[GRASS-SVN] r61919 - in grass/branches/releasebranch_7_0: . raster/r.in.lidar vector/v.in.lidar
svn_grass at osgeo.org
Sat Sep 13 14:49:50 PDT 2014
Author: annakrat
Date: 2014-09-13 14:49:50 -0700 (Sat, 13 Sep 2014)
New Revision: 61919
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/raster/r.in.lidar/main.c
grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html
grass/branches/releasebranch_7_0/vector/v.in.lidar/main.c
grass/branches/releasebranch_7_0/vector/v.in.lidar/v.in.lidar.html
r/v.in.lidar: add class_filter option, rename return_filter option, update man pages, merge from trunk, r61831, r61916, r61918
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61891,61905,61907,61913-61914
+ /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61831,61891,61905,61907,61913-61914,61916,61918
Modified: grass/branches/releasebranch_7_0/raster/r.in.lidar/main.c
--- grass/branches/releasebranch_7_0/raster/r.in.lidar/main.c 2014-09-13 21:46:04 UTC (rev 61918)
+++ grass/branches/releasebranch_7_0/raster/r.in.lidar/main.c 2014-09-13 21:49:50 UTC (rev 61919)
@@ -125,6 +125,8 @@
double pass_north, pass_south;
int arr_row, arr_col;
unsigned long count, count_total;
+ int skipme, i;
+ int point_class;
double min = 0.0 / 0.0; /* init as nan */
double max = 0.0 / 0.0; /* init as nan */
@@ -143,7 +145,7 @@
int r_low, r_up;
struct GModule *module;
- struct Option *input_opt, *output_opt, *percent_opt, *type_opt, *filter_opt;
+ struct Option *input_opt, *output_opt, *percent_opt, *type_opt, *filter_opt, *class_opt;
struct Option *method_opt, *zrange_opt, *zscale_opt;
struct Option *trim_opt, *pth_opt, *res_opt;
struct Flag *print_flag, *scan_flag, *shell_style, *over_flag, *extents_flag, *intens_flag;
@@ -244,13 +246,22 @@
_("Output raster resolution");
filter_opt = G_define_option();
- filter_opt->key = "filter";
+ filter_opt->key = "return_filter";
filter_opt->type = TYPE_STRING;
filter_opt->required = NO;
filter_opt->label = _("Only import points of selected return type");
filter_opt->description = _("If not specified, all points are imported");
filter_opt->options = "first,last,mid";
+ class_opt = G_define_option();
+ class_opt->key = "class_filter";
+ class_opt->type = TYPE_INTEGER;
+ class_opt->multiple = YES;
+ class_opt->required = NO;
+ class_opt->label = _("Only import points of selected class(es)");
+ class_opt->description = _("Input is comma separated integers. "
+ "If not specified, all points are imported.");
print_flag = G_define_flag();
print_flag->key = 'p';
print_flag->description =
@@ -775,7 +786,7 @@
if (return_filter != LAS_ALL) {
int return_no = LASPoint_GetReturnNumber(LAS_point);
int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
- int skipme = 1;
+ skipme = 1;
if (n_returns > 1) {
@@ -799,6 +810,21 @@
continue;
+ if (class_opt->answer) {
+ point_class = (int) LASPoint_GetClassification(LAS_point);
+ i = 0;
+ skipme = TRUE;
+ while (class_opt->answers[i]) {
+ if (point_class == atoi(class_opt->answers[i])) {
+ skipme = FALSE;
+ break;
+ i++;
+ if (skipme) {
+ continue;
if (y <= pass_south || y > pass_north) {
continue;
Modified: grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html
--- grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html 2014-09-13 21:46:04 UTC (rev 61918)
+++ grass/branches/releasebranch_7_0/raster/r.in.lidar/r.in.lidar.html 2014-09-13 21:49:50 UTC (rev 61919)
@@ -89,9 +89,14 @@
used to obtain a digital surface model (DSM) where e.g. canopy cover is
represented. The last return values can be used to obtain a digital
terrain model (DTM) where e.g. the forest floor instead of canopy
-cover is represented. The <b>filter</b> option allows to select one of
+cover is represented. The <b>return_filter</b> option allows to select one of
first, mid, or last returns.
<p>
+LiDAR points can be already classified into standardized classes. For example,
+class number 2 represents ground (for other classes see LAS format specification
+in references). The <b>class_filter</b> option allows to select one or more
+classes, as numbers (integers) separated by comma.
+<p>
The default map <b>type</b>=<tt>FCELL</tt> is intended as compromise between
preserving data precision and limiting system resource consumption.
@@ -280,6 +285,13 @@
<a href="v.surf.bspline.html">v.surf.bspline</a>
</em>
+<h2>REFERENCES</h2>
+<a href="http://www.asprs.org/Committee-General/LASer-LAS-File-Format-Exchange-Activities.html">
+ASPRS LAS format</a><br>
+<a href="http://www.liblas.org/">LAS library</a> <br>
+<a href="http://test.liblas.org/doxygen/liblas_8h.htm">LAS library C API</a> documentation
<h2>AUTHORS</h2>
Markus Metz<br>
Modified: grass/branches/releasebranch_7_0/vector/v.in.lidar/main.c
--- grass/branches/releasebranch_7_0/vector/v.in.lidar/main.c 2014-09-13 21:46:04 UTC (rev 61918)
+++ grass/branches/releasebranch_7_0/vector/v.in.lidar/main.c 2014-09-13 21:49:50 UTC (rev 61919)
@@ -111,7 +111,7 @@
int i;
float xmin = 0., ymin = 0., xmax = 0., ymax = 0.;
- struct Option *in_opt, *out_opt, *spat_opt, *filter_opt;
+ struct Option *in_opt, *out_opt, *spat_opt, *filter_opt, *class_opt;
struct Option *outloc_opt;
struct Flag *print_flag, *notab_flag, *region_flag, *notopo_flag;
struct Flag *over_flag, *extend_flag, *no_import_flag;
@@ -140,12 +140,14 @@
int las_point_format;
int have_time, have_color;
int return_filter;
+ int skipme;
+ int point_class;
unsigned int not_valid;
struct line_pnts *Points;
struct line_cats *Cats;
- unsigned int n_features, feature_count, n_outside, n_filtered;
+ unsigned int n_features, feature_count, n_outside, n_filtered, n_class_filtered;
int overwrite;
G_gisinit(argv[0]);
@@ -181,13 +183,22 @@
outloc_opt->key_desc = "name";
@@ -623,6 +634,7 @@
feature_count = 0;
n_outside = 0;
n_filtered = 0;
+ n_class_filtered = 0;
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -654,7 +666,7 @@
- int skipme = 1;
+ skipme = 1;
@@ -678,6 +690,22 @@
continue;
+ i = 0;
+ skipme = TRUE;
+ skipme = FALSE;
+ break;
+ i++;
+ if (skipme) {
+ n_class_filtered++;
+ continue;
Vect_append_point(Points, x, y, z);
Vect_cat_set(Cats, 1, cat);
@@ -782,13 +810,16 @@
Vect_build(&Map);
Vect_close(&Map);
- G_message(_("%d points imported"), n_features - not_valid - n_outside - n_filtered);
+ G_message(_("%d points imported"),
+ n_features - not_valid - n_outside - n_filtered - n_class_filtered);
if (not_valid)
G_message(_("%d input points were not valid"), not_valid);
if (n_outside)
G_message(_("%d input points were outside of the selected area"), n_outside);
if (n_filtered)
G_message(_("%d input points were filtered by return number"), n_filtered);
+ if (n_class_filtered)
+ G_message(_("%d input points were filtered by class number"), n_class_filtered);
/* Extend current window based on dataset. */
Modified: grass/branches/releasebranch_7_0/vector/v.in.lidar/v.in.lidar.html
--- grass/branches/releasebranch_7_0/vector/v.in.lidar/v.in.lidar.html 2014-09-13 21:46:04 UTC (rev 61918)
+++ grass/branches/releasebranch_7_0/vector/v.in.lidar/v.in.lidar.html 2014-09-13 21:49:50 UTC (rev 61919)
@@ -23,8 +23,13 @@
+<p>
<h2>Location Creation</h2>
@@ -71,7 +76,7 @@
<h2>REFERENCES</h2>
-<a href="http://www.asprs.org/a/society/committees/standards/lidar_exchange_format.html">
