[GRASS-SVN] r61993 - grass/trunk/gui/wxpython/modules
svn_grass at osgeo.org
Tue Sep 16 04:31:29 PDT 2014
Author: martinl
Date: 2014-09-16 04:31:29 -0700 (Tue, 16 Sep 2014)
New Revision: 61993
grass/trunk/gui/wxpython/modules/extensions.py
wxGUI/extension: load data in different thread
Modified: grass/trunk/gui/wxpython/modules/extensions.py
--- grass/trunk/gui/wxpython/modules/extensions.py 2014-09-16 11:17:22 UTC (rev 61992)
+++ grass/trunk/gui/wxpython/modules/extensions.py 2014-09-16 11:31:29 UTC (rev 61993)
@@ -28,6 +28,7 @@
from core import globalvar
from core.gcmd import GError, RunCommand, GException, GMessage
from core.utils import SetAddOnPath, _
+from core.gthread import gThread
from core.menutree import TreeModel, ModuleNode
from gui_core.widgets import GListCtrl, SearchModuleWidget
from gui_core.treeview import CTreeView
@@ -63,6 +64,8 @@
self.search.showSearchResult.connect(lambda result: self.tree.Select(result))
# show text in statusbar when notification appears
self.search.showNotification.connect(lambda message: self.SetStatusText(message))
+ # load data in different thread
+ self.thread = gThread()
self.optionBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
label = " %s " % _("Options"))
@@ -187,14 +190,17 @@
wx.BeginBusyCursor()
self.SetStatusText(_("Fetching list of modules from GRASS-Addons SVN (be patient)..."), 0)
try:
- self.modelBuilder.Load(url = self.repo.GetValue().strip())
+ self.thread.Run(callable=self.modelBuilder.Load, url=self.repo.GetValue().strip(),
+ ondone=lambda event: self._fetchDone())
except GException as e:
+ self._fetchDone()
GError(unicode(e), parent = self, showTraceback = False)
+ def _fetchDone(self):
self.tree.RefreshItems()
self.SetStatusText("", 0)
wx.EndBusyCursor()
def OnContextMenu(self, node):
if not hasattr (self, "popupID"):
self.popupID = dict()
