[GRASS-SVN] r61983 - in grass/trunk: include lib/temporal/lib
svn_grass at osgeo.org
Mon Sep 15 15:29:55 PDT 2014
Author: huhabla
Date: 2014-09-15 15:29:55 -0700 (Mon, 15 Sep 2014)
New Revision: 61983
grass/trunk/include/temporal.h
grass/trunk/lib/temporal/lib/connect.c
grass/trunk/lib/temporal/lib/default_name.c
temporal library: Default temporal database path is now mapset specific. Correct handling of environment switch for mapset specific metadata reading.
Modified: grass/trunk/include/temporal.h
--- grass/trunk/include/temporal.h 2014-09-15 18:51:01 UTC (rev 61982)
+++ grass/trunk/include/temporal.h 2014-09-15 22:29:55 UTC (rev 61983)
@@ -7,7 +7,8 @@
#define TGISDB_DEFAULT_DRIVER "sqlite"
-#define TGISDB_DEFAULT_SQLITE_PATH "PERMANENT/tgis/sqlite.db"
+/* Default path in the current location */
+#define TGISDB_DEFAULT_SQLITE_PATH "tgis/sqlite.db"
int tgis_set_connection(dbConnection * connection);
Modified: grass/trunk/lib/temporal/lib/connect.c
--- grass/trunk/lib/temporal/lib/connect.c 2014-09-15 18:51:01 UTC (rev 61982)
+++ grass/trunk/lib/temporal/lib/connect.c 2014-09-15 22:29:55 UTC (rev 61983)
@@ -91,26 +91,28 @@
const char *val = NULL;
char *ret_val = NULL;
- const char *orig_mapset;
int ret;
- orig_mapset = G__getenv("MAPSET");
- ret = G__mapset_permissions2(G__getenv("GISDBASE"), G__getenv("LOCATION_NAME"), mapset);
+ ret = G__mapset_permissions2(G__getenv("GISDBASE"),
+ G__getenv("LOCATION_NAME"), mapset);
switch (ret) {
case 0:
- G_fatal_error(_("You don't have permission to access the mapset <%s>"),
+ G_warning(_("You don't have permission to access the mapset <%s>"),
mapset);
break;
case -1:
- G_fatal_error(_("Mapset <%s> does not exist."),
+ G_warning(_("Mapset <%s> does not exist."),
mapset);
break;
default:
break;
- G_setenv("MAPSET", mapset);
+ G_create_alt_env();
+ G__setenv("GISDBASE", G_gisdbase());
+ G__setenv("LOCATION_NAME", G_location());
+ G__setenv("MAPSET", mapset);
+ G__read_mapset_env();
if(contype == DATABASE_NAME) {
if ((val = G__getenv2("TGISDB_DATABASE", G_VAR_MAPSET)))
@@ -120,7 +122,7 @@
ret_val = G_store(val);
- G_setenv("MAPSET", orig_mapset);
+ G_switch_env();
return ret_val;
@@ -129,8 +131,8 @@
* \brief Get TGIS driver name from a specific mapset
- * This function will call G_fatal_error() in case the mapset does not exists
- * or it is not allowed to access the mapset.
+ * This function give a warning in case the mapset does not exists
+ * or it is not allowed to access the mapset. NULL is returned in this case.
* \param mapset The name of the mapset to receive the driver name from
@@ -145,8 +147,8 @@
* \brief Get TGIS database name
+ * or it is not allowed to access the mapset. NULL is returned in this case..
Modified: grass/trunk/lib/temporal/lib/default_name.c
--- grass/trunk/lib/temporal/lib/default_name.c 2014-09-15 18:51:01 UTC (rev 61982)
+++ grass/trunk/lib/temporal/lib/default_name.c 2014-09-15 22:29:55 UTC (rev 61983)
@@ -39,27 +39,10 @@
char *tgis_get_default_database_name(void)
char default_connection[2048];
- char use_current_mapset = 0;
- /* Check GRASS environmental variable if mapset specific
- * temporal databases should be created
+ G_snprintf(default_connection, 2048, "%s/%s/%s/%s", G_gisdbase(), G_location(),
+ G_mapset(), TGISDB_DEFAULT_SQLITE_PATH);
- if(G__getenv2("TGIS_USE_CURRENT_MAPSET", G_VAR_MAPSET)) {
- use_current_mapset = 1;
- } else {
- if(G__getenv2("TGIS_USE_CURRENT_MAPSET", G_VAR_GISRC))
- if(!use_current_mapset) {
- G_snprintf(default_connection, 2048, "%s/%s/%s", G_gisdbase(), G_location(),
- TGISDB_DEFAULT_SQLITE_PATH);
- } else {
- G_snprintf(default_connection, 2048, "%s/%s/%s/tgis/sqlite.db", G_gisdbase(), G_location(),
- G_mapset());
return G_store(default_connection);
