[GRASS-SVN] r62090 - grass/trunk/vector/v.select
svn_grass at osgeo.org
Fri Sep 26 05:47:11 PDT 2014
Author: mmetz
Date: 2014-09-26 05:47:11 -0700 (Fri, 26 Sep 2014)
New Revision: 62090
grass/trunk/vector/v.select/args.c
v.select: fix default answers
Modified: grass/trunk/vector/v.select/args.c
--- grass/trunk/vector/v.select/args.c 2014-09-26 12:45:33 UTC (rev 62089)
+++ grass/trunk/vector/v.select/args.c 2014-09-26 12:47:11 UTC (rev 62090)
@@ -20,6 +20,7 @@
parm->type[0] = G_define_standard_option(G_OPT_V_TYPE);
parm->type[0]->label = _("Feature type (vector map A)");
parm->type[0]->key = "atype";
+ parm->type[0]->answer = "point,line,area";
parm->type[0]->guisection = _("Selection");
parm->input[1] = G_define_standard_option(G_OPT_V_INPUT);
@@ -34,6 +35,7 @@
parm->type[1] = G_define_standard_option(G_OPT_V_TYPE);
parm->type[1]->label = _("Feature type (vector map B)");
parm->type[1]->key = "btype";
+ parm->type[1]->answer = "point,line,area";
parm->type[1]->guisection = _("Selection");
parm->output = G_define_standard_option(G_OPT_V_OUTPUT);
