[GRASS-SVN] r62054 - in grass/branches/releasebranch_7_0: . gui/wxpython/modules
svn_grass at osgeo.org
Tue Sep 23 07:50:49 PDT 2014
Author: martinl
Date: 2014-09-23 07:50:49 -0700 (Tue, 23 Sep 2014)
New Revision: 62054
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/gui/wxpython/modules/extensions.py
wxGUI/extension: load data in different thread
(merge r61993 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61829,61831,61840,61851-61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61921,61938,61967-61968,61975,61980,61986,62005
+ /grass/trunk:60289,60696,61269,61380,61420,61422,61480,61500,61764,61808,61829,61831,61840,61851-61854,61858,61888,61891,61905,61907,61913-61914,61916,61918,61921,61938,61967-61968,61975,61980,61986,61993,62005
Modified: grass/branches/releasebranch_7_0/gui/wxpython/modules/extensions.py
--- grass/branches/releasebranch_7_0/gui/wxpython/modules/extensions.py 2014-09-23 12:36:25 UTC (rev 62053)
+++ grass/branches/releasebranch_7_0/gui/wxpython/modules/extensions.py 2014-09-23 14:50:49 UTC (rev 62054)
@@ -28,6 +28,7 @@
from core import globalvar
from core.gcmd import GError, RunCommand, GException, GMessage
from core.utils import SetAddOnPath, _
+from core.gthread import gThread
from core.menutree import TreeModel, ModuleNode
from gui_core.widgets import GListCtrl, SearchModuleWidget
from gui_core.treeview import CTreeView
@@ -63,6 +64,8 @@
self.search.showSearchResult.connect(lambda result: self.tree.Select(result))
# show text in statusbar when notification appears
self.search.showNotification.connect(lambda message: self.SetStatusText(message))
+ # load data in different thread
+ self.thread = gThread()
self.optionBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
label = " %s " % _("Options"))
@@ -187,14 +190,17 @@
wx.BeginBusyCursor()
self.SetStatusText(_("Fetching list of modules from GRASS-Addons SVN (be patient)..."), 0)
try:
- self.modelBuilder.Load(url = self.repo.GetValue().strip())
+ self.thread.Run(callable=self.modelBuilder.Load, url=self.repo.GetValue().strip(),
+ ondone=lambda event: self._fetchDone())
except GException as e:
+ self._fetchDone()
GError(unicode(e), parent = self, showTraceback = False)
+ def _fetchDone(self):
self.tree.RefreshItems()
self.SetStatusText("", 0)
wx.EndBusyCursor()
def OnContextMenu(self, node):
if not hasattr (self, "popupID"):
self.popupID = dict()
