[GRASS-SVN] r62044 - in grass/branches/releasebranch_7_0/raster: r.cost r.walk
svn_grass at osgeo.org
Sat Sep 20 07:37:10 PDT 2014
Author: mmetz
Date: 2014-09-20 07:37:10 -0700 (Sat, 20 Sep 2014)
New Revision: 62044
grass/branches/releasebranch_7_0/raster/r.cost/main.c
grass/branches/releasebranch_7_0/raster/r.walk/main.c
sync r.cost and r.walk
Modified: grass/branches/releasebranch_7_0/raster/r.cost/main.c
--- grass/branches/releasebranch_7_0/raster/r.cost/main.c 2014-09-20 14:36:46 UTC (rev 62043)
+++ grass/branches/releasebranch_7_0/raster/r.cost/main.c 2014-09-20 14:37:10 UTC (rev 62044)
@@ -319,7 +319,7 @@
Rast_set_d_null_value(&null_cost, 1);
else if (keep_nulls)
- G_debug(1, "Null cell will be retained into output map");
+ G_debug(1,"Input null cell will be retained into output map");
if (opt7->answer) {
search_mapset = G_find_vector2(opt7->answer, "");
@@ -405,7 +405,7 @@
mem_mb = (double) srows * scols * 24. / 1048576. * segments_in_memory;
mem_mb += nrows * ncols * 0.05 * 20. / 1048576.; /* for Dijkstra search */
if (flag5->answer) {
fprintf(stdout, _("Will need at least %.2f MB of disk space"), disk_mb);
fprintf(stdout, "\n");
@@ -431,7 +431,6 @@
if (segment_open(&dir_seg, G_tempfile(), nrows, ncols, srows, scols,
sizeof(FCELL), segments_in_memory) != 1)
G_fatal_error(_("Can not create temporary file"));
/* Write the cost layer in the segmented file */
@@ -495,14 +494,11 @@
if (dir == TRUE) {
- int i;
G_message(_("Initializing directional output..."));
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 2);
- for (i = 0; i < ncols; i++) {
- segment_put(&dir_seg, &dnullval, row, i);
+ for (col = 0; col < ncols; col++) {
+ segment_put(&dir_seg, &dnullval, row, col);
G_percent(1, 1, 1);
@@ -511,7 +507,7 @@
* Create a heap of starting points ordered by increasing costs.
init_heap();
/* read vector with start points */
if (opt7->answer) {
struct Map_info In;
@@ -646,7 +642,7 @@
Vect_close(&In);
if (!have_stop_points)
- G_warning(_("No stop points found in vector <%s>"), opt8->answer);
+ G_fatal_error(_("No stop points found in vector <%s>"), opt8->answer);
/* read raster with start points */
@@ -660,7 +656,7 @@
if (search_mapset == NULL)
G_fatal_error(_("Raster map <%s> not found"), opt9->answer);
fd = Rast_open_old(opt9->answer, search_mapset);
data_type2 = Rast_get_map_type(fd);
nearest_data_type = data_type2;
@@ -724,7 +720,6 @@
insert(zero, top_start_pt->row, top_start_pt->col);
segment_get(&cost_seg, &costs, top_start_pt->row,
top_start_pt->col);
costs.cost_out = *value;
costs.nearest = top_start_pt->value;
@@ -741,6 +736,8 @@
* 3) Free the memory allocated to the present cell.
+ G_debug(1, "total cells: %ld", total_cells);
+ G_debug(1, "nrows x ncols: %d", nrows * ncols);
G_message(_("Finding cost path..."));
n_processed = 0;
@@ -768,12 +765,12 @@
- row = pres_cell->row;
- col = pres_cell->col;
my_cost = costs.cost_in;
nearest = costs.nearest;
+ row = pres_cell->row;
+ col = pres_cell->col;
G_percent(n_processed++, total_cells, 1);
/* 9 10 Order in which neighbors
@@ -881,99 +878,86 @@
if (col < 0 || col >= ncols)
continue;
+ min_cost = dnullval;
+ segment_get(&cost_seg, &costs, row, col);
switch (neighbor) {
case 1:
- segment_get(&cost_seg, &costs, row, col);
W = costs.cost_in;
fcost = (double)(W + my_cost);
min_cost = pres_cell->min_cost + fcost * EW_fac;
break;
case 2:
E = costs.cost_in;
fcost = (double)(E + my_cost);
break;
case 3:
N = costs.cost_in;
fcost = (double)(N + my_cost);
min_cost = pres_cell->min_cost + fcost * NS_fac;
break;
case 4:
S = costs.cost_in;
fcost = (double)(S + my_cost);
break;
case 5:
NW = costs.cost_in;
fcost = (double)(NW + my_cost);
min_cost = pres_cell->min_cost + fcost * DIAG_fac;
break;
case 6:
NE = costs.cost_in;
fcost = (double)(NE + my_cost);
break;
case 7:
SE = costs.cost_in;
fcost = (double)(SE + my_cost);
break;
case 8:
SW = costs.cost_in;
fcost = (double)(SW + my_cost);
break;
case 9:
NNW = costs.cost_in;
fcost = (double)(N + NW + NNW + my_cost);
min_cost = pres_cell->min_cost + fcost * V_DIAG_fac;
break;
case 10:
NNE = costs.cost_in;
fcost = (double)(N + NE + NNE + my_cost);
break;
case 11:
SSE = costs.cost_in;
fcost = (double)(S + SE + SSE + my_cost);
break;
case 12:
SSW = costs.cost_in;
fcost = (double)(S + SW + SSW + my_cost);
break;
case 13:
WNW = costs.cost_in;
fcost = (double)(W + NW + WNW + my_cost);
min_cost = pres_cell->min_cost + fcost * H_DIAG_fac;
break;
case 14:
ENE = costs.cost_in;
fcost = (double)(E + NE + ENE + my_cost);
break;
case 15:
ESE = costs.cost_in;
fcost = (double)(E + SE + ESE + my_cost);
break;
case 16:
WSW = costs.cost_in;
fcost = (double)(W + SW + WSW + my_cost);
@@ -984,6 +968,7 @@
if (Rast_is_d_null_value(&min_cost))
continue;
old_min_cost = costs.cost_out;
/* add to list */
@@ -1015,9 +1000,8 @@
delete(pres_cell);
pres_cell = get_lowest();
- if (ct == pres_cell) {
+ if (ct == pres_cell)
G_warning(_("Error, ct == pres_cell"));
G_percent(1, 1, 1);
@@ -1194,7 +1178,7 @@
- /* Create colours for output map */
+ /* Create colours for output map */
* Rast_read_range (cum_cost_layer, current_mapset, &range);
@@ -1203,8 +1187,8 @@
* Rast_write_colors (cum_cost_layer,current_mapset,&colors);
- G_done_msg(_("Peak cost value: %f."), peak);
+ G_done_msg(_("Peak cost value: %g"), peak);
exit(EXIT_SUCCESS);
@@ -1231,7 +1215,7 @@
if (east < window.west || east > window.east ||
north < window.south || north > window.north) {
- G_warning(_("Warning, ignoring point outside window: %.4f,%.4f"),
+ G_warning(_("Warning, ignoring point outside window: %g, %g"),
east, north);
continue;
Modified: grass/branches/releasebranch_7_0/raster/r.walk/main.c
--- grass/branches/releasebranch_7_0/raster/r.walk/main.c 2014-09-20 14:36:46 UTC (rev 62043)
+++ grass/branches/releasebranch_7_0/raster/r.walk/main.c 2014-09-20 14:37:10 UTC (rev 62044)
@@ -123,7 +123,6 @@
const char *dtm_mapset, *cost_mapset, *search_mapset;
void *dtm_cell, *cost_cell, *cum_cell, *dir_cell, *cell2 = NULL;
SEGMENT cost_seg, dir_seg;
- const char *in_file, *dir_out_file = NULL;
double *value;
char buf[400];
extern struct Cell_head window;
@@ -139,7 +138,6 @@
int segments_in_memory;
int cost_fd, cum_fd, dtm_fd, dir_fd;
int have_stop_points = 0, dir = 0;
- int in_fd, dir_out_fd = 0;
double my_dtm, my_cost, check_dtm;
double null_cost, dnullval;
double a, b, c, d, lambda, slope_factor;
@@ -169,6 +167,7 @@
struct History history;
double peak = 0.0;
int dtm_dsize, cost_dsize;
+ double disk_mb, mem_mb;
/* Definition for dimension and region check */
struct Cell_head dtm_cellhd, cost_cellhd;
@@ -240,6 +239,7 @@
opt5 = G_define_option();
opt5->key = "max_cost";
opt5->type = TYPE_INTEGER;
+ opt5->key_desc = "value";
opt5->required = NO;
opt5->multiple = NO;
opt5->answer = "0";
@@ -248,18 +248,20 @@
opt6 = G_define_option();
opt6->key = "null_cost";
opt6->type = TYPE_DOUBLE;
+ opt6->key_desc = "value";
opt6->required = NO;
opt6->multiple = NO;
opt6->description =
_("Cost assigned to null cells. By default, null cells are excluded");
opt6->guisection = _("NULL cells");
opt10 = G_define_option();
opt10->key = "percent_memory";
opt10->type = TYPE_INTEGER;
+ opt10->key_desc = "value";
opt10->required = NO;
opt10->multiple = NO;
- opt10->answer = "100";
+ opt10->answer = "40";
opt10->options = "0-100";
opt10->description = _("Percent of map to keep in memory");
@@ -308,10 +310,10 @@
flag4->key = 'r';
flag4->description = _("Start with values in raster map");
flag4->guisection = _("Start");
flag5 = G_define_flag();
flag5->key = 'i';
- flag5->description = _("Only print info about disk space and memory requirements");
+ flag5->description = _("Print info about disk space and memory requirements and exit");
/* Parse options */
if (G_parser(argc, argv))
@@ -321,11 +323,6 @@
if (opt11->answer != NULL)
dir = 1;
- /* Initalize access to database and create temporary files */
- in_file = G_tempfile();
- if (dir == 1)
- dir_out_file = G_tempfile();
/* Get database window parameters */
Rast_get_window(&window);
@@ -419,7 +416,7 @@
if (!Rast_is_d_null_value(&null_cost)) {
if (null_cost < 0.0) {
- G_warning(_("Warning: assigning negative cost to null cell. Null cells excluded."));
+ G_warning(_("Assigning negative cost to null cell. Null cells excluded."));
@@ -513,62 +510,45 @@
segments_in_memory = 1;
/* report disk space and memory requirements */
- G_message("--------------------------------------------");
if (dir == 1) {
- double disk_mb, mem_mb;
disk_mb = (double) nrows * ncols * 28. / 1048576.;
mem_mb = (double) srows * scols * 28. / 1048576. * segments_in_memory;
- G_message(_("Will need at least %.2f MB of disk space"), disk_mb);
- G_message(_("Will need at least %.2f MB of memory"), mem_mb);
else {
disk_mb = (double) nrows * ncols * 24. / 1048576.;
+ fprintf(stdout, _("Will need at least %.2f MB of disk space"), disk_mb);
+ fprintf(stdout, "\n");
+ fprintf(stdout, _("Will need at least %.2f MB of memory"), mem_mb);
Rast_close(cost_fd);
Rast_close(dtm_fd);
exit(EXIT_SUCCESS);
- /* Create segmented format file for cost layer and output layer */
+ G_verbose_message("--------------------------------------------");
+ G_verbose_message(_("Will need at least %.2f MB of disk space"), disk_mb);
+ G_verbose_message(_("Will need at least %.2f MB of memory"), mem_mb);
+ /* Create segmented format files for cost layer and output layer */
G_verbose_message(_("Creating some temporary files..."));
- in_fd = creat(in_file, 0600);
- if (segment_format(in_fd, nrows, ncols, srows, scols, sizeof(struct cc)) != 1)
- G_fatal_error("can not create temporary file");
+ if (segment_open(&cost_seg, G_tempfile(), nrows, ncols, srows, scols,
+ sizeof(struct cc), segments_in_memory) != 1)
+ G_fatal_error(_("Can not create temporary file"));
- close(in_fd);
if (dir == 1) {
- dir_out_fd = creat(dir_out_file, 0600);
- if (segment_format(dir_out_fd, nrows, ncols, srows, scols,
- sizeof(FCELL)) != 1)
- close(dir_out_fd);
+ if (segment_open(&dir_seg, G_tempfile(), nrows, ncols, srows, scols,
+ sizeof(FCELL), segments_in_memory) != 1)
- /* Open and initialize all segment files */
- in_fd = open(in_file, 2);
- if (segment_init(&cost_seg, in_fd, segments_in_memory) != 1)
- G_fatal_error("can not initialize temporary file");
- if (dir == 1) {
- dir_out_fd = open(dir_out_file, 2);
- if (segment_init(&dir_seg, dir_out_fd, segments_in_memory) != 1)
/* Write the dtm and cost layers in the segmented file */
G_message(_("Reading raster maps <%s> and <%s>, initializing output..."),
G_fully_qualified_name(dtm_layer, dtm_mapset),
@@ -655,7 +635,7 @@
if (dir == 1) {
- G_message(_("Initializing directional output "));
+ G_message(_("Initializing directional output..."));
@@ -679,8 +659,6 @@
struct start_pt *new_start_pt;
int type, got_one = 0;
- G_message(_("Reading vector map <%s> with start points..."), opt7->answer);
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -689,6 +667,9 @@
if (1 > Vect_open_old(&In, opt7->answer, ""))
G_fatal_error(_("Unable to open vector map <%s>"), opt7->answer);
+ G_message(_("Reading vector map <%s> with start points..."),
+ Vect_get_full_name(&In));
Vect_rewind(&In);
Vect_region_box(&window, &box);
@@ -821,9 +802,8 @@
if (!cell2)
G_fatal_error(_("Unable to allocate memory"));
- G_message(_("Reading %s... "), opt9->answer);
+ G_message(_("Reading raster map <%s> with start points..."), opt9->answer);
Rast_get_row(fd, cell2, row, data_type2);
ptr2 = cell2;
@@ -851,14 +831,13 @@
ptr2 = G_incr_void_ptr(ptr2, dsize2);
G_percent(1, 1, 1);
Rast_close(fd);
G_free(cell2);
if (!got_one)
- G_fatal_error(_("No start points found in raster <%s>"), opt9->answer);
+ G_fatal_error(_("No start points"));
/* If the starting points are given on the command line start a linked
@@ -892,7 +871,7 @@
- G_message(_("Finding cost path"));
+ G_message(_("Finding cost path..."));
n_processed = 0;
@@ -1052,6 +1031,7 @@
switch (neighbor) {
case 1:
W_dtm = costs.dtm;
@@ -1341,19 +1321,23 @@
+ /* add to list */
if (Rast_is_d_null_value(&old_min_cost)) {
costs.cost_out = min_cost;
segment_put(&cost_seg, &costs, row, col);
insert(min_cost, row, col);
- if (dir == 1)
+ if (dir == 1) {
segment_put(&dir_seg, &cur_dir, row, col);
+ /* update with lower costs */
else if (old_min_cost > min_cost) {
- if (dir == 1)
+ if (dir == 1) {
@@ -1376,7 +1360,7 @@
cum_cell = Rast_allocate_buf(cum_data_type);
/* Copy segmented map to output map */
- G_message(_("Writing output raster map %s... "), cum_cost_layer);
+ G_message(_("Writing output raster map <%s>... "), cum_cost_layer);
cell2 = Rast_allocate_buf(dtm_data_type);
@@ -1440,7 +1424,7 @@
dir_fd = Rast_open_new(move_dir_layer, dir_data_type);
dir_cell = Rast_allocate_buf(dir_data_type);
- G_message(_("Writing movement direction file %s..."), move_dir_layer);
+ G_message(_("Writing output movement direction raster map <%s>..."), move_dir_layer);
p = dir_cell;
@@ -1449,25 +1433,21 @@
p = G_incr_void_ptr(p, dir_size);
Rast_put_row(dir_fd, dir_cell, dir_data_type);
+ G_percent(row, nrows, 2);
G_percent(1, 1, 1);
G_free(dir_cell);
- segment_release(&cost_seg); /* release memory */
+ segment_close(&cost_seg); /* release memory */
if (dir == 1)
- segment_release(&dir_seg);
+ segment_close(&dir_seg);
Rast_close(dtm_fd);
Rast_close(cum_fd);
if (dir == 1)
Rast_close(dir_fd);
- close(in_fd); /* close all files */
- if (dir == 1)
- unlink(in_file); /* remove submatrix files */
- if (dir == 1)
- unlink(dir_out_file);
/* writing history file */
Rast_short_history(cum_cost_layer, "raster", &history);
@@ -1489,21 +1469,17 @@
* Rast_write_colors (cum_cost_layer,"",&colors);
- G_done_msg(_("Peak cost value: %g."), peak);
exit(EXIT_SUCCESS);
int
process_answers(char **answers, struct start_pt **points,
struct start_pt **top_start_pt)
int col, row;
double east, north;
int got_one = 0;
@@ -1549,9 +1525,6 @@
return (got_one);
int time_to_stop(int row, int col)
static int total = 0;
