[GRASS-SVN] r62083 - grass/trunk/vector/v.select
svn_grass at osgeo.org
Thu Sep 25 07:42:18 PDT 2014
Author: neteler
Date: 2014-09-25 07:42:18 -0700 (Thu, 25 Sep 2014)
New Revision: 62083
grass/trunk/vector/v.select/args.c
grass/trunk/vector/v.select/main.c
v.select: attempt to improve parameter description
Modified: grass/trunk/vector/v.select/args.c
--- grass/trunk/vector/v.select/args.c 2014-09-25 13:27:05 UTC (rev 62082)
+++ grass/trunk/vector/v.select/args.c 2014-09-25 14:42:18 UTC (rev 62083)
@@ -9,7 +9,7 @@
char *desc;
parm->input[0] = G_define_standard_option(G_OPT_V_INPUT);
- parm->input[0]->description = _("Name of input vector map (A)");
+ parm->input[0]->description = _("Input vector map from which to select features (A)");
parm->input[0]->key = "ainput";
parm->field[0] = G_define_standard_option(G_OPT_V_FIELD);
@@ -23,7 +23,7 @@
parm->type[0]->guisection = _("Selection");
parm->input[1] = G_define_standard_option(G_OPT_V_INPUT);
- parm->input[1]->description = _("Name of input vector map (B)");
+ parm->input[1]->description = _("Query vector map (B)");
parm->input[1]->key = "binput";
parm->field[1] = G_define_standard_option(G_OPT_V_FIELD);
Modified: grass/trunk/vector/v.select/main.c
--- grass/trunk/vector/v.select/main.c 2014-09-25 13:27:05 UTC (rev 62082)
+++ grass/trunk/vector/v.select/main.c 2014-09-25 14:42:18 UTC (rev 62083)
@@ -7,7 +7,7 @@
* Markus Neteler <neteler itc.it>
* Martin Landa <landa.martin gmail.com> (GEOS support)
* PURPOSE: Select features from one map by features in another map.
- * COPYRIGHT: (C) 2003-2011 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2014 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
