/raster/r.horizon/r.horizon.html
--- grass/branches/releasebranch_7_0/raster/r.horizon/r.horizon.html 2014-09-13 18:21:59 UTC (rev 61900)
+++ grass/branches/releasebranch_7_0/raster/r.horizon/r.horizon.html 2014-09-13 18:24:08 UTC (rev 61901)
@@ -167,7 +167,6 @@
<em>
<a href="r.sun.html">r.sun</a>,
<a href="r.sunmask.html">r.sunmask</a>,
-<a href="r.los.html">r.los</a>,
<a href="r.viewshed.html">r.viewshed</a></em>
Modified: grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html
--- grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html 2014-09-13 18:21:59 UTC (rev 61900)
+++ grass/branches/releasebranch_7_0/raster/r.viewshed/r.viewshed.html 2014-09-13 18:24:08 UTC (rev 61901)
@@ -226,7 +226,6 @@
<h2>SEE ALSO</h2>
<em>
<a href="r.mapcalc.html">r.mapcalc</a>
</em>
Deleted: grass/branches/releasebranch_7_0/raster/r.viewshed/testscript.sh
--- grass/branches/releasebranch_7_0/raster/r.viewshed/testscript.sh 2014-09-13 18:21:59 UTC (rev 61900)
+++ grass/branches/releasebranch_7_0/raster/r.viewshed/testscript.sh 2014-09-13 18:24:08 UTC (rev 61901)
@@ -1,38 +0,0 @@
-#!/bin/sh
-# Test script for r.viewshed based on a synthetic DEM
-# RUN THIS IS ANY GRASS LOCATION, e.g. NC or Spearfish
-# create first hemisphere
-g.region n=1000 s=0 w=0 e=1000 -p res=1
-r.mapcalc 'disk.15031=if(sqrt((col() - 500)^2 + (500 - row())^2)<500,sqrt((col() - 500)^2 + (500 - row())^2),null())'
-r.mapcalc 'hemisphere1=500 * sin(acos (disk.15031/500))'
-# create second hemisphere
-g.region n=500 s=0 w=0 e=500 -p res=1
-r.mapcalc 'disk.14947=if(sqrt((col() - 500)^2 + (500 - row())^2)<500,sqrt((col() - 500)^2 + (500 - row())^2),null())'
-r.mapcalc 'hemisphere2=500 * sin(acos (disk.14947/500))'
-g.remove --q rast=disk.14947,disk.15031
-# merge both
-r.mapcalc "hemisphere=hemisphere1 + hemisphere2"
-d.mon x0
-d.rast hemisphere
-# run r.viewshed
-r.viewshed hemisphere out=hemisphere_viewshed coord=250,250 max=1000000 obs=100 mem=2000 --o
-r.shaded.relief hemisphere --o
-d.his h=hemisphere_viewshed i=hemisphere.shade
-# compare to r.los
-r.los hemisphere out=hemisphere_los coord=250,250 max=1000000 obs=100 --o
-d.mon x1
-d.his h=hemisphere_los i=hemisphere.shade
-r.mapcalc "hemisphere_diff = hemisphere_viewshed - hemisphere_los"
-r.colors hemisphere_diff color=differences
-d.mon x2
-d.rast.leg pos=80 map=hemisphere_diff
-nviz hemisphere col=hemisphere_viewshed
