[GRASS-SVN] r61918 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Sat Sep 13 14:46:04 PDT 2014
Author: annakrat
Date: 2014-09-13 14:46:04 -0700 (Sat, 13 Sep 2014)
New Revision: 61918
grass/trunk/raster/r.in.lidar/r.in.lidar.html
r.in.lidar: update man page
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html 2014-09-13 21:45:23 UTC (rev 61917)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html 2014-09-13 21:46:04 UTC (rev 61918)
@@ -89,9 +89,14 @@
used to obtain a digital surface model (DSM) where e.g. canopy cover is
represented. The last return values can be used to obtain a digital
terrain model (DTM) where e.g. the forest floor instead of canopy
-cover is represented. The <b>filter</b> option allows to select one of
+cover is represented. The <b>return_filter</b> option allows to select one of
first, mid, or last returns.
<p>
+LiDAR points can be already classified into standardized classes. For example,
+class number 2 represents ground (for other classes see LAS format specification
+in references). The <b>class_filter</b> option allows to select one or more
+classes, as numbers (integers) separated by comma.
+<p>
The default map <b>type</b>=<tt>FCELL</tt> is intended as compromise between
preserving data precision and limiting system resource consumption.
@@ -280,6 +285,13 @@
<a href="v.surf.bspline.html">v.surf.bspline</a>
</em>
+<h2>REFERENCES</h2>
+<a href="http://www.asprs.org/Committee-General/LASer-LAS-File-Format-Exchange-Activities.html">
+ASPRS LAS format</a><br>
+<a href="http://www.liblas.org/">LAS library</a> <br>
+<a href="http://test.liblas.org/doxygen/liblas_8h.htm">LAS library C API</a> documentation
<h2>AUTHORS</h2>
Markus Metz<br>
