[GRASS-SVN] r62092 - grass/branches/releasebranch_7_0/lib/vector/Vlib
svn_grass at osgeo.org
Fri Sep 26 06:12:21 PDT 2014
Author: neteler
Date: 2014-09-26 06:12:21 -0700 (Fri, 26 Sep 2014)
New Revision: 62092
grass/branches/releasebranch_7_0/lib/vector/Vlib/open.c
Vlib: fix messages if open failed (trunk r62088)
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/open.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/open.c 2014-09-26 12:52:24 UTC (rev 62091)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/open.c 2014-09-26 13:12:21 UTC (rev 62092)
@@ -404,7 +404,7 @@
if (!ogr_mapset) {
/* for direct OGR read access is built pseudo-topology on the fly */
G_warning(_("Unable to open vector map <%s> on level %d. "
- "Try to rebuild vector topology by v.build."),
+ "Try to rebuild vector topology with v.build."),
Vect_get_full_name(Map), level_request);
return -1;
@@ -421,13 +421,8 @@
if (level >= 2) { /* support files opened */
dig_free_plus(&(Map->plus));
- if (level_request == 0)
- G_fatal_error(_("Unable to open vector map <%s>"),
- Vect_get_full_name(Map));
- else
- G_fatal_error(_("Unable to open vector map <%s> on level %d. "
- Vect_get_full_name(Map), level_request);
+ G_fatal_error(_("Unable to open vector map <%s>"),
+ Vect_get_full_name(Map));
return -1;
if (ogr_mapset && !head_only && level_request != 1) {
@@ -859,7 +854,9 @@
dig_init_plus(&(Map->plus));
/* open new spatial index */
- Vect_open_sidx(Map, 2);
+ if (Vect_open_sidx(Map, 2) < 0)
+ G_fatal_error(_("Unable to open spatial index file for vector map <%s>"),
Map->open = VECT_OPEN_CODE;
Map->head_only = FALSE;
@@ -1164,6 +1161,7 @@
\param[in,out] Map pointer to Map_info
\param mode 0 old, 1 update, 2 new
+ \return 1 if sidx file is not available
\return 0 on success
\return -1 on error
