[GRASS-SVN] r62082 - grass/trunk/mswindows
Thu Sep 25 06:27:05 PDT 2014
Author: hellik
Date: 2014-09-25 06:27:05 -0700 (Thu, 25 Sep 2014)
New Revision: 62082
   grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
nsis: attempt to fix optional MS runtime installation
Modified: grass/trunk/mswindows/GRASS-Installer.nsi.tmpl
--- grass/trunk/mswindows/GRASS-Installer.nsi.tmpl	2014-09-25 10:44:26 UTC (rev 62081)
+++ grass/trunk/mswindows/GRASS-Installer.nsi.tmpl	2014-09-25 13:27:05 UTC (rev 62082)
@@ -931,14 +931,6 @@
 	untgz::extract "-d" "$TEMP\$ORIGINAL_UNTAR_FOLDER" "-zbz2" "$TEMP\$ARCHIVE_NAME"
 	Pop $0
 	StrCmp $0 "success" untar_ok untar_failed
-	;move ExecWait, CopyFiles, Delete, RMDir commands out of the download function as these seems not to work if these are nested in a function
-	untar_ok:
-	ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe" /q'
-	ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe" /q'
-	ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe" /q'
-	CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTALL_DIR\extrabin"
-	Goto end
 	download_failed:
 	DetailPrint "$0" ;print error message to log
@@ -951,6 +943,19 @@
 	untar_failed:
+	untar_ok:
+	DetailPrint "Archive successfully unzipped."
+	DetailPrint "Installing vcredist_2005_x86.exe ..."
+	ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2005_x86.exe" /q'
+	DetailPrint "Installing vcredist_2008_x86.exe ..."
+	ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2008_x86.exe" /q'
+	DetailPrint "Installing vcredist_2010_x86.exe ..."
+	ExecWait '"$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\vcredist_2010_x86.exe" /q'
+	DetailPrint "Copying runtime files ..."
+	CopyFiles "$TEMP\$ORIGINAL_UNTAR_FOLDER\bin\*.dll" "$INSTALL_DIR\extrabin"
+	DetailPrint "MS runtime files installed."
+	Goto end
 	end:
