[GRASS-SVN] r61994 - in grass/trunk: general/g.parser include include/defs lib/gis
svn_grass at osgeo.org
Tue Sep 16 05:05:44 PDT 2014
Author: glynn
Date: 2014-09-16 05:05:44 -0700 (Tue, 16 Sep 2014)
New Revision: 61994
Added:
grass/trunk/general/g.parser/rules.c
grass/trunk/general/g.parser/global.h
grass/trunk/general/g.parser/main.c
grass/trunk/general/g.parser/parse.c
grass/trunk/general/g.parser/proto.h
grass/trunk/include/defs/gis.h
grass/trunk/include/gis.h
grass/trunk/lib/gis/parser_dependencies.c
Extend g.parser to support dependency rules
Modified: grass/trunk/general/g.parser/global.h
--- grass/trunk/general/g.parser/global.h 2014-09-16 11:31:29 UTC (rev 61993)
+++ grass/trunk/general/g.parser/global.h 2014-09-16 12:05:44 UTC (rev 61994)
@@ -6,7 +6,8 @@
S_TOPLEVEL,
S_MODULE,
S_FLAG,
- S_OPTION
+ S_OPTION,
+ S_RULES
struct context
Modified: grass/trunk/general/g.parser/main.c
--- grass/trunk/general/g.parser/main.c 2014-09-16 11:31:29 UTC (rev 61993)
+++ grass/trunk/general/g.parser/main.c 2014-09-16 12:05:44 UTC (rev 61994)
@@ -129,6 +129,9 @@
case S_OPTION:
parse_option(&ctx, cmd, arg);
break;
+ case S_RULES:
+ parse_rule(&ctx, cmd, arg);
+ break;
Modified: grass/trunk/general/g.parser/parse.c
--- grass/trunk/general/g.parser/parse.c 2014-09-16 11:31:29 UTC (rev 61993)
+++ grass/trunk/general/g.parser/parse.c 2014-09-16 12:05:44 UTC (rev 61994)
@@ -62,6 +62,11 @@
return;
+ if (G_strcasecmp(cmd, "rules") == 0) {
+ ctx->state = S_RULES;
+ return;
fprintf(stderr, _("Unknown command \"%s\" at line %d\n"), cmd, ctx->line);
Modified: grass/trunk/general/g.parser/proto.h
--- grass/trunk/general/g.parser/proto.h 2014-09-16 11:31:29 UTC (rev 61993)
+++ grass/trunk/general/g.parser/proto.h 2014-09-16 12:05:44 UTC (rev 61994)
@@ -17,3 +17,6 @@
/* translate.c */
char *translate(const char *);
+/* rules.c */
+void parse_rule(struct context *, const char *, const char *);
Added: grass/trunk/general/g.parser/rules.c
--- grass/trunk/general/g.parser/rules.c (rev 0)
+++ grass/trunk/general/g.parser/rules.c 2014-09-16 12:05:44 UTC (rev 61994)
@@ -0,0 +1,92 @@
+#include <string.h>
+#include "proto.h"
+#include <grass/glocale.h>
+static void *find_flag(const struct context *ctx, int key)
+ struct Flag *flag;
+ for (flag = ctx->first_flag; flag; flag = flag->next_flag)
+ if (flag->key == key)
+ return flag;
+ fprintf(stderr, _("Unknown flag \"-%c\" in rule\n"), key);
+ return NULL;
+static void *find_option(const struct context *ctx, const char *key)
+ struct Option *option;
+ for (option = ctx->first_option; option; option = option->next_opt)
+ if (G_strcasecmp(option->key, key) == 0)
+ return option;
+ fprintf(stderr, _("Unknown option \"%s\" in rule\n"), key);
+ return NULL;
+static void add_rule(struct context *ctx, int type, const char *data)
+ char **tokens;
+ int ntokens;
+ void **opts;
+ int i;
+ tokens = G_tokenize(data, ",");
+ ntokens = G_number_of_tokens(tokens);
+ opts = G_malloc(ntokens * sizeof(void *));
+ for (i = 0; i < ntokens; i++) {
+ char buf[256];
+ char *name;
+ strcpy(buf, tokens[i]);
+ name = G_chop(buf);
+ opts[i] = (name[0] == '-')
+ ? find_flag(ctx, name[1])
+ : find_option(ctx, name);
+ G_free_tokens(tokens);
+ G__option_rule(type, ntokens, opts);
+void parse_rule(struct context *ctx, const char *cmd, const char *arg)
+ if (G_strcasecmp(cmd, "exclusive") == 0) {
+ add_rule(ctx, RULE_EXCLUSIVE, arg);
+ return;
+ if (G_strcasecmp(cmd, "requires") == 0) {
+ add_rule(ctx, RULE_REQUIRES, arg);
+ return;
+ if (G_strcasecmp(cmd, "requires_all") == 0) {
+ add_rule(ctx, RULE_REQUIRES_ALL, arg);
+ return;
+ if (G_strcasecmp(cmd, "excludes") == 0) {
+ add_rule(ctx, RULE_EXCLUDES, arg);
+ return;
+ if (G_strcasecmp(cmd, "collective") == 0) {
+ add_rule(ctx, RULE_COLLECTIVE, arg);
+ return;
+ if (G_strcasecmp(cmd, "end") == 0) {
+ ctx->state = S_TOPLEVEL;
+ return;
+ fprintf(stderr, _("Unknown rule type \"%s\" at line %d\n"),
+ cmd, ctx->line);
Property changes on: grass/trunk/general/g.parser/rules.c
___________________________________________________________________
Added: svn:mime-type
+ text/x-csrc
Added: svn:eol-style
+ native
Modified: grass/trunk/include/defs/gis.h
--- grass/trunk/include/defs/gis.h 2014-09-16 11:31:29 UTC (rev 61993)
+++ grass/trunk/include/defs/gis.h 2014-09-16 12:05:44 UTC (rev 61994)
@@ -516,11 +516,12 @@
void G_close_option_file(FILE *);
/* parser_dependencies.c */
-void G_option_exclusive(void *first, ...);
-void G_option_required(void *first, ...);
-void G_option_requires(void *first, ...);
-void G_option_requires_all(void *first, ...);
-void G_option_collective(void *first, ...);
+void G__option_rule(int, int, void **);
+void G_option_exclusive(void *, ...);
+void G_option_required(void *, ...);
+void G_option_requires(void *, ...);
+void G_option_requires_all(void *, ...);
+void G_option_collective(void *, ...);
/* paths.c */
int G_mkdir(const char *);
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h 2014-09-16 11:31:29 UTC (rev 61993)
+++ grass/trunk/include/gis.h 2014-09-16 12:05:44 UTC (rev 61994)
@@ -305,6 +305,16 @@
G_FLG_V_TOPO, /*!< do not build topology */
} STD_FLG;
+/* Parser rules for G__option_rule() */
+enum rule_type {
+ RULE_EXCLUSIVE,
+ RULE_REQUIRED,
+ RULE_REQUIRES,
+ RULE_REQUIRES_ALL,
+ RULE_EXCLUDES,
+ RULE_COLLECTIVE
/* Message format */
#define G_INFO_FORMAT_STANDARD 0 /* GRASS_MESSAGE_FORMAT=standard or not defined */
#define G_INFO_FORMAT_GUI 1 /* GRASS_MESSAGE_FORMAT=gui */
Modified: grass/trunk/lib/gis/parser_dependencies.c
--- grass/trunk/lib/gis/parser_dependencies.c 2014-09-16 11:31:29 UTC (rev 61993)
+++ grass/trunk/lib/gis/parser_dependencies.c 2014-09-16 12:05:44 UTC (rev 61994)
@@ -20,15 +20,6 @@
#include "parser_local_proto.h"
-enum rule_type {
- RULE_EXCLUSIVE,
- RULE_REQUIRED,
- RULE_REQUIRES,
- RULE_REQUIRES_ALL,
- RULE_EXCLUDES,
- RULE_COLLECTIVE
struct vector {
size_t elsize;
size_t increment;
@@ -68,11 +59,21 @@
static struct vector rules = {sizeof(struct rule), 50};
+void G__option_rule(int type, int nopts, void **opts)
+ struct rule rule;
+ rule.type = type;
+ rule.count = nopts;
+ rule.opts = opts;
+ vector_append(&rules, &rule);
static void make_rule(int type, void *first, va_list ap)
struct vector opts;
void *opt;
- struct rule rule;
vector_new(&opts, sizeof(void *), 10);
@@ -85,11 +86,7 @@
vector_append(&opts, &opt);
- rule.type = type;
- rule.count = opts.count;
- rule.opts = (void**) opts.data;
- vector_append(&rules, &rule);
+ G__option_rule(type, opts.count, (void**) opts.data);
static int is_flag(const void *p)
