[GRASS-SVN] r62053 - grass-addons/grass7/vector/v.surf.mass
svn_grass at osgeo.org
Tue Sep 23 05:36:26 PDT 2014
Author: mmetz
Date: 2014-09-23 05:36:25 -0700 (Tue, 23 Sep 2014)
New Revision: 62053
grass-addons/grass7/vector/v.surf.mass/globals.h
grass-addons/grass7/vector/v.surf.mass/main.c
v.surf.mass: fix weight usage
Modified: grass-addons/grass7/vector/v.surf.mass/globals.h
--- grass-addons/grass7/vector/v.surf.mass/globals.h 2014-09-22 20:51:02 UTC (rev 62052)
+++ grass-addons/grass7/vector/v.surf.mass/globals.h 2014-09-23 12:36:25 UTC (rev 62053)
@@ -23,4 +23,5 @@
double adj; /* cumulative adjustments */
double avgdiff; /* difference between interpolated and original */
int count_neg; /* count of negatives */
+ int weight; /* 0 = all weights 0, 1 = at least one weight > 0 */
Modified: grass-addons/grass7/vector/v.surf.mass/main.c
--- grass-addons/grass7/vector/v.surf.mass/main.c 2014-09-22 20:51:02 UTC (rev 62052)
+++ grass-addons/grass7/vector/v.surf.mass/main.c 2014-09-23 12:36:25 UTC (rev 62053)
@@ -25,7 +25,6 @@
#include <fcntl.h>
#include "globals.h"
-#define SEGSIZE 64
/* activate to use the original algorithm of Tobler 1979
#define TOBLER_STRICT
@@ -35,8 +34,10 @@
const char *mapset, *column;
int row, col, nrows, ncols, rrow, ccol, nrow, ncol;
int r1, r2, c1, c2;
+ int nsize, rlo, rhi;
SEGMENT out_seg;
+ int srows, scols;
int w_fd, out_fd, have_weights;
DCELL *drastbuf;
double seg_size;
@@ -58,10 +59,10 @@
struct History history;
struct lcell thiscell, ngbrcell;
- double outside_val, value;
+ double outside_val, interp, value;
#ifdef TOBLER_STRICT
- double interp, avgdiff;
+ double avgdiff;
#endif
struct GModule *module;
@@ -204,15 +205,19 @@
seg_size = sizeof(struct lcell);
- seg_size = (seg_size * SEGSIZE * SEGSIZE) / (1 << 20);
+ srows = 64;
+ scols = 64;
+ seg_size = (seg_size * srows * scols) / (1 << 20);
segments_in_memory = seg_mb / seg_size + 0.5;
- G_debug(1, "%d %dx%d segments held in memory", segments_in_memory, SEGSIZE, SEGSIZE);
+ if (segments_in_memory < 3)
+ segments_in_memory = 3;
+ G_debug(1, "%d %dx%d segments held in memory", segments_in_memory, srows, scols);
/* initialize */
G_message(_("Initializing..."));
if (segment_open(&out_seg, G_tempfile(),
- nrows, ncols, SEGSIZE, SEGSIZE,
+ nrows, ncols, srows, scols,
sizeof(struct lcell), segments_in_memory) != 1)
G_fatal_error(_("Can not create temporary file"));
@@ -227,6 +232,7 @@
G_message(_("Reading area values..."));
/* read values from attribute table or z */
driver = NULL;
+ Fi = NULL;
if (layer > 0) {
Fi = Vect_get_field(&In, layer);
@@ -258,8 +264,10 @@
areas[i].interp = 0;
areas[i].adj = 0;
areas[i].avgdiff = 0;
+ areas[i].weight = 0;
G_debug(1, "Starting to read from areas...");
+ G_percent(0, nareas, 2);
for (i = 1; i <= nareas; i++) {
G_percent(i, nareas, 2);
@@ -268,6 +276,7 @@
areas[i].adj = 0;
if (driver) {
if (Vect_get_area_cats(&In, i, Cats) == 0) {
@@ -351,7 +360,7 @@
thiscell.weight = 1.;
if (have_weights) {
if (Rast_is_d_null_value(&drastbuf[col])) {
- thiscell.weight = drastbuf[col]; /* OK ? */
+ thiscell.weight = 0; /* OK ? was drastbuf[col] */
else {
@@ -371,6 +380,7 @@
IPoints = NULL;
ibox = NULL;
isl_allocated = 0;
double x, y;
int inside = 0;
@@ -387,6 +397,15 @@
r2 = floor(Rast_northing_to_row(abox.S, &window)) + 1;
c1 = floor(Rast_easting_to_col(abox.W, &window));
c2 = floor(Rast_easting_to_col(abox.E, &window)) + 1;
+ if (r1 < 0)
+ r1 = 0;
+ if (r2 > nrows)
+ r2 = nrows;
+ if (c1 < 0)
+ c1 = 0;
+ if (c2 > ncols)
+ c2 = ncols;
if (r2 < r1 || c2 < c1)
continue;
@@ -435,6 +454,8 @@
thiscell.interp *= thiscell.weight;
ap->interp += thiscell.weight;
+ if (ap->weight == 0)
+ ap->weight = thiscell.weight != 0.0;
segment_put(&out_seg, &thiscell, row, col);
@@ -462,12 +483,20 @@
ap = &areas[thiscell.area];
value = thiscell.interp / ap->count;
if (have_weights) {
- if (ap->interp > 0)
- value = thiscell.interp / ap->interp;
+ if (ap->weight == 0) {
+ thiscell.weight = 1;
+ value = ap->value / ap->count;
+ else {
+ if (ap->interp > 0)
+ value = thiscell.interp / ap->interp;
thiscell.interp = value;
- segment_put(&out_seg, &thiscell, row, col);
+ if (areas[thiscell.area].count == 0)
+ thiscell.interp = outside_val;
+ segment_put(&out_seg, &thiscell, row, col);
G_percent(row, nrows, 2);
@@ -475,12 +504,53 @@
G_message(_("Mass-preserving interpolation"));
doit = 1;
iter = 0;
+ nsize = 1;
+ rlo = -nsize;
+ rhi = nsize + 1;
while (doit) {
int l_row = -1, l_col = -1;
maxadj = 0;
G_percent(iter, maxiter, 1);
iter++;
+ if (have_weights && iter > 1 && iter == maxiter) {
+ for (i = 1; i <= nareas; i++) {
+ areas[i].interp = .0;
+ areas[i].adj = .0;
+ areas[i].avgdiff = .0;
+ areas[i].count_neg = 0;
+ for (row = 0; row < nrows; row++) {
+ for (col = 0; col < ncols; col++) {
+ segment_get(&out_seg, &thiscell, row, col);
+ if (thiscell.area > 0 &&
+ !Rast_is_d_null_value(&thiscell.interp)) {
+ ap = &areas[thiscell.area];
+ thiscell.interp *= thiscell.weight;
+ ap->interp += thiscell.interp;
+ value = 1;
+ if (ap->interp != 0)
+ value = ap->value / ap->interp;
+ thiscell.interp = value * thiscell.interp;
areas[i].adj = .0;
@@ -500,9 +570,9 @@
value = .0;
- for (rrow = -1; rrow < 2; rrow++) {
+ for (rrow = rlo; rrow < rhi; rrow++) {
nrow = row + rrow;
- for (ccol = -1; ccol < 2; ccol++) {
+ for (ccol = rlo; ccol < rhi; ccol++) {
ncol = col + ccol;
if (nrow >= 0 && nrow < nrows &&
ncol >= 0 && ncol < ncols) {
@@ -535,8 +605,9 @@
areas[thiscell.area].adj += thiscell.adj;
areas[thiscell.area].interp += thiscell.interp + thiscell.adj;
- else
+ else {
areas[thiscell.area].interp += thiscell.interp;
@@ -641,15 +712,22 @@
- thiscell.interp = value * (thiscell.interp + thiscell.adj);
- if (ap->count)
- value = thiscell.adj - ap->adj / ap->count;
- if (maxadj < value * value) {
- maxadj = value * value;
- l_row = row;
- l_col = col;
+ if (ap->interp == 0 && ap->value != 0)
+ interp = ap->value / ap->count;
+ else
+ interp = value * (thiscell.interp + thiscell.adj);
+ if (negative || (!negative && interp >= 0)) {
+ value = thiscell.interp - interp;
+ thiscell.interp = interp;
+ if (maxadj < value * value) {
+ maxadj = value * value;
+ l_row = row;
+ l_col = col;
@@ -658,50 +736,18 @@
G_verbose_message(_("Largest squared adjustment: %g"), maxadj);
G_verbose_message(_("Largest row, col: %d %d"), l_row, l_col);
- if (iter >= maxiter || maxadj < threshold)
+ if (iter >= maxiter)
doit = 0;
+ if (maxadj < threshold) {
+ if (have_weights)
+ maxiter = iter + 1;
+ else
+ doit = 0;
+ G_verbose_message(_("Interpolation converged after %d iterations"), iter);
G_percent(maxiter, maxiter, 1);
- if (have_weights) {
- G_message(_("Weighing output..."));
- for (i = 1; i <= nareas; i++) {
- areas[i].interp = .0;
- areas[i].adj = .0;
- areas[i].avgdiff = .0;
- areas[i].count_neg = 0;
- for (row = 0; row < nrows; row++) {
- for (col = 0; col < ncols; col++) {
- segment_get(&out_seg, &thiscell, row, col);
- if (thiscell.area > 0 &&
- !Rast_is_d_null_value(&thiscell.interp)) {
- ap = &areas[thiscell.area];
- thiscell.interp *= thiscell.weight;
- ap->interp += thiscell.interp;
- value = 1;
- if (ap->interp != 0)
- value = ap->value / ap->interp;
- thiscell.interp = value * thiscell.interp;
/* write output */
G_message(_("Writing output <%s>"), out_opt->answer);
drastbuf = Rast_allocate_d_buf();
@@ -715,6 +761,8 @@
+ segment_close(&out_seg);
Rast_close(out_fd);
Rast_short_history(out_opt->answer, "raster", &history);
Rast_command_history(&history);
