[GRASS-SVN] r62089 - grass/trunk/lib/vector/Vlib
Fri Sep 26 05:45:33 PDT 2014
Author: mmetz
Date: 2014-09-26 05:45:33 -0700 (Fri, 26 Sep 2014)
New Revision: 62089
   grass/trunk/lib/vector/Vlib/intersect2.c
Vlib: fix Vect_line_check_intersection2()
Modified: grass/trunk/lib/vector/Vlib/intersect2.c
--- grass/trunk/lib/vector/Vlib/intersect2.c	2014-09-26 12:43:45 UTC (rev 62088)
+++ grass/trunk/lib/vector/Vlib/intersect2.c	2014-09-26 12:45:33 UTC (rev 62089)
@@ -294,7 +294,7 @@
 /* sift up routine for min heap */
-int sift_up(struct boq *q, int start)
+static int sift_up(struct boq *q, int start)
     register int parent, child;
     struct qitem a, *b;
@@ -325,7 +325,7 @@
     return child;
-int boq_add(struct boq *q, struct qitem *i)
+static int boq_add(struct boq *q, struct qitem *i)
     if (q->count + 2 >= q->alloc) {
 	q->alloc = q->count + 100;
@@ -340,7 +340,7 @@
 /* drop point routine for min heap */
-int boq_drop(struct boq *q, struct qitem *qi)
+static int boq_drop(struct boq *q, struct qitem *qi)
     register int child, childr, parent;
     register int i;
@@ -430,7 +430,7 @@
     return 0;
-int boq_load(struct boq *q, struct line_pnts *Pnts,
+static int boq_load(struct boq *q, struct line_pnts *Pnts,
              struct bound_box *abbox, int l, int with_z)
     int i, loaded;
@@ -1219,6 +1219,9 @@
     APnts = APoints;
     BPnts = BPoints;
+    ABPnts[0] = APnts;
+    ABPnts[1] = BPnts;
     /* TODO: 3D, RE (representation error) threshold, GV_POINTS (line x point) */
     if (!IPnts)
@@ -1322,10 +1325,16 @@
     bo_queue.i = G_malloc(bo_queue.alloc * sizeof(struct qitem));
     /* load APnts to queue */
-    boq_load(&bo_queue, APnts, &abbox, 0, with_z);
+    if (!boq_load(&bo_queue, APnts, &abbox, 0, with_z)) {
+	G_free(bo_queue.i);
+	return 0;
     /* load BPnts to queue */
-    boq_load(&bo_queue, BPnts, &abbox, 1, with_z);
+    if (!boq_load(&bo_queue, BPnts, &abbox, 1, with_z)) {
+	return 0;
     /* initialize search tree */
     bo_ta = rbtree_create(cmp_t_y, sizeof(struct qitem));
