[GRASS-SVN] r61981 - in grass/branches/releasebranch_7_0: . raster/r.bitpattern
Mon Sep 15 11:41:44 PDT 2014
Author: martinl
Date: 2014-09-15 11:41:44 -0700 (Mon, 15 Sep 2014)
New Revision: 61981
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/raster/r.bitpattern/main.c
r.bitpattern: remove -q (quiet) flag - replaced by standardized flag --q
              (merge r61980 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61829,61831,61851-61852,61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61921,61938,61967-61968,61975
   + /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61829,61831,61851-61852,61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61921,61938,61967-61968,61975,61980
Modified: grass/branches/releasebranch_7_0/raster/r.bitpattern/main.c
--- grass/branches/releasebranch_7_0/raster/r.bitpattern/main.c	2014-09-15 18:39:43 UTC (rev 61980)
+++ grass/branches/releasebranch_7_0/raster/r.bitpattern/main.c	2014-09-15 18:41:44 UTC (rev 61981)
@@ -23,7 +23,7 @@
  *			binary: 0000 -> integer: 0 -> patval=0
  *                 if value can be arbitray (0/1), then assume 0 value
- * COPYRIGHT:    (C) 2002 by the GRASS Development Team
+ * COPYRIGHT:    (C) 2002-2014 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
@@ -50,12 +50,10 @@
     int nrows, ncols;
     int row, col;
     int infd, outfd;
-    int verbose;
     RASTER_MAP_TYPE data_type;
     int pat, patv;
     struct GModule *module;
     struct Option *input, *output, *pattern, *patval;
-    struct Flag *flag1;
     G_gisinit(argv[0]);
@@ -82,18 +80,11 @@
     patval->required = YES;
     patval->description = _("Bit pattern value");
-    /* Define the different flags */
-    flag1 = G_define_flag();
-    flag1->key = 'q';
-    flag1->description = _("Quiet");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     name = input->answer;
     result = output->answer;
-    verbose = (!flag1->answer);
     pat = atoi(pattern->answer);
     patv = atoi(patval->answer);
@@ -117,8 +108,7 @@
     for (row = 0; row < nrows; row++) {
 	CELL c;
-	if (verbose)
-	    G_percent(row, nrows, 2);
+        G_percent(row, nrows, 2);
 	/* read input map */
 	Rast_get_row(infd, inrast, row, data_type);
@@ -137,11 +127,12 @@
 	Rast_put_row(outfd, outrast, data_type);
+    G_percent(1, 1, 1);
     G_free(inrast);
     G_free(outrast);
     Rast_close(infd);
     Rast_close(outfd);
-    return (EXIT_SUCCESS);
+    exit(EXIT_SUCCESS);
