[GRASS-SVN] r62045 - in grass/trunk: include/defs lib/vector/Vlib
Sat Sep 20 07:46:53 PDT 2014
Author: mmetz
Date: 2014-09-20 07:46:53 -0700 (Sat, 20 Sep 2014)
New Revision: 62045
Added:
   grass/trunk/lib/vector/Vlib/intersect2.c
   grass/trunk/include/defs/vector.h
Vlib: add Bentley-Ottmann algorithm to find line intersections
Modified: grass/trunk/include/defs/vector.h
--- grass/trunk/include/defs/vector.h	2014-09-20 14:37:10 UTC (rev 62044)
+++ grass/trunk/include/defs/vector.h	2014-09-20 14:46:53 UTC (rev 62045)
@@ -439,9 +439,16 @@
                            struct bound_box *, struct bound_box *,
                            struct line_pnts ***, struct line_pnts ***, int *,
                            int *, int);
+int Vect_line_intersection2(struct line_pnts *, struct line_pnts *,
+                            struct bound_box *, struct bound_box *,
+                            struct line_pnts ***, struct line_pnts ***, int *,
+                            int *, int);
 int Vect_line_check_intersection(struct line_pnts *, struct line_pnts *, int);
+int Vect_line_check_intersection2(struct line_pnts *, struct line_pnts *, int);
 int Vect_line_get_intersections(struct line_pnts *, struct line_pnts *,
+int Vect_line_get_intersections2(struct line_pnts *, struct line_pnts *,
+                                 struct line_pnts *, int);
 char *Vect_subst_var(const char *, const struct Map_info *);
 /* Custom spatial index */
Copied: grass/trunk/lib/vector/Vlib/intersect2.c (from rev 61910, grass/trunk/lib/vector/Vlib/intersect.c)
--- grass/trunk/lib/vector/Vlib/intersect2.c	                        (rev 0)
+++ grass/trunk/lib/vector/Vlib/intersect2.c	2014-09-20 14:46:53 UTC (rev 62045)
@@ -0,0 +1,1422 @@
+   \file lib/vector/Vlib/intersect.c
+   \brief Vector library - intersection
+   Higher level functions for reading/writing/manipulating vectors.
+   Some parts of code taken from grass50 v.spag/linecros.c
+   Based on the following:
+   <code>
+   (ax2-ax1)r1 - (bx2-bx1)r2 = ax2 - ax1
+   (ay2-ay1)r1 - (by2-by1)r2 = ay2 - ay1
+   </code>
+   Solving for r1 and r2, if r1 and r2 are between 0 and 1, then line
+   segments (ax1,ay1)(ax2,ay2) and (bx1,by1)(bx2,by2) intersect.
+   Intersect 2 line segments.
+   Returns: 0 - do not intersect
+   1 - intersect at one point
+   <pre>
+   2 - partial overlap         ( \/                      )
+   ------      a          (    distance < threshold )
+   ------   b          (                         )
+   3 - a contains b            ( /\                      )
+   ----------  a    ----------- a
+   ----     b          ----- b
+   4 - b contains a
+   ----     a          ----- a
+   ----------  b    ----------- b
+   5 - identical
+   ----------  a
+   ----------  b
+   </pre>
+   Intersection points:
+   <pre>
+   return  point1 breakes: point2 breaks:    distance1 on:   distance2 on:
+   0        -              -                  -              -
+   1        a,b            -                  a              b
+   2        a              b                  a              b
+   3        a              a                  a              a
+   4        b              b                  b              b
+   5        -              -                  -              -
+   </pre>
+   Sometimes (often) is important to get the same coordinates for a x
+   b and b x a.  To reach this, the segments a,b are 'sorted' at the
+   beginning, so that for the same switched segments, results are
+   identical. (reason is that double values are always rounded because
+   of limited number of decimal places and for different order of
+   coordinates, the results would be different)
+   (C) 2001-2014 by the GRASS Development Team
+   This program is free software under the GNU General Public License
+   (>=v2).  Read the file COPYING that comes with GRASS for details.
+   \author Original author CERL, probably Dave Gerdes or Mike Higgins.
+   \author Update to GRASS 5.7 Radim Blazek.
+   \author Update to GRASS 7 Markus Metz.
+#include <stdlib.h>
+#include <stdio.h>
+#include <unistd.h>
+#include <math.h>
+#include <grass/vector.h>
+#include <grass/rbtree.h>
+#include <grass/glocale.h>
+/* function prototypes */
+static int cmp_cross(const void *pa, const void *pb);
+static void add_cross(int asegment, double adistance, int bsegment,
+		      double bdistance, double x, double y);
+static double dist2(double x1, double y1, double x2, double y2);
+static int debug_level = -1;
+#if 0
+static int ident(double x1, double y1, double x2, double y2, double thresh);
+#endif
+static int cross_seg(int i, int j);
+static int find_cross(int i, int j);
+typedef struct
+{				/* in arrays 0 - A line , 1 - B line */
+    int segment[2];		/* segment number, start from 0 for first */
+    double distance[2];
+    double x, y, z;
+} CROSS;
+/* Current line in arrays is for some functions like cmp() set by: */
+static int current;
+static int second;		/* line which is not current */
+static int a_cross = 0;
+static int n_cross;
+static CROSS *cross = NULL;
+static int *use_cross = NULL;
+static double rethresh = 0.000001;	/* TODO */
+    if (n_cross == a_cross) {
+	/* Must be space + 1, used later for last line point, do it better */
+	cross =
+	    (CROSS *) G_realloc((void *)cross,
+				(a_cross + 101) * sizeof(CROSS));
+	use_cross =
+	    (int *)G_realloc((void *)use_cross,
+			     (a_cross + 101) * sizeof(int));
+	a_cross += 100;
+    G_debug(5,
+	    "  add new cross: aseg/dist = %d/%f bseg/dist = %d/%f, x = %f y = %f",
+	    asegment, adistance, bsegment, bdistance, x, y);
+    cross[n_cross].segment[0] = asegment;
+    cross[n_cross].distance[0] = adistance;
+    cross[n_cross].segment[1] = bsegment;
+    cross[n_cross].distance[1] = bdistance;
+    cross[n_cross].x = x;
+    cross[n_cross].y = y;
+    n_cross++;
+    CROSS *p1 = (CROSS *) pa;
+    CROSS *p2 = (CROSS *) pb;
+    if (p1->segment[current] < p2->segment[current])
+	return -1;
+    if (p1->segment[current] > p2->segment[current])
+	return 1;
+    /* the same segment */
+    if (p1->distance[current] < p2->distance[current])
+	return -1;
+    if (p1->distance[current] > p2->distance[current])
+	return 1;
+    return 0;
+    double dx, dy;
+    dx = x2 - x1;
+    dy = y2 - y1;
+    return (dx * dx + dy * dy);
+#if 0
+/* returns 1 if points are identical */
+    double dx, dy;
+    dx = x2 - x1;
+    dy = y2 - y1;
+    if ((dx * dx + dy * dy) <= thresh * thresh)
+	return 1;
+    return 0;
+#endif
+/* shared by Vect_line_intersection, Vect_line_check_intersection, cross_seg, find_cross */
+static struct line_pnts *APnts, *BPnts, *ABPnts[2], *IPnts;
+/* break segments */
+    double x1, y1, z1, x2, y2, z2;
+    double y1min, y1max, y2min, y2max;
+    int ret;
+    y1min = APnts->y[i];
+    y1max = APnts->y[i + 1];
+    if (APnts->y[i] > APnts->y[i + 1]) {
+	y1min = APnts->y[i + 1];
+	y1max = APnts->y[i];
+    y2min = BPnts->y[j];
+    y2max = BPnts->y[j + 1];
+    if (BPnts->y[j] > BPnts->y[j + 1]) {
+	y2min = BPnts->y[j + 1];
+	y2max = BPnts->y[j];
+    if (y1min > y2max || y1max < y2min)
+	return 0;
+    ret = Vect_segment_intersection(APnts->x[i], APnts->y[i], APnts->z[i],
+				    APnts->x[i + 1], APnts->y[i + 1],
+				    APnts->z[i + 1], BPnts->x[j], BPnts->y[j],
+				    BPnts->z[j], BPnts->x[j + 1],
+				    BPnts->y[j + 1], BPnts->z[j + 1], &x1,
+				    &y1, &z1, &x2, &y2, &z2, 0);
+    /* add ALL (including end points and duplicates), clean later */
+    if (ret > 0) {
+	G_debug(2, "  -> %d x %d: intersection type = %d", i, j, ret);
+	if (ret == 1) {		/* one intersection on segment A */
+	    G_debug(3, "    in %f, %f ", x1, y1);
+	    add_cross(i, 0.0, j, 0.0, x1, y1);
+	else if (ret == 2 || ret == 3 || ret == 4 || ret == 5) {
+	    /*  partial overlap; a broken in one, b broken in one
+	     *  or a contains b; a is broken in 2 points (but 1 may be end)
+	     *  or b contains a; b is broken in 2 points (but 1 may be end)
+	     *  or identical */
+	    G_debug(3, "    in %f, %f; %f, %f", x1, y1, x2, y2);
+	    add_cross(i, 0.0, j, 0.0, x2, y2);
+    return 1;			/* keep going */
+/* event queue for Bentley-Ottmann */
+#define QEVT_IN 1
+#define QEVT_OUT 2
+#define QEVT_CRS 3
+#define GET_PARENT(p, c) ((p) = (int) (((c) - 2) / 3 + 1))
+#define GET_CHILD(c, p) ((c) = (int) (((p) * 3) - 1))
+struct qitem
+    int l;	/* line 0 - A line , 1 - B line */
+    int s;	/* segment index */
+    int p;	/* point index */
+    int e;	/* event type */
+struct boq
+    int count;
+    int alloc;
+    struct qitem *i;
+/* compare two queue points */
+/* return 1 if a < b else 0 */
+static int cmp_q_x(struct qitem *a, struct qitem *b)
+    x1 = ABPnts[a->l]->x[a->p];
+    y1 = ABPnts[a->l]->y[a->p];
+    z1 = ABPnts[a->l]->z[a->p];
+    x2 = ABPnts[b->l]->x[b->p];
+    y2 = ABPnts[b->l]->y[b->p];
+    z2 = ABPnts[b->l]->z[b->p];
+    if (x1 < x2)
+	return 1;
+    if (x1 > x2)
+	return 0;
+    if (y1 < y2)
+	return 1;
+    if (y1 > y2)
+	return 0;
+    if (z1 < z2)
+	return 1;
+    if (z1 > z2)
+	return 0;
+    if (a->e < b->e)
+	return 1;
+    if (a->l < b->l)
+	return 1;
+    if (a->s < b->s)
+	return 1;
+    return 0;
+/* sift up routine for min heap */
+int sift_up(struct boq *q, int start)
+    register int parent, child;
+    struct qitem a, *b;
+    child = start;
+    a = q->i[child];
+    while (child > 1) {
+	GET_PARENT(parent, child);
+	b = &q->i[parent];
+	/* child smaller */
+	if (cmp_q_x(&a, b)) {
+	    /* push parent point down */
+	    q->i[child] = q->i[parent];
+	    child = parent;
+	else
+	    /* no more sifting up, found new slot for child */
+	    break;
+    /* put point in new slot */
+    if (child < start) {
+	q->i[child] = a;
+    return child;
+int boq_add(struct boq *q, struct qitem *i)
+    if (q->count + 2 >= q->alloc) {
+	q->alloc = q->count + 100;
+	q->i = G_realloc(q->i, q->alloc * sizeof(struct qitem));
+    q->i[q->count + 1] = *i;
+    sift_up(q, q->count + 1);
+    q->count++;
+    return 1;
+/* drop point routine for min heap */
+int boq_drop(struct boq *q, struct qitem *qi)
+    register int child, childr, parent;
+    register int i;
+    struct qitem *a, *b;
+    if (q->count == 0)
+	return 0;
+    *qi = q->i[1];
+    if (q->count == 1) {
+	q->count = 0;
+	return 1;
+    /* start with root */
+    parent = 1;
+    /* sift down: move hole back towards bottom of heap */
+    while (GET_CHILD(child, parent) <= q->count) {
+	a = &q->i[child];
+	i = child + 3;
+	for (childr = child + 1; childr <= q->count && childr < i; childr++) {
+	    b = &q->i[childr];
+	    if (cmp_q_x(b, a)) {
+		child = childr;
+		a = &q->i[child];
+	/* move hole down */
+	q->i[parent] = q->i[child];
+	parent = child;
+    /* hole is in lowest layer, move to heap end */
+    if (parent < q->count) {
+	q->i[parent] = q->i[q->count];
+	/* sift up last swapped point, only necessary if hole moved to heap end */
+	sift_up(q, parent);
+    /* the actual drop */
+    q->count--;
+    return 1;
+/* compare two tree points */
+/* return -1 if a < b, 1 if a > b, 0 if a == b */
+static int cmp_t_y(const void *aa, const void *bb)
+    struct qitem *a = (struct qitem *) aa;
+    struct qitem *b = (struct qitem *) bb;
+    if (y1 < y2)
+	return -1;
+    if (y1 > y2)
+	return 1;
+    if (x1 < x2)
+	return -1;
+    if (x1 > x2)
+	return 1;
+    if (z1 < z2)
+	return -1;
+    if (z1 > z2)
+	return 1;
+    if (a->s < b->s)
+	return -1;
+    if (a->s > b->s)
+	return 1;
+    return 0;
+int boq_load(struct boq *q, struct line_pnts *Pnts,
+             struct bound_box *abbox, int l, int with_z)
+    int i, loaded;
+    int vi, vo;
+    struct bound_box box;
+    struct qitem qi;
+    /* load Pnts to queue */
+    qi.l = l;
+    loaded = 0;
+    for (i = 0; i < Pnts->n_points - 1; i++) {
+	x1 = Pnts->x[i];
+	y1 = Pnts->y[i];
+	z1 = Pnts->z[i];
+	x2 = Pnts->x[i + 1];
+	y2 = Pnts->y[i + 1];
+	z2 = Pnts->z[i + 1];
+	if (x1 == x2 && y1 == y2 && (!with_z || z1 == z2))
+	    continue;
+	if (x1 < x2) {
+	    box.W = x1;
+	    box.E = x2;
+	else {
+	    box.E = x1;
+	    box.W = x2;
+	if (y1 < y2) {
+	    box.S = y1;
+	    box.N = y2;
+	else {
+	    box.N = y1;
+	    box.S = y2;
+	if (z1 < z2) {
+	    box.B = z1;
+	    box.T = z2;
+	else {
+	    box.T = z1;
+	    box.B = z2;
+	box.W -= rethresh;
+	box.S -= rethresh;
+	box.B -= rethresh;
+	box.E += rethresh;
+	box.N += rethresh;
+	box.T += rethresh;
+	if (!Vect_box_overlap(abbox, &box))
+	    continue;
+	vi = i;
+	vo = i + 1;
+	if (x1 < x2) {
+	    vi = i;
+	    vo = i + 1;
+	else if (x1 > x2) {
+	    vi = i + 1;
+	    vo = i;
+	else {
+	    if (y1 < y2) {
+		vi = i;
+		vo = i + 1;
+	    else if (y1 > y2) {
+		vi = i + 1;
+		vo = i;
+	    else {
+		if (z1 < z2) {
+		    vi = i;
+		    vo = i + 1;
+		else if (z1 > z2) {
+		    vi = i + 1;
+		    vo = i;
+		else {
+		    G_fatal_error("Identical points");
+	qi.s = i;
+	/* event in */
+	qi.e = QEVT_IN;
+	qi.p = vi;
+	boq_add(q, &qi);
+	/* event out */
+	qi.e = QEVT_OUT;
+	qi.p = vo;
+	boq_add(q, &qi);
+	loaded += 2;
+    return loaded;
+ * \brief Intersect 2 lines.
+ * Creates array of new lines created from original A line, by
+ * intersection with B line. Points (Points->n_points == 1) are not
+ * supported.
+ * simplified Bentley–Ottmann Algorithm
+ * \param APoints first input line
+ * \param BPoints second input line
+ * \param[out] ALines array of new lines created from original A line
+ * \param[out] BLines array of new lines created from original B line
+ * \param[out] nalines number of new lines (ALines)
+ * \param[out] nblines number of new lines (BLines)
+ * \param with_z 3D, not supported!
+ * \return 0 no intersection
+ * \return 1 intersection found
+int
+Vect_line_intersection2(struct line_pnts *APoints,
+		        struct line_pnts *BPoints,
+		        struct bound_box *ABox,
+		        struct bound_box *BBox,
+		        struct line_pnts ***ALines,
+		        struct line_pnts ***BLines,
+		        int *nalines, int *nblines, int with_z)
+    int i, j, k, l, nl, last_seg, seg, last;
+    int n_alive_cross;
+    double dist, curdist, last_x, last_y, last_z;
+    double x, y;
+    struct line_pnts **XLines, *Points;
+    struct line_pnts *Points1, *Points2;	/* first, second points */
+    int seg1, seg2, vert1, vert2;
+    struct bound_box abbox;
+    struct boq bo_queue;
+    struct qitem qi, *found;
+    struct RB_TREE *bo_ta, *bo_tb;
+    struct RB_TRAV bo_t_trav;
+    int same = 0;
+    if (debug_level == -1) {
+	const char *dstr = G__getenv("DEBUG");
+	if (dstr != NULL)
+	    debug_level = atoi(dstr);
+	else
+	    debug_level = 0;
+    n_cross = 0;
+    APnts = APoints;
+    BPnts = BPoints;
+    ABPnts[0] = APnts;
+    ABPnts[1] = BPnts;
+    *nalines = 0;
+    *nblines = 0;
+    /* RE (representation error).
+     *  RE thresh above is nonsense of course, the RE threshold should be based on
+     *  number of significant digits for double (IEEE-754) which is 15 or 16 and exponent.
+     *  The number above is in fact not required threshold, and will not work
+     *  for example: equator length is 40.075,695 km (8 digits), units are m (+3)
+     *  and we want precision in mm (+ 3) = 14 -> minimum rethresh may be around 0.001
+     *  ?Maybe all nonsense?
+     *  Use rounding error of the unit in the least place ?
+     *  max of fabs(x), fabs(y)
+     *  rethresh = pow(2, log2(max) - 53) */
+    /* Warning: This function is also used to intersect the line by itself i.e. APoints and
+     * BPoints are identical. I am not sure if it is clever, but it seems to work, but
+     * we have to keep this in mind and handle some special cases (maybe) */
+    /* TODO: 3D, RE threshold, GV_POINTS (line x point) */
+    /* Take each segment from A and intersect by each segment from B.
+     *  All intersections are found first and saved to array, then sorted by a distance along the line,
+     *  and then the line is split to pieces.
+     *  Note: If segments are collinear, check if previous/next segments are also collinear,
+     *  in that case do not break:
+     *  +----+-----+  etc.
+     *  doesn't need to be broken
+     *  Note: If 2 adjacent segments of line B have common vertex exactly (or within thresh) on line A,
+     *  intersection points for these B segments may differ due to RE:
+     *  ------------ a       ----+--+----            ----+--+----
+     *      /\         =>       /    \     or maybe       \/
+     *  b0 /  \ b1             /      \      even:        /\
+     *  -> solution: snap all breaks to nearest vertices first within RE threshold
+     *  Question: Snap all breaks to each other within RE threshold?
+     *  Note: If a break is snapped to end point or two breaks are snapped to the same vertex
+     *        resulting new line is degenerated => before line is added to array, it must be checked
+     *        if line is not degenerated
+     *  Note: to snap to vertices is important for cases where line A is broken by B and C line
+     *  at the same point:
+     *   \  /  b   no snap     \    /
+     *    \/       could    ----+--+----
+     *  ------ a   result
+     *    /\       in ?:         /\
+     *   /  \  c                /  \
+     *  Note: once we snap breaks to vertices, we have to do that for both lines A and B in the same way
+     *  and because we cannot be sure that A childrens will not change a bit by break(s)
+     *  we have to break both A and B  at once i.e. in one Vect_line_intersection () call.
+    if (!Vect_box_overlap(ABox, BBox)) {
+	*nalines = 0;
+	*nblines = 0;
+	return 0;
+    /* overlap box of A line and B line */
+    abbox = *BBox;
+    if (abbox.N > ABox->N)
+	abbox.N = ABox->N;
+    if (abbox.S < ABox->S)
+	abbox.S = ABox->S;
+    if (abbox.E > ABox->E)
+	abbox.E = ABox->E;
+    if (abbox.W < ABox->W)
+	abbox.W = ABox->W;
+    if (abbox.T > ABox->T)
+	abbox.T = ABox->T;
+    if (abbox.B < ABox->B)
+	abbox.B = ABox->B;
+    abbox.N += rethresh;
+    abbox.S -= rethresh;
+    abbox.E += rethresh;
+    abbox.W -= rethresh;
+    abbox.T += rethresh;
+    abbox.B -= rethresh;
+    if (APnts->n_points < 2 || BPnts->n_points < 2) {
+	G_fatal_error("Intersection with points is not yet supported");
+	return 0;
+    if (APnts->n_points == BPnts->n_points) {
+	same = 1;
+	for (i = 0; i < APnts->n_points; i++) {
+	    if (APnts->x[i] != BPnts->x[i] ||
+	        APnts->y[i] != BPnts->y[i] ||
+		(with_z && APnts->z[i] != BPnts->z[i])) {
+		same = 0;
+		break;
+	if (same)
+	    G_debug(3, "Intersecting different lines");
+    /* initialize queue */
+    bo_queue.count = 0;
+    bo_queue.alloc = 2 * (APnts->n_points + BPnts->n_points);
+    bo_queue.i = G_malloc(bo_queue.alloc * sizeof(struct qitem));
+    /* load APnts to queue */
+    boq_load(&bo_queue, APnts, &abbox, 0, with_z);
+    if (!same) {
+	/* load BPnts to queue */
+	boq_load(&bo_queue, BPnts, &abbox, 1, with_z);
+    /* initialize search tree */
+    bo_ta = rbtree_create(cmp_t_y, sizeof(struct qitem));
+    if (same)
+	bo_tb = bo_ta;
+    else
+	bo_tb = rbtree_create(cmp_t_y, sizeof(struct qitem));
+    /* find intersections */
+    while (boq_drop(&bo_queue, &qi)) {
+	if (qi.e == QEVT_IN) {
+	    /* not the original Bentley-Ottmann algorithm */
+	    if (qi.l == 0) {
+		/* test for intersection of s with all segments in T */
+		rbtree_init_trav(&bo_t_trav, bo_tb);
+		while ((found = rbtree_traverse(&bo_t_trav))) {
+		    cross_seg(qi.s, found->s);
+		/* insert s in T */
+		rbtree_insert(bo_ta, &qi);
+	    else {
+		rbtree_init_trav(&bo_t_trav, bo_ta);
+		    cross_seg(found->s, qi.s);
+		rbtree_insert(bo_tb, &qi);
+	else if (qi.e == QEVT_OUT) {
+	    /* remove from T */
+	    /* adjust p */
+	    if (qi.p == qi.s)
+		qi.p++;
+	    else
+		qi.p--;
+	    if (qi.l == 0) {
+		if (!rbtree_remove(bo_ta, &qi))
+		    G_fatal_error("RB tree error!");
+	    else {
+		if (!rbtree_remove(bo_tb, &qi))
+    G_free(bo_queue.i);
+    rbtree_destroy(bo_ta);
+    if (!same)
+	rbtree_destroy(bo_tb);
+    G_debug(2, "n_cross = %d", n_cross);
+    /* Lines do not cross each other */
+    if (n_cross == 0) {
+	return 0;
+    /* Snap breaks to nearest vertices within RE threshold */
+    /* Calculate distances along segments */
+    for (i = 0; i < n_cross; i++) {
+	/* 1. of A seg */
+	seg = cross[i].segment[0];
+	curdist =
+	    dist2(cross[i].x, cross[i].y, APoints->x[seg], APoints->y[seg]);
+	x = APoints->x[seg];
+	y = APoints->y[seg];
+	cross[i].distance[0] = curdist;
+	/* 2. of A seg */
+	dist =
+	    dist2(cross[i].x, cross[i].y, APoints->x[seg + 1],
+		  APoints->y[seg + 1]);
+	if (dist < curdist) {
+	    curdist = dist;
+	    x = APoints->x[seg + 1];
+	    y = APoints->y[seg + 1];
+	/* 1. of B seg */
+	seg = cross[i].segment[1];
+	dist =
+	    dist2(cross[i].x, cross[i].y, BPoints->x[seg], BPoints->y[seg]);
+	cross[i].distance[1] = dist;
+	    curdist = dist;
+	    x = BPoints->x[seg];
+	    y = BPoints->y[seg];
+	/* 2. of B seg */
+	dist = dist2(cross[i].x, cross[i].y, BPoints->x[seg + 1], BPoints->y[seg + 1]);
+	    curdist = dist;
+	    x = BPoints->x[seg + 1];
+	    y = BPoints->y[seg + 1];
+	if (curdist < rethresh * rethresh) {
+	    cross[i].x = x;
+	    cross[i].y = y;
+	    /* Update distances along segments */
+		dist2(APoints->x[seg], APoints->y[seg], cross[i].x, cross[i].y);
+		dist2(BPoints->x[seg], BPoints->y[seg], cross[i].x, cross[i].y);
+    /* l = 1 ~ line A, l = 2 ~ line B */
+    nl = 3;
+    if (same)
+	nl = 2;
+    for (l = 1; l < nl; l++) {
+	    use_cross[i] = 1;
+	/* Create array of lines */
+	XLines = G_malloc((n_cross + 1) * sizeof(struct line_pnts *));
+	if (l == 1) {
+	    G_debug(2, "Clean and create array for line A");
+	    Points = APoints;
+	    Points1 = APoints;
+	    Points2 = BPoints;
+	    current = 0;
+	    second = 1;
+	else {
+	    G_debug(2, "Clean and create array for line B");
+	    Points = BPoints;
+	    Points1 = BPoints;
+	    Points2 = APoints;
+	    current = 1;
+	    second = 0;
+	/* Sort points along lines */
+	qsort((void *)cross, sizeof(char) * n_cross, sizeof(CROSS),
+	      cmp_cross);
+	/* Print all (raw) breaks */
+	/* avoid loop when not debugging */
+	if (debug_level > 2) {
+		G_debug(3,
+			"  cross = %d seg1/dist1 = %d/%f seg2/dist2 = %d/%f x = %f y = %f",
+			i, cross[i].segment[current],
+			sqrt(cross[i].distance[current]),
+			cross[i].segment[second], sqrt(cross[i].distance[second]),
+			cross[i].x, cross[i].y);
+	/* Remove breaks on first/last line vertices */
+	    if (use_cross[i] == 1) {
+		j = Points1->n_points - 1;
+		/* Note: */
+		if ((cross[i].segment[current] == 0 &&
+		     cross[i].x == Points1->x[0] &&
+		     cross[i].y == Points1->y[0]) ||
+		    (cross[i].segment[current] == j - 1 &&
+		     cross[i].x == Points1->x[j] &&
+		     cross[i].y == Points1->y[j])) {
+		    use_cross[i] = 0;	/* first/last */
+		    G_debug(3, "cross %d deleted (first/last point)", i);
+	/* Remove breaks with collinear previous and next segments on 1 and 2 */
+	/* Note: breaks with collinear previous and nex must be remove duplicates,
+	 *        otherwise some cross may be lost. Example (+ is vertex):
+	 *             B          first cross intersections: A/B  segment:
+	 *             |               0/0, 0/1, 1/0, 1/1 - collinear previous and next
+	 *     AB -----+----+--- A     0/4, 0/5, 1/4, 1/5 - OK
+	 *              \___|
+	 *                B
+	 *  This should not inluence that break is always on first segment, see below (I hope)
+	/* TODO: this doesn't find identical with breaks on revious/next */
+	    if (use_cross[i] == 0)
+		continue;
+	    G_debug(3, "  is %d between colinear?", i);
+	    seg1 = cross[i].segment[current];
+	    seg2 = cross[i].segment[second];
+	    /* Is it vertex on 1, which? */
+	    if (cross[i].x == Points1->x[seg1] &&
+		cross[i].y == Points1->y[seg1]) {
+		vert1 = seg1;
+	    else if (cross[i].x == Points1->x[seg1 + 1] &&
+		     cross[i].y == Points1->y[seg1 + 1]) {
+		vert1 = seg1 + 1;
+	    else {
+		G_debug(3, "  -> is not vertex on 1. line");
+		continue;
+	    /* Is it vertex on 2, which? */
+	    /* For 1. line it is easy, because breaks on vertex are always at end vertex
+	     *  for 2. line we need to find which vertex is on break if any (vert2 starts from 0) */
+	    if (cross[i].x == Points2->x[seg2] &&
+		cross[i].y == Points2->y[seg2]) {
+		vert2 = seg2;
+	    else if (cross[i].x == Points2->x[seg2 + 1] &&
+		     cross[i].y == Points2->y[seg2 + 1]) {
+		vert2 = seg2 + 1;
+	    else {
+		G_debug(3, "  -> is not vertex on 2. line");
+		continue;
+	    G_debug(3, "    seg1/vert1 = %d/%d  seg2/ver2 = %d/%d", seg1,
+		    vert1, seg2, vert2);
+	    /* Check if the second vertex is not first/last */
+	    if (vert2 == 0 || vert2 == Points2->n_points - 1) {
+		G_debug(3, "  -> vertex 2 (%d) is first/last", vert2);
+		continue;
+	    /* Are there first vertices of this segment identical */
+	    if (!((Points1->x[vert1 - 1] == Points2->x[vert2 - 1] &&
+		   Points1->y[vert1 - 1] == Points2->y[vert2 - 1] &&
+		   Points1->x[vert1 + 1] == Points2->x[vert2 + 1] &&
+		   Points1->y[vert1 + 1] == Points2->y[vert2 + 1]) ||
+		  (Points1->x[vert1 - 1] == Points2->x[vert2 + 1] &&
+		   Points1->y[vert1 - 1] == Points2->y[vert2 + 1] &&
+		   Points1->x[vert1 + 1] == Points2->x[vert2 - 1] &&
+		   Points1->y[vert1 + 1] == Points2->y[vert2 - 1])
+		G_debug(3, "  -> previous/next are not identical");
+		continue;
+	    use_cross[i] = 0;
+	    G_debug(3, "    -> collinear -> remove");
+	/* Remove duplicates, i.e. merge all identical breaks to one.
+	 *  We must be careful because two points with identical coordinates may be distant if measured along
+	 *  the line:
+	 *       |         Segments b0 and b1 overlap, b0 runs up, b1 down.
+	 *       |         Two inersections may be merged for a, because they are identical,
+	 *  -----+---- a   but cannot be merged for b, because both b0 and b1 must be broken.
+	 *       |         I.e. Breaks on b have identical coordinates, but there are not identical
+	 *       b0 | b1      if measured along line b.
+	 *      -> Breaks may be merged as identical if lay on the same segment, or on vertex connecting
+	 *      2 adjacent segments the points lay on
+	 *  Note: if duplicate is on a vertex, the break is removed from next segment =>
+	 *        break on vertex is always on first segment of this vertex (used below)
+	last = -1;
+		continue;
+	    if (last == -1) {	/* set first alive */
+		last = i;
+		continue;
+	    seg = cross[i].segment[current];
+	    /* compare with last */
+	    G_debug(3, "  duplicate ?: cross = %d seg = %d dist = %f", i,
+		    cross[i].segment[current], cross[i].distance[current]);
+	    if ((cross[i].segment[current] == cross[last].segment[current] &&
+		 cross[i].distance[current] == cross[last].distance[current])
+		|| (cross[i].segment[current] ==
+		    cross[last].segment[current] + 1 &&
+		    cross[i].distance[current] == 0 &&
+		    cross[i].x == cross[last].x &&
+		    cross[i].y == cross[last].y)) {
+		G_debug(3, "  cross %d identical to last -> removed", i);
+		use_cross[i] = 0;	/* identical */
+	    else {
+		last = i;
+	/* Create array of new lines */
+	/* Count alive crosses */
+	n_alive_cross = 0;
+	G_debug(3, "  alive crosses:");
+		G_debug(3, "  %d", i);
+		n_alive_cross++;
+	k = 0;
+	if (n_alive_cross > 0) {
+	    /* Add last line point at the end of cross array (cross alley) */
+	    use_cross[n_cross] = 1;
+	    j = Points->n_points - 1;
+	    cross[n_cross].x = Points->x[j];
+	    cross[n_cross].y = Points->y[j];
+	    cross[n_cross].segment[current] = Points->n_points - 2;
+	    last_seg = 0;
+	    last_x = Points->x[0];
+	    last_y = Points->y[0];
+	    last_z = Points->z[0];
+	    /* Go through all cross (+last line point) and create for each new line
+	     *  starting at last_* and ending at cross (last point) */
+	    for (i = 0; i <= n_cross; i++) {	/* i.e. n_cross + 1 new lines */
+		G_debug(2, "%d seg = %d dist = %f", i, seg,
+			cross[i].distance[current]);
+		if (use_cross[i] == 0) {
+		    G_debug(3, "   removed -> next");
+		    continue;
+		G_debug(2, " New line:");
+		XLines[k] = Vect_new_line_struct();
+		/* add last intersection or first point first */
+		Vect_append_point(XLines[k], last_x, last_y, last_z);
+		G_debug(2, "   append last vert: %f %f", last_x, last_y);
+		/* add first points of segments between last and current seg */
+		for (j = last_seg + 1; j <= seg; j++) {
+		    G_debug(2, "  segment j = %d", j);
+		    /* skipp vertex identical to last break */
+		    if ((j == last_seg + 1) && Points->x[j] == last_x &&
+			Points->y[j] == last_y) {
+			G_debug(2, "   -> skip (identical to last break)");
+			continue;
+		    Vect_append_point(XLines[k], Points->x[j], Points->y[j],
+				      Points->z[j]);
+		    G_debug(2, "   append first of seg: %f %f", Points->x[j],
+			    Points->y[j]);
+		last_seg = seg;
+		last_x = cross[i].x;
+		last_y = cross[i].y;
+		last_z = 0;
+		/* calculate last_z */
+		if (Points->z[last_seg] == Points->z[last_seg + 1]) {
+		    last_z = Points->z[last_seg + 1];
+		else if (last_x == Points->x[last_seg] &&
+		    last_y == Points->y[last_seg]) {
+		    last_z = Points->z[last_seg];
+		else if (last_x == Points->x[last_seg + 1] &&
+		    last_y == Points->y[last_seg + 1]) {
+		else {
+		    dist = dist2(Points->x[last_seg],
+		                 Points->x[last_seg + 1],
+				 Points->y[last_seg],
+				 Points->y[last_seg + 1]);
+		    if (with_z) {
+			last_z = (Points->z[last_seg] * sqrt(cross[i].distance[current]) +
+				  Points->z[last_seg + 1] *
+				  (sqrt(dist) - sqrt(cross[i].distance[current]))) /
+				  sqrt(dist);
+		/* add current cross or end point */
+		Vect_append_point(XLines[k], cross[i].x, cross[i].y, last_z);
+		G_debug(2, "   append cross / last point: %f %f", cross[i].x,
+			cross[i].y);
+		/* Check if line is degenerate */
+		if (dig_line_degenerate(XLines[k]) > 0) {
+		    G_debug(2, "   line is degenerate -> skipped");
+		    Vect_destroy_line_struct(XLines[k]);
+		else {
+		    k++;
+	if (l == 1) {
+	    *nalines = k;
+	    *ALines = XLines;
+	else {
+	    *nblines = k;
+	    *BLines = XLines;
+    return 1;
+static int cross_found;		/* set by find_cross() */
+    int ret;
+	return 0;
+    if (!IPnts)
+	IPnts = Vect_new_line_struct();
+    switch (ret) {
+    case 0:
+    case 5:
+	break;
+    case 1:
+	if (0 > Vect_copy_xyz_to_pnts(IPnts, &x1, &y1, &z1, 1))
+	    G_warning(_("Error while adding point to array. Out of memory"));
+	break;
+    case 2:
+    case 3:
+    case 4:
+	if (0 > Vect_copy_xyz_to_pnts(IPnts, &x2, &y2, &z2, 1))
+	break;
+    if (ret > 0) {
+	cross_found = 1;
+	return 0;
+ * \brief Check if 2 lines intersect.
+ * Points (Points->n_points == 1) are also supported.
+ * \param with_z 3D, not supported (only if one or both are points)!
+int
+Vect_line_check_intersection2(struct line_pnts *APoints,
+			      struct line_pnts *BPoints, int with_z)
+    double dist;
+    struct bound_box ABox, BBox, abbox;
+    APnts = APoints;
+    BPnts = BPoints;
+    /* TODO: 3D, RE (representation error) threshold, GV_POINTS (line x point) */
+    if (!IPnts)
+    /* If one or both are point (Points->n_points == 1) */
+    if (APoints->n_points == 1 && BPoints->n_points == 1) {
+	if (APoints->x[0] == BPoints->x[0] && APoints->y[0] == BPoints->y[0]) {
+	    if (!with_z) {
+		if (0 >
+		    Vect_copy_xyz_to_pnts(IPnts, &APoints->x[0],
+					  &APoints->y[0], NULL, 1))
+		return 1;
+	    else {
+		if (APoints->z[0] == BPoints->z[0]) {
+		    if (0 >
+					      &APoints->y[0], &APoints->z[0],
+					      1))
+		    return 1;
+		else
+		    return 0;
+	else {
+	    return 0;
+    if (APoints->n_points == 1) {
+	Vect_line_distance(BPoints, APoints->x[0], APoints->y[0],
+			   APoints->z[0], with_z, NULL, NULL, NULL, &dist,
+			   NULL, NULL);
+	if (dist <= rethresh) {
+	    if (0 >
+		Vect_copy_xyz_to_pnts(IPnts, &APoints->x[0], &APoints->y[0],
+				      &APoints->z[0], 1))
+	    return 1;
+	else {
+	    return 0;
+    if (BPoints->n_points == 1) {
+	Vect_line_distance(APoints, BPoints->x[0], BPoints->y[0],
+			   BPoints->z[0], with_z, NULL, NULL, NULL, &dist,
+			   NULL, NULL);
+	    if (0 >
+		Vect_copy_xyz_to_pnts(IPnts, &BPoints->x[0], &BPoints->y[0],
+				      &BPoints->z[0], 1))
+	    return 1;
+	else
+	    return 0;
+    /* Take each segment from A and find if intersects any segment from B. */
+    dig_line_box(APoints, &ABox);
+    dig_line_box(BPoints, &BBox);
+    if (!Vect_box_overlap(&ABox, &BBox)) {
+	return 0;
+    /* overlap box */
+    abbox = BBox;
+    if (abbox.N > ABox.N)
+	abbox.N = ABox.N;
+    if (abbox.S < ABox.S)
+	abbox.S = ABox.S;
+    if (abbox.E > ABox.E)
+	abbox.E = ABox.E;
+    if (abbox.W < ABox.W)
+	abbox.W = ABox.W;
+    if (abbox.T > ABox.T)
+	abbox.T = ABox.T;
+    if (abbox.B < ABox.B)
+	abbox.B = ABox.B;
+    /* find intersection */
+    cross_found = 0;
+	    if (qi.l == 0) {
+		    find_cross(qi.s, found->s);
+		    if (cross_found) {
+			break;
+	    else {
+		    find_cross(found->s, qi.s);
+			break;
+	    /* adjust p */
+	    if (qi.p == qi.s)
+		qi.p++;
+	    else
+		qi.p--;
+	    if (qi.l == 0) {
+	    else {
+	    break;
+    return cross_found;
+ * \brief Get 2 lines intersection points.
+ * A wrapper around Vect_line_check_intersection() function.
+ * \param[out] IPoints output with intersection points
+int
+Vect_line_get_intersections2(struct line_pnts *APoints,
+			     struct line_pnts *IPoints, int with_z)
+    int ret;
+    IPnts = IPoints;
+    ret = Vect_line_check_intersection2(APoints, BPoints, with_z);
+    return ret;
