[GRASS-SVN] r61982 - grass/branches/releasebranch_7_0/mswindows
svn_grass at osgeo.org
Mon Sep 15 11:51:01 PDT 2014
Author: hellik
Date: 2014-09-15 11:51:01 -0700 (Mon, 15 Sep 2014)
New Revision: 61982
Removed:
grass/branches/releasebranch_7_0/mswindows/FileAssociation.nsh
grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl
nsis: Clean downloaded MS runtime files by .onInstSuccess; remove not needed py file association (bat-file solution for python scripts) (merge from trunk: 61911,61951,61952)
Deleted: grass/branches/releasebranch_7_0/mswindows/FileAssociation.nsh
--- grass/branches/releasebranch_7_0/mswindows/FileAssociation.nsh 2014-09-15 18:41:44 UTC (rev 61981)
+++ grass/branches/releasebranch_7_0/mswindows/FileAssociation.nsh 2014-09-15 18:51:01 UTC (rev 61982)
@@ -1,190 +0,0 @@
-_____________________________________________________________________________
- File Association
- Based on code taken from http://nsis.sourceforge.net/File_Association
- Usage in script:
- 1. !include "FileAssociation.nsh"
- 2. [Section|Function]
- ${FileAssociationFunction} "Param1" "Param2" "..." $var
- [SectionEnd|FunctionEnd]
- FileAssociationFunction=[RegisterExtension|UnRegisterExtension]
- ${RegisterExtension} "[executable]" "[extension]" "[description]"
-"[executable]" ; executable which opens the file format
-"[extension]" ; extension, which represents the file format to open
-"[description]" ; description for the extension. This will be display in Windows Explorer.
- ${UnRegisterExtension} "[extension]" "[description]"
- Macros
- Change log window verbosity (default: 3=no script)
- Example:
- !include "FileAssociation.nsh"
- !insertmacro RegisterExtension
- ${FileAssociation_VERBOSE} 4 # all verbosity
- !insertmacro UnRegisterExtension
- ${FileAssociation_VERBOSE} 3 # no script
-!ifndef FileAssociation_INCLUDED
-!define FileAssociation_INCLUDED
-!include Util.nsh
-!verbose push
-!verbose 3
-!ifndef _FileAssociation_VERBOSE
- !define _FileAssociation_VERBOSE 3
-!endif
-!verbose ${_FileAssociation_VERBOSE}
-!define FileAssociation_VERBOSE `!insertmacro FileAssociation_VERBOSE`
-!verbose pop
-!macro FileAssociation_VERBOSE _VERBOSE
- !verbose push
- !verbose 3
- !undef _FileAssociation_VERBOSE
- !define _FileAssociation_VERBOSE ${_VERBOSE}
- !verbose pop
-!macroend
-!macro RegisterExtensionCall _EXECUTABLE _EXTENSION _DESCRIPTION
- !verbose push
- !verbose ${_FileAssociation_VERBOSE}
- Push `${_DESCRIPTION}`
- Push `${_EXTENSION}`
- Push `${_EXECUTABLE}`
- ${CallArtificialFunction} RegisterExtension_
- !verbose pop
-!macroend
-!macro UnRegisterExtensionCall _EXTENSION _DESCRIPTION
- !verbose push
- ${CallArtificialFunction} UnRegisterExtension_
- !verbose pop
-!macroend
-!define RegisterExtension `!insertmacro RegisterExtensionCall`
-!define un.RegisterExtension `!insertmacro RegisterExtensionCall`
-!macroend
-!macro un.RegisterExtension
-!macroend
-!macro RegisterExtension_
- !verbose push
- Exch $R2 ;exe
- Exch
- Exch $R1 ;ext
- Exch
- Exch 2
- Exch $R0 ;desc
- Exch 2
- Push $0
- Push $1
- ReadRegStr $1 HKCR $R1 "" ; read current file association
- StrCmp "$1" "" NoBackup ; is it empty
- StrCmp "$1" "$R0" NoBackup ; is it our own
- WriteRegStr HKCR $R1 "backup_val" "$1" ; backup current value
-NoBackup:
- WriteRegStr HKCR $R1 "" "$R0" ; set our file association
- ReadRegStr $0 HKCR $R0 ""
- StrCmp $0 "" 0 Skip
- WriteRegStr HKCR "$R0" "" "$R0"
- WriteRegStr HKCR "$R0\shell" "" "open"
- WriteRegStr HKCR "$R0\DefaultIcon" "" "$R2,0"
-Skip:
- WriteRegStr HKCR "$R0\shell\open\command" "" '"$R2" "%1"'
- WriteRegStr HKCR "$R0\shell\edit" "" "Edit $R0"
- WriteRegStr HKCR "$R0\shell\edit\command" "" '"$R2" "%1"'
- Pop $1
- Pop $0
- Pop $R2
- Pop $R1
- Pop $R0
- !verbose pop
-!macroend
-!define UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
-!define un.UnRegisterExtension `!insertmacro UnRegisterExtensionCall`
-!macroend
-!macro un.UnRegisterExtension
-!macroend
-!macro UnRegisterExtension_
- !verbose push
- Exch $R1 ;desc
- Exch
- Exch $R0 ;ext
- Exch
- Push $0
- Push $1
- ReadRegStr $1 HKCR $R0 ""
- StrCmp $1 $R1 0 NoOwn ; only do this if we own it
- ReadRegStr $1 HKCR $R0 "backup_val"
- StrCmp $1 "" 0 Restore ; if backup="" then delete the whole key
- DeleteRegKey HKCR $R0
- Goto NoOwn
-Restore:
- WriteRegStr HKCR $R0 "" $1
- DeleteRegValue HKCR $R0 "backup_val"
- DeleteRegKey HKCR $R1 ;Delete key with association name settings
-NoOwn:
- Pop $1
- Pop $0
- Pop $R1
- Pop $R0
- !verbose pop
-!macroend
-!endif # !FileAssociation_INCLUDED
Modified: grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl
--- grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl 2014-09-15 18:41:44 UTC (rev 61981)
+++ grass/branches/releasebranch_7_0/mswindows/GRASS-Installer.nsi.tmpl 2014-09-15 18:51:01 UTC (rev 61982)
@@ -59,7 +59,7 @@
!include "MUI2.nsh"
!include "LogicLib.nsh"
-!include "FileAssociation.nsh"
+!include "Sections.nsh"
@@ -632,10 +632,6 @@
WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "URLInfoAbout" "${WEB_SITE}"
WriteRegStr HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}" "Publisher" "${PUBLISHER}"
- ;File Association
- ;${registerExtension} "$INSTALL_DIR\extrabin\pythonw.exe" ".py" "Python File"
- ;${registerExtension} "$INSTALL_DIR\extrabin\pythonw.exe" ".pyc" "Compiled Python File"
- ;${registerExtension} "$INSTALL_DIR\extrabin\pythonw.exe" ".pyw" "Python File (no console)"
;Create the Desktop Shortcut
SetShellVarContext current
@@ -935,16 +931,13 @@
untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME"
Pop $0
StrCmp $0 "success" untar_ok untar_failed
+ ;move ExecWait, CopyFiles, Delete, RMDir commands out of the download function as these seems not to work if these are nested in a function
untar_ok:
ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe" /q'
ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe" /q'
ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe" /q'
CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTALL_DIR\extrabin"
- Delete "$TEMP\$ARCHIVE_NAME"
- RMDir /r "$TEMP\$ORIGINAL_UNTAR_FOLDER"
- ;the following doesn't work. Maybe because the installer is still running?
- RMDir "$TEMP\$ORIGINAL_UNTAR_FOLDER"
Goto end
download_failed:
@@ -1068,7 +1061,18 @@
SectionEnd
+;Clean downloaded MS runtime files by .onInstSuccess
+Function .onInstSuccess
+ ${If} ${SectionIsSelected} ${SecMSRuntime}
+ Delete "$TEMP\$ARCHIVE_NAME"
+ RMDir /r "$TEMP\$ORIGINAL_UNTAR_FOLDER"
+ RMDir "$TEMP\$ORIGINAL_UNTAR_FOLDER"
+ ${EndIf}
+FunctionEnd
;Uninstaller Section
Section "Uninstall"
@@ -1095,10 +1099,6 @@
DeleteRegKey HKLM "Software\${GRASS_BASE}"
DeleteRegKey HKLM "Software\Microsoft\Windows\CurrentVersion\Uninstall\${GRASS_BASE}"
- ;File Association
- ${unregisterExtension} ".py" "Python File"
- ${unregisterExtension} ".pyc" "Compiled Python File"
- ${unregisterExtension} ".pyw" "Python File (no console)"
SectionEnd
